    T113加载wifi驱动8189fs.so,但却没有触发sdc2的操作,求助!
    • zhongtao1701
      钟工 LV 7 最后由 YuzukiTsuru 编辑
      T113的板子上焊接rtl8189模块,驱动编译成动态库模式,系统起来后,手工加载驱动
      insmod /lib/modules/5.4.61/kernel/drivers/net/wireless/rtl8189fs/8189fs.ko
      [ 41.238505] RTL871X: module init start
      [ 41.242814] RTL871X: rtl8189fs v4.3.24.8_22657.20170607
      [ 41.248914] RTL871X: module init ret=0
      没触发sdio的读卡操作,由于板子内还有xr829的驱动,尝试加载一下,发现它是可以触发sdio的操作,而且它还能发现芯片是RTL8188F, 于是继续运行8189的驱动,完成eFUSE读取
      以及FW的加载
      # insmod /lib/modules/5.4.61/kernel/drivers/net/wireless/xr829/xr829.ko
      [  145.348636] ======== XRADIO WIFI OPEN ========
      [  145.355347] [XRADIO] Driver Label:XR_V02.16.84_P2P_HT40_01.31
      [  145.362187] [XRADIO] Allocated hw_priv @ c656bdcd
      [  145.367544] [ADDR_MGT] get_addr_by_name: t->addr:
      [  145.374343] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
      [  145.390658] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
      [  145.597899] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  145.601670] [XRADIO] Detect SDIO card 1
      [  145.609181] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [  145.632659] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  145.657667] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  145.672341] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  145.685743] sunxi-mmc 4021000.sdmmc: card claims to support voltages below defined range
      [  145.704547] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [  145.716202] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [  145.728416] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      [  145.741281] mmc1: new high speed SDIO card at address 0001
      [  145.748826] RTL871X: CHIP TYPE: RTL8188F
      [  145.753747] RTL871X: rtw_hal_config_rftype RF_Type is 3 TotalTxPath is 1
      [  145.761339] RTL871X: Chip Version Info: CHIP_8188F_Normal_Chip_SMIC_B_CUT_1T1R_RomVer(0)
      [  145.770631] RTL871X: SetHwReg8188F: hci_sus_state=1
      [  145.777750] RTL871X: SetHwReg8188F: bMacPwrCtrlOn=1
      [  145.783258] RTL871X: SetHwReg8188F: hci_sus_state=2
      [  145.783725] RTL871X: PowerOnCheck: val_mix:0x0000063f, res:0x0000063f
      [  145.783732] RTL871X: PowerOnCheck: 0x100 the result of cmd52 and cmd53 is the same.
      [  145.783802] RTL871X: PowerOnCheck: 0x1B8 test Pass.
      [  145.783881] RTL871X: EEPROM type is E-FUSE
      [  145.784522] RTL871X: hal_EfuseSwitchToBank: Efuse switch bank to 0
      [  145.852933] RTL871X: hal_ReadEFuse_WiFi: data end at address=0x98
      [  145.859788] RTL871X: HW EFUSE
      [  145.863151] RTL871X: 0x000:
      在系统启动记录中,有下面提示,是否提示SDC2的插卡检测是需要软件控制的, 8189 的驱动没有这个功能, 而xr829驱动却有?
      [ 4.532621] sunxi-mmc 4021000.sdmmc: detmode:manually by software
      看起来硬件是好的,驱动也是好的, 会是什么问题,哪位大侠指点一下,谢谢!
      下面是完整启动记录
      [05.758]Starting kernel ...
      [05.761][mmc]: MMC Device 2 not found
      [05.764][mmc]: mmc 2 not find, so not exit
      [    0.000000] Linux version 5.4.61 (forlinx@ubuntu) (arm-linux-gnueabi-gcc (Linaro GCC 7.2-2017.11) 7.2.1 20171011, GNU ld (Linaro_Binutils-2017.11) 2.28.2.20170706) #5 SMP PREEMPT Thu Sep 15 20:54:19 PDT 2022
      [    0.000000] cma: Reserved 16 MiB at 0x47000000
      [    0.000000] percpu: Embedded 15 pages/cpu s30860 r8192 d22388 u61440
      [    0.000000] pcpu-alloc: s30860 r8192 d22388 u61440 alloc=15*4096
      [    0.000000] Kernel command line: earlycon=uart8250,mmio32,0x05000000 clk_ignore_unused initcall_debug=0 console=ttyS3,115200 loglevel=8 root=/dev/mmcblk0p5 init=/sbin/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:dsp0@mmcblk0p6 cma=16M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw20p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05-config-dirty(07/24/2022-00:56:35) disp_reserve=2457600,0x448a5000 androidboot.dramsize=128
      [    0.000000] Memory: 90604K/131072K available (7168K kernel code, 406K rwdata, 2324K rodata, 1024K init, 170K bss, 24084K reserved, 16384K cma-reserved)
      [    0.000000] random: get_random_bytes called from start_kernel+0x248/0x3d0 with crng_init=0
      [    0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
      [    0.000019] Switching to timer-based delay loop, resolution 41ns
      [    0.000217] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
      [    0.000823] Console: colour dummy device 80x30
      [    0.000870] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.000884] pid_max: default: 32768 minimum: 301
      [    0.000974] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.000988] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.001675] CPU: Testing write buffer coherency: ok
      [    0.002070] /cpus/cpu@0 missing clock-frequency property
      [    0.002094] /cpus/cpu@1 missing clock-frequency property
      [    0.002107] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [    0.002856] Setting up static identity map for 0x40100000 - 0x40100060
      [    0.003031] rcu: Hierarchical SRCU implementation.
      [    0.003421] BOOTEVENT:         3.410707: ON
      [    0.003657] smp: Bringing up secondary CPUs ...
      [    0.005270] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [    0.005449] smp: Brought up 1 node, 2 CPUs
      [    0.005465] SMP: Total of 2 processors activated (96.00 BogoMIPS).
      [    0.005473] CPU: All CPU(s) started in SVC mode.
      [    0.006127] devtmpfs: initialized
      [    0.122020] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [    0.126539] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.126579] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
      [    0.127400] pinctrl core: initialized pinctrl subsystem
      [    0.135472] NET: Registered protocol family 16
      [    0.141535] DMA: preallocated 256 KiB pool for atomic coherent allocations
      [    0.515640] rtc_ccu: sunxi ccu init OK
      [    0.563371] ccu: sunxi ccu init OK
      [    0.568556] r_ccu: sunxi ccu init OK
      [    1.131520] iommu: Default domain type: Translated
      [    1.137048] sunxi iommu: irq = 24
      [    1.165758] SCSI subsystem initialized
      [    1.177759] usbcore: registered new interface driver usbfs
      [    1.185941] usbcore: registered new interface driver hub
      [    1.186133] usbcore: registered new device driver usb
      [    1.189247] mc: Linux media interface: v0.10
      [    1.196536] videodev: Linux video capture interface: v2.00
      [    1.208511] Advanced Linux Sound Architecture Driver Initialized.
      [    1.229698] Bluetooth: Core ver 2.22
      [    1.229841] NET: Registered protocol family 31
      [    1.229852] Bluetooth: HCI device and connection manager initialized
      [    1.229882] Bluetooth: HCI socket layer initialized
      [    1.229896] Bluetooth: L2CAP socket layer initialized
      [    1.229968] Bluetooth: SCO socket layer initialized
      [    1.230336] pwm module init!
