    XR829模块加载出现Timeout waiting for FIFO问题
    5
    14
    11045
    • K
      konosiba LV 4 最后由 编辑
      sdk是tina d1-h v2.0
      报错log:
      root@TinaLinux:/lib/modules/5.4.61# modprobe xr829.ko
      [  105.303891] ======== XRADIO WIFI OPEN ========
      [  105.309402] [XRADIO] Driver Label:XR_V02.16.85_P2P_HT40_01.31
      [  105.316356] [XRADIO] Allocated hw_priv @ 00000000954129d5
      [  105.324282] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
      [  105.353732] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
      [  105.560907] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  105.572134] [XRADIO] Detect SDIO card 1
      [  105.582373] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [  105.606991] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  105.632012] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  105.646794] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  105.669352] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [  105.681086] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [  105.693095] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      [  105.706020] mmc1: new high speed SDIO card at address 0001
      [  105.713319] [SBUS] XRadio Device:sdio clk=50000000
      [  105.723772] [XRADIO] XRADIO_HW_REV 1.0 detected.
      [  105.784245] [XRADIO] xradio_update_dpllctrl: DPLL_CTRL Sync=0x00c00000.
      [  105.826623] [XRADIO] Bootloader complete
      [  110.834766] [XRADIO_ERR] xradio_firmware: Timeout waiting for FIFO.
      [  110.841820] [XRADIO_ERR] xradio_load_firmware: can't download firmware.
      [  110.849439] [XRADIO_ERR] xradio_load_firmware failed(-110).
      [  110.857344] sunxi-rfkill soc@3000000:rfkill@0: wlan power off success
      [  110.977958] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
      [  110.984755] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
      [  110.991527] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
      [  110.998302] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
      [  111.005372] mmc1: card 0001 removed
      [  111.009416] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [  111.020948] [XRADIO] Remove SDIO card 1
      [  111.035014] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  111.046794] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [  111.066566] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  111.079594] xradio_core_init failed (-110)!
      [  111.097884] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [  111.105594] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [  111.112423] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  111.127303] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  111.141260] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [  111.148868] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [  111.157100] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [  111.164708] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [  111.171576] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      1 module could not be probed
