    SD卡启动,如何挂载剩余容量为overlayfs
    14
    9918
    • allwinner_account
      allwinner_account LV 5 最后由 编辑
      小白根据教程编译的标准tina镜像,烧录SD卡启动,使用opkg安装应用时报只读错误.😰
      翻阅论坛帖子和相关资料后了解到需要配置overlayfs才可以写入,尝试配置后依然无法工作,想问问各位大佬还有哪里需要修改?😵
      下面是我已经做的修改
      修改.\device\config\chips\d1-h\configs\nezha\sys_partition.fex文件
      [partition]
          name         = rootfs_data
          size         = 8388608
          downloadfile = "/home/ubt/tina-d1-h/fex/rootfs_data.fex"
          user_type    = 0x8000
      使用./out/host/bin/make_ext4fs创建文件系统,这里的null为空目录
      home/ubt/tina-d1-h/out/d1-h-nezha/image/rootfs_data.fex /home/ubt/tina-d1-h/null
      Creating filesystem with parameters:
          Block size: 1024
          Blocks per group: 8192
          Inodes per group: 2048
          Inode size: 256
          Journal blocks: 1024
          Label:
          Blocks: 8192
          Block groups: 1
          Reserved blocks: 0
          Reserved block group size: 31
      Created filesystem with 11/2048 inodes and 1575/8192 blocks
      烧录运行后查看挂载情况,还是没有overlayfs挂载
      root@TinaLinux:/# df -kh
      /dev/root                15.8M     15.8M         0 100% /
      devtmpfs                492.8M         0    492.8M   0% /dev
      tmpfs                   498.9M     32.0K    498.9M   0% /tmp
      /dev/mmcblk0p1            8.0M     66.0K      7.9M   1% /mnt/SDCARD
      root@TinaLinux:/# mount
      /dev/root on / type squashfs (ro,noatime)
      devtmpfs on /dev type devtmpfs (rw,relatime,size=504672k,nr_inodes=126168,mode=7
      proc on /proc type proc (rw,nosuid,nodev,noexec,noatime)
      sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,noatime)
      tmpfs on /tmp type tmpfs (rw,nosuid,nodev,noatime)
      devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,mode=600,ptmxmode=000)
      debugfs on /sys/kernel/debug type debugfs (rw,noatime)
      /dev/mmcblk0p1 on /mnt/SDCARD type vfat (rw,relatime,fmask=0000,dmask=0000,allowhortname=mixed,errors=remount-ro)
      fstab文件
      config 'mount'
              option  target          '/boot'
              option  device          '/dev/by-name/boot'
              option  options         'ro,sync'
              option  enabled         '1'
      config 'mount'
              option  target          '/boot-res'
              option  device          '/dev/by-name/boot-res'
              option  enabled         '1'
      config 'mount'
              option  target          '/mnt/UDISK'
              option  device          '/dev/by-name/UDISK'
              option  options         'rw,async'
              option  enabled         '0'
      config 'mount'
              option  target          '/overlay'
              option  enabled         '1'
      config 'mount'
              option  target          '/mnt/SDCARD'
              option  device          '/dev/mmcblk0'
              option  enabled         '1'
      config 'mount'
              option  device          '/dev/mmcblk0p1'
              option  enabled         '1'
      config 'mount'
              option  target          '/mnt/exUDISK'
              option  device          '/dev/sda'
              option  enabled         '1'
      config 'mount'
              option  device          '/dev/sda1'
              option  enabled         '1'
        yixiuge LV 5 最后由 编辑
        root@TinaLinux:/#
        Filesystem           1K-blocks      Used Available Use% Mounted on
        /dev/root                17152     17152         0 100% /rom
        devtmpfs                 26312         0     26312   0% /dev