      [    1.250079] g2d 5410000.g2d: Adding to iommu group 0
      [    1.252932] G2D: rcq version initialized.major:251
      [    1.263351] input: sunxi-keyboard as /devices/virtual/input/input0
      [    1.272574] clocksource: Switched to clocksource arch_sys_counter
      [    1.485627] sun8iw20-pinctrl pio: initialized sunXi PIO driver
      [    1.956951] thermal_sys: Registered thermal governor 'step_wise'
      [    1.956958] thermal_sys: Registered thermal governor 'user_space'
      [    1.972214] NET: Registered protocol family 2
      [    1.980713] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
      [    1.980756] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    1.980781] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
      [    1.980805] TCP: Hash tables configured (established 1024 bind 1024)
      [    1.981033] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    1.981078] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    1.986670] NET: Registered protocol family 1
      [    2.008566] sun8iw20-pinctrl pio: pio supply vcc-pc not found, using dummy regulator
      [    2.016631] spi spi0: spi0 supply spi not found, using dummy regulator
      [    2.020589] sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
      [    2.027832] sunxi_spi_resource_get()2189 - Failed to get sample mode
      [    2.027851] sunxi_spi_resource_get()2194 - Failed to get sample delay
      [    2.027862] sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_delay:-1431633921
      [    2.027957] sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
      [    2.040158] sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base c8821000, irq 42
      [    2.080029] Initialise system trusted keyrings
      [    2.080272] workingset: timestamp_bits=30 max_order=15 bucket_order=0
      [    2.092141] fuse: init (API version 7.31)
      [    2.131366] NET: Registered protocol family 38
      [    2.131397] Key type asymmetric registered
      [    2.131407] Asymmetric key parser 'x509' registered
      [    2.131524] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
      [    2.131537] io scheduler mq-deadline registered
      [    2.131546] io scheduler kyber registered
      [    2.131715] atomic64_test: passed
      [    2.150726] [DISP]disp_module_init
      [    2.172023] disp 5000000.disp: Adding to iommu group 0
      [    2.178604] [DISP] disp_init,line:2386:
      [    2.178612] smooth display screen:0 type:1 mode:4
      [    2.193887] disp 5000000.disp: 5000000.disp supply vcc-lcd not found, using dummy regulator
      [    2.194359] disp 5000000.disp: 5000000.disp supply vcc-pd not found, using dummy regulator
      [    2.207850] display_fb_request,fb_id:0
      [    2.219650] Freeing logo buffer memory: 2400K
      [    2.231800] disp_al_manager_apply ouput_type:1
      [    2.247170] [DISP] lcd_clk_config,line:732:
      [    2.247184] disp 0, clk: pll(306000000),clk(306000000),dclk(51000000) dsi_rate(306000000)
      [    2.247184]      clk real:pll(300000000),clk(300000000),dclk(50000000) dsi_rate(0)
      [    2.247685] sun8iw20-pinctrl pio: pio supply vcc-pd not found, using dummy regulator
      [    2.260888] [DISP]disp_module_init finish
      [    2.273916] sunxi_sid_init()551 - insmod ok
      [    2.274697] pwm-regulator: supplied by regulator-dummy
      [    2.315349] sun8iw20-pinctrl pio: pio supply vcc-pg not found, using dummy regulator
      [    2.315930] uart uart1: get regulator failed
      [    2.315956] uart uart1: uart1 supply uart not found, using dummy regulator
      [    2.324172] uart1: ttyS1 at MMIO 0x2500400 (irq = 34, base_baud = 1500000) is a SUNXI
      [    2.336786] sun8iw20-pinctrl pio: pio supply vcc-pb not found, using dummy regulator
      [    2.337240] uart uart3: get regulator failed
      [    2.337266] uart uart3: uart3 supply uart not found, using dummy regulator
      [    2.341742] uart3: ttyS3 at MMIO 0x2500c00 (irq = 35, base_baud = 1500000) is a SUNXI
      [    2.341780] sw_console_setup()1784 - console setup baud 115200 parity n bits 8, flow n
      [    3.297011] printk: console [ttyS3] enabled
      [    3.322654] misc dump reg init
      [    3.359745] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
      [    3.367057] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
      [    3.374416] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
      [    3.381804] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
      [    3.388325] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
      [    3.395244] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
      [    3.402966] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
      [    3.410791] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
      [    3.418884] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
      [    3.430593] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
      [    3.437405] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
      [    3.444962] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=207 assert=0
      [    3.515525] libphy: Fixed MDIO Bus: probed
      [    3.530259] sun8iw20-pinctrl pio: pio supply vcc-pe not found, using dummy regulator
      [    3.543463] sunxi gmac driver's version: 1.0.0
      [    3.552631] gmac-power0: NULL
      [    3.555984] gmac-power1: NULL
      [    3.559285] gmac-power2: NULL
      [    3.580185] Failed to alloc md5
      [    3.583796] eth0: Use random mac address
      [    3.596492] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    3.603897] sunxi-ehci: EHCI SUNXI driver
      [    3.608975] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    3.616068] sunxi-ohci: OHCI SUNXI driver
      [    3.621614] usbcore: registered new interface driver uas
      [    3.635824] usbcore: registered new interface driver usb-storage
      [    3.642745] usbcore: registered new interface driver ums-alauda
      [    3.649768] usbcore: registered new interface driver ums-cypress
      [    3.656667] usbcore: registered new interface driver ums-datafab
      [    3.663577] usbcore: registered new interface driver ums_eneub6250
      [    3.670588] usbcore: registered new interface driver ums-freecom
      [    3.677960] usbcore: registered new interface driver ums-isd200
      [    3.684797] usbcore: registered new interface driver ums-jumpshot
      [    3.692012] usbcore: registered new interface driver ums-karma
      [    3.700400] usbcore: registered new interface driver ums-onetouch
      [    3.717393] usbcore: registered new interface driver ums-realtek
      [    3.724313] usbcore: registered new interface driver ums-sddr09
      [    3.731019] usbcore: registered new interface driver ums-sddr55
      [    3.742029] usbcore: registered new interface driver ums-usbat
      [    3.762153] ts probe start
      [    3.774326] input: 2009c00.rtp as /devices/platform/soc@3000000/2009c00.rtp/input/input1
      [    3.794877] ts probe success
      [    3.799518] sunxi_gpadc_init,2137, success
      [    3.807784] sunxi_gpadc_setup: get channel scan data failed
      [    3.816508] input: sunxi-gpadc0 as /devices/virtual/input/input2
      [    3.864805] sunxi-rtc 7090000.rtc: registered as rtc0
      [    3.870634] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T03:06:01 UTC (11161)
      [    3.879941] sunxi-rtc 7090000.rtc: sunxi rtc probed
      [    3.886019] i2c /dev entries driver
      [    3.892321] IR NEC protocol handler initialized
      [    3.897490] IR RC5(x/sz) protocol handler initialized
      [    3.903727] sunxi_ir_startup: get ir protocol failed
      [    3.903758] (NULL device *): deviceless supply  not found, using dummy regulator
      [    3.920062] Registered IR keymap rc_map_sunxi
      [    3.930990] rc rc0: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0
      [    3.948012] input: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0/s_cir_rx
      [    3.976050] usbcore: registered new interface driver uvcvideo
      [    3.982500] USB Video Class driver (1.1.1)
      [    3.987098] gspca_main: v2.14.0 registered
      [    3.991667] sunxi cedar version 1.1
      [    3.995894] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
      [    4.002137] VE: sunxi_cedar_probe power-domain init!!!
      [    4.007890] VE: install start!!!
      [    4.007890]
      [    4.013703] VE: cedar-ve the get irq is 43
      [    4.013703]
      [    4.028717] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
      [    4.028717]
      [    4.038044] VE: install end!!!
      [    4.038044]
      [    4.043116] VE: sunxi_cedar_probe
      [    4.069433] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      [    4.078779] Bluetooth: HCI UART driver ver 2.3
      [    4.083808] Bluetooth: HCI UART protocol H4 registered
      [    4.089541] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
      [    4.096915] [XR_BT_LPM] bluesleep_probe: bt_wake polarity: 1
      [    4.103351] [XR_BT_LPM] bluesleep_probe: host_wake polarity: 1
      [    4.109887] [XR_BT_LPM] bluesleep_probe: wakeup source is disabled!
      [    4.109887]
      [    4.118546] [XR_BT_LPM] bluesleep_probe: uart_index(1)
      [    4.182727] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-05-24 16:10)
      [    4.192880] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
      [    4.199084] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
      [    4.205448] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
      [    4.211859] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
      [    4.218276] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
      [    4.224796] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
      [    4.231298] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
      [    4.237811] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
      [    4.249152] sunxi-mmc 4020000.sdmmc: Got CD GPIO
      [    4.254791] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
      [    4.261731] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    4.272925] random: fast init done
      [    4.276852] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
      [    4.297051] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    4.321709] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
      [    4.327461] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    4.348025] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-05-24 16:10)
      [    4.351014] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    4.358134] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
      [    4.371880] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    4.375722] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
      [    4.390315] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    4.393672] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
      [    4.393679] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
      [    4.393686] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
      [    4.393692] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
      [    4.393698] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
      [    4.393704] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
      [    4.393754] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
      [    4.437269] mmc0: host does not support reading read-only switch, assuming write-enable
      [    4.466850] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    4.467179] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    4.478830] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    4.489611] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [    4.502162] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    4.509281] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      [    4.532514] mmc0: new high speed SD card at address 1388
      [    4.547339] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    4.557793] usbcore: registered new interface driver usbhid
      [    4.557931] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    4.564404] usbhid: USB HID core driver
      [    4.575346] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    4.592553] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    4.600210] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    4.600477] mmcblk0: mmc0:1388 CS004 482 MiB
      [    4.609034] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    4.620956] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    4.628966] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    4.629058] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    4.630710] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
      [    4.630710]
      [    4.667459] GPT:Primary header thinks Alt. header is not at the end of the disk.