      - xr829
      这里是我的board.dts:
       * Allwinner Technology CO., Ltd. sun20iw1p1 fpga.
       * fpga support.
      /dts-v1/;
      /memreserve/ 0x42000000 0x100000;  /* dsp used 1MB */
      #include "sun20iw1p1.dtsi"
      	compatible = "allwinner,d1-h", "arm,sun20iw1p1", "allwinner,sun20iw1p1";
      	aliases {
      		dsp0 = &dsp0;
      		dsp0_gpio_int= &dsp0_gpio_int;
      		gmac0 = &gmac0;
      	dsp0: dsp0 {
      		compatible = "allwinner,sun20iw1-dsp";
      	dsp0_gpio_int: dsp0_gpio_int {
      		compatible = "allwinner,sun20iw1-dsp-gpio-int";
      		pin-group = "PB", "PC", "PD", "PE";
      		status = "disabled";
      	reg_vdd_cpu: vdd-cpu {
      		pwms = <&pwm 0 5000 1>;
      		regulator-name = "vdd_cpu";
      		regulator-ramp-delay = <25>;
      		regulator-always-on;
      		regulator-boot-on;
      	reg_usb1_vbus: usb1-vbus {
      		regulator-name = "usb1-vbus";
      		gpio = <&pio PD 19 GPIO_ACTIVE_HIGH>;
      		enable-active-high;
      &CPU0 {
      	cpu-supply = <&reg_vdd_cpu>;
      &pio {
      	sdc0_pins_a: sdc0@0 {
      				 "PF3", "PF4", "PF5";
      		allwinner,function = "sdc0";
      		allwinner,muxsel = <2>;
      		allwinner,drive = <3>;
      		allwinner,pull = <1>;
      		function = "sdc0";
      		drive-strength = <30>;
      		bias-pull-up;
      		power-source = <3300>;
      	sdc0_pins_b: sdc0@1 {
      		function = "sdc0";
      		bias-pull-up;
      		power-source = <1800>;
      	sdc0_pins_c: sdc0@2 {
      		function = "gpio_in";
      	/* TODO: add jtag pin */
      	sdc0_pins_d: sdc0@3 {
      		pins = "PF2", "PF4";
      		function = "uart0";
      		drive-strength = <10>;
      		bias-pull-up;
      	sdc0_pins_e: sdc0@4 {
      		pins = "PF0", "PF1", "PF3",
      			"PF5";
      		function = "jtag";
      		bias-pull-up;
      	sdc1_pins_a: sdc1@0 {
      		pins = "PG0", "PG1", "PG2",
      		       "PG3", "PG4", "PG5";
      		function = "sdc1";
      		bias-pull-up;
      	sdc1_pins_b: sdc1@1 {
      	sdc2_pins_a: sdc2@0 {
      				 "PC5", "PC6", "PC7";
      		allwinner,function = "sdc2";
      		allwinner,muxsel = <3>;
      		function = "sdc2";
      		bias-pull-up;
      	sdc2_pins_b: sdc2@1 {
      	wlan_pins_a:wlan@0 {
      		pins = "PG11";
      		function = "clk_fanout1";
      	uart0_pins_a: uart0_pins@0 {  /* For nezha board */
      		pins = "PB8", "PB9";
      		function = "uart0";
      		bias-pull-up;
      	uart0_pins_b: uart0_pins@1 {  /* For nezha board */
      		function = "uart1";
      		bias-pull-up;
      		pins = "PC0", "PC1";
      		function = "uart2";
      		bias-pull-up;
      		pins = "PD10", "PD11";
      		function = "uart3";
      		muxsel = <5>;
      		bias-pull-up;
      	twi0_pins_a: twi0@0 {
      		function = "twi0";
      	twi0_pins_b: twi0@1 {
      	twi1_pins_a: twi1@0 {
      		pins = "PB4", "PB5";
      		function = "twi1";
      	twi1_pins_b: twi1@1 {
      	twi2_pins_a: twi2@0 {
      		pins = "PB0", "PB1";
      		function = "twi2";
      	twi2_pins_b: twi2@1 {
      	twi3_pins_a: twi3@0 {
