    v853开发板遇到了Kernerl panic:rootfs不能挂载,进入crash dump的问题
      carpediem LV 4 最后由 编辑
      在使用NPU Demo中的YOLOV3模型,进行Tina Linux SDK的编译,make之后并pack,遇到了rootfs.fex文件过大,分区容量设置过小的问题
      mbr size = 4096
      mbr magic softw411
      disk name=boot-resource
      disk name=env
      disk name=boot
      disk name=rootfs
      ERROR: dl file rootfs.fex size too large
      ERROR: filename = rootfs.fex
      ERROR: dl_file_size = 119040 sector
      ERROR: part_size = 45360 sector
      update_for_part_info -1
      ERROR: update mbr file fail
      ERROR: update_mbr failed
      根据官方文档,修改了device/config/chips/v853/configs/vision/linux-4.9/sys_partition.fex文件中rootf.fex的大小
      [partition]
          name         = rootfs
          size         = 119040
          downloadfile = "rootfs.fex"
          user_type    = 0x8000
      之后进行make,pack之后,将img烧录在sd卡上,并插入v853开发板,启动,遇到了rootfs不能挂载,进入crash dump的问题,以下是完整的串口输出的log,请问大家有没有解决方法
      [143]HELLO! BOOT0 is starting!
      [146]BOOT0 commit : 2a3ec52022
      [149]set pll start
      [151]periph0 has been enabled
      [154]set pll end
      [157]PMU: AXP21
      [159]board init ok
      [161]rtc[0] value = 0x80000001
      [164]DRAM use external ZQ!!
      [167]chip id check OK
      [169]DRAM_VCC set to 1500 mv
      [172]trefi:7.8ms
      [175][AUTO DEBUG] single rank and full DQ!
      [179]trefi:7.8ms
      [181][AUTO DEBUG] rank 0 row = 15
      [185][AUTO DEBUG] rank 0 bank = 8
      [188][AUTO DEBUG] rank 0 page size = 2 KB
      [192]DRAM BOOT DRIVE INFO: V0.16
      [195]DRAM CLK = 936 MHz
      [197]DRAM Type = 3 (2:DDR2,3:DDR3)
      [201]DRAMC ZQ value: 0x7b7bfb
      [203]DRAM ODT value: 0x42.
      [207]DRAM SIZE =512 M
      [209]dram_tpr4:0x0
      [216]DRAM simple test OK.
      [219]rtc standby flag is 0x0, super standby flag is 0x0
      [224]dram size =512
      [227]audio:avcc calibration
      [229]card no is 0
      [231]sdcard 0 line count 4
      [233][mmc]: mmc driver ver 2021-12-27 10:07
      [243][mmc]: Wrong media type 0x0
      [246][mmc]: ***Try SD card 0***
      [265][mmc]: HSSDR52/SDR25 4 bit
      [268][mmc]: 50000000 Hz
      [270][mmc]: 15193 MB
      [272][mmc]: ***SD/MMC 0 init OK!!!***
      [349]Loading boot-pkg Succeed(index=0).
      [353]Entry_name        = optee
      [356]Entry_name        = u-boot
      [363]Entry_name        = dtb
      [366]mmc not para
      [368]Jump to second Boot.
      U-Boot 2018.05-g3a34d5f (Jul 08 2022 - 07:00:11 +0000) Allwinner Technology
      [00.539]CPU:   Allwinner Family
      [00.542]Model: sun8iw21
      I2C:   ready
      [00.568]DRAM:  512 MiB
      [00.571]Relocation Offset is: 1ced0000
      [00.595]secure enable bit: 0
      [00.610]PMU: AXP21
      [00.612]BMU: AXP21
      FDT ERROR:fdt_get_regulator_name:get property handle twi-supply error:FDT_ERR_INTERNAL
      bias_name:pc_bias        bias_vol:1800
      bias_name:pi_bias        bias_vol:1800
      [00.636]CPU=900 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=24Mhz  MBus=300Mhz
      [00.642]gic: sec monitor mode
      sunxi flash map init
      [00.646]flash init start
      [00.649]workmode = 0,storage type = 1
      [00.652][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
      [00.657][mmc]: get sdc_type fail and use default host:tm1.