      [    4.675902] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
      [    4.693130] GPT:631911 != 987135
      [    4.702069] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
      [    4.712451] GPT:Alternate GPT header not at the end of the disk.
      [    4.751501] GPT:631911 != 987135
      [    4.751561] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
      [    4.755427] GPT: Use GNU Parted to correct GPT errors.
      [    4.765184] [SNDCODEC][sunxi_card_init][583]:card init finished
      [    4.770880]  mmcblk0: p1 p2 p3 p4 p5 p6
      [    4.809308] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
      [    4.905206] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input4
      [    4.938528] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
      [    4.946847] NET: Registered protocol family 10
      [    4.956473] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
      [    4.973417] Segment Routing with IPv6
      [    4.977705] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
      [    5.023005] NET: Registered protocol family 17
      [    5.028060] NET: Registered protocol family 15
      [    5.033356] Bluetooth: RFCOMM TTY layer initialized
      [    5.038919] Bluetooth: RFCOMM socket layer initialized
      [    5.044835] Bluetooth: RFCOMM ver 1.11
      [    5.049915] Registering SWP/SWPB emulation handler
      [    5.065049] Loading compiled-in X.509 certificates
      [    5.529486] i2c i2c2: i2c2 supply twi not found, using dummy regulator
      [    5.560554] i2c i2c2: probe success
      [    5.642376] get ehci0-controller wakeup-source is fail.
      [    5.648471] sunxi ehci0-controller don't init wakeup source
      [    5.654801] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0c86800, 0x:c88e6000, irq_no:3a
      [    5.666834] [sunxi-ehci0]: Not init ehci0
      [    5.671878] get ohci0-controller wakeup-source is fail.
      [    5.677958] sunxi ohci0-controller don't init wakeup source
      [    5.684247] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0c86a90
      [    5.693941] [sunxi-ohci0]: Not init ohci0
      [    5.708225] get ehci1-controller wakeup-source is fail.
      [    5.714323] sunxi ehci1-controller don't init wakeup source
      [    5.720627] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0c86d20, 0x:c88ef000, irq_no:3c
      [    5.742193] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
      [    5.760640] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
      [    5.767987] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
      [    5.782724] sunxi-ehci 4200000.ehci1-controller: irq 60, io mem 0x04200000
      [    5.822590] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
      [    5.836451] hub 1-0:1.0: USB hub found
      [    5.840756] hub 1-0:1.0: 1 port detected
      [    5.869743] get ohci1-controller wakeup-source is fail.
      [    5.880462] sunxi ohci1-controller don't init wakeup source
      [    5.886786] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0c86fb0
      [    5.908922] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
      [    5.935568] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
      [    5.942886] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
      [    5.953756] sunxi-ohci 4200400.ohci1-controller: irq 61, io mem 0x04200400
      [    6.053643] hub 2-0:1.0: USB hub found
      [    6.064428] hub 2-0:1.0: 1 port detected
      [    6.124379] sun8iw20-pinctrl pio: pin PB6 already requested by 2500c00.uart; cannot claim for pio:38
      [    6.134745] sun8iw20-pinctrl pio: pin-38 (pio:38) status -22
      [    6.141107] ERR: id gpio_request failed
      [    6.186492] cfg80211: Loading compiled-in X.509 certificates for regulatory database
      [    6.198736] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      [    6.206682] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      [    6.212659] clk: Not disabling unused clocks
      [    6.216495] cfg80211: failed to load regulatory.db
      [    6.221184] ALSA device list:
      [    6.230050]   #0: audiocodec
      [    6.233367] alloc_fd: slot 0 not NULL!
      [    6.243745] EXT4-fs (mmcblk0p5): INFO: recovery required on readonly filesystem
      [    6.251959] EXT4-fs (mmcblk0p5): write access will be enabled during recovery
      [    6.328394] EXT4-fs (mmcblk0p5): recovery complete
      [    6.336317] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
      [    6.345582] VFS: Mounted root (ext4 filesystem) readonly on device 179:5.
      [    6.354169] devtmpfs: mounted
      [    6.359570] Freeing unused kernel memory: 1024K
      [    6.364877] Kernel init done
      [    6.368109] Run /sbin/init as init process
      INIT: version  booting
      INIT: No inittab.d directory found
      [    6.796129] EXT4-fs (mmcblk0p5): re-mounted. Opts: (null)
      INIT: Entering runlevel: 3
      Starting syslogd: OK
      Starting klogd: OK
      Running sysctl: OK
      Populating /dev using udev: [    7.643763] udevd[1013]: starting version 3.2.11
      [    7.667257] random: udevd: uninitialized urandom read (16 bytes read)
      [    7.676450] random: udevd: uninitialized urandom read (16 bytes read)
      [    7.683921] random: udevd: uninitialized urandom read (16 bytes read)
      [    7.725267] udevd[1014]: starting eudev-3.2.11
      done
      Initializing random number generator: FAIL
      Starting network: OK
      Starting swupdate: OK
      Welcome to T113 Pro
      t113 login: root
      # ins[   18.695643] random: crng init done
      crypto/  drivers/
      # insmod /lib/modules/5.4.61/kernel/drivers/net/wireless/rtl8189fs/8189fs.ko
      [  145.863156] 29
      [  145.866368] 81
      [  145.868318] 03
      [  145.870269] CC
      [  145.872219] 00
      [  145.874209] 00
      [  145.876170] 50
      [  145.878122] 00
      [  145.880071] 00
      [  145.882313] 00
      [  145.884311] 04
      [  145.884316] CC
      [  145.884319] 0A
      [  145.884323] 0C
      [  145.884327] 00
      [  145.884330] 00
      [  145.884334] RTL871X: 0x010:
      [  145.884338] 29
      [  145.884342] 29
      [  145.884345] 28
      [  145.884349] 29
      [  145.884353] 28
      [  145.884356] 28
      [  145.884359] 2A
      [  145.884363] 2A
      [  145.884367] 29
      [  145.884370] 2B
      [  145.884374] 2B
      [  145.884377] 02
      [  145.884381] FF
      [  145.884384] FF
      [  145.884388] FF
      [  145.884391] FF
      [  145.884395] RTL871X: 0x020:
      [  145.884399] FF
      [  145.884402] FF
      [  145.884406] FF
      [  145.884409] FF
      [  145.884413] FF
      [  145.884416] FF
      [  145.884420] FF
      [  145.884423] FF
      [  145.884427] FF
      [  145.884430] FF
      [  145.884434] FF
      [  145.884437] FF
      [  145.884441] FF
      [  145.884444] FF
      [  145.884448] FF
      [  145.884452] FF
      [  145.884455] RTL871X: 0x030:
      [  145.884459] FF
      [  145.884462] FF
      [  145.884466] FF
      [  145.884469] FF
      [  145.884472] FF
      [  145.884474] FF
      [  145.884477] FF
      [  145.884480] FF
      [  145.884482] FF
      [  145.884485] FF
      [  145.884488] FF
      [  145.884490] FF
      [  145.884493] FF
      [  145.884495] FF
      [  145.884498] FF
      [  145.884500] FF
      [  145.884503] RTL871X: 0x040:
