    T113-S3无法下载镜像
    • how0723
      how0723 LV 5 最后由 编辑
        linsen LV 7 @how0723 最后由 编辑
        @how0723更换电脑USB口,更换USB数据线,重启电脑,检查T113板晶振工作情况
          WhycanService LV 8 @lansecd 最后由 whycan 编辑
          @how0723
          楼主您好,这是贴log的正确姿势:
          [22]HELLO! BOOT0 is starting!
          [25]BOOT0 commit : 88480af-dirty
          [28]set pll start
          [34]periph0 has been enabled
          [37]set pll end
          [38][pmu]: bus read error
          [41]board init ok
          [43]ZQ value = 0x2f
          [44]get_pmu_exist() = -1
          [47]ddr_efuse_type: 0xa
          [49]trefi:7.8ms
          [52][AUTO DEBUG] single rank and full DQ!
          [56]ddr_efuse_type: 0xa
          [58]trefi:7.8ms
          [60][AUTO DEBUG] rank 0 row = 13
          [63][AUTO DEBUG] rank 0 bank = 8
          [67][AUTO DEBUG] rank 0 page size = 2 KB
          [70]DRAM BOOT DRIVE INFO: V0.33
          [73]DRAM CLK = 936 MHz
          [76]DRAM Type = 3 (2:DDR2,3:DDR3)
          [79]DRAMC read ODT  off.
          [81]DRAM ODT value: 0x42.
          [84]ddr_efuse_type: 0xa
          [87]DRAM SIZE =128 M
          [89]dram_tpr4:0x0
          [90]PLL_DDR_CTRL_REG:0xf8004d00
          [93]DRAM_CLK_REG:0xc0000000
          [96][TIMING DEBUG] MR2= 0x20
          [104]DRAM simple test OK.
          [106]rtc standby flag is 0x0, super standby flag is 0x0
          [111]dram size =128
          [114]card no is 0
          [116]sdcard 0 line count 4
          [118][mmc]: mmc driver ver 2021-05-21 14:47
          [128][mmc]: Wrong media type 0x0
          [130][mmc]: ***Try SD card 0***
          [143][mmc]: HSSDR52/SDR25 4 bit
          [146][mmc]: 50000000 Hz
          [148][mmc]: 1876 MB
          [150][mmc]: ***SD/MMC 0 init OK!!!***
          [232]Loading boot-pkg Succeed(index=0).
          [236]Entry_name        = u-boot
          [241]Entry_name        = optee
          [245]Entry_name        = dtb
          [248]mmc not para
          [250]Jump to second Boot.
          U-Boot 2018.05-g24521d6-dirty (Sep 21 2022 - 12:06:27 +0800) Allwinner Technology
          [00.303]CPU:   Allwinner Family
          [00.306]Model: sun8iw20
          ready
          [00.327]DRAM:  128 MiB
          [00.330]Relocation Offset is: 04f01000
          [00.350]secure enable bit: 0
          [00.352]smc_tee_inform_fdt failed with: -65526[00.357]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
          [00.363]gic: sec monitor mode
          [00.366]flash init start
          [00.368]workmode = 0,storage type = 1
          [00.371][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
          [00.377][mmc]: get sdc_type fail and use default host:tm1.