      		pins = "PB6", "PB7";
      		function = "twi3";
      	twi3_pins_b: twi3@1 {
      	gmac_pins_a: gmac@0 {
      		       "PE4", "PE5", "PE6", "PE7",
      		       "PE8", "PE9", "PE10", "PE11",
      		       "PE12", "PE13", "PE14", "PE15";
      		function = "gmac0";
      		muxsel = <8>; /* for uboot driver */
      	gmac_pins_b: gmac@1 {
      	dmic_pins_a: dmic@0 {
      		/* DMIC_PIN: CLK, DATA0, DATA1, DATA2 */
      		pins = "PE17", "PB11", "PB10", "PD17";
      		function = "dmic";
      		drive-strength = <20>;
      		bias-disable;
      	dmic_pins_b: dmic@1 {
      		function = "io_disabled";
      		bias-disable;
      	daudio0_pins_a: daudio0@0 {
      		/* MCLK, BCLK, LRCK */
      		pins = "PE17", "PE16", "PE15";
      		function = "i2s0";
      		bias-disable;
      	daudio0_pins_b: daudio0@1 {
      		/* DIN0 */
      		pins = "PE14";
      		function = "i2s0_din";
      		bias-disable;
      	daudio0_pins_c: daudio0@2 {
      		/* DOUT0 */
      		pins = "PE13";
      		function = "i2s0_dout";
      		bias-disable;
      	daudio0_pins_d: daudio0_sleep@0 {
      		bias-disable;
      	daudio1_pins_a: daudio1@0 {
      		/* MCLK, LRCK, BCLK */
      		pins = "PG11", "PG12", "PG13";
      		function = "i2s1";
      		bias-disable;
      	daudio1_pins_b: daudio1@1 {
      		/* DIN0 */
      		pins = "PG14";
      		function = "i2s1_din";
      		bias-disable;
      	daudio1_pins_c: daudio1@2 {
      		/* DOUT0 */
      		pins = "PG15";
      		function = "i2s1_dout";
      		bias-disable;
      	daudio1_pins_d: daudio1_sleep@0 {
      		bias-disable;
      	daudio2_pins_a: daudio2@0 {
      		pins = "PB7", "PB5", "PB6";
      		function = "i2s2";
      		bias-disable;
      	daudio2_pins_b: daudio2@1 {
      		/* I2S_PIN: DOUT0 */
      		pins = "PB4";
      		function = "i2s2_dout";
      		bias-disable;
      	daudio2_pins_c: daudio2@2 {
      		/* I2S_PIN: DIN0 */
      		pins = "PB3";
      		function = "i2s2_din";
      		bias-disable;
      		pins = "PB7", "PB5", "PB6", "PB4", "PB3";
      		bias-disable;
      	spdif_pins_a: spdif@0 {
      		/* SPDIF_PIN: SPDIF_OUT */
      		pins = "PB0";
      		function = "spdif";
      		bias-disable;
      	spdif_pins_b: spdif_sleep@0 {
      		pins = "PB0";
      		bias-disable;
      	spi0_pins_a: spi0@0 {
      		function = "spi0";
      		muxsel = <2>;
      	spi0_pins_b: spi0@1 {
      		pins = "PC3", "PC7", "PC6";
      		function = "spi0";
      		muxsel = <2>;
      	spi0_pins_c: spi0@2 {
      		muxsel = <0>;
      	spi1_pins_a: spi1@0 {
      		function = "spi1";
      	spi1_pins_b: spi1@1 {
      		function = "spi1";
      	spi1_pins_c: spi1@2 {
      	ledc_pins_a: ledc@0 {
      		pins = "PC0";
      		function = "ledc";
      	ledc_pins_b: ledc@1 {
      		pins = "PC0";
      	pwm0_pin_a: pwm0@0 {
      		pins = "PD16";
      		function = "pwm0";
      		bias-pull-up;
      	pwm0_pin_b: pwm0@1 {
      		pins = "PD16";
      		bias-disable;
      	pwm2_pin_a: pwm2@0 {
      		pins = "PD18";
      		function = "pwm2";
      		bias-pull-up;
      	pwm2_pin_b: pwm2@1 {
