    T113 USB0不能读取U盘
    5799
    • hxhlb
      香蕉苹果胡萝卜 LV 2 最后由 编辑
      T113 usb1读取U盘正常, usb0不能读取.
      表现为, 插入U盘毫无反应, 就和没插入一样.
      确认已经进行过usbhost指令切换.
      使用usb1时, 输出:
      [   12.519347] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   12.797467] usb 1-1: new high-speed USB device number 2 using sunxi-ehci
      [   13.000365] usb-storage 1-1:1.0: USB Mass Storage device detected
      [   13.007895] scsi host0: usb-storage 1-1:1.0
      [   14.048728] scsi 0:0:0:0: Direct-Access     SanDisk  Cruzer Blade     1.00 PQ: 0 ANSI: 6
      [   14.065939] sd 0:0:0:0: [sda] 61341696 512-byte logical blocks: (31.4 GB/29.3 GiB)
      [   14.076421] sd 0:0:0:0: [sda] Write Protect is off
      [   14.081846] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
      [   14.088548] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
      [   14.191826]  sda: sda1 sda2
      [   14.211084] sd 0:0:0:0: [sda] Attached SCSI removable disk
      [   14.317085] [EXFAT] trying to mount...
      [   14.321379] EXFAT: Attempted to mount VFAT filesystem
      [   14.469469] FAT-fs (sda2): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
      [   14.561102] ntfs: volume version 3.1.
      [   14.565253] ntfs: (device sda1): load_system_files(): Volume is dirty.  Mounting read-only.  Run chkdsk and mount in Windows.
      [   14.581433] ntfs: (device sda1): load_system_files(): $LogFile is not clean.  Will not be able to remount read-write.  Mount in Windows.
      进行 usbhost 切换时, 显示为:
      [ 1396.620617] android_work: did not send uevent (0 0 00000000)
      [ 1396.627196] hci: ERR: sunxi_ehci is null
      [ 1396.631626] hci: ERR: sunxi_ohci is null
      host_chose finished!
      进行usbdevice切换时, 显示为:
      [ 1381.640980] hci: ERR: sunxi_ehci is null
      [ 1381.645354] hci: ERR: sunxi_ohci is null
      [ 1381.650047] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
      配置如下:
      &usbc0 {
      	device_type = "usbc0";
      	usb_port_type = <0x2>;
      	usb_detect_type = <0x1>;
      	usb_detect_mode = <0>;
      	usb_id_gpio = <&pio PG 0 GPIO_ACTIVE_HIGH>;
      	enable-active-high;
      	usb_det_vbus_gpio = <&pio PG 0 GPIO_ACTIVE_HIGH>;
      	usb_wakeup_suspend = <0>;
      	usb_serial_unique = <1>;
      	usb_serial_number = "1357924680";
      	rndis_wceis = <1>;
      &ehci0 {
      	/*drvvbus-supply = <&reg_usb0_vbus>;*/
      &ohci0 {
      &usbc1 {
      	device_type = "usbc1";
          usb_port_type = <0x01>;
      	usb_regulator_io = "nocare";
      &ehci1 {
      &ohci1 {
      上边注释掉的 reg_usb0_vbus 配置是抄的 reg_usb1_vbus, 以为是这里配置错了呢.
      	reg_usb0_vbus: usb0-vbus {
      		regulator-name = "usb0-vbus";
      		gpio = <&pio PB 3 GPIO_ACTIVE_HIGH>;
      		enable-active-high;
      	reg_usb1_vbus: usb1-vbus {
      		regulator-name = "usb1-vbus";
      		enable-active-high;
      经过测试也不行.
      把usb0 的 usb_port_type 配置为 1 时, 内核启动可以看到如下输出:
      [    1.624357] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    1.631732] sunxi-ehci: EHCI SUNXI driver
      [    1.636644] get ehci1-controller wakeup-source is fail.
      [    1.642629] sunxi ehci1-controller don't init wakeup source
      [    1.648904] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0b63aa8, 0x:c8839000, irq_no:3c
      [    1.660939] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator
      [    1.673429] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
      [    1.685604] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
      [    1.692899] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
      [    1.702870] sunxi-ehci 4200000.ehci1-controller: irq 60, io mem 0x04200000
      [    1.737465] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
      [    1.746129] hub 1-0:1.0: USB hub found
      [    1.750396] hub 1-0:1.0: 1 port detected
      [    1.755352] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    1.762352] sunxi-ohci: OHCI SUNXI driver
      [    1.767316] get ohci1-controller wakeup-source is fail.
      [    1.773305] sunxi ohci1-controller don't init wakeup source
      [    1.779575] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0b63d38
      [    1.789268] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator
      [    1.801762] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
      [    1.813962] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
      [    1.821234] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
      [    1.831133] sunxi-ohci 4200400.ohci1-controller: irq 61, io mem 0x04200400
      [    1.912244] hub 2-0:1.0: USB hub found
      [    1.916488] hub 2-0:1.0: 1 port detected
      插入U盘也毫无反应.
      求教到底是哪里的问题.
        whycan晕哥 LV 9 @hxhlb 最后由 whycan 编辑
        @hxhlb
        find / -name usb_host | xargs cat
        试一试这个。
        hxhlb 1 条回复 最后回复 回复 引用 分享 0
        • hxhlb
          香蕉苹果胡萝卜 LV 2 @whycan 最后由 编辑
          @whycan 在 T113 USB0不能读取U盘 中说:
          一样的
          alias usbhost="cat /sys/devices/platform/soc@3000000/soc@3000000:usbc0@0/usb_host"
          alias usbdevice="cat /sys/devices/platform/soc@3000000/soc@3000000:usbc0@0/usb_device"
          • hxhlb
            香蕉苹果胡萝卜 LV 2 最后由 编辑
            忘记说了, 作为device模式时, 很正常, adb通信很好.
            • T
              TX_dw LV 5 最后由 编辑
              大佬解决了么,我最近也在用usb0挂载U盘