          [00.383][mmc]: can't find node "mmc0",will add new node
          [00.388][mmc]: fdt err returned <no error>
          [00.391][mmc]: Using default timing para
          [00.395][mmc]: SUNXI SDMMC Controller Version:0x50310
          [00.416][mmc]: card_caps:0x3000000a
          [00.419][mmc]: host_caps:0x3000003f
          [00.423]sunxi flash init ok
          [00.435]Loading Environment from SUNXI_FLASH... OK
          [00.469]Item0 (Map) magic is bad
          [00.471]the secure storage item0 copy0 magic is bad
          [00.488]Item0 (Map) magic is bad
          [00.491]the secure storage item0 copy1 magic is bad
          [00.495]Item0 (Map) magic is bad
          [00.501]secure storage read widevine fail with:-1
          [00.508]secure storage read ec_key fail with:-1
          [00.516]secure storage read ec_cert1 fail with:-1
          [00.523]secure storage read ec_cert2 fail with:-1
          [00.531]secure storage read ec_cert3 fail with:-1
          [00.538]secure storage read rsa_key fail with:-1
          [00.545]secure storage read rsa_cert1 fail with:-1
          [00.553]secure storage read rsa_cert2 fail with:-1
          [00.561]secure storage read rsa_cert3 fail with:-1
          [00.565]out of usb burn from boot: not need burn key
          root_partition is rootfs
          set root to /dev/mmcblk0p5
          [00.575]update part info
          [00.579]update bootcmd
          [00.583]change working_fdt 0x43ec0e70 to 0x43ea0e70
          [00.604]update dts
          [01.795]no vendor_boot partition is found
          Android's image name: t113-nezha
          [01.806]Starting kernel ...
          [01.808][mmc]: MMC Device 2 not found
          [01.812][mmc]: mmc 2 not find, so not exit
          [    0.000000] Linux version 5.4.61 (xulu@mylinux) (arm-openwrt-linux-muslgnueabi-gcc.bin (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) 6.4.1, GNU ld (GNU Binutils) 2.27) #138 SMP PREEMPT Sun Oct 2 02:45:48 UTC 2022
          [    0.000000] cma: Reserved 8 MiB at 0x47800000
          [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500C00 clk_ignore_unused initcall_debug=0 console=ttyS3,115200 loglevel=8 root=/dev/mmcblk0p5 init=/pseudo_init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:private@mmcblk0p6:rootfs_data@mmcblk0p7:UDISK@mmcblk0p8 cma=8M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun8iw20p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05-g24521d6-dirty(09/21/2022-12:06:27) androidboot.dramsize=128
          [    0.000000] Memory: 109632K/131072K available (6144K kernel code, 269K rwdata, 1580K rodata, 1024K init, 1165K bss, 13248K reserved, 8192K cma-reserved)
          [    0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
          [    0.007998] Switching to timer-based delay loop, resolution 41ns
          [    0.014167] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
          [    0.023871] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
          [    0.034220] pid_max: default: 32768 minimum: 301
          [    0.038944] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
          [    0.046258] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
          [    0.054569] CPU: Testing write buffer coherency: ok
          [    0.059781] /cpus/cpu@0 missing clock-frequency property
          [    0.065104] /cpus/cpu@1 missing clock-frequency property
          [    0.070444] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
          [    0.076596] Setting up static identity map for 0x40100000 - 0x40100060
          [    0.083259] rcu: Hierarchical SRCU implementation.
          [    0.088460] smp: Bringing up secondary CPUs ...
          [    0.094065] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
          [    0.094183] smp: Brought up 1 node, 2 CPUs
          [    0.103995] SMP: Total of 2 processors activated (96.00 BogoMIPS).
          [    0.110165] CPU: All CPU(s) started in SVC mode.
          [    0.115230] devtmpfs: initialized
          [    0.130017] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
          [    0.138100] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
          [    0.147982] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
          [    0.155211] pinctrl core: initialized pinctrl subsystem
          [    0.161628] NET: Registered protocol family 16
          [    0.167481] DMA: preallocated 256 KiB pool for atomic coherent allocations
          [    0.211609] rtc_ccu: sunxi ccu init OK
          [    0.217805] ccu: sunxi ccu init OK
          [    0.221657] r_ccu: sunxi ccu init OK
          [    0.264086] iommu: Default domain type: Translated
          [    0.269170] sunxi iommu: irq = 24
          [    0.273590] SCSI subsystem initialized
          [    0.277912] usbcore: registered new interface driver usbfs
          [    0.285093] usbcore: registered new interface driver hub
          [    0.290546] usbcore: registered new device driver usb
          [    0.295853] videodev: Linux video capture interface: v2.00
          [    0.302387] Advanced Linux Sound Architecture Driver Initialized.