      		pins = "PD18";
      		function = "gpio_out";
      	pwm7_pin_a: pwm7@0 {
      		pins = "PD22";
      		function = "pwm7";
      		bias-pull-up;
      	pwm7_pin_b: pwm7@1 {
      		pins = "PD22";
      	s_cir0_pins_a: s_cir@0 {
      		pins = "PB12";
      		function = "ir";
      		bias-pull-up;
      	s_cir0_pins_b: s_cir@1 {
      		pins = "PB12";
      	ir1_pins_a: ir1@0 {
      		pins = "PB0";
      		function = "ir";
      		bias-pull-up;
      	ir1_pins_b: ir1@1 {
      		pins = "PB0";
      &uart0 {
      	pinctrl-0 = <&uart0_pins_a>;
      	pinctrl-1 = <&uart0_pins_b>;
      &uart1 {
      	pinctrl-0 = <&uart1_pins_a>;
      	pinctrl-1 = <&uart1_pins_b>;
      &uart2 {
      	pinctrl-0 = <&uart2_pins_a>;
      	pinctrl-1 = <&uart2_pins_b>;
      &uart3 {
      	pinctrl-0 = <&uart3_pins_a>;
      	pinctrl-1 = <&uart3_pins_a>;
      &soc {
      	card0_boot_para@2 {
      		reg = <0x0 0x2 0x0 0x0>;
      		card_ctrl = <0x0>;
      		card_high_speed = <0x1>;
      		card_line = <0x4>;
      		pinctrl-0 = <&sdc0_pins_a>;
      	card2_boot_para@3 {
      		reg = <0x0 0x3 0x0 0x0>;
      		card_ctrl = <0x2>;
      		card_line = <0x4>;
      		pinctrl-0 = <&sdc2_pins_a>;
      		/*sdc_ex_dly_used = <0x2>;*/
      		sdc_io_1v8 = <0x1>;
      		/*sdc_type = "tm4";*/
      		sdc_ex_dly_used = <2>;
      		/*sdc_tm4_win_th = <8>;*/
      	rfkill: rfkill@0 {
      		chip_en;
      		power_en;
      		pinctrl-0 = <&wlan_pins_a>;
      		pinctrl-names = "default";
      		status        = "okay";
      		wlan: wlan@0 {
      			clock-names = "32k-fanout1";
      			wlan_busnum    = <0x1>;
      			/*interrupt-parent = <&pio>;
      			wakeup-source;
      		bt: bt@0 {
      			/*bt_power_num = <0x01>;*/
      			/*bt_io_vol = <3300000>;*/
      			/*bt_power_vol = <330000>;*/
      			bt_rst_n      = <&pio PG 18 GPIO_ACTIVE_LOW>;
      			status        = "okay";
      	btlpm: btlpm@0 {
      		uart_index  = <0x1>;
      		bt_wake     = <&pio PG 16 GPIO_ACTIVE_HIGH>;
      		bt_hostwake = <&pio PG 17 GPIO_ACTIVE_HIGH>;
      		status      = "okay";
      	addr_mgt: addr_mgt@0 {
      		type_addr_wifi = <0x0>;
      		type_addr_bt   = <0x0>;
      		type_addr_eth  = <0x0>;
      		status         = "okay";
      &sdc2 {
      	non-removable;
      	bus-width = <4>;
      	mmc-ddr-1_8v;
      	mmc-hs200-1_8v;
      	no-sdio;
      	//no-sd;
      	ctl-spec-caps = <0x308>;
      	cap-mmc-highspeed;
      	sunxi-power-save-mode;
      	sunxi-dis-signal-vol-sw;
      	mmc-bootpart-noacc;
      	max-frequency = <150000000>;
      	/*emmc io vol 3.3v*/
      	/*emmc io vol 1.8v*/
      &sdc0 {
      	bus-width = <4>;
      	/*non-removable;*/
      	/*broken-cd;*/
      	cd-inverted;
      	/*data3-detect;*/
      	cd-used-24M;
      	cap-sd-highspeed;
      	/*sd-uhs-sdr50;*/
      	/*sd-uhs-ddr50;*/
      	/*sd-uhs-sdr104;*/
      	no-sdio;
      	no-mmc;
      	/*sunxi-dis-signal-vol-sw;*/
      	ctl-spec-caps = <0x8>;
      &sdc1 {
      	bus-width = <4>;
      	//no-mmc;
      	no-sd;
      	cap-sd-highspeed;