      [  145.884505] FF
      [  145.884507] FF
      [  145.884510] FF
      [  145.884512] FF
      [  145.884515] FF
      [  145.884518] FF
      [  145.884520] FF
      [  145.884523] FF
      [  145.884525] FF
      [  145.884528] FF
      [  145.884530] FF
      [  145.884533] FF
      [  145.884535] FF
      [  145.884538] FF
      [  145.884540] FF
      [  145.884543] FF
      [  145.884546] RTL871X: 0x050:
      [  145.884548] FF
      [  145.884550] FF
      [  145.884553] FF
      [  145.884555] FF
      [  145.884558] FF
      [  145.884561] FF
      [  145.884563] FF
      [  145.884566] FF
      [  145.884568] FF
      [  145.884571] FF
      [  145.884573] FF
      [  145.884576] FF
      [  145.884578] FF
      [  145.884581] FF
      [  145.884583] FF
      [  145.884586] FF
      [  145.884589] RTL871X: 0x060:
      [  145.884591] FF
      [  145.884593] FF
      [  145.884596] FF
      [  145.884598] FF
      [  145.884601] FF
      [  145.884604] FF
      [  145.884606] FF
      [  145.884609] FF
      [  145.884611] FF
      [  145.884614] FF
      [  145.884616] FF
      [  145.884619] FF
      [  145.884621] FF
      [  145.884624] FF
      [  145.884626] FF
      [  145.884629] FF
      [  145.884632] RTL871X: 0x070:
      [  145.884633] FF
      [  145.884636] FF
      [  145.884638] FF
      [  145.884641] FF
      [  145.884644] FF
      [  145.884646] FF
      [  145.884649] FF
      [  145.884651] FF
      [  145.884654] FF
      [  145.884656] FF
      [  145.884659] FF
      [  145.884661] FF
      [  145.884664] FF
      [  145.884666] FF
      [  145.884669] FF
      [  145.884672] FF
      [  145.884674] RTL871X: 0x080:
      [  145.884676] FF
      [  145.884679] FF
      [  145.884681] FF
      [  145.884684] FF
      [  145.884686] FF
      [  145.884689] FF
      [  145.884691] FF
      [  145.884694] FF
      [  145.884697] FF
      [  145.884699] FF
      [  145.884701] FF
      [  145.884704] FF
      [  145.884707] FF
      [  145.884709] FF
      [  145.884712] FF
      [  145.884714] FF
      [  145.884717] RTL871X: 0x090:
      [  145.884719] FF
      [  145.884721] FF
      [  145.884724] FF
      [  145.884726] FF
      [  145.884729] FF
      [  145.884732] FF
      [  145.884734] FF
      [  145.884737] FF
      [  145.884739] FF
      [  145.884742] FF
      [  145.884744] FF
      [  145.884747] FF
      [  145.884749] FF
      [  145.884752] FF
      [  145.884754] FF
      [  145.884757] FF
      [  145.884760] RTL871X: 0x0a0:
      [  145.884762] FF
      [  145.884765] FF
      [  145.884767] FF
      [  145.884769] FF
      [  145.884772] FF
      [  145.884775] FF
      [  145.884777] FF
      [  145.884780] FF
      [  145.884782] FF
      [  145.884785] FF
      [  145.884788] FF
      [  145.884790] FF
      [  145.884793] FF
      [  145.884795] FF
      [  145.884798] FF
      [  145.884801] FF
      [  145.884803] RTL871X: 0x0b0:
      [  145.884805] FF
      [  145.884807] FF
      [  145.884810] FF
      [  145.884813] FF
      [  145.884815] FF
      [  145.884818] FF
      [  145.884820] FF
      [  145.884823] FF
      [  145.884825] 23
      [  145.884828] 2F
      [  145.884830] 20
      [  145.884833] 00
      [  145.884835] 00
      [  145.884838] 00
      [  145.884840] 00
      [  145.884843] FF
      [  145.884846] RTL871X: 0x0c0:
      [  145.884848] FF
      [  145.884851] 02
      [  145.884853] 00
      [  145.884856] 10
      [  145.884858] 00
      [  145.884861] FF
      [  145.884863] 00
      [  145.884866] FF
      [  145.884868] 00
      [  145.884871] 00
      [  145.884873] FF
      [  145.884876] FF
      [  145.884878] FF
      [  145.884881] FF
      [  145.884883] FF
      [  145.884886] FF
      [  145.884889] RTL871X: 0x0d0:
      [  145.884891] 3E
      [  145.884893] 10
      [  145.884896] 01
      [  145.884898] 12
      [  145.884901] 23
      [  145.884904] FF
      [  145.884906] FF
      [  145.884908] FF
      [  145.884911] 20
      [  145.884914] 04
      [  145.884916] 4C
      [  145.884919] 02
      [  145.884921] 79
      [  145.884924] F1
      [  145.884926] 21
      [  145.884929] 02
      [  145.884932] RTL871X: 0x0e0:
      [  145.884934] 0C
      [  145.884936] 00
      [  145.884939] 22
      [  145.884941] 04
      [  145.884944] 00
      [  145.884946] 08
      [  145.884949] 00
      [  145.884951] 32
      [  145.884954] FF
      [  145.884956] 21
      [  145.884959] 02
      [  145.884961] 0C
      [  145.884964] 00
      [  145.884966] 22
      [  145.884969] 2A
      [  145.884971] 01
      [  145.884974] RTL871X: 0x0f0:
      [  145.884976] 01
      [  145.884979] 00
      [  145.884981] 00
      [  145.884984] 00
      [  145.884986] 00
      [  145.884989] 00
      [  145.884991] 00
      [  145.884994] 00
      [  145.884997] 00
      [  145.884999] 00
      [  145.885001] 00
      [  145.885004] 00
      [  145.885006] 02
      [  145.885009] 00
      [  145.885012] FF
      [  145.885014] FF
      [  145.885017] RTL871X: 0x100:
      [  145.885019] 00
      [  145.885022] 00
      [  145.885024] 00
      [  145.885027] 00
      [  145.885029] 00
      [  145.885031] 00
      [  145.885034] 00
      [  145.885037] 00
      [  145.885039] 00
      [  145.885042] 00
      [  145.885044] 00
      [  145.885047] 00
      [  145.885049] 00
      [  145.885052] 00
      [  145.885054] 00
      [  145.885057] 00
      [  145.885059] RTL871X: 0x110:
      [  145.885061] 00
      [  145.885064] EB
      [  145.885066] 00
      [  145.885069] 6E
      [  145.885072] 01
      [  145.885074] 00
      [  145.885077] 00
      [  145.885079] 00
      [  145.885082] 00
      [  145.885084] FF
      [  145.885087] 60
      [  145.885089] FB
      [  145.885092] 00
      [  145.885094] 79
      [  145.885097] 45
      [  145.885100] 21
      [  145.885102] RTL871X: 0x120:
      [  145.885105] FF
      [  145.885107] FF
      [  145.885110] FF
      [  145.885112] FF
      [  145.885115] FF
      [  145.885117] FF
      [  145.885120] FF
      [  145.885122] FF
      [  145.885125] FF
      [  145.885128] FF
      [  145.885130] FF
      [  145.885132] FF
      [  145.885135] FF
      [  145.885137] FF
      [  145.885140] FF
      [  145.885143] FF
      [  145.885145] RTL871X: 0x130:
      [  145.885147] FF
      [  145.885150] FF
      [  145.885152] FF
      [  145.885155] FF
      [  145.885157] FF
      [  145.885160] FF
      [  145.885162] FF
      [  145.885165] FF
      [  145.885168] FF
      [  145.885170] FF
      [  145.885173] FF
      [  145.885175] FF
      [  145.885178] FF
      [  145.885180] FF
      [  145.885183] FF
      [  145.885186] FF
      [  145.885188] RTL871X: 0x140:
      [  145.885191] FF
      [  145.885194] FF
      [  145.885197] FF
      [  145.885199] FF
      [  145.885202] FF
      [  145.885205] FF
      [  145.885207] FF
      [  145.885209] FF
      [  145.885212] FF
      [  145.885215] FF
      [  145.885217] FF
      [  145.885220] FF
      [  145.885222] FF
      [  145.885225] FF
      [  145.885227] FF
      [  145.885230] FF
      [  145.885233] RTL871X: 0x150:
      [  145.885235] FF
      [  145.885237] FF
      [  145.885240] FF
      [  145.885242] FF
      [  145.885245] FF
      [  145.885247] FF
      [  145.885250] FF
      [  145.885253] FF
      [  145.885255] FF