          [    0.309133] Bluetooth: Core ver 2.22
          [    0.312798] NET: Registered protocol family 31
          [    0.317254] Bluetooth: HCI device and connection manager initialized
          [    0.323626] Bluetooth: HCI socket layer initialized
          [    0.328516] Bluetooth: L2CAP socket layer initialized
          [    0.333579] Bluetooth: SCO socket layer initialized
          [    0.338731] pwm module init!
          [    0.342993] g2d 5410000.g2d: Adding to iommu group 0
          [    0.348329] G2D: rcq version initialized.major:252
          [    0.353972] clocksource: Switched to clocksource arch_sys_counter
          [    0.368946] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
          [    0.378684] NET: Registered protocol family 2
          [    0.383578] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
          [    0.391989] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
          [    0.399671] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
          [    0.406732] TCP: Hash tables configured (established 1024 bind 1024)
          [    0.413190] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
          [    0.419765] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
          [    0.426926] NET: Registered protocol family 1
          [    0.432249] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
          [    0.442561] spi spi0: spi0 supply spi not found, using dummy regulator
          [    0.449343] sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
          [    0.455501] sunxi_spi_resource_get()2189 - Failed to get sample mode
          [    0.461864] sunxi_spi_resource_get()2194 - Failed to get sample delay
          [    0.468324] sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_delay:-1431633921
          [    0.476740] sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
          [    0.483069] sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base c881f000, irq 40
          [    0.493011] workingset: timestamp_bits=30 max_order=15 bucket_order=0
          [    0.506531] squashfs: version 4.0 (2009/01/31) Phillip Lougher
          [    0.512555] ntfs: driver 2.1.32 [Flags: R/W].
          [    0.547028] io scheduler mq-deadline registered
          [    0.551559] io scheduler kyber registered
          [    0.557580] [DISP]disp_module_init
          [    0.561532] disp 5000000.disp: Adding to iommu group 0
          [    0.583707] display_fb_request,fb_id:0
          [    0.589425] [DISP] Fb_copy_boot_fb,line:1443:
          [    0.589430] no boot_fb0
          [    0.596728] disp_al_manager_apply ouput_type:0
          [    0.602105] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
          [    0.604531] [DISP]disp_module_init finish
          [    0.617262] sunxi_sid_init()551 - insmod ok
          [    0.622539] uart uart3: get regulator failed
          [    0.626866] uart uart3: uart3 supply uart not found, using dummy regulator
          [    0.634076] uart3: ttyS3 at MMIO 0x2500c00 (irq = 34, base_baud = 1500000) is a SUNXI
          [    0.641922] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
          ▒[    0.649930] printk: console [ttyS3] enabled
          [    0.658862] printk: bootconsole [earlycon0] disabled
          [    0.670428] misc dump reg init
          [    0.675116] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
          [    0.686351] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
          [    0.693592] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
          [    0.700940] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
          [    0.708377] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
          [    0.714929] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
          [    0.721877] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
          [    0.729617] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
          [    0.737485] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
          [    0.745623] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
          [    0.753276] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
          [    0.760059] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
          [    0.767614] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=141 assert=0
          [    0.775158] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
          [    0.787006] [ADDR_MGT] addr_mgt_probe: module version: v1.0.10
          [    0.794269] [ADDR_MGT] addr_mgt_probe: success.