      	/*sd-uhs-sdr12*/
      	/*sd-uhs-sdr25;*/
      	/*sd-uhs-sdr50;*/
      	/*sd-uhs-ddr50;*/
      	/*sd-uhs-sdr104;*/
      	/*sunxi-power-save-mode;*/
      	cap-sdio-irq;
      	keep-power-in-suspend;
      	ignore-pm-notify;
      tvd configuration
                             mode,mean enable)
      &tvd {
      	tvd_sw          = <1>;
      	tvd_interface   = <0>;
      	tvd_format      = <0>;
      	tvd_system      = <1>;
      	tvd_row         = <1>;
      	tvd_column      = <1>;
      	tvd_channel0_en = <1>;
      	tvd_channel1_en = <0>;
      	tvd_channel2_en = <0>;
      	tvd_channel3_en = <0>;
      	/*tvd_power0      = "dc1sw"*/
      	/*tvd_power1      = "eldo3"*/
      &tvd0 {
      /* Audio Driver modules */
      &sunxi_rpaf_dsp0 {
      &codec {
      	mic1gain 	= <0x13>;
      	mic2gain 	= <0x13>;
      	mic3gain 	= <0x13>;
      	adcdrc_cfg 	= <0x0>;
      	adchpf_cfg 	= <0x1>;
      	dacdrc_cfg 	= <0x0>;
      	dachpf_cfg 	= <0x0>;
      	/* Volume about */
      	digital_vol 	= <0x00>;
      	lineout_vol 	= <0x1a>;
      	headphonegain	= <0x03>;
      	/* Pa enabled about */
      	pa_level 	= <0x01>;
      	pa_pwr_level 	= <0x01>;
      	pa_msleep_time 	= <0x78>;
      	/* gpio-spk	= <&pio PF 2 GPIO_ACTIVE_HIGH>; */
      	/* regulator about */
      &sndcodec {
      	hp_detect_case	= <0x01>;
      	jack_enable	= <0x01>;
      &dummy_cpudai {
      	/* CMA config about */
      	playback_cma	= <128>;
      	capture_cma	= <256>;
      &dmic {
      &sounddmic {
      &dmic_codec {
       * tdm_config		0 --> pcm
       *			1 --> i2s
       * mclk_div		0 --> not output
       *			1 --> HDMI audio type
      &daudio0 {
      	mclk_div 	= <0x01>;
      	frametype 	= <0x00>;
      	tdm_config 	= <0x01>;
      	sign_extend 	= <0x00>;
      	msb_lsb_first 	= <0x00>;
      	pcm_lrck_period = <0x80>;
      	slot_width_select = <0x20>;
      	pinctrl-0       = <&daudio0_pins_a &daudio0_pins_b &daudio0_pins_c>;
      	pinctrl-1       = <&daudio0_pins_d>;
      	pinctrl_used	= <0x0>;
      &sounddaudio0 {
      		/* sound-dai = <&ac108>; */
      &daudio1 {
      	mclk_div 	= <0x01>;
      	frametype 	= <0x00>;
      	pinctrl-0       = <&daudio1_pins_a &daudio1_pins_b &daudio1_pins_c>;
      	pinctrl-1       = <&daudio1_pins_d>;
      &sounddaudio1 {
      &daudio2 {
      	mclk_div 	= <0x00>;
      	frametype 	= <0x00>;
      	tx_data_mode 	= <0x00>;
      	rx_data_mode 	= <0x00>;
      	pcm_lrck_period = <0x20>;
      	asrc_function_en  = <0x00>;
      	/*pinctrl-0       = <&daudio2_pins_a &daudio2_pins_b &daudio2_pins_c>;*/
      	/*pinctrl-1       = <&daudio2_pins_d>;*/
      	/* HDMI audio, no need pin */
      	pinctrl-0;
      	pinctrl-1;
      	daudio_type	= <0x1>;
      &hdmiaudio {
      &sounddaudio2 {
      	simple-audio-card,name = "sndhdmi";
      		sound-dai = <&hdmiaudio>;
      &spdif {
      &soundspdif {
      &usbc0 {
      	device_type = "usbc0";
      	usb_port_type = <0x2>;
      	usb_detect_type = <0x1>;
      	usb_detect_mode = <0>;
      	usb_id_gpio = <&pio PD 21 GPIO_ACTIVE_HIGH>;
      	enable-active-high;