      [00.664][mmc]: can't find node "mmc0",will add new node
      [00.669][mmc]: fdt err returned <no error>
      [00.672][mmc]: Using default timing para
      [00.676][mmc]: SUNXI SDMMC Controller Version:0x50400
      [00.702][mmc]: card_caps:0x3000000a
      [00.705][mmc]: host_caps:0x3000003f
      [00.710]sunxi flash init ok
      [00.713]line:724 init_clocks
      [00.716]drv_disp_init
      request pwm success, pwm9:pwm9:0x2000c00.
      [00.730]drv_disp_init finish
      GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645
      part_get_info_efi: ***        Using Backup GPT ***
      [00.876]Loading Environment from SUNXI_FLASH... OK
      [00.897]boot_gui_init:start
      [00.899]set disp.dev2_output_type fail. using defval=0
      [00.904][ICN6202 TO LVDS] LINE:0146-->lcd_open_flow:
      [00.909][ICN6202 TO LVDS] LINE:0167-->lcd_power_on:
      [00.927]boot_gui_init:finish
      part_get_info_efi: *** E[00.940][ICN6202 TO LVDS] LINE:0575-->lcd_panel_init:
      [01.106][ICN6202 TO LVDS] LINE:0620-->lcd_panel_init:initialization:icn6202 init reg from mipi
      [01.133]bmp_name=bootlogo.bmp size 38454
      38454 bytes read in 3 ms (12.2 MiB/s)
      [01.161]Item0 (Map) magic is bad
      [01.163]the secure storage item0 copy0 magic is bad
      [01.183]Item0 (Map) magic is bad
      [01.185]the secure storage item0 copy1 magic is bad
      [01.190]Item0 (Map) magic is bad
      [01.193]out of usb burn from boot: not need burn key
      root_partition is rootfs
      set root to /dev/mmcblk0p4
      [01.222]update part info
      par[01.239][ICN6202 TO LVDS] LINE:0203-->lcd_bl_open:
      [01.245]LCD open finish
      [01.251]update bootcmd
      [01.273]change working_fdt 0x5de8fe70 to 0x5de6fe70
      [01.288]The storage not support sample function
      [01.294]## error: update_fdt_dram_para : FDT_ERR_NOTFOUND
      [01.304]update dts
      [02.675]no vendor_boot partition is found
      [02.724]Starting kernel ...
      [02.726][mmc]: MMC Device 2 not found
      [02.730][mmc]: mmc 2 not find, so not exit
      Uncompressing Linux...0229.332ms done, booting the kernel.
      [    0.000000] Linux version 4.9.191 (allwinner@allwinner-VirtualBox) (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05) ) #1 PREEMPT Thu Oct 13 16:16:36 CST 2022
      [    0.000000] OF: fdt:Machine model: sun8iw21
      [    0.000000] bootconsole [earlycon0] enabled
      [    0.000000] ion_mem_reserve: err format for ion reserve list!
      [    0.000000] disp reserve base 0x5df1a000 ,size 0x3e8000
      [    0.000000] Reserved memory: created DMA memory pool at 0x47000000, size 0 MiB
      [    0.000000] OF: reserved mem: initialized node vdev0buffer@47000000, compatible id shared-dma-pool
      [    0.000000] Memory policy: Data cache writeback
      [    0.000000] On node 0 totalpages: 129920
      [    0.000000] free_area_init_node: node 0, pgdat c0b5d394, node_mem_map dfbf8000
      [    0.000000]   Normal zone: 1024 pages used for memmap
      [    0.000000]   Normal zone: 129920 pages, LIFO batch:31
      [    0.000000] CPU: All CPU(s) started in SVC mode.