          [    0.799749] dma-buf: Running sanitycheck
          [    0.804201] dma-buf: Running dma_fence
          [    0.808403] sizeof(dma_fence)=48
          [    0.812132] dma-buf: Running dma_fence/sanitycheck
          [    0.817542] dma-buf: Running dma_fence/test_signaling
          [    0.823209] dma-buf: Running dma_fence/test_add_callback
          [    0.829201] dma-buf: Running dma_fence/test_late_add_callback
          [    0.835673] dma-buf: Running dma_fence/test_rm_callback
          [    0.841534] dma-buf: Running dma_fence/test_late_rm_callback
          [    0.847892] dma-buf: Running dma_fence/test_status
          [    0.853265] dma-buf: Running dma_fence/test_error
          [    0.858547] dma-buf: Running dma_fence/test_wait
          [    0.863726] dma-buf: Running dma_fence/test_wait_timeout
          [    0.865711] smallwitpi lcd_panel_init 235 xxxxxxxxxxxxxxxxxx
          [    0.913980] dma-buf: Running dma_fence/test_stub
          [    0.919179] dma-buf: Running dma_fence/race_signal_callback
          [    0.954159] [DISP] disp_device_attached_and_enable,line:233:
          [    0.954165] attached ok, mgr0<-->dev0
          [    0.973972] [DISP] disp_device_attached_and_enable,line:236:
          [    0.973980] type:1,mode:0,fmt:rgb,bits:8bits,eotf:4,cs:0 dvi_hdmi:2, range:2 scan:0 ratio:8
          [    0.993994] thread_signal_callback[0] completed 21929 passes, 42 misses
          [    1.001451] thread_signal_callback[1] completed 21954 passes, 67 misses
          [    1.073978] thread_signal_callback[0] completed 40388 passes, 40387 misses
          [    1.081723] thread_signal_callback[1] completed 40461 passes, 40461 misses
          [    1.090015] sunxi-spinand: AW SPINand MTD Layer Version: 2.0 20201228
          [    1.097355] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
          [    1.111065] random: fast init done
          [    1.395865] random: crng init done
          [    2.104026] sunxi-spinand-phy: read id failed : -110
          [    2.109618] spi-nand: probe of spi0.0 failed with error -110
          [    2.116495] libphy: Fixed MDIO Bus: probed
          [    2.121960] sunxi gmac driver's version: 1.0.0
          [    2.127162] gmac-power0: NULL
          [    2.130490] gmac-power1: NULL
          [    2.133839] gmac-power2: NULL
          [    2.138219] Failed to alloc md5
          [    2.141749] eth0: Use random mac address
          [    2.146493] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
          [    2.153839] sunxi-ehci: EHCI SUNXI driver
          [    2.158826] get ehci0-controller wakeup-source is fail.
          [    2.164851] sunxi ehci0-controller don't init wakeup source
          [    2.171108] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0b5f278, 0x:c8837000, irq_no:3b
          [    2.183138] [sunxi-ehci0]: Not init ehci0
          [    2.187929] get ehci1-controller wakeup-source is fail.
          [    2.193873] sunxi ehci1-controller don't init wakeup source
          [    2.200173] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0b5f798, 0x:c883b000, irq_no:3d
          [    2.212223] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator
          [    2.224780] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
          [    2.236997] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
          [    2.244275] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
          [    2.254246] sunxi-ehci 4200000.ehci1-controller: irq 61, io mem 0x04200000
          [    2.283996] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
          [    2.292670] hub 1-0:1.0: USB hub found
          [    2.296949] hub 1-0:1.0: 1 port detected
          [    2.302045] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
          [    2.309026] sunxi-ohci: OHCI SUNXI driver
          [    2.314028] get ohci0-controller wakeup-source is fail.
          [    2.320019] sunxi ohci0-controller don't init wakeup source
          [    2.326290] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0b5f508
          [    2.335969] [sunxi-ohci0]: Not init ohci0
          [    2.340739] get ohci1-controller wakeup-source is fail.
          [    2.346709] sunxi ohci1-controller don't init wakeup source
          [    2.352982] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0b5fa28
          [    2.362680] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator
          [    2.375215] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
          [    2.387439] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
          [    2.394717] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
          [    2.404646] sunxi-ohci 4200400.ohci1-controller: irq 62, io mem 0x04200400
          [    2.478849] hub 2-0:1.0: USB hub found
          [    2.483120] hub 2-0:1.0: 1 port detected
          [    2.488382] i2c /dev entries driver
          [    2.492388] sunxi cedar version 1.1
          [    2.496513] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
          [    2.502828] VE: sunxi_cedar_probe power-domain init!!!
          [    2.508610] VE: install start!!!