      	usb_det_vbus_gpio = <&pio PD 20 GPIO_ACTIVE_HIGH>;
      	usb_wakeup_suspend = <0>;
      	usb_serial_unique = <0>;
      	rndis_wceis = <1>;
      &ehci0 {
      &ohci0 {
      &usbc1 {
      	device_type = "usbc1";
      	usb_regulator_io = "nocare";
      &ehci1 {
      &ohci1 {
      &twi0 {
      	clock-frequency = <400000>;
      	pinctrl-0 = <&twi0_pins_a>;
      	pinctrl-1 = <&twi0_pins_b>;
      	eeprom@50 {
      		compatible = "atmel,24c16";
      		reg = <0x50>;
      &twi1 {
      	pinctrl-0 = <&twi1_pins_a>;
      	pinctrl-1 = <&twi1_pins_b>;
      &twi2 {
      	pinctrl-0 = <&twi2_pins_a>;
      	pinctrl-1 = <&twi2_pins_b>;
      	dmas = <&dma 45>, <&dma 45>;
      	dma-names = "tx", "rx";
      	/* pcf8574-usage:
      	 * pin set:
      	 * interrupt set:
      	pcf8574: gpio@38 {
      		compatible = "nxp,pcf8574";
      		reg = <0x38>;
      		gpio_base = <2020>;
      		gpio-controller;
      		#gpio-cells = <2>;
      		interrupt-controller;
      		#interrupt-cells = <2>;
      	ctp@14 {
      		device_type = "ctp";
      		reg = <0x14>;
      		ctp_name = "gt9xxnew_ts";
      		ctp_twi_id = <0x2>;
      		ctp_twi_addr = <0x14>;
      		ctp_screen_max_x = <0x320>;
      		ctp_screen_max_y = <0x500>;
      		ctp_revert_x_flag = <0x0>;
      		ctp_revert_y_flag = <0x1>;
      		ctp_int_port = <&pio PG 14 GPIO_ACTIVE_HIGH>;
      		ctp_wakeup = <&pio PG 15 GPIO_ACTIVE_HIGH>;
      &twi3 {
      	pinctrl-0 = <&twi3_pins_a>;
      	pinctrl-1 = <&twi3_pins_b>;
      &gmac0 {
      	phy-mode = "rmii";
      	use_ephy25m = <1>;
      	pinctrl-0 = <&gmac_pins_a>;
      	pinctrl-1 = <&gmac_pins_b>;
      	phy-rst = <&pio PE 16 GPIO_ACTIVE_HIGH>;
      	tx-delay = <3>; /*2~4*/
      	rx-delay = <0>;
      &spi0 {
      	pinctrl-1 = <&spi0_pins_c>;
      	spi_slave_mode = <0>;
      	spi0_cs_number = <1>;
              spi0_cs_bitmap = <1>;
      	spi-nand@0 {
      		compatible = "spi-nand";
      		spi-max-frequency=<0x5F5E100>;
      		reg = <0x0>;
      		spi-rx-bus-width=<0x04>;
      		spi-tx-bus-width=<0x04>;
      		status="disabled";
      &spi1 {
      	pinctrl-1 = <&spi1_pins_c>;
      	spi1_cs_number = <1>;
      	spi1_cs_bitmap = <1>;
      	spi_dbi_enable = <1>;
      	spi_board1@0 {
      		device_type = "spi-dbi";
      		compatible = "sunxi,spidbi";
      		reg = <0x0>;
      		spi-rx-bus-width = <0x4>;
      		spi-tx-bus-width = <0x4>;
      	/* spi_board1@0 {
      		device_type = "spi_board1";
      		compatible = "rohm,dh2228fv";
      		reg = <0x0>;
      &ledc {
      	pinctrl-0 = <&ledc_pins_a>;
      	pinctrl-1 = <&ledc_pins_b>;
      	led_count = <12>;
      	output_mode = "GRB";
      	reset_ns = <84>;
      	t1h_ns = <800>;
      	t1l_ns = <320>;
      	t0h_ns = <300>;
      	t0l_ns = <800>;
      	wait_time0_ns = <84>;
      	wait_time1_ns = <84>;
      	wait_data_time_ns = <600000>;
      	status	= "okay";
      &keyboard0 {
      	key0 = <210 0x160>;
      	wakeup-source;
      disp init configuration
      set fbX_height to lcd_x)
                         in display.