      [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 128896
      [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p4 rootwait init=/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:boot@mmcblk0p3:rootfs@mmcblk0p4:rootfs_data@mmcblk0p5:recovery@mmcblk0p6:UDISK@mmcblk0p7 cma= mac_addr= wifi_mac= bt_mac= selinux= specialstr= coherent_pool=32K ion_carveout_list= androidboot.mode=normal androidboot.hardware=sun8iw21p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05-g3a34d5f(07/08/2022-07:00:11) mbr_offset=1032192 disp_reserve=4096000,0x5df1a000 bootreason=unknow androidboot.dramsize=512
      [    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
      [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
      [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
      [    0.000000] Memory: 498688K/519680K available (6144K kernel code, 377K rwdata, 2268K rodata, 1024K init, 182K bss, 20992K reserved, 0K cma-reserved, 0K highmem)
      [    0.000000]     vmalloc : 0xe0800000 - 0xff800000   ( 496 MB)
      [    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
      [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      [    0.000000]       .text : 0xc0008000 - 0xc0700000   (7136 kB)
      [    0.000000]       .init : 0xc0a00000 - 0xc0b00000   (1024 kB)
      [    0.000000]       .data : 0xc0b00000 - 0xc0b5e490   ( 378 kB)
      [    0.000000]        .bss : 0xc0b5e490 - 0xc0b8bd28   ( 183 kB)
      [    0.008121] Switching to timer-based delay loop, resolution 41ns
      [    0.014455] Console: colour dummy device 80x30
      [    0.019043] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.029528] pid_max: default: 32768 minimum: 301
      [    0.034435] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
      [    0.041176] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
      [    0.048844] CPU: Testing write buffer coherency: ok
      [    0.054385] Setting up static identity map for 0x40100000 - 0x40100058
      [    0.062526] devtmpfs: initialized
      [    0.100611] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [    0.108916] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.119079] futex hash table entries: 256 (order: -1, 3072 bytes)
      [    0.125440] atomic64_test: passed
      [    0.128923] pinctrl core: initialized pinctrl subsystem
      [    0.135744] NET: Registered protocol family 16
      [    0.141291] DMA: preallocated 32 KiB pool for atomic coherent allocations
      [    0.149947] dump_class_init,857, success
      [    0.184188] cpuidle: using governor menu
      [    0.189393] platform 2010000.iommu: iova_base: 0x48400000
      [    0.195677] sunxi iommu: irq = 22
      [    0.218576] sun8iw21p1-pinctrl pio: initialized sunXi PIO driver
      [    0.226604] sunxi hwspinlock vbase:0xe0824000
      [    0.232961] iommu: Adding device npu to group 0
      [    0.239027] iommu: Adding device 1c0e000.ve to group 0
      [    0.257631] iommu: Adding device 5410000.g2d to group 0
      [    0.264100] iommu: Adding device 5000000.disp to group 0
      [    0.279557] iommu: Adding device 5908000.tdm to group 0
      [    0.285957] iommu: Adding device 5900000.isp to group 0
      [    0.292088] iommu: Adding device 58ffffc.isp to group 0
      [    0.298294] iommu: Adding device 58ffff8.isp to group 0
      [    0.304424] iommu: Adding device 58ffff4.isp to group 0
      [    0.310324] iommu: Adding device 5800800.vind:isp@4 to group 0
      [    0.317057] iommu: Adding device 5910000.scaler to group 0
      [    0.323226] iommu: Adding device 590fffc.scaler to group 0
      [    0.329364] iommu: Adding device 590fff8.scaler to group 0
      [    0.335507] iommu: Adding device 590fff4.scaler to group 0
      [    0.341888] iommu: Adding device 5910400.scaler to group 0
      [    0.348046] iommu: Adding device 59103fc.scaler to group 0
      [    0.354188] iommu: Adding device 59103f8.scaler to group 0
      [    0.360336] iommu: Adding device 59103f4.scaler to group 0
      [    0.366704] iommu: Adding device 5910800.scaler to group 0
      [    0.372878] iommu: Adding device 59107fc.scaler to group 0
      [    0.379027] iommu: Adding device 59107f8.scaler to group 0
      [    0.385170] iommu: Adding device 59107f4.scaler to group 0
      [    0.391574] iommu: Adding device 5910c00.scaler to group 0
      [    0.397702] iommu: Adding device 5910bfc.scaler to group 0
      [    0.403863] iommu: Adding device 5910bf8.scaler to group 0
      [    0.410013] iommu: Adding device 5910bf4.scaler to group 0
      [    0.416972] iommu: Adding device vinc0 to group 0
      [    0.422736] iommu: Adding device vinc4 to group 0
      [    0.428362] iommu: Adding device vinc8 to group 0
      [    0.433977] iommu: Adding device vinc12 to group 0
      [    0.445231] iommu: Adding device e907_rproc@0 to group 0
      [    0.451001] iommu: Adding device rpbuf_controller@0 to group 0
      [    0.494713] pwm module init!
      [    0.505351] sunxi-pm debug v3.10
      [    0.511827] SCSI subsystem initialized
      [    0.516919] usbcore: registered new interface driver usbfs
      [    0.523216] usbcore: registered new interface driver hub
      [    0.528869] usbcore: registered new device driver usb
      [    0.534679] sunxi_i2c_adap_init()2754 - init
      [    0.539554] sunxi_i2c_probe()2449 - [i2c0] twi_drv_used = 0
      [    0.545613] sunxi_i2c_probe()2456 - [i2c0] twi_pkt_interval = 0
      [    0.551725] twi_regulator_request()653 - [i2c0] regulator not found(isn't configured in dts)!