          [    2.508610]
          [    2.514181] VE: cedar-ve the get irq is 41
          [    2.514181]
          [    2.520650] VE: ve_debug_proc_info:de196ca4, data:2a6a4c60, lock:3e85bfd2
          [    2.520650]
          [    2.529941] VE: install end!!!
          [    2.529941]
          [    2.535042] VE: sunxi_cedar_probe
          [    2.539055] Bluetooth: HCI UART driver ver 2.3
          [    2.544068] Bluetooth: HCI UART protocol H4 registered
          [    2.549847] Bluetooth: HCI UART protocol BCSP registered
          [    2.555818] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
          [    2.564876] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
          [    2.574892] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
          [    2.581092] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
          [    2.587466] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
          [    2.593912] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
          [    2.600382] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
          [    2.606934] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
          [    2.613477] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
          [    2.620035] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
          [    2.627023] sunxi-mmc 4020000.sdmmc: Got CD GPIO
          [    2.632418] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
          [    2.639108] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
          [    2.650298] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
          [    2.670456] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [    2.694879] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
          [    2.700586] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [    2.704582] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
          [    2.715353] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [    2.722181] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
          [    2.735935] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [    2.739796] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
          [    2.754362] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [    2.757706] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
          [    2.775766] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
          [    2.782211] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
          [    2.788764] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
          [    2.795316] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
          [    2.801857] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
          [    2.805387] mmc0: host does not support reading read-only switch, assuming write-enable
          [    2.808429] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
          [    2.819487] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
          [    2.826879] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
          [    2.837831] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
          [    2.848826] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
          [    2.860667] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
          [    2.879919] mmc0: new high speed SD card at address 0001
          [    2.880652] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [    2.887052] mmcblk0: mmc0:0001 SD2GB 1.83 GiB
          [    2.906090]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
          [    2.910168] sunxi-mmc 4021000.sdmmc: detmode:manually by software
          [    2.918581] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [    2.924427] sun8iw20-pinctrl 2000000.pinctrl: unsupported function ledc on pin PE11
          [    2.939102] sunxi_led_probe()1749 - start
          [    2.940093] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [    2.943625] sunxi_get_str_of_property()1595 - failed to get the string of propname led_regulator!
          [    2.965225] sunxi-mmc 4021000.sdmmc: card claims to support voltages below defined range
          [    2.974347] sunxi_register_led_classdev()1483 - led_classdev start
          [    2.982461] sun8iw20-pinctrl 2000000.pinctrl: unsupported function ledc on pin PE11
          [    2.991201] sunxi_ledc_pinctrl_init()1345 - devm_pinctrl_get_select_default failed!
          [    2.999960] sunxi_led_probe()1845 - finish
          [    3.004892] exFAT: Version 1.3.0
          [    3.011286] sun8iw20-pinctrl 2000000.pinctrl: unsupported function i2s1 on pin PG14
          [    3.019977] sun8iw20-pinctrl 2000000.pinctrl: unsupported function i2s1 on pin PG15
          [    3.028814] sun8iw20-pinctrl 2000000.pinctrl: pin PG11 already requested by soc@3000000:rfkill@0; cannot claim for 2033000.daudio
          [    3.041932] sun8iw20-pinctrl 2000000.pinctrl: pin-203 (2033000.daudio) status -22
          [    3.050377] sun8iw20-pinctrl 2000000.pinctrl: could not request pin 203 (PG11) from group PG11  on device 2000000.pinctrl