      &disp {
      	/*VCC-LCD*/
      	/*VCC-DSI*/
      	/*VCC-PD*/
      ;lcd0 configuration
      ;Pin setting for gpio:
      ;fsync setting, pulse to csi
      &lcd0 {
      	lcd_used            = <1>;
      	lcd_driver_name     = "tft08006";
      	lcd_backlight       = <100>;
      	lcd_if              = <4>;
      	lcd_x               = <800>;
      	lcd_y               = <1280>;
      	lcd_width           = <52>;
      	lcd_height          = <52>;
      	lcd_dclk_freq       = <70>;
      	lcd_pwm_used        = <1>;
      	lcd_pwm_ch          = <2>;
      	lcd_pwm_freq        = <1000>;
      	lcd_pwm_pol         = <0>;
      	lcd_pwm_max_limit   = <255>;
      	lcd_hbp             = <32>;
      	lcd_ht              = <868>;
      	lcd_hspw            = <4>;
      	lcd_vbp             = <12>;
      	lcd_vt              = <1311>;
      	lcd_vspw            = <4>;
      	lcd_dsi_if          = <0>;
      	lcd_dsi_lane        = <4>;
      	lcd_lvds_if         = <0>;
      	lcd_lvds_colordepth = <0>;
      	lcd_lvds_mode       = <0>;
      	lcd_frm             = <0>;
      	lcd_hv_clk_phase    = <0>;
      	lcd_hv_sync_polarity= <0>;
      	lcd_gamma_en        = <0>;
      	lcd_bright_curve_en = <0>;
      	lcd_cmap_en         = <0>;
      	lcd_fsync_en        = <0>;
      	lcd_fsync_act_time  = <1000>;
      	lcd_fsync_dis_time  = <1000>;
      	lcd_fsync_pol       = <0>;
      	deu_mode            = <0>;
      	lcdgamma4iep        = <22>;
      	smart_color         = <90>;
      &hdmi {
      	hdmi_used = <1>;
      	hdmi_power_cnt = <0>;
      	hdmi_cts_compatibility = <1>;
      	hdmi_hdcp_enable = <1>;
      	hdmi_hdcp22_enable = <0>;
      	hdmi_cec_support = <1>;
      	hdmi_cec_super_standby = <0>;
      	ddc_en_io_ctrl = <0>;
      	power_io_ctrl = <0>;
      &pwm0 {
      	pinctrl-0 = <&pwm0_pin_a>;
      	pinctrl-1 = <&pwm0_pin_b>;
      &pwm2 {
      	pinctrl-0 = <&pwm2_pin_a>;
      	pinctrl-1 = <&pwm2_pin_b>;
      &pwm7 {
      	pinctrl-0 = <&pwm7_pin_a>;
      	pinctrl-1 = <&pwm7_pin_b>;
      &rtp {
      	allwinner,ts-attached;
      &gpadc {
      	channel_num = <2>;
      	channel_select = <3>;
      	channel_data_select = <3>;
      	channel_compare_select = <3>;
      	channel_cld_select = <3>;
      	channel_chd_select = <3>;
      &s_cir0 {
      	pinctrl-0 = <&s_cir0_pins_a>;
      	pinctrl-1 = <&s_cir0_pins_b>;
      &ir1 {
      	pinctrl-0 = <&ir1_pins_a>;
      	pinctrl-1 = <&ir1_pins_b>;
      /* &lcd_fb0 {
      	lcd_used = <1>;
      	lcd_driver_name = "kld35512";
      	lcd_if = <1>;
      	lcd_dbi_if = <4>;
      	lcd_data_speed = <60>;
      	lcd_spi_bus_num = <1>;
      	lcd_x = <320>;
      	lcd_y = <480>;
      	lcd_pixel_fmt = <10>;
      	lcd_dbi_fmt = <2>;
      	lcd_rgb_order = <0>;
      	lcd_width = <60>;
      	lcd_height = <95>;
