    求助,D1s开启热点失败
      siguadao LV 4 最后由 siguadao 编辑
      WIFI芯片为RTL8723DS芯片,系统启动后lsmod查看已加载ko。
      使用softap_up开启热点报如下错误:
      root@TinaLinux:~# softap_up yscrs 1234567890
      Start hostapd test!
      wpa2-psk!
      Start to set softap!
      Message is: OK
      Set softap finished!
      killall: wpa_supplicant: no process killed
      Start to start softap!
      SoftAP started successfullyHaving catch sig_chld!
      Message is: OK
      Start softap finished!
      iptables v1.4.21: Couldn't load target `MASQUERADE':No such file or directory
      Try `iptables -h' or 'iptables --help' for more information.
      enable data forward failed!
      论坛中搜索相关帖子,按照帖子https://bbs.aw-ol.com/topic/1963/d1-h%E5%90%AF%E5%8A%A8softap_up%E5%A4%B1%E8%B4%A5中大神所说,在kernel_menuconfig中将有关MASQUERADE的所有选项都选上了,仍然不行。kernel_menuconfig相应选项如下:
      Symbol: IP6_NF_TARGET_MASQUERADE [=y]
      Type  : tristate
      Prompt: MASQUERADE target support
          -> Networking support (NET [=y])
            -> Networking options
              -> Network packet filtering framework (Netfilter) (NETFILTER [=y])
                -> IPv6: Netfilter Configuration
                  -> IP6 tables support (required for filtering) (IP6_NF_IPTABLES [=y])
      (1)           -> ip6tables NAT support (IP6_NF_NAT [=y])
        Defined at net/ipv6/netfilter/Kconfig:272
        Depends on: NET [=y] && INET [=y] && IPV6 [=y] && NETFILTER [=y] && IP6_NF_IPTABLES [=y] && IP6_NF_NAT [=y]
        Selects: NETFILTER_XT_TARGET_MASQUERADE [=y]
      Symbol: IP_NF_TARGET_MASQUERADE [=y]
      Type  : tristate
                -> IP: Netfilter Configuration
                  -> IP tables support (required for filtering/masq/NAT) (IP_NF_IPTABLES [=y])
      (2)           -> iptables NAT support (IP_NF_NAT [=y])
        Defined at net/ipv4/netfilter/Kconfig:226
        Depends on: NET [=y] && INET [=y] && NETFILTER [=y] && IP_NF_IPTABLES [=y] && IP_NF_NAT [=y]
      Symbol: NETFILTER_XT_TARGET_MASQUERADE [=y]
      Type  : tristate
                -> Core Netfilter Configuration
      (3)         -> Netfilter Xtables support (required for ip_tables) (NETFILTER_XTABLES [=y])
        Defined at net/netfilter/Kconfig:1010
        Depends on: NET [=y] && INET [=y] && NETFILTER [=y] && NETFILTER_XTABLES [=y] && NF_NAT [=y]
        Selects: NF_NAT_MASQUERADE [=y]
        Selected by [y]:
        - IP_NF_TARGET_MASQUERADE [=y] && NET [=y] && INET [=y] && NETFILTER [=y] && IP_NF_IPTABLES [=y] && IP_NF_NAT [=y]
        - IP6_NF_TARGET_MASQUERADE [=y] && NET [=y] && INET [=y] && IPV6 [=y] && NETFILTER [=y] && IP6_NF_IPTABLES [=y] && IP6_NF_NAT [=y]
      Symbol: NF_NAT_MASQUERADE [=y]
      Type  : bool
        Defined at net/netfilter/Kconfig:434
        Depends on: NET [=y] && INET [=y] && NETFILTER [=y] && NF_CONNTRACK [=y]
        Selected by [y]:
        - NFT_MASQ [=y] && NET [=y] && INET [=y] && NETFILTER [=y] && NF_TABLES [=y] && NF_CONNTRACK [=y] && NF_NAT [=y]
        - NETFILTER_XT_TARGET_MASQUERADE [=y] && NET [=y] && INET [=y] && NETFILTER [=y] && NETFILTER_XTABLES [=y] && NF_NAT [=y]
      看提示应该和iptables有关,又把iptables相关选项全选上,仍然不行。如下:
      Symbol: IP6_NF_IPTABLES [=y]
      Type  : tristate
      Prompt: IP6 tables support (required for filtering)
      (1)       -> IPv6: Netfilter Configuration
        Defined at net/ipv6/netfilter/Kconfig:74
        Depends on: NET [=y] && NETFILTER [=y] && INET [=y] && IPV6 [=y]
        Selects: NETFILTER_XTABLES [=y]
        Selected by [y]:
        - IP_VS_IPV6 [=y] && NET [=y] && NETFILTER [=y] && IP_VS [=y] && (IPV6 [=y]=y || IP_VS [=y]=IPV6 [=y])
      Symbol: IP_NF_IPTABLES [=y]
      Type  : tristate
      Prompt: IP tables support (required for filtering/masq/NAT)
      (2)       -> IP: Netfilter Configuration
        Defined at net/ipv4/netfilter/Kconfig:121
      求助各位,不知道还需要怎么设置?
        arthasarthas LV 2 @siguadao 最后由 编辑
        @siguadao 请问下,楼主最终成功了吗