          [    3.062695] sunxi-daudio 2033000.daudio: Error applying setting, reverse things back
          [    3.071435] sunxi-daudio: probe of 2033000.daudio failed with error -22
          [    3.079152] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
          [    3.090631] sunxi-daudio 2034000.daudio: regulator missing or invalid
          [    3.098415] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
          [    3.098415]
          [    3.115651] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
          [    3.126618] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
          [    3.127039] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
          [    3.138271] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
          [    3.147362] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
          [    3.168095] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
          [    3.168161] [SNDCODEC][sunxi_card_init][583]:card init finished
          [    3.187171] mmc1: new high speed SDIO card at address 0001
          [    3.187311] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
          [    3.204374] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input0
          [    3.216423] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
          [    3.224993] NET: Registered protocol family 10
          [    3.231028] Segment Routing with IPv6
          [    3.235214] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
          [    3.242651] NET: Registered protocol family 17
          [    3.247808] Bluetooth: RFCOMM TTY layer initialized
          [    3.253290] Bluetooth: RFCOMM socket layer initialized
          [    3.259180] Bluetooth: RFCOMM ver 1.11
          [    3.264002] Registering SWP/SWPB emulation handler
          [    3.283528] sun8iw20-pinctrl 2000000.pinctrl: pin PB3 already requested by 2034000.daudio; cannot claim for 2502000.twi
          [    3.295717] sun8iw20-pinctrl 2000000.pinctrl: pin-35 (2502000.twi) status -22
          [    3.303726] sun8iw20-pinctrl 2000000.pinctrl: could not request pin 35 (PB3) from group PB3  on device 2000000.pinctrl
          [    3.315776] sunxi-i2c 2502000.twi: Error applying setting, reverse things back
          [    3.323910] sunxi-i2c: probe of 2502000.twi failed with error -22
          [    3.331607] sun8iw20-pinctrl 2000000.pinctrl: unsupported function i2s1 on pin PG14
          [    3.340228] sun8iw20-pinctrl 2000000.pinctrl: unsupported function i2s1 on pin PG15
          [    3.349024] sun8iw20-pinctrl 2000000.pinctrl: pin PG11 already requested by soc@3000000:rfkill@0; cannot claim for 2033000.daudio
          [    3.362115] sun8iw20-pinctrl 2000000.pinctrl: pin-203 (2033000.daudio) status -22
          [    3.370522] sun8iw20-pinctrl 2000000.pinctrl: could not request pin 203 (PG11) from group PG11  on device 2000000.pinctrl
          [    3.382825] sunxi-daudio 2033000.daudio: Error applying setting, reverse things back
          [    3.391543] sunxi-daudio: probe of 2033000.daudio failed with error -22
          [    3.400453] sunxi-audio-card 20340a0.sounddaudio2: use dummy codec for simple card.
          [    3.409221] debugfs: Directory '2034000.daudio' with parent 'snddaudio2' already present!
          [    3.418835] sunxi-audio-card 20340a0.sounddaudio2: snd-soc-dummy-dai <-> 2034000.daudio mapping ok
          [    3.433231] clk: Not disabling unused clocks
          [    3.438459] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
          [    3.444004] ALSA device list:
          [    3.448169] cfg80211: failed to load regulatory.db
          [    3.451497]   #0: audiocodec
          [    3.460083]   #1: snddaudio2
          [    3.463318] alloc_fd: slot 0 not NULL!
          [    3.474409] VFS: Mounted root (squashfs filesystem) readonly on device 179:5.
          [    3.487240] devtmpfs: mounted
          [    3.492457] Freeing unused kernel memory: 1024K
          [    3.504169] Run /pseudo_init as init process
          mount: mounting /dev/by-name/rootfs_data on /overlay failed: No such device
          Mount Failed: formating /dev/by-name/rootfs_data to ext4 ...
          /pseudo_init: line 395: mkfs.ext4: not found
          /etc/init.d/rcS: line 136: mkfs.ext4: not found
          [    3.813916] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
          ------run rc.final file-----
            : values=on
          ------light up RGB LED-----
          [    3.983090] file system registered
          [    4.000113] configfs-gadget 4100000.udc-controller: failed to start g1: -19
          [    4.022329] read descriptors
          [    4.025614] read strings
          ------light up LED-----
          ------run profile file-----
          Wed Jun  1 00:00:00 GMT 2022
          nodev   debugfs
          root@TinaLinux:/# [    7.034253] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
          root@TinaLinux:/#
          root@TinaLinux:/#
          root@TinaLinux:/#
          root@TinaLinux:/#
          root@TinaLinux:/#
          root@TinaLinux:/#
          root@TinaLinux:/#
          以上是 T113-S3从SDC0 TF卡启动日志。
