    T113+SPI NAND 零下40度,这样正常么?
    6435
      linsen LV 7 最后由 编辑
      大家有做过T113的低温实验么,零下40度工作出现了下面的情况:
      [    3.367765] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      [    3.370354] clk: Not disabling unused clocks
      [    3.377538] cfg80211: failed to load regulatory.db
      [    3.382098] ALSA device list:
      [    3.390698]   #0: audiocodec
      [    3.391058] hub 1-1:1.0: USB hub found
      [    3.393898] alloc_fd: slot 0 not NULL!
      [    3.398583] hub 1-1:1.0: 4 ports detected
      [    3.410969] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
      [    3.420662] devtmpfs: mounted
      [    3.425613] Freeing unused kernel memory: 1024K
      [    3.460496] Run /sbin/init as init process
      [    3.616526] init: Console is alive
      [    3.620561] init: - watchdog -
      [    3.624037] init: - preinit -
      [    3.637034] SQUASHFS error: zlib decompression failed, data probably corrupt
      [    3.647018] SQUASHFS error: squashfs_read_data failed to read block 0x1519f6
      [    3.654939] SQUASHFS error: Unable to read fragment cache entry [1519f6]
      [    3.662496] SQUASHFS error: Unable to read page, block 1519f6, size 1b4b8
      [    3.670246] SQUASHFS error: Unable to read fragment cache entry [1519f6]
      [    3.677766] SQUASHFS error: Unable to read page, block 1519f6, size 1b4b8
      [    3.685448] SQUASHFS error: Unable to read fragment cache entry [1519f6]
      [    3.692995] SQUASHFS error: Unable to read page, block 1519f6, size 1b4b8
      [    3.700619] SQUASHFS error: Unable to read fragment cache entry [1519f6]
      [    3.708063] SQUASHFS error: Unable to read page, block 1519f6, size 1b4b8
      [    3.715684] SQUASHFS error: Unable to read fragment cache entry [1519f6]
      [    3.723170] SQUASHFS error: Unable to read page, block 1519f6, size 1b4b8
      [    3.731183] init: Failed to start kmodloader
      [    3.780731] 8<--- cut here ---
      [    3.784146] Unable to handle kernel paging request at virtual address 57ac6e9d
      [    3.792152] pgd = a9329b06
      [    3.795144] [57ac6e9d] *pgd=00000000
      [    3.799103] Internal error: Oops: 805 [#1] PREEMPT SMP ARM
      [    3.805176] Modules linked in:
      [    3.808559] CPU: 1 PID: 1134 Comm: kworker/1:3 Not tainted 5.4.61 #239
      [    3.815791] Hardware name: Generic DT based system
      [    3.815806] Workqueue: ubiblock0_5 ubiblock_do_work
      [    3.826514] PC is at do_wait_for_common+0xfc/0x168
      [    3.831821] LR is at arch_spin_lock+0xc/0x48
      [    3.836546] pc : [<c0782ca4>]    lr : [<c014f780>]    psr: 20000193
      [    3.843484] sp : c72dda00  ip : 00100100  fp : 00000000
      [    3.849267] r10: 00000002  r9 : c078502c  r8 : c7987748
      [    3.855050] r7 : c0c04e08  r6 : c72dc000  r5 : c7987744  r4 : 000001f4
      [    3.862282] r3 : 57ac6e9d  r2 : c798774c  r1 : c7987748  r0 : 00000000
      [    3.862293] Flags: nzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
      [    3.877506] Control: 10c5387d  Table: 46b9c06a  DAC: 00000051
      [    3.883868] Process kworker/1:3 (pid: 1134, stack limit = 0xee25e517)
      [    3.891000] Stack: (0xc72dda00 to 0xc72de000)
      [    3.895827] da00: 00000001 c7946400 c013a534 c798774c c798774c 2429ebe8 c0c1d898 c7987748
      [    3.904887] da20: c7987744 000001f4 00000002 c7987440 c8868000 00000002 c8868000 c0782d78
      [    3.913952] da40: c7987440 c72ddb9c c0c2a940 c7af8c00 c7987440 c040ca54 c7ebad80 c72b9980
      [    3.923014] da60: 00000113 c7af8ec8 c7986440 c8868000 c7987754 c7af8ec8 c72ddb9c 00000000
      [    3.932075] da80: c72ddb9c c72ddb64 c7986000 c7986390 c7af8c00 c7a53410 c7af8ec8 c0407bc8
      [    3.941136] daa0: 00000000 00000000 c72ddaec c0785f18 c72ddac0 c7986000 c72ddb20 c72ddb88