      [    0.560437] twi_request_gpio()469 - [i2c0] init name: (null)
      [    0.567090] sunxi_i2c_probe()2449 - [i2c1] twi_drv_used = 0
      [    0.573034] sunxi_i2c_probe()2456 - [i2c1] twi_pkt_interval = 0
      [    0.579136] twi_regulator_request()653 - [i2c1] regulator not found(isn't configured in dts)!
      [    0.587871] twi_request_gpio()469 - [i2c1] init name: (null)
      [    0.594504] sunxi_i2c_probe()2449 - [i2c2] twi_drv_used = 0
      [    0.600390] sunxi_i2c_probe()2456 - [i2c2] twi_pkt_interval = 0
      [    0.606492] twi_regulator_request()653 - [i2c2] regulator not found(isn't configured in dts)!
      [    0.615195] twi_request_gpio()469 - [i2c2] init name: (null)
      [    0.622272] sunxi_i2c_probe()2449 - [i2c3] twi_drv_used = 0
      [    0.628211] sunxi_i2c_probe()2456 - [i2c3] twi_pkt_interval = 0
      [    0.634341] twi_regulator_request()653 - [i2c3] regulator not found(isn't configured in dts)!
      [    0.643040] twi_request_gpio()469 - [i2c3] init name: (null)
      [    0.650025] sunxi_i2c_probe()2449 - [i2c4] twi_drv_used = 0
      [    0.655927] sunxi_i2c_probe()2456 - [i2c4] twi_pkt_interval = 0
      [    0.662042] twi_regulator_request()653 - [i2c4] regulator not found(isn't configured in dts)!
      [    0.670789] twi_request_gpio()469 - [i2c4] init name: (null)
      [    0.677493] axp20x-i2c 4-0034: AXP20x variant AXP2101 found
      [    0.699740] random: fast init done
      [    0.716250] axp20x-i2c 4-0034: AXP20X driver loaded
      [    0.722679] media: Linux media interface: v0.10
      [    0.727687] Linux video capture interface: v2.00
      [    0.734740] ion_parse_dt_heap_common: id 0 type 0 name sys_user align 1000
      [    0.742622] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
      [    0.750157] Advanced Linux Sound Architecture Driver Initialized.
      [    0.757619] Bluetooth: Core ver 2.22
      [    0.761697] NET: Registered protocol family 31
      [    0.766252] Bluetooth: HCI device and connection manager initialized
      [    0.772890] Bluetooth: HCI socket layer initialized
      [    0.777901] Bluetooth: L2CAP socket layer initialized
      [    0.783219] Bluetooth: SCO socket layer initialized
      [    0.790514] G2D: rcq version initialized.major:251
      [    0.797330] clocksource: Switched to clocksource arch_sys_counter
      [    0.831378] udc_init,0
      [    0.835114] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
      [    0.844079] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
      [    0.852703] NET: Registered protocol family 2
      [    0.887484] TCP established hash table entries: 16 (order: -6, 64 bytes)
      [    0.894270] TCP bind hash table entries: 16 (order: -6, 64 bytes)
      [    0.900490] TCP: Hash tables configured (established 16 bind 16)
      [    0.906641] UDP hash table entries: 256 (order: 0, 4096 bytes)
      [    0.912603] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
      [    0.919200] NET: Registered protocol family 1
      [    0.927452] workingset: timestamp_bits=29 max_order=17 bucket_order=0
      [    0.950619] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [    0.961398] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
      [    0.969432] io scheduler noop registered
      [    0.973449] io scheduler deadline registered
      [    0.978354] io scheduler cfq registered (default)
      [    0.984862] [DISP]disp_module_init
      [    0.990006] [DISP] disp_init,line:2340:
      [    0.993679] smooth display screen:0 type:1 mode:4
      [    1.034861] lcd 0, driver_name icn6202,  panel_name default_lcd
      [    1.040991] lcd 0, driver_name icn6202,  panel_name he0801a068
      [    1.046921] lcd 0, driver_name icn6202,  panel_name inet_dsi_panel
      [    1.053217] lcd 0, driver_name icn6202,  panel_name lq101r1sx03
      [    1.059243] lcd 0, driver_name icn6202,  panel_name WilliamLcd
      [    1.065179] lcd 0, driver_name icn6202,  panel_name bp101wx1
      [    1.070952] lcd 0, driver_name icn6202,  panel_name k101im2qa04