      [  145.885258] FF
      [  145.885261] FF
      [  145.885263] FF
      [  145.885266] FF
      [  145.885268] FF
      [  145.885271] FF
      [  145.885273] FF
      [  145.885276] RTL871X: 0x160:
      [  145.885279] FF
      [  145.885281] FF
      [  145.885284] FF
      [  145.885286] FF
      [  145.885289] FF
      [  145.885291] FF
      [  145.885294] FF
      [  145.885296] FF
      [  145.885299] FF
      [  145.885302] FF
      [  145.885304] FF
      [  145.885307] FF
      [  145.885309] FF
      [  145.885312] FF
      [  145.885314] FF
      [  145.885317] FF
      [  145.885319] RTL871X: 0x170:
      [  145.885322] FF
      [  145.885324] FF
      [  145.885327] FF
      [  145.885330] FF
      [  145.885332] FF
      [  145.885335] FF
      [  145.885337] FF
      [  145.885340] FF
      [  145.885342] FF
      [  145.885345] FF
      [  145.885348] FF
      [  145.885350] FF
      [  145.885353] FF
      [  145.885356] FF
      [  145.885358] FF
      [  145.885361] FF
      [  145.885363] RTL871X: 0x180:
      [  145.885366] FF
      [  145.885369] FF
      [  145.885371] FF
      [  145.885373] FF
      [  145.885377] FF
      [  145.885379] FF
      [  145.885382] FF
      [  145.885384] FF
      [  145.885387] FF
      [  145.885389] FF
      [  145.885392] FF
      [  145.885394] FF
      [  145.885397] FF
      [  145.885399] FF
      [  145.885402] FF
      [  145.885405] FF
      [  145.885407] RTL871X: 0x190:
      [  145.885409] FF
      [  145.885412] FF
      [  145.885414] FF
      [  145.885417] FF
      [  145.885419] FF
      [  145.885422] FF
      [  145.885425] FF
      [  145.885427] FF
      [  145.885430] FF
      [  145.885432] FF
      [  145.885435] FF
      [  145.885437] FF
      [  145.885440] FF
      [  145.885443] FF
      [  145.885445] FF
      [  145.885448] FF
      [  145.885450] RTL871X: 0x1a0:
      [  145.885452] FF
      [  145.885455] FF
      [  145.885457] FF
      [  145.885460] FF
      [  145.885463] FF
      [  145.885465] FF
      [  145.885467] FF
      [  145.885470] FF
      [  145.885473] FF
      [  145.885475] FF
      [  145.885478] FF
      [  145.885480] FF
      [  145.885483] FF
      [  145.885485] FF
      [  145.885488] FF
      [  145.885491] FF
      [  145.885493] RTL871X: 0x1b0:
      [  145.885495] FF
      [  145.885498] FF
      [  145.885500] FF
      [  145.885503] FF
      [  145.885505] FF
      [  145.885508] FF
      [  145.885510] FF
      [  145.885513] FF
      [  145.885515] FF
      [  145.885518] FF
      [  145.885520] FF
      [  145.885523] FF
      [  145.885525] FF
      [  145.885528] FF
      [  145.885531] FF
      [  145.885533] FF
      [  145.885536] RTL871X: 0x1c0:
      [  145.885538] FF
      [  145.885540] FF
      [  145.885543] FF
      [  145.885545] FF
      [  145.885548] FF
      [  145.885550] FF
      [  145.885553] FF
      [  145.885555] FF
      [  145.885558] FF
      [  145.885560] FF
      [  145.885563] FF
      [  145.885565] FF
      [  145.885568] FF
      [  145.885570] FF
      [  145.885573] FF
      [  145.885576] FF
      [  145.885578] RTL871X: 0x1d0:
      [  145.885580] FF
      [  145.885583] FF
      [  145.885585] FF
      [  145.885588] FF
      [  145.885591] FF
      [  145.885593] FF
      [  145.885596] FF
      [  145.885598] FF
      [  145.885601] FF
      [  145.885603] FF
      [  145.885606] FF
      [  145.885609] FF
      [  145.885611] FF
      [  145.885613] FF
      [  145.885616] FF
      [  145.885619] FF
      [  145.885621] RTL871X: 0x1e0:
      [  145.885623] FF
      [  145.885626] FF
      [  145.885629] FF
      [  145.885631] FF
      [  145.885634] FF
      [  145.885636] FF
      [  145.885639] FF
      [  145.885641] FF
      [  145.885644] FF
      [  145.885646] FF
      [  145.885649] FF
      [  145.885651] FF
      [  145.885654] FF
      [  145.885656] FF
      [  145.885659] FF
      [  145.885662] FF
      [  145.885665] RTL871X: 0x1f0:
      [  145.885667] FF
      [  145.885669] FF
      [  145.885672] FF
      [  145.885674] FF
      [  145.885677] FF
      [  145.885679] FF
      [  145.885682] FF
      [  145.885684] FF
      [  145.885687] FF
      [  145.885690] FF
      [  145.885692] FF
      [  145.885695] FF
      [  145.885697] FF
      [  145.885700] FF
      [  145.885702] FF
      [  145.885705] FF
      [  145.885707]
      [  145.885742] RTL871X: hal_com_config_channel_plan chplan:0x23
      [  145.886166] RTL871X: kfree flag:1
      [  145.886172] RTL871X: bb_gain:-1
      [  145.886292] RTL871X: rtl8188f_FirmwareDownload((null)) tmp_ps=3
      [  145.886300] RTL871X: rtl8188f_FirmwareDownload fw: FW_NIC, size: 21020
      [  145.886309] RTL871X: rtl8188f_FirmwareDownload: fw_ver=4 fw_subver=0000 sig=0x88f1, Month=08, Date=22, Hour=17, Minute=36
      [  145.886313] RTL871X: rtl8188f_FirmwareDownload(): Shift for fw header!
      [  145.886316] RTL871X: rtl8188f_FirmwareDownload by IO write!
      [  147.166965] RTL871X: polling_fwdl_chksum: Checksum report OK! (1, 0ms), REG_MCUFWDL:0x07050105
      [  147.176948] RTL871X: _8051Reset8188: Finish
      [  147.190525] RTL871X: _FWFreeToGo: Polling FW ready OK! (111, 10ms), REG_MCUFWDL:0x070501c6
      [  147.199793] RTL871X: rtl8188f_FirmwareDownload: DLFW OK !
      [  147.205845] RTL871X: rtl8188f_FirmwareDownload success. write_fw:1, 1320ms
      [  147.213600] RTL871X:  <=== rtl8188f_FirmwareDownload()
      [  147.219621] RTL871X: hal_read_mac_hidden_rpt OK! (1, 0ms), fwdl:1, id:0x19
      [  147.227926] RTL871X: SetHwReg8188F: bMacPwrCtrlOn=0
      [  147.233401] RTL871X: SetHwReg8188F: hci_sus_state=3
      [  147.239378] RTL871X: SetHwReg8188F: hci_sus_state=0
      [  147.244870] RTL871X: rtw_hal_read_chip_info in 1480 ms
      [  147.250837] RTL871X: init_channel_set((null)) ChannelPlan ID:0x23, ch num:14
      [  147.259749] RTL871X: rtw_alloc_macid((null)) if1, hwaddr:ff:ff:ff:ff:ff:ff macid:1
      [  147.268424] RTL871X: Init_ODM_ComInfo_8188f(): fab_ver=0 cut_ver=1
      [  147.275379] RTL871X: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1
      [  147.275548] RTL871X: phy_ConfigBBWithPgParaFile(): No File PHY_REG_PG.txt, Load from HWImg Array!
      [  147.295782] RTL871X: default power by rate loaded
      [  147.301349] RTL871X: rtw_macaddr_cfg mac addr:60:fb:00:79:45:21
      [  147.308117] RTL871X: bDriverStopped:True, bSurpriseRemoved:False, bup:0, hw_init_completed:0
      [  147.317893] RTL871X: rtw_wiphy_alloc(phy1)
      [  147.322483] RTL871X: rtw_wdev_alloc(padapter=64322601)
      [  147.328283] RTL871X: rtw_wiphy_register(phy1)
      [  147.333190] RTL871X: Register RTW cfg80211 vendor cmd(0x67) interface
      [  147.340106] RTL871X: _rtw_reg_notifier
      [  147.344764] RTL871X: _rtw_reg_notifier_apply: NL80211_REGDOM_SET_BY_CORE to DRV
      [  147.353532] RTL871X: rtw_ndev_init(wlan0) if1 mac_addr=60:fb:00:79:45:21
      [  147.379611] RTL871X: cfg80211_rtw_get_txpower
      [  147.632783] sunxi-rfkill soc@3000000:rfkill@0: wlan power off success
      [  147.740073] [XRADIO] Remove SDIO card 1
      [  147.740084] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
      [  147.751143] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
      [  147.757888] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
      [  147.761129] [SBUS_ERR] sdio probe timeout!