      [    3.950196] dac0: c72ddb64 c79862a4 00000000 c7a53410 c7a53410 c0408104 c7986000 00000000
      [    3.959258] dae0: 00000000 c7986000 c7af8c00 c72ddb64 c7af8ec8 c7986390 c04058e4 00000000
      [    3.968321] db00: c79862bc c04084e4 c0c04e08 60000113 00000001 00000000 00000000 c72ddb1c
      [    3.977382] db20: c72ddb1c 2429ebe8 c72ddb38 c7af8c00 c72ddb64 c796d9c2 c0c04e08 00000001
      [    3.986443] db40: c72ddc7b c7af8c00 c72ddc6a c0408560 c796d9c0 c72ddb64 c796d9c2 c040866c
      [    3.995503] db60: 00000002 c72ddbe0 c72ddc2c c7af8c00 00000000 c0405844 c72ddb14 00000003
      [    4.004563] db80: 00000000 ffffff8d c72ddb88 c72ddb88 00000000 c72ddb94 c72ddb94 c796d9c0
      [    4.013627] dba0: 00000000 00000002 00000000 00000000 00000000 00000000 00000000 00000000
      [    4.022687] dbc0: 00000000 00000000 00000802 00000000 00000000 05f5e100 00000000 00000000
      [    4.031748] dbe0: c72ddc2c c72ddb64 00000000 c796d9c2 00000001 00000000 00000000 00000000
      [    4.040809] dc00: 00000000 00000000 00000000 00000000 00000000 00000810 00000000 00000000
      [    4.049869] dc20: 05f5e100 00000000 00000000 c72ddb64 c72ddbe0 2429ebe8 c72ddcb0 c0c04e08
      [    4.058931] dc40: c72ddcd8 c72ddc7b c72ddcad c7a2e858 ffff8caa c0c2a210 c0c02d00 c04025e0
      [    4.067994] dc60: 00000001 0000000f c00f00c0 2429ebe8 c0c04e08 c04023ac 00a2e858 2429ebe8
      [    4.077054] dc80: 2429ebe8 c7a2e858 c72ddcd8 c0c04e08 0000b6f5 08000000 c0c29e8c c7a2e858
      [    4.086116] dca0: 00000000 c0402b38 c7a2e84c c000000c f5b60013 2429ebe8 c72ddcd4 00000000
      [    4.095175] dcc0: c0c04e08 c7a2e858 00000000 00000000 00000000 c0403574 000002db 00000035
      [    4.104235] dce0: 00000000 00000000 00000800 c0b85800 00000000 00000000 00000800 2429ebe8
      [    4.113298] dd00: c7a2e880 c7a2e880 c72dddcc c72ddd28 c7a2e840 c03ffa80 c72dddcc c72ddd28
      [    4.122358] dd20: c0c2a210 c0c04e08 0000016d 00000035 00000000 00000000 00001000 c0b85000
      [    4.131418] dd40: 00000000 00000000 0000ac00 2429ebe8 00000000 c7b80400 00000000 00000000
      [    4.140479] dd60: c7b80400 00500000 00000000 c0b84c00 c090f8af c03e1cf0 c72dddcc c03e1cbc
      [    4.149538] dd80: c72dddcc 00000000 c7b80400 05674c00 00000000 c03df45c c72dddcc 00000000
      [    4.158597] dda0: 05674c00 00000000 c0c04e08 c72dddcc c72dde30 05674c00 00000000 c03df514
      [    4.167660] ddc0: c72dddcc c0139868 c7838000 00000000 0000b000 00000400 00000000 00000000
      [    4.176720] dde0: 00000000 c0b84c00 00000000 2429ebe8 c7b23000 c7b23000 0000b000 00000159
      [    4.185780] de00: 00034c00 00000004 c0b84c00 c03f7ddc 0000b000 c72dde30 c0b84c00 00000000
      [    4.194840] de20: 05674c00 00000000 c7b23548 c0c04e08 00000005 2429ebe8 00000005 c7b23000
      [    4.203901] de40: 00000000 00000000 00000000 c72dc000 c69a5400 c69a5400 c72dc000 c03f6414
      [    4.212964] de60: 0000b000 80150011 00000005 00000159 00000000 c0b84c00 00000000 0000b000
      [    4.222024] de80: c6a13cd0 0000b000 c6a13cd0 c72dc000 c7b23000 c69a5400 00000000 c03f65b4
      [    4.231085] dea0: 00033c00 0000b000 00000000 c6a13cd8 c7f101e0 c69a5400 00000000 0000b000
      [    4.240144] dec0: c7b23000 00033c00 00000005 c6a13cd0 00000000 c03f509c 00033c00 0000b000
      [    4.249204] dee0: 00000000 2429ebe8 c6a13c00 00000000 c6a13cd0 0000b000 0000b000 c6a13c00
      [    4.258264] df00: c70c2600 00000000 00000000 c03fed20 0000b000 00000000 00000000 c693a600
      [    4.267327] df20: c7ec9980 c6a13cb0 ff7f1300 00000000 00000000 c6a13cb4 00000000 c012f434
      [    4.276388] df40: c693a600 c6a13cb0 c693a600 c693a614 c7ec9980 c72dc000 c7ec9998 c0c02d00
      [    4.285449] df60: c0c0d09c c012fa64 00000000 c7243b00 c72dc000 c693b540 c693a600 c012f830
