    F133-A 烧录新的镜像后重启打印 no vendor_boot partition is found
      jianwei LV 3 最后由 编辑
      烧录镜像后重启无法进入系统
      重启打印如下
      [53]HELLO! BOOT0 is starting!
      [56]BOOT0 commit : 977af20-dirty
      [59]set pll start
      [61]periph0 has been enabled
      [64]set pll end
      [65][pmu]: bus read error
      [67]board init ok
      [69]ZQ value = 0x31
      [71]get_pmu_exist() = -1
      [73]DRAM BOOT DRIVE INFO: V0.33
      [76]DRAM CLK = 528 MHz
      [78]DRAM Type = 2 (2:DDR2,3:DDR3)
      [81]DRAMC read ODT  off.
      [84]DRAM ODT off.
      [86]ddr_efuse_type: 0xa
      [88]DRAM SIZE =64 M
      [90]dram_tpr4:0x0
      [92]PLL_DDR_CTRL_REG:0xf8002b00
      [95]DRAM_CLK_REG:0xc0000000
      [97][TIMING DEBUG] MR2= 0x0
      [102]DRAM simple test OK.
      [104]dram size =64
      [106]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
      [111]block from 8 to 32
      [167]Check is correct.
      [169]dma 0x30338 int is not used yet
      [173]dma 0x30338 int is free, you do not need to free it again
      [179]Entry_name        = opensbi
      [182]Entry_name        = u-boot
      [186]Entry_name        = dtb
      [188]Jump to second Boot.
      OpenSBI auto-t113-linux-V0.8-1-g771d82e
              |_|
      Platform Max HARTs     : 1
      Current Hart           : 0
      Runtime SBI Version    : 0.2
      MIDELEG : 0x0000000000000222
      MEDELEG : 0x000000000000b1ff
      PMP3    : 0x0000000000020000-0x0000000000027fff (A,
      U-Boot 2018.05-00006-g294b3a0-config-dirty (Feb 09 2022 - 17:06:36 +0800) Allwinner Technology
      [00.275]DRAM:  64 MiB
      [00.277]Relocation Offset is: 01ede000
      [00.282]secure enable bit: 0
      [00.284]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.291]flash init start
      [00.293]workmode = 0,storage type = 0
      defaults:
      mtdids  : nand0=nand
      [00.469]ubi0: attaching mtd4
      [00.657]ubi0: scanning is finished
      [00.664]ubi0: attached mtd4 (name "sys", size 251 MiB)
      [00.669]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [00.675]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [00.681]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [00.688]ubi0: good PEBs: 1004, bad PEBs: 0, corrupted PEBs: 0
      [00.693]ubi0: user volume: 10, internal volumes: 1, max. volumes count: 128
      [00.700]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
      [00.708]ubi0: available PEBs: 0, total reserved PEBs: 1004, PEBs reserved for bad PEB handling: 40
      [00.716]sunxi flash init ok
      [00.719]line:703 init_clocks
      [00.722]drv_disp_init
      [00.740]unable to map hdmi registers
      [00.743]drv_disp_init finish
      [00.848]Loading Environment from SUNXI_FLASH... OK
      [00.868]boot_gui_init:start
      [00.871]set disp.dev2_output_type fail. using defval=0
      [00.878]boot_gui_init:finish
      [00.898]bmp_name=bootlogo.bmp size 38454
      38454 bytes read in 3 ms (12.2 MiB/s)
      [00.909]out of usb burn from boot: not need burn key
      [00.915]Item0 (Map) magic is bad
      List file under ULI/factory
      [00.934]update bootcmd
      [00.946]change working_fdt 0x42a9dda0 to 0x42a7dda0
      [00.975]update dts
      noncached_alloc(): addr = 0x42b11e00
      noncached_alloc(): addr = 0x42b11e40
      noncached_alloc(): addr = 0x42b11e80
      noncached_alloc(): addr = 0x42b126c0
      geth_sys_init fail!
      [00.995]Board Net Initialization Failed
      [00.998]No ethernet found.
      [01.069]LCD open finish
      [02.303]no vendor_boot partition is found
      Android's image name: f133-evb1
      Detect comp none
      [02.319]
      Starting kernel ...
      有没有前辈能指点一下是什么情况导致的
      而且想要再次进行烧录的时候检测不到USB设备了
        lct_123 LV 2 最后由 编辑
        你好,我也遇到了一模一样的问题,请问解决了吗