        tmpfs                    28412        32     28380   0% /tmp
        tmpfs                    28412        20     28392   0% /tmp/root
        overlayfs:/tmp/root      28412        20     28392   0% /
        root@TinaLinux:/#
        root@TinaLinux:/#
        /dev/root on /rom type squashfs (ro,relatime)
        devtmpfs on /dev type devtmpfs (rw,relatime,size=26312k,nr_inodes=6578,mode=755)
        tmpfs on /tmp/root type tmpfs (rw,noatime,mode=755)
        overlayfs:/tmp/root on / type overlay (rw,noatime,lowerdir=/,upperdir=/tmp/root/upper,workdir=/tmp/root/work)
        root@TinaLinux:/#
        root@TinaLinux:/#
        root@TinaLinux:/#
        root@TinaLinux:/# ls /tmp/root/
        upper  work
        root@TinaLinux:/#
        root@TinaLinux:/#
        看下我的
        allwinner_account 1 条回复 最后回复 回复 引用 分享 0
        • allwinner_account
          allwinner_account LV 5 @yixiuge 最后由 编辑
          @yixiuge 请问是不是fstab文件还需要什么更改啊
          • allwinner_account
            补充一下,改完sys_partition.fex之后我执行了mboot和pack指令,起初我把make_ext4fs生成的文件放在out目录下,打包时似乎会直接被顶掉找不到,所以我后面放在外面了
            • allwinner_account
              又翻了遍手册,怎么感觉按默认配置什么都不改UDISK会自动分配剩余大小然后挂载到overlayfs的,但实际上不行?
              config 'mount'
              	option	enabled		'1'
              是否是overlayfs还需要什么配置才能启用?但是在defconfig文件内也没有找到
              • allwinner_account
                尝试更改了多次fstab和sys_partition文件都没什么用,注意到开机时有报错
                formating /dev/by-name/UDISK to ext4
                /etc/preinit: line 1: mkfs.ext4: not found
                formating /dev/by-name/rootfs_data to ext4
                是因为没有成功创建ext4文件系统导致的?
                  whycan晕哥 LV 9 @allwinner_account 最后由 编辑
                  @allwinner_account
                  修改 target/allwinner/d1-h-nezha/defconfig (注意路径)
                  打开:
                  CONFIG_PACKAGE_e2fsprogs=y
                  • allwinner_account
                    allwinner_account LV 5 @whycan 最后由 编辑
                    @whycan 在 SD卡启动,如何挂载剩余容量为overlayfs 中说:
                    e2fsprogs
                    感谢大佬回复,还是不行😢
                    这是我现在运行的一些信息
                    /dev/root                16.0M     16.0M         0 100% /
                    devtmpfs on /dev type devtmpfs (rw,relatime,size=504672k,nr_inodes=126168,mode=755)
                    root@TinaLinux:/# cd dev/
                    root@TinaLinux:/dev# ls
                    mmcblk0          mmcblk0p1        mmcblk0p2        mmcblk0p3        mmcblk0p4        mmcblk0p5        mmcblk0p6        mmcblk0p7        mmcblk0p8        mmcblk0p9  ...
                    root@TinaLinux:/dev# cd by-name/
                    root@TinaLinux:/dev/by-name# ls
                    UDISK          boot-resource  env            recovery       rootfs_data
                    boot           dsp0           env-redund     rootfs
                    我用的tf卡是一张16g的,被分成了9个分区,根据手册描述默认是加载第一个分区,和之前的运行情况一致.
                    当前fstab文件的配置
                    config 'mount'
                            option  enabled         '0'
                    config 'mount'
                            option  enabled         '1'
                    config 'mount'
                      option  device    '/dev/by-name/rootfs_data'
                      option  options   'rw,sync'
                      option  enabled   '1'
                    config 'mount'
                            option  enabled         '1'
                    config 'mount'
                            option  enabled         '0'
                    有个小疑问,这里都是将by-name目录下的udisk或者rootfs_data挂载到某一个分区,这个所谓的udisk/rootfs_data是怎么和实际设备mmcblk0联系起来的呢?