      [    1.076966] lcd 0, driver_name icn6202,  panel_name t050k589
      [    1.082748] lcd 0, driver_name icn6202,  panel_name kd080d24
      [    1.088520] lcd 0, driver_name icn6202,  panel_name icn6202
      [    1.094181] lcd 0, driver_name icn6202,  panel_name super_lcd_driver
      [    1.100761] display_fb_request,fb_id:0
      [    1.114891] [DISP] de_fcm_set_para,line:491:
      [    1.119055] fcm lut 0 not find, auto retry after init
      [    1.125690] [DISP]disp_module_init finish
      [    1.130057] [DISP] de_fcm_set_para,line:491:
      [    1.130057] fcm lut 0 not find, auto retry after init
      [    1.130076] [DISP] de_fcm_set_para,line:491:
      [    1.130076] fcm lut 0 not find, auto retry after init
      [    1.130152] [DISP] lcd_clk_config,line:702:
      [    1.130153] disp 0, clk: pll(426000000),clk(426000000),dclk(71000000) dsi_rate(71000000)
      [    1.130153]      clk real:pll(420000000),clk(420000000),dclk(105000000) dsi_rate(150000000)
      [    1.177435] Freeing logo buffer memory: 4000K
      [    1.184261] uart0: ttyS0 at MMIO 0x2500000 (irq = 289, base_baud = 1500000) is a SUNXI
      [    1.192507] sw_console_setup()2050 - console setup baud 115200 parity n bits 8, flow n
      [    1.200722] console [ttyS0] enabled
      [    1.208275] bootconsole [earlycon0] disabled
      [    1.218929] uart3: ttyS3 at MMIO 0x2500c00 (irq = 290, base_baud = 1500000) is a SUNXI
      [    1.229259] misc dump reg init
      [    1.233497] npu[1][1] vipcore, platform driver device=0xdf5e2210
      [    1.240480] npu[1][1] vipcore irq number is 291.
      [    1.245658] gckvip_drv_adjust_param 232 SUCCESS
      [    1.250831] Want set pclk rate(504000000) support(504000000) real(504000000)
      [    1.258865] Want set mclk rate(504000000) support(504000000) real(504000000)
      [    1.266750] npu[1][1] This device support 64bits DMA
      [    1.272802] npu[1][1] core_0, request irqline=291, name=vipcore_0
      [    1.279903] npu[1][1] =======vipcore parameter=====
      [    1.285343] npu[1][1] registerMemBase     0x03050000,
      [    1.291125] npu[1][1] registerMemSize     0x00020000,
      [    1.296870] npu[1][1] irqLine             0x00000123,
      [    1.302629] npu[1][1] contiguousSize      0x02000000
      [    1.308229] npu[1][1] contiguousBase      0x30000000
      [    1.313772] npu[1][1] vipContiguousBase   0x0
      [    1.318657] npu[1][1] drvType             0x00000000
      [    1.324189] npu[1][1] AXISramSize         0x00000000
      [    1.329759] npu[1][1] AXISramBaseAddress  0x00000000
      [    1.335289] npu[1][1] VIPSramSize         0x00020000
      [    1.340833] npu[1][1] VIPSramBaseAddress  0x00400000
      [    1.346372] npu[1][1] sysHeapSize         0x00200000
      [    1.351913] npu[1][1] ===============================
      [    1.357635] npu[1][1] VIPLite driver version 1.8.0.0-AW-2022-04-21
      [    1.365813] sun8iw21p1-pinctrl pio: expect_func as:fanout0, but muxsel(3) is func:clk
      [    1.374859] sunxi-wlan soc@03000000:wlan@0: wlan_busnum (1)
      [    1.381175] sunxi-wlan soc@03000000:wlan@0: wlan power voltage (3300000)
      [    1.388687] sunxi-wlan soc@03000000:wlan@0: wlan io voltage (3300000)
      [    1.395878] sunxi-wlan soc@03000000:wlan@0: wlan_power_num (1)
      [    1.402460] sunxi-wlan soc@03000000:wlan@0: wlan_power_name (axp2101-dcdc1)
      [    1.410269] sunxi-wlan soc@03000000:wlan@0: io_regulator_name (axp2101-dcdc1)
      [    1.418292] sunxi-wlan soc@03000000:wlan@0: wlan_regon gpio=239  mul-sel=1  pull=1  drv_level=2  data=0
      [    1.428821] sunxi-wlan soc@03000000:wlan@0: get gpio chip_en failed
      [    1.435824] sunxi-wlan soc@03000000:wlan@0: wlan_hostwake gpio=199  mul-sel=14  pull=1  drv_level=2  data=0
      [    1.446830] sunxi-wlan soc@03000000:wlan@0: clk_name ()
      [    1.454143] libphy: Fixed MDIO Bus: probed
      [    1.459631] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    1.467268] get ehci0-controller, regulator_io is no nocare
      [    1.473667] get ehci0-controller wakeup-source is fail.