      	lcd_pwm_used = <1>;
      	lcd_pwm_ch = <7>;
      	lcd_pwm_freq = <5000>;
      	lcd_pwm_pol = <1>;
      	lcd_frm = <1>;
      	lcd_gamma_en = <1>;
      	fb_buffer_num = <2>;
      	lcd_fps = <40>;
      	lcd_dbi_te = <1>;
      	lcd_dbi_clk_mode = <1>;
      	lcd_gpio_0 = <&pio PC 0 GPIO_ACTIVE_HIGH>;
      /* &lcd_fb0 {
      	lcd_used = <1>;
      	lcd_driver_name = "kld2844b";
      	lcd_if = <1>;
      	lcd_dbi_if = <4>;
      	lcd_x = <240>;
      	lcd_y = <320>;
      	lcd_width = <60>;
      	lcd_height = <95>;
      	lcd_pwm_used = <1>;
      	lcd_pwm_ch = <7>;
      	lcd_pwm_pol = <0>;
      	lcd_pixel_fmt = <0>;
      	lcd_dbi_fmt = <3>;
      	lcd_frm = <1>;
      	lcd_gamma_en = <1>;
      	lcd_dbi_te = <1>;
      	lcd_fps = <60>;
      • K
        补充一下,扫卡是正常的,但是下载固件失败,以及参考了论坛里很多回答的解决方法,但是依旧没有解决
        L 2 条回复 最后回复 回复 引用 分享 0
          lgkgkfg LV 6 @konosiba 最后由 编辑
          @konosiba 一样的毛病,连日志都一样...
          K 1 条回复 最后回复 回复 引用 分享 0
            @konosiba 你的文件系统有问题吗,我的暂时只能读,不知道是不是这个引起的
            • K
              konosiba LV 4 @lgkgkfg 最后由 编辑
              @lgkgkfg 文件系统不正常的话参考这个
              https://bbs.aw-ol.com/topic/1701/tina-linux-存储介质切换-emmc-spi-nand-spi-nor-sd-card-sd-nand?_=1665631296189
                lgkgkfg LV 6 最后由 编辑
                @konosiba 我的问题找到了,SDK的内核固件默认编译40M晶振固件,而我实际晶振24M,得把内核40M支持换成24M就可以了
                • tigger
                  tigger LV 7 最后由 编辑
                  @lgkgkfg
                  请问具体怎么换呢?
                  whycan L 2 条回复 最后回复 回复 引用 分享 0
                    lgkgkfg LV 6 @tigger 最后由 lgkgkfg 编辑
                    @tigger
                    依次,
                    `make menuconfig--> > Kernel modules > Wireless Drivers,
                    勾选 <*> kmod-net-xr829................................... xr829 support (staging),
                    取消勾选
                    < > kmod-net-xr829-40M............................... xr829 support (staging),
                    进入
                    > Firmware,
                    取消勾选
                     [ ] xr829 with 40M sdd,
                    ,这个必须,make,完活。
                      whycan晕哥 LV 9 @tigger 最后由 编辑
                      @tigger
                      • K
                        konosiba LV 4 @whycan 最后由 编辑
                        @whycan 晕哥你看看我镇楼图这是啥问题,我试了改成24m的和40m的,都不行,错误代码也不是not responding,而是timeout waiting for fifo
                        • K
                          @lgkgkfg 你确定你和我的报错一样?看底下发的24m和40m搞错了的报错信息,貌似不一样啊。我也试过改24m,还是一样的报错
                            @konosiba 确实一样,你试试我那个方法吧,不光得改firmware,还得改Wireless Drivers,这俩都改才行,单改一个没用
                            • K
                              @lgkgkfg 好家伙,确实解决了,我之前只改了wireless driver里的选项,没改firmware
                                cdzlll LV 3 @konosiba 最后由 编辑
                                @konosiba 你好 请教一下 wireless driver里要怎样改成24Mhz