                    然后我也尝试了手动挂载,报错都是一样
                    mount rootfs_data /overlay/
                    NTFS signature is missing.
                    Failed to mount '/dev/mmcblk0p8': Invalid argument
                    The device '/dev/mmcblk0p8' doesn't seem to have a valid NTFS.
                    无效的NTFS系统?是否和sd卡文件系统的格式有关?我是直接phoenixCard刷的
                    太多疑问了,搞不明白😵 😵 😵
                      @allwinner_account
                      mkfs.ext4 可以执行吗?
                      • allwinner_account
                        @whycan 不可以执行,提示找不到
                          @allwinner_account
                          贴日志看看。
                          • allwinner_account
                            @whycan 可以了!!!😳
                            /dev/root                16.3M     16.3M         0 100% /rom
                                                    891.0K     49.0K    802.0K   6% /overlay
                            overlayfs:/overlay      891.0K     49.0K    802.0K   6% /
                            /dev/by-name/UDISK       13.1G     24.0K     13.1G   0% /mnt/UDISK
                            /dev/root on /rom type squashfs (ro,noatime)
                            /dev/by-name/rootfs_data on /overlay type ext4 (rw,relatime)
                            overlayfs:/overlay on / type overlay (rw,noatime,lowerdir=/,upperdir=/overlay/upper,workdir=/overlay/work)
                            /dev/by-name/UDISK on /mnt/UDISK type ext4 (rw,relatime)
                            刚才终于搞明白了fstab和sys_oartition.fex的对应关系重新配置了一下就可以了,现在是这么设置的
                            config 'mount'
                            	option	enabled		'1'
                            config 'mount'
                            	option	enabled		'1'
                            [partition]
                                name         = rootfs_data
                                size         = 2097152
                                downloadfile = "/home/ubt/tina-d1-h/fex/2Gb.fex"
                                user_type    = 0x8000
                            [partition]
                                name = UDISK
                                user_type = 0x8000
                            就是rootfs_data我设置的是2G,不知道为啥它变成891k了
                            这个2Gb.fex我是用这个rootfs_data.fex生成的
                            • allwinner_account
                              试了下不配置downloadfile也是可行的,初始化时可以根据大小自动格式化系统
                              mke2fs 1.46.4 (18-Aug-2021)
                              [    4.827559] random: mkfs.ext4: uninitialized urandom read (16 bytes read)
                              [    4.835361] random: mkfs.ext4: uninitialized urandom read (16 bytes read)
                              Creating filesystem with 3516935 4k blocks and 879552 inodes
                              Filesystem UUID: 84f444b8-02d2-4035-b7b1-ec4f15a8f417
                              Superblock backups stored on blocks:
                                      32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208
                              Allocating group tables: done
                              Writing inode tables: done
                              Creating journal (16384 blocks): [    6.281300]
                              [    6.281300] insmod_device_driver
                              [    6.281300]
                              [    6.288462] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
                              [    6.321295] hdmi_hpd_sys_config_release
                              done
                              Writing superblocks and filesystem accounting information: done
                              [   17.598480] random: mkfs.ext4: uninitialized urandom read (16 bytes read)
                              [   17.606271] random: mkfs.ext4: uninitialized urandom read (16 bytes read)
                              Creating filesystem with 262144 4k blocks and 65536 inodes
                              Filesystem UUID: 56bbb4d6-0db1-47ec-a35c-f66492e4fdad
                              Creating journal (8192 blocks): done
                              就是大小还不太对,我再研究下🤤
                              总之还是感谢大佬帮助🤠
                              L 1 条回复 最后回复 回复 引用 分享 2
                                linkeb LV 1 @allwinner_account 最后由 编辑
                                @allwinner_account 我也遇到这个问题,修改partion的rootfs_data size,最后pack出来的overlay还是不变,请问你后来找到原因了吗?