      [    1.479747] sunxi ehci0-controller don't init wakeup source
      [    1.485966] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0b7ecc8, 0x:e0848000, irq_no:136
      [    1.498144] [sunxi-ehci0]: Not init ehci0
      [    1.503093] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    1.510576] get ohci0-controller, regulator_io is no nocare
      [    1.516792] get ohci0-controller wakeup-source is fail.
      [    1.522842] sunxi ohci0-controller don't init wakeup source
      [    1.529229] [sunxi-ohci0]: probe, pdev->name: 4101000.ohci0-controller, sunxi_ohci: 0xc0b7eeec
      [    1.538894] [sunxi-ohci0]: Not init ohci0
      [    1.544021] usbcore: registered new interface driver uas
      [    1.550378] usbcore: registered new interface driver usb-storage
      [    1.557424] usbcore: registered new interface driver ums-alauda
      [    1.564223] usbcore: registered new interface driver ums-cypress
      [    1.571229] usbcore: registered new interface driver ums-datafab
      [    1.578310] usbcore: registered new interface driver ums_eneub6250
      [    1.585456] usbcore: registered new interface driver ums-freecom
      [    1.592429] usbcore: registered new interface driver ums-isd200
      [    1.599315] usbcore: registered new interface driver ums-jumpshot
      [    1.606364] usbcore: registered new interface driver ums-karma
      [    1.613172] usbcore: registered new interface driver ums-onetouch
      [    1.620330] usbcore: registered new interface driver ums-realtek
      [    1.627394] usbcore: registered new interface driver ums-sddr09
      [    1.634157] usbcore: registered new interface driver ums-sddr55
      [    1.641111] usbcore: registered new interface driver ums-usbat
      [    1.647910] usb_serial_number:20080411
      [    1.652537] get ctp_power is fail, -22
      [    1.656720] get ctp_power_ldo_vol is fail, -22
      [    1.661951] sunxi_ctp_startup: ctp_power_io is invalid.
      [    1.667903] fw_index:22
      [    1.714097] input: gslX680 as /devices/platform/soc/twi2/i2c-2/2-0040/input/input0
      [    1.723674] sunxi_i2c_do_xfer()1974 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x40)
      [    1.733487] twi_stop()544 - engine-mode: bus state: 0x0, isn't idle
      [    1.740563] sunxi_i2c_do_xfer()1974 - [i2c1] incomplete xfer (status: 0xff, dev addr: 0x40)
      [    1.750103] sunxi_i2c_do_xfer()1974 - [i2c3] incomplete xfer (status: 0x20, dev addr: 0x40)
      [    1.759658] sunxi_i2c_do_xfer()1974 - [i2c4] incomplete xfer (status: 0x20, dev addr: 0x40)
      [    1.775748] input: axp2101-pek as /devices/platform/soc/twi4/i2c-4/4-0034/axp2101-pek.0/input/input1
      [    1.787972] input: sunxi-wiegand0 as /devices/virtual/input/input2
      [    1.796193] sunxi_gpadc_init,1949, success
      [    1.801444] sunxi_gpadc_setup: get channel scan data failed
      [    1.808919] input: sunxi-gpadc0 as /devices/virtual/input/input3
      [    1.817889] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
      [    1.824758] sunxi-rtc rtc: RTC enabled
      [    1.829286] fix to hot reboot, save boot reason
      [    1.834754] i2c /dev entries driver
      [    1.840498] sunxi cedar version 0.1
      [    1.844674] VE: install start!!!
      [    1.844674]
      [    1.850461] VE: cedar-ve the get irq is 292
      [    1.855228] VE: regs_csi = e0883000
      [    1.859851] VE: ve_debug_proc_info:c0b83748, data:decc8000, lock:c0b837d0, flag: 1
      [    1.859851]
      [    1.870236] VE: install end!!!
