    d1-h系统缺少etc/config/wireless
    • K
      konosiba LV 4 最后由 编辑
      使用的是d1h的sdk,驱动正常加载了,wlan0也能正常联网,开热点,但是不知为何缺少etc/config/wireless这个文件,导致luci页面中缺少无线的选项,因此也无法在页面上直接修改热点密码和名称
      6e6ddf93-81d5-4ad3-b42f-c728030447f6-image.png 、
      这个是iw list输出的结果
      root@TinaLinux:/# iw list
      Wiphy phy0
      	max # scan SSIDs: 2
      	max scan IEs length: 2257 bytes
      	max # sched scan SSIDs: 0
      	max # match sets: 0
      	Retry short limit: 7
      	Retry long limit: 4
      	Coverage class: 0 (up to 0m)
      	Device supports AP-side u-APSD.
      	Available Antennas: TX 0 RX 0
      	Supported interface modes:
      		 * IBSS
      		 * managed
      		 * AP
      		 * AP/VLAN
      		 * monitor
      		 * P2P-client
      		 * P2P-GO
      		 * P2P-device
      	Band 1:
      		Capabilities: 0x172
      			HT20/HT40
      			Static SM Power Save
      			RX Greenfield
      			RX HT20 SGI
      			RX HT40 SGI
      			RX STBC 1-stream
      			Max AMSDU length: 3839 bytes
      			No DSSS/CCK HT40
      		Maximum RX AMPDU length 32767 bytes (exponent: 0x002)
      		Minimum RX AMPDU time spacing: No restriction (0x00)
      		HT TX/RX MCS rate indexes supported: 0-7
      		Frequencies:
      			* 2412 MHz [1] (20.0 dBm)
      			* 2417 MHz [2] (20.0 dBm)
      			* 2422 MHz [3] (20.0 dBm)
      			* 2427 MHz [4] (20.0 dBm)
      			* 2432 MHz [5] (20.0 dBm)
      			* 2437 MHz [6] (20.0 dBm)
      			* 2442 MHz [7] (20.0 dBm)
      			* 2447 MHz [8] (20.0 dBm)
      			* 2452 MHz [9] (20.0 dBm)
      			* 2457 MHz [10] (20.0 dBm)
      			* 2462 MHz [11] (20.0 dBm)
      			* 2467 MHz [12] (20.0 dBm) (no IR)
      			* 2472 MHz [13] (20.0 dBm) (no IR)
      			* 2484 MHz [14] (20.0 dBm) (no IR)
      	valid interface combinations:
      		 * #{ managed } <= 2, #{ AP } <= 1,
      		   total <= 3, #channels <= 1
      		 * #{ managed } <= 3,
      		 * #{ managed } <= 2, #{ P2P-client, P2P-GO } <= 1,
      这个是ifconfig -a的输出,可见wlan正常启动
      root@TinaLinux:/# ifconfig -a
      eth0      Link encap:Ethernet  HWaddr 46:0D:1B:C8:FF:DD
                inet addr:192.168.7.142  Bcast:192.168.7.255  Mask:255.255.255.0
                inet6 addr: fe80::440d:1bff:fec8:ffdd/64 Scope:Link
                inet6 addr: fda1:fb1c:6054::1/60 Scope:Global
                RX packets:42457 errors:0 dropped:0 overruns:0 frame:0
                TX packets:30999 errors:0 dropped:0 overruns:0 carrier:0
                collisions:0 txqueuelen:1000
                RX bytes:44403994 (42.3 MiB)  TX bytes:3726900 (3.5 MiB)
                Interrupt:62
                RX packets:9900 errors:0 dropped:0 overruns:0 frame:0
                TX packets:9900 errors:0 dropped:0 overruns:0 carrier:0
                RX bytes:845772 (825.9 KiB)  TX bytes:845772 (825.9 KiB)
      mon.wlan0 Link encap:UNSPEC  HWaddr C8-25-BD-47-71-70-00-00-00-00-00-00-00-00-00-00
                RX packets:2 errors:0 dropped:0 overruns:0 frame:0
                RX bytes:273 (273.0 B)  TX bytes:0 (0.0 B)
      sit0      Link encap:IPv6-in-IPv4
                NOARP  MTU:1480  Metric:1
      wlan0     Link encap:Ethernet  HWaddr C8:25:BD:47:71:70
                inet addr:192.168.5.1  Bcast:192.168.5.255  Mask:255.255.255.0
                inet6 addr: fe80::ca25:bdff:fe47:7170/64 Scope:Link
                RX packets:31335 errors:0 dropped:1 overruns:0 frame:0
                TX packets:37668 errors:0 dropped:0 overruns:0 carrier:0
                RX bytes:3862446 (3.6 MiB)  TX bytes:45169868 (43.0 MiB)
      不知如何解决