      [  147.769211] [XRADIO_ERR] sbus_sdio_init failed
      [  147.769225] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
      [  147.781065] RTL871X: rtw_wdev_unregister(wdev=de0483d8)
      [  147.781631] xradio_core_init failed (-110)!
      [  147.792196] RTL871X: cfg80211_rtw_get_txpower
      [  147.852838] RTL871X: rtw_ndev_uninit(wlan0) if1
      [  147.892943] RTL871X: rtw_wiphy_unregister(phy1)
      [  147.898018] RTL871X: Vendor: Unregister RTW cfg80211 vendor interface
      [  147.942998] RTL871X: 5rtw_dev_remove: device had been removed!
      [  147.949669] RTL871X: ### Clean STA_(1) info ###
      [  147.954826] RTL871X: rtw_dev_unload: bup==_FALSE
      [  147.959986] RTL871X: +r871xu_dev_remove, hw_init_completed=0
      [  147.966826] RTL871X: rtw_wdev_free(wdev=de0483d8)
      [  147.972096] RTL871X: rtw_wiphy_free(phy1)
      [  147.976730] RTL871X: 3sdio_deinit: sdio_disable_func(-5)
      [  147.982926] RTL871X: 3sdio_deinit: sdio_release_irq(-123)
      [  147.989303] mmc1: card 0001 removed
      [  147.993572] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [  148.006225] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  148.017671] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [  148.021298] ======== XRADIO WIFI OPEN ========
      [  148.031177] [XRADIO] Driver Label:XR_V02.16.84_P2P_HT40_01.31
      [  148.037946] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  148.049834] [XRADIO] Allocated hw_priv @ 933ee241
      [  148.055155] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [  148.062054] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [  148.062093] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  148.070256] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  148.080713] [ADDR_MGT] get_addr_by_name: t->addr:
      [  148.097686] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [  148.104499] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [  148.111278] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [  148.118078] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [  148.118281] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [  148.133316] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
      [  148.152367] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
      [  148.359713] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  148.370892] [XRADIO] Detect SDIO card 1
      [  148.375405] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [  148.395657] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  148.420644] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  148.435367] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  148.448724] sunxi-mmc 4021000.sdmmc: card claims to support voltages below defined range
      [  148.467679] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [  148.479373] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [  148.491319] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      [  148.503977] mmc1: new high speed SDIO card at address 0001
      [  148.511008] RTL871X: CHIP TYPE: RTL8188F
      [  148.515996] RTL871X: rtw_hal_config_rftype RF_Type is 3 TotalTxPath is 1
      [  148.523706] RTL871X: Chip Version Info: CHIP_8188F_Normal_Chip_SMIC_B_CUT_1T1R_RomVer(0)
      [  148.533042] RTL871X: SetHwReg8188F: hci_sus_state=1
      [  148.540141] RTL871X: SetHwReg8188F: bMacPwrCtrlOn=1
      [  148.545660] RTL871X: SetHwReg8188F: hci_sus_state=2
      [  148.551371] RTL871X: PowerOnCheck: val_mix:0x0000063f, res:0x0000063f
      [  148.558640] RTL871X: PowerOnCheck: 0x100 the result of cmd52 and cmd53 is the same.
      [  148.567312] RTL871X: PowerOnCheck: 0x1B8 test Pass.
      [  148.572940] RTL871X: EEPROM type is E-FUSE
      [  148.577864] RTL871X: hal_EfuseSwitchToBank: Efuse switch bank to 0
      [  148.616772] RTL871X: hal_ReadEFuse_WiFi: data end at address=0x98
      [  148.623685] RTL871X: HW EFUSE
      [  148.627016] RTL871X: 0x000:
      [  148.627021] 29
      [  148.630240] 81
      [  148.632196] 03
      [  148.634185] CC
      [  148.636151] 00
      [  148.638111] 00
      [  148.640083] 50
      [  148.642041] 00
      [  148.644042] 00
      [  148.646295] 00
      [  148.648253] 04
      [  148.650213] CC
      [  148.652171] 0A
      [  148.654172] 0C
      [  148.656140] 00
      [  148.658098] 00
      [  148.661912] RTL871X: 0x010:
      [  148.661914] 29
      [  148.665184] 29
      [  148.667147] 28
      [  148.669121] 29
      [  148.671079] 28
      [  148.673148] 28
      [  148.675113] 2A
      [  148.677073] 2A
      [  148.679028] 29
      [  148.681276] 2B
      [  148.683283] 2B
      [  148.685245] 02
      [  148.687203] FF
      [  148.689158] FF
      [  148.691115] FF
      [  148.693108] FF
      [  148.696938] RTL871X: 0x020:
      [  148.696941] FF
      [  148.700164] FF
      [  148.702122] FF
      [  148.704120] FF
      [  148.706078] FF
      [  148.708037] FF
      [  148.709994] FF
      [  148.711960] FF
      [  148.713954] FF
      [  148.716210] FF
      [  148.718168] FF
      [  148.720126] FF
      [  148.722083] FF
      [  148.724096] FF
      [  148.726070] FF
      [  148.728030] FF
      [  148.731844] RTL871X: 0x030:
      [  148.731846] FF
      [  148.735105] FF
      [  148.737069] FF
      [  148.739062] FF
      [  148.741021] FF
      [  148.743014] FF
      [  148.744977] FF
      [  148.746934] FF
      [  148.748893] FF
      [  148.751139] FF
      [  148.753140] FF
      [  148.755103] FF
      [  148.757061] FF
      [  148.759016] FF
      [  148.760975] FF
      [  148.762964] FF
      [  148.766784] RTL871X: 0x040:
      [  148.766787] FF
      [  148.770022] FF
      [  148.771982] FF
      [  148.773997] FF
      [  148.775959] FF
      [  148.777918] FF
      [  148.779876] FF
      [  148.781854] FF
      [  148.783851] FF
      [  148.786106] FF
      [  148.788064] FF
      [  148.790020] FF
      [  148.791977] FF
      [  148.793969] FF
      [  148.795949] FF
      [  148.797908] FF
      [  148.801720] RTL871X: 0x050:
      [  148.801722] FF
      [  148.804983] FF
      [  148.806943] FF
      [  148.808901] FF
      [  148.810868] FF
      [  148.812859] FF
      [  148.814822] FF
      [  148.816780] FF
      [  148.818736] FF
      [  148.820984] FF
      [  148.822993] FF
      [  148.824964] FF
      [  148.826922] FF
      [  148.828878] FF
      [  148.830834] FF
      [  148.832824] FF
      [  148.836638] RTL871X: 0x060:
      [  148.836641] FF
      [  148.839869] FF
      [  148.841828] FF
      [  148.843820] FF
      [  148.845785] FF
      [  148.847742] FF
      [  148.849697] FF
      [  148.851655] FF
      [  148.853651] FF
      [  148.855902] FF
      [  148.857861] FF
      [  148.859819] FF
      [  148.861776] FF
      [  148.863766] FF
      [  148.865728] FF
      [  148.867693] FF
      [  148.871508] RTL871X: 0x070:
      [  148.871510] FF
      [  148.874782] FF
      [  148.876742] FF
      [  148.878701] FF
      [  148.880657] FF
      [  148.882654] FF
      [  148.884614] FF
      [  148.886570] FF
      [  148.888528] FF
      [  148.890776] FF
      [  148.892767] FF
      [  148.894726] FF
      [  148.896697] FF
      [  148.898652] FF
      [  148.900610] FF
      [  148.902607] FF
      [  148.906420] RTL871X: 0x080:
      [  148.906422] FF
      [  148.909668] FF
      [  148.911626] FF
      [  148.913616] FF
      [  148.915575] FF
      [  148.917533] FF
      [  148.919492] FF