      [    1.870236]
      [    1.875790] google_vp9: sunxi google vp9 version 0.1
      [    1.885203] axp2101_charger: read chipid = 4a
      [    1.885203]
      [    1.899193] thermal thermal_zone3: power_allocator: sustainable_power will be estimated
      [    1.930340] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      [    1.940288] Bluetooth: HCI UART driver ver 2.2.d448471.20181218-163903
      [    1.948266] Bluetooth: HCI UART protocol H4 registered
      [    1.954148] Bluetooth: HCI H4 protocol initialized
      [    1.960653] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 01.00.07
      [    1.969672] axp2101_charger: the gauge have been reset, need to reload param
      [    1.969672]
      [    1.979739] bt_fdi debugfs_init
      [    1.983293] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 900000 KHz
      [    2.017387] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 912000 KHz
      [    2.057910] cpuidle: enable-method property 'psci' found operations
      [    2.067542] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.59 2022-4-21 13:40)
      [    2.077074] sunxi-mmc sdc0: ***ctl-spec-caps*** 408
      [    2.084559] sunxi-mmc sdc0: No vqmmc regulator found
      [    2.090268] sunxi-mmc sdc0: No vdmmc regulator found
      [    2.096405] sunxi-mmc sdc0: set host busy
      [    2.101147] sunxi-mmc sdc0: Got CD GPIO
      [    2.106143] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 22 width 1 timing LEGACY(SDR12) dt B
      [    2.357432] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
      [    2.387354] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
      [    2.427600] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
      [    2.438400] sunxi-mmc sdc0: detmode:gpio irq
      [    2.439030] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.59 2022-4-21 13:40)
      [    2.439175] sunxi-mmc sdc1: ***ctl-spec-caps*** 8
      [    2.439265] sunxi-mmc sdc1: No vmmc regulator found
      [    2.439275] sunxi-mmc sdc1: No vqmmc regulator found
      [    2.439279] sunxi-mmc sdc1: No vdmmc regulator found
      [    2.439283] sunxi-mmc sdc1: No vd33sw regulator found
      [    2.439286] sunxi-mmc sdc1: No vd18sw regulator found
      [    2.439290] sunxi-mmc sdc1: No vq33sw regulator found
      [    2.439299] sunxi-mmc sdc1: No vq18sw regulator found
      [    2.440052] sunxi-mmc sdc1: set host busy
      [    2.440128] mmc:failed to get gpios
      [    2.440532] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.470769] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.499232] sunxi-mmc sdc1: detmode:manually by software
      [    2.501006] usbcore: registered new interface driver usbhid
      [    2.501008] usbhid: USB HID core driver
      [    2.511914] [sound 1158][DAUDIO snd_sunxi_regulator_init] regulator missing or invalid
      [    2.513691] sunxi-snd-mach soc@03000000:codec_mach: sunxi-snd-codec <-> soc@03000000:codec_plat mapping ok
      [    2.522183] axp2101_charger: the gauge have been reset, need to reload param
      [    2.522183]
      [    2.524720] random: crng init done
      [    2.528817] sunxi-snd-mach soc@03000000:daudio0_mach: snd-soc-dummy-dai <-> 2032000.daudio0_plat mapping ok
      [    2.542025] Netfilter messages via NETLINK v0.30.
      [    2.542483] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
      [    2.542684] ctnetlink v0.93: registering with nfnetlink.