      [  148.921451] FF
      [  148.923454] FF
      [  148.925717] FF
      [  148.927675] FF
      [  148.929630] FF
      [  148.931588] FF
      [  148.933579] FF
      [  148.935541] FF
      [  148.937502] FF
      [  148.941323] RTL871X: 0x090:
      [  148.941326] FF
      [  148.944581] FF
      [  148.946544] FF
      [  148.948502] FF
      [  148.950459] FF
      [  148.952442] FF
      [  148.954435] FF
      [  148.956397] FF
      [  148.958355] FF
      [  148.960602] FF
      [  148.962592] FF
      [  148.964554] FF
      [  148.966529] FF
      [  148.968486] FF
      [  148.970444] FF
      [  148.972400] FF
      [  148.976270] RTL871X: 0x0a0:
      [  148.976273] FF
      [  148.979494] FF
      [  148.981461] FF
      [  148.983452] FF
      [  148.985416] FF
      [  148.987373] FF
      [  148.989330] FF
      [  148.991286] FF
      [  148.993272] FF
      [  148.995535] FF
      [  148.997498] FF
      [  148.999454] FF
      [  149.001410] FF
      [  149.003406] FF
      [  149.005368] FF
      [  149.007325] FF
      [  149.011165] RTL871X: 0x0b0:
      [  149.011168] FF
      [  149.014424] FF
      [  149.016387] FF
      [  149.018345] FF
      [  149.020301] FF
      [  149.022257] FF
      [  149.024277] FF
      [  149.026240] FF
      [  149.028203] 23
      [  149.030452] 2F
      [  149.032410] 20
      [  149.034403] 00
      [  149.036363] 00
      [  149.038332] 00
      [  149.040289] 00
      [  149.042248] FF
      [  149.046098] RTL871X: 0x0c0:
      [  149.046101] FF
      [  149.049324] 02
      [  149.051281] 00
      [  149.053273] 10
      [  149.055232] 00
      [  149.057189] FF
      [  149.059145] 00
      [  149.061102] FF
      [  149.063093] 00
      [  149.065344] 00
      [  149.067313] FF
      [  149.069271] FF
      [  149.071230] FF
      [  149.073236] FF
      [  149.075201] FF
      [  149.077162] FF
      [  149.080986] RTL871X: 0x0d0:
      [  149.080989] 3E
      [  149.084243] 10
      [  149.086203] 01
      [  149.088161] 12
      [  149.090119] 23
      [  149.092076] FF
      [  149.094064] FF
      [  149.096033] FF
      [  149.097990] 20
      [  149.100240] 04
      [  149.102195] 4C
      [  149.104185] 02
      [  149.106147] 79
      [  149.108104] F1
      [  149.110069] 21
      [  149.112028] 02
      [  149.115883] RTL871X: 0x0e0:
      [  149.115887] 0C
      [  149.119107] 00
      [  149.121062] 22
      [  149.123091] 04
      [  149.125052] 00
      [  149.127010] 08
      [  149.128966] 00
      [  149.130923] 32
      [  149.132913] FF
      [  149.135166] 21
      [  149.137148] 02
      [  149.139106] 0C
      [  149.141062] 00
      [  149.143058] 22
      [  149.145028] 2A
      [  149.146986] 01
      [  149.150799] RTL871X: 0x0f0:
      [  149.150801] 01
      [  149.154063] 00
      [  149.156022] 00
      [  149.157981] 00
      [  149.159938] 00
      [  149.161894] 00
      [  149.163883] 00
      [  149.165867] 00
      [  149.167825] 00
      [  149.170075] 00
      [  149.172031] 00
      [  149.174036] 00
      [  149.175996] 02
      [  149.177955] 00
      [  149.179932] FF
      [  149.181890] FF
      [  149.185741] RTL871X: 0x100:
      [  149.185744] 00
      [  149.188967] 00
      [  149.190924] 00
      [  149.192913] 00
      [  149.194884] 00
      [  149.196843] 00
      [  149.198800] 00
      [  149.200758] 00
      [  149.202753] 00
      [  149.205003] 00
      [  149.206962] 00
      [  149.208928] 00
      [  149.210886] 00
      [  149.212872] 00
      [  149.214832] 00
      [  149.216791] 00
      [  149.220602] RTL871X: 0x110:
      [  149.220605] 00
      [  149.223879] EB
      [  149.225843] 00
      [  149.227806] 6E
      [  149.229766] 01
      [  149.231723] 00
      [  149.233717] 00
      [  149.235682] 00
      [  149.237652] 00
      [  149.239905] FF
      [  149.241861] 60
      [  149.243854] FB
      [  149.245814] 00
      [  149.247771] 79
      [  149.249728] 45
      [  149.251692] 21
      [  149.255537] RTL871X: 0x120:
      [  149.255540] FF
      [  149.258762] FF
      [  149.260719] FF
      [  149.262709] FF
      [  149.264669] FF
      [  149.266636] FF
      [  149.268595] FF
      [  149.270553] FF
      [  149.272510] FF
      [  149.274807] FF
      [  149.276770] FF
      [  149.278727] FF
      [  149.280698] FF
      [  149.282695] FF
      [  149.284654] FF
      [  149.286611] FF
      [  149.290422] RTL871X: 0x130:
      [  149.290424] FF
      [  149.293694] FF
      [  149.295656] FF
      [  149.297615] FF
      [  149.299570] FF
      [  149.301527] FF
      [  149.303522] FF
      [  149.305481] FF
      [  149.307437] FF
      [  149.309694] FF
      [  149.311651] FF
      [  149.313640] FF
      [  149.315602] FF
      [  149.317560] FF
      [  149.319518] FF
      [  149.321478] FF
      [  149.325351] RTL871X: 0x140:
      [  149.325354] FF
      [  149.328580] FF
      [  149.330539] FF
      [  149.332494] FF
      [  149.334483] FF
      [  149.336469] FF
      [  149.338428] FF
      [  149.340384] FF
      [  149.342345] FF
      [  149.344631] FF
      [  149.346594] FF
      [  149.348553] FF
      [  149.350525] FF
      [  149.352482] FF
      [  149.354476] FF
      [  149.356439] FF
      [  149.360250] RTL871X: 0x150:
      [  149.360253] FF
      [  149.363505] FF
      [  149.365477] FF
      [  149.367435] FF
      [  149.369392] FF
      [  149.371349] FF
      [  149.373354] FF
      [  149.375316] FF
      [  149.377276] FF
      [  149.379533] FF
      [  149.381488] FF
      [  149.383484] FF
      [  149.385445] FF
      [  149.387402] FF
      [  149.389360] FF
      [  149.391315] FF
      [  149.395186] RTL871X: 0x160:
      [  149.395189] FF
      [  149.398408] FF
      [  149.400363] FF
      [  149.402317] FF
      [  149.404311] FF
      [  149.406272] FF
      [  149.408241] FF
      [  149.410197] FF
      [  149.412154] FF
      [  149.414432] FF
      [  149.416394] FF
      [  149.418351] FF
      [  149.420307] FF
      [  149.422270] FF
      [  149.424276] FF
      [  149.426240] FF
      [  149.430052] RTL871X: 0x170:
      [  149.430054] FF
      [  149.433306] FF
      [  149.435273] FF
      [  149.437247] FF
      [  149.439205] FF
      [  149.441159] FF
      [  149.443146] FF
      [  149.445108] FF
      [  149.447069] FF
      [  149.449323] FF
      [  149.451291] FF
      [  149.453282] FF
      [  149.455246] FF
      [  149.457206] FF
      [  149.459167] FF
      [  149.461125] FF
      [  149.464979] RTL871X: 0x180:
      [  149.464982] FF
      [  149.468208] FF
      [  149.470167] FF
      [  149.472126] FF
      [  149.474133] FF
      [  149.476101] FF
      [  149.478065] FF
      [  149.480034] FF
      [  149.481996] FF
      [  149.484278] FF
      [  149.486245] FF
      [  149.488206] FF
      [  149.490162] FF
      [  149.492122] FF
      [  149.494111] FF
      [  149.496075] FF
      [  149.499898] RTL871X: 0x190:
      [  149.499901] FF
      [  149.503166] FF
      [  149.505127] FF
      [  149.507113] FF
      [  149.509078] FF
      [  149.511037] FF
      [  149.513035] FF
      [  149.515000] FF
      [  149.516959] FF
      [  149.519209] FF
      [  149.521187] FF
      [  149.523201] FF
      [  149.525165] FF
      [  149.527127] FF
      [  149.529088] FF
      [  149.531045] FF
      [  149.534895] RTL871X: 0x1a0:
      [  149.534898] FF
      [  149.538137] FF
      [  149.540094] FF
      [  149.542054] FF
      [  149.544045] FF
      [  149.546011] FF
      [  149.547971] FF
      [  149.549956] FF
      [  149.551918] FF
      [  149.554198] FF
      [  149.556164] FF
      [  149.558126] FF
      [  149.560085] FF
      [  149.562042] FF
      [  149.564059] FF
      [  149.566026] FF
      [  149.569846] RTL871X: 0x1b0:
      [  149.569849] FF
      [  149.573131] FF
      [  149.575096] FF
      [  149.577058] FF
      [  149.579030] FF
      [  149.580991] FF
      [  149.582982] FF
      [  149.584949] FF
      [  149.586910] FF
      [  149.589163] FF
      [  149.591120] FF
      [  149.593114] FF
      [  149.595076] FF
      [  149.597037] FF
      [  149.598994] FF
      [  149.600954] FF
      [  149.604805] RTL871X: 0x1c0:
      [  149.604809] FF
      [  149.608045] FF
      [  149.610003] FF
      [  149.611964] FF
      [  149.613954] FF
      [  149.615917] FF
      [  149.617876] FF
      [  149.619834] FF
      [  149.621806] FF
      [  149.624105] FF
      [  149.626069] FF
      [  149.628031] FF
      [  149.629990] FF
      [  149.631949] FF
      [  149.633940] FF
      [  149.635917] FF
      [  149.639737] RTL871X: 0x1d0:
      [  149.639739] FF
      [  149.642998] FF
      [  149.644962] FF
      [  149.646928] FF
      [  149.648886] FF
      [  149.650851] FF
      [  149.652850] FF
      [  149.654815] FF
      [  149.656774] FF
      [  149.659030] FF
      [  149.660988] FF
      [  149.662978] FF
      [  149.664951] FF
      [  149.666911] FF
      [  149.668870] FF
      [  149.670830] FF
      [  149.674704] RTL871X: 0x1e0:
      [  149.674707] FF
      [  149.677958] FF
      [  149.679916] FF
      [  149.681878] FF
      [  149.683875] FF
      [  149.685839] FF
      [  149.687799] FF
      [  149.689757] FF
      [  149.691715] FF
      [  149.694003] FF
      [  149.695970] FF
      [  149.697933] FF
      [  149.699889] FF
      [  149.701850] FF
      [  149.703844] FF
      [  149.705810] FF
      [  149.709640] RTL871X: 0x1f0:
      [  149.709643] FF
      [  149.712961] FF
      [  149.714928] FF
      [  149.716887] FF
      [  149.718846] FF
      [  149.720819] FF
      [  149.722851] FF
      [  149.724966] FF
      [  149.727018] FF
      [  149.729277] FF
      [  149.731240] FF
      [  149.733247] FF
      [  149.735234] FF
      [  149.737198] FF
      [  149.739156] FF
      [  149.741114] FF
      [  149.744970]
      [  149.746671] RTL871X: hal_com_config_channel_plan chplan:0x23
      [  149.753570] RTL871X: kfree flag:1
      [  149.757285] RTL871X: bb_gain:-1
      [  149.760892] RTL871X: rtl8188f_FirmwareDownload((null)) tmp_ps=3
      [  149.767591] RTL871X: rtl8188f_FirmwareDownload fw: FW_NIC, size: 21020
      [  149.774971] RTL871X: rtl8188f_FirmwareDownload: fw_ver=4 fw_subver=0000 sig=0x88f1, Month=08, Date=22, Hour=17, Minute=36
      [  149.787261] RTL871X: rtl8188f_FirmwareDownload(): Shift for fw header!
      [  149.794597] RTL871X: rtl8188f_FirmwareDownload by IO write!
      [  149.936171] RTL871X: polling_fwdl_chksum: Checksum report OK! (1, 0ms), REG_MCUFWDL:0x07050105
      [  149.946178] RTL871X: _8051Reset8188: Finish
      [  149.959695] RTL871X: _FWFreeToGo: Polling FW ready OK! (123, 10ms), REG_MCUFWDL:0x070501c6
      [  149.969003] RTL871X: rtl8188f_FirmwareDownload: DLFW OK !
      [  149.975117] RTL871X: rtl8188f_FirmwareDownload success. write_fw:1, 180ms
      [  149.982819] RTL871X:  <=== rtl8188f_FirmwareDownload()
      [  149.988888] RTL871X: hal_read_mac_hidden_rpt OK! (1, 0ms), fwdl:1, id:0x19
      [  149.997085] RTL871X: SetHwReg8188F: bMacPwrCtrlOn=0
      [  150.002581] RTL871X: SetHwReg8188F: hci_sus_state=3
      [  150.008649] RTL871X: SetHwReg8188F: hci_sus_state=0
      [  150.014142] RTL871X: rtw_hal_read_chip_info in 1480 ms
      [  150.020128] RTL871X: init_channel_set((null)) ChannelPlan ID:0x23, ch num:14
      [  150.029114] RTL871X: rtw_alloc_macid((null)) if1, hwaddr:ff:ff:ff:ff:ff:ff macid:1
      [  150.037845] RTL871X: Init_ODM_ComInfo_8188f(): fab_ver=0 cut_ver=1
      [  150.044812] RTL871X: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1
      [  150.055361] RTL871X: phy_ConfigBBWithPgParaFile(): No File PHY_REG_PG.txt, Load from HWImg Array!
      [  150.065365] RTL871X: default power by rate loaded
      [  150.070940] RTL871X: rtw_macaddr_cfg mac addr:60:fb:00:79:45:21
      [  150.077815] RTL871X: bDriverStopped:True, bSurpriseRemoved:False, bup:0, hw_init_completed:0
      [  150.087459] RTL871X: rtw_wiphy_alloc(phy3)
      [  150.092073] RTL871X: rtw_wdev_alloc(padapter=64322601)
      [  150.097882] RTL871X: rtw_wiphy_register(phy3)
      [  150.102781] RTL871X: Register RTW cfg80211 vendor cmd(0x67) interface
      [  150.111063] RTL871X: _rtw_reg_notifier
      [  150.115356] RTL871X: _rtw_reg_notifier_apply: NL80211_REGDOM_SET_BY_CORE to DRV
      [  150.124115] RTL871X: rtw_ndev_init(wlan0) if1 mac_addr=60:fb:00:79:45:21
      [  150.139004] RTL871X: cfg80211_rtw_get_txpower
      [  150.432796] sunxi-rfkill soc@3000000:rfkill@0: wlan power off success
      [  150.540085] [XRADIO] Remove SDIO card 1
      [  150.540097] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
      [  150.551173] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
      [  150.557924] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
      [  150.561160] [SBUS_ERR] sdio probe timeout!
      [  150.569246] [XRADIO_ERR] sbus_sdio_init failed
      [  150.569260] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
      [  150.581096] RTL871X: rtw_wdev_unregister(wdev=f84f15ed)
      [  150.582284] xradio_core_init failed (-110)!
      [  150.592290] RTL871X: cfg80211_rtw_get_txpower
      [  150.622831] RTL871X: rtw_ndev_uninit(wlan0) if1
      [  150.662939] RTL871X: rtw_wiphy_unregister(phy3)
      [  150.668027] RTL871X: Vendor: Unregister RTW cfg80211 vendor interface
      [  150.712982] RTL871X: 5rtw_dev_remove: device had been removed!
      [  150.719647] RTL871X: ### Clean STA_(1) info ###
      [  150.724800] RTL871X: rtw_dev_unload: bup==_FALSE
      [  150.729991] RTL871X: +r871xu_dev_remove, hw_init_completed=0
      [  150.736847] RTL871X: rtw_wdev_free(wdev=f84f15ed)
      [  150.742121] RTL871X: rtw_wiphy_free(phy3)
      [  150.746762] RTL871X: 3sdio_deinit: sdio_disable_func(-5)
      [  150.746901] RTL871X: 3sdio_deinit: sdio_release_irq(-123)
      [  150.747160] mmc1: card 0001 removed
      [  150.763505] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      insmod: can't insert '/lib/modules/5.4.61/kernel/drivers/net/wireless/xr829/xr829.ko': Connection timed out[  150.776084] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  150.795764] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      # [  150.816086] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  150.841261] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [  150.848955] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [  150.855844] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  150.870509] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  150.884328] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [  150.891898] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [  150.899467] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [  150.907045] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [  150.913822] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      ^C
      • zhongtao1701
        钟工 LV 7 最后由 编辑
        上面的描述有一个错误, 不是sdc2,wifi接在sdc1上面