      [    2.543079] ip_tables: (C) 2000-2006 Netfilter Core Team
      [    2.545322] NET: Registered protocol family 10
      [    2.547067] NET: Registered protocol family 17
      [    2.547114] NET: Registered protocol family 15
      [    2.547256] Bluetooth: RFCOMM TTY layer initialized
      [    2.547278] Bluetooth: RFCOMM socket layer initialized
      [    2.547307] Bluetooth: RFCOMM ver 1.11
      [    2.549154] Registering SWP/SWPB emulation handler
      [    2.691626] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
      [    2.704347] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
      [    2.711203] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
      [    2.717183] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.728598] sunxi-rtc rtc: setting system clock to 1970-01-01 00:16:32 UTC (992)
      [    2.729505] clk: Not disabling unused clocks
      [    2.729628] usb-vbus: disabling
      [    2.730027] axp2101-dcdc2: disabling
      [    2.739128] axp2101-rtcldo1: disabling
      [    2.739298] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
      [    2.740504] axp2101-aldo2: disabling
      [    2.746451] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
      [    2.747894] axp2101-aldo3: disabling
      [    2.789816] axp2101-aldo4: disabling
      [    2.794512] axp2101-bldo2: disabling
      [    2.799936] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.811063] axp2101-dldo2: disabling
      [    2.815943] axp2101-cpusldo: disabling
      [    2.820179] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    2.826104] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    2.832007] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    2.837939] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    2.838975] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
      [    2.838999] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
      [    2.839027] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    2.840115] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.873335] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.873463] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
      [    2.907116] ALSA device list:
      [    2.910481] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
      [    2.916501] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
      [    2.916529] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.924659] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.936515] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    2.936546] mmc0: host does not support reading read-only switch, assuming write-enable
      [    2.947335] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    2.953230] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    2.953257] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 4 timing LEGACY(SDR12) dt B
      [    2.962377] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    2.962401] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 4 timing UHS-SDR104 dt B
      [    2.962477] sunxi-mmc sdc0: sdc set ios:clk 150000000Hz bm PP pm ON vdd 22 width 4 timing UHS-SDR104 dt B
      [    2.962605] mmc0: new ultra high speed SDR104 SDHC card at address aaaa
      [    2.963116] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    2.964207] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.970766] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
      [    2.989068] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.989316] Primary GPT is invalid, using alternate GPT.
      [    2.989353]  mmcblk0: p1 p2 p3 p4 p5 p6 p7
      [    3.028028] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
      [    3.038428] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
      [    3.038472] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.050971] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.057924] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    3.069170] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    3.075376] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    3.080024] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    3.080073] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    3.081169] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.115299] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.149941] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
      [    3.160272] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
      [    3.160421] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.173527] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.180677] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    3.186795] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    3.197582] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    3.208510] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    3.208558] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    3.243733]   #0: audiocodec
      [    3.246965]   #1: snddaudio0
      [    3.257038] List of all partitions:
      [    3.261070] b300        15558144 mmcblk0  driver: mmcblk
      [    3.267088]   b301            3008 mmcblk0p1 a0085546-4166-744a-a353-fca9272b8e45
      [    3.275541]   b302             504 mmcblk0p2 a0085546-4166-744a-a353-fca9272b8e46
      [    3.284072]   b303           12600 mmcblk0p3 a0085546-4166-744a-a353-fca9272b8e47
      [    3.292507]   b304           21920 mmcblk0p4 a0085546-4166-744a-a353-fca9272b8e48
      [    3.300952]   b305            5040 mmcblk0p5 a0085546-4166-744a-a353-fca9272b8e49
      [    3.309367]   b306           10080 mmcblk0p6 a0085546-4166-744a-a353-fca9272b8e4a
      [    3.317783]   b307        15480399 mmcblk0p7 a0085546-4166-744a-a353-fca9272b8e4b
      [    3.326183] No filesystem could mount root, tried:  ext3 ext2 ext4 squashfs vfat msdos
      [    3.335144] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,4)
      [    3.344602] CPU: 0 PID: 1 Comm: swapper Not tainted 4.9.191 #1
      [    3.351134] Hardware name: sun8iw21
      [    3.355063] [<c010d660>] (unwind_backtrace) from [<c010a754>] (show_stack+0x10/0x14)
      [    3.363747] [<c010a754>] (show_stack) from [<c017074c>] (panic+0xac/0x2b8)
      [    3.371458] [<c017074c>] (panic) from [<c0a012cc>] (mount_block_root+0x258/0x300)
      [    3.379850] [<c0a012cc>] (mount_block_root) from [<c0a01500>] (prepare_namespace+0x118/0x178)
      [    3.389410] [<c0a01500>] (prepare_namespace) from [<c0a00eb4>] (kernel_init_freeable+0x144/0x178)
      [    3.399359] [<c0a00eb4>] (kernel_init_freeable) from [<c066ac8c>] (kernel_init+0x8/0x118)
      [    3.408530] [<c066ac8c>] (kernel_init) from [<c0106ec8>] (ret_from_fork+0x14/0x2c)
      [    3.417016] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,4)
      [    3.427345] sunxi dump enabled
      [    3.430760] dump regs done
      [    3.433813] flush cache done
      [    3.437048] crashdump enter
        size再改大一点,重新烧录或者换张卡试一试。
          carpediem LV 4 @whycan 最后由 编辑
          @whycan
          试了试扩大roofs.fex大小,换了张64G的SD卡,重新烧录,好像还是不行。不过其他的demo,比如lenet,是不会出现这个问题的。只有YOLOV3 会有这个问题。