      [    4.294509] df80: c7873ec4 c7243b1c 00000000 c0134270 c693b540 c0134154 00000000 00000000
      [    4.303569] dfa0: 00000000 00000000 00000000 c01010e8 00000000 00000000 00000000 00000000
      [    4.312631] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
      [    4.321691] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
      [    4.330763] [<c0782ca4>] (do_wait_for_common) from [<c0782d78>] (wait_for_common+0x30/0x48)
      [    4.340020] [<c0782d78>] (wait_for_common) from [<c040ca54>] (sunxi_spi_transfer_one+0x500/0xb84)
      [    4.349854] [<c040ca54>] (sunxi_spi_transfer_one) from [<c0407bc8>] (spi_transfer_one_message+0xd8/0x3e0)
      [    4.360361]
      [    4.360361] insmod_device_driver
      [    4.360361]
      [    4.360460] [<c0407bc8>] (spi_transfer_one_message) from [<c0408104>] (__spi_pump_messages+0x234/0x4c0)
      [    4.367596] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
      [    4.377695] [<c0408104>] (__spi_pump_messages) from [<c04084e4>] (__spi_sync+ 0x148/0x1a0)
      [    4.377703] [<c04084e4>] (__spi_sync) from [<c0408560>] (spi_sync+0x24/0x3c)
      [    4.377711] [<c0408560>] (spi_sync) from [<c040866c>] (spi_write_then_read+0xf4/0x17c)
      [    4.377721] [<c040866c>] (spi_write_then_read) from [<c04025e0>] (aw_spinand_chip_read_reg+0x30/0x50)
      [    4.377731] [<c04025e0>] (aw_spinand_chip_read_reg) from [<c04023ac>] (aw_spinand_chip_wait+0x48/0xd8)
      [    4.377741] [<c04023ac>] (aw_spinand_chip_wait) from [<c0402b38>] (aw_spinand_chip_read_single_page+0x160/0x27c)
      [    4.377751] [<c0402b38>] (aw_spinand_chip_read_single_page) from [<c0403574>](aw_spinand_chip_read_super_page+0x68/0xcc)
      [    4.377764] [<c0403574>] (aw_spinand_chip_read_super_page) from [<c03ffa80>](aw_spinand_read_oob+0x16c/0x1d8)
      [    4.400618] device_chose finished 139!
      [    4.406265] [<c03ffa80>] (aw_spinand_read_oob) from [<c03e1cf0>] (part_read_oob+0x34/0x6c)
      [    4.406276] [<c03e1cf0>] (part_read_oob) from [<c03df45c>] (mtd_read_oob+0x70/0xcc)
      [    4.406285] [<c03df45c>] (mtd_read_oob) from [<c03df514>] (mtd_read+0x5c/0x84)
      [    4.406296] [<c03df514>] (mtd_read) from [<c03f7ddc>] (ubi_io_read+0x124/0x2cc)
      [    4.406309] [<c03f7ddc>] (ubi_io_read) from [<c03f6414>] (ubi_eba_read_leb+0x210/0x2e8)
      [    4.516768] [<c03f6414>] (ubi_eba_read_leb) from [<c03f65b4>] (ubi_eba_read_leb_sg+0xc8/0x134)
      [    4.516783] [<c03f65b4>] (ubi_eba_read_leb_sg) from [<c03f509c>] (ubi_leb_read_sg+0x74/0xb4)
      [    4.535658] [<c03f509c>] (ubi_leb_read_sg) from [<c03fed20>] (ubiblock_do_work+0xf0/0x108)
      [    4.535672] [<c03fed20>] (ubiblock_do_work) from [<c012f434>] (process_one_work+0x144/0x210)
      [    4.554159] [<c012f434>] (process_one_work) from [<c012fa64>] (worker_thread+0x234/0x2d8)
      [    4.563228] [<c012fa64>] (worker_thread) from [<c0134270>] (kthread+0x11c/0x128)
      [    4.563240] [<c0134270>] (kthread) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
      [    4.579413] Exception stack(0xc72ddfb0 to 0xc72ddff8)
      [    4.585006] dfa0:                                     00000000 00000000 00000000 00000000
      [    4.594065] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
      [    4.603123] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000
      [    4.610456] Code: 1affffe6 e59d3010 e59d200c e5823004 (e5832000)
      [    4.617204] ---[ end trace c70083dfb240bf2b ]---
      [    4.622316] note: kworker/1:3[1134] exited with preempt_count 1
        WhycanService LV 8 最后由 编辑
        看报错是 SPI NAND 错误,检查一下 SPI NAND 能不能 -40 启动
        • xiaogcc23333
          xiaogcc23333 LV 4 最后由 编辑
          请问楼主T113 文件系统用的是 squashfs+jffs2 吗?
            linsen LV 7 @WhycanService 最后由 编辑
            @whycanservice 我也怀疑了NAND,NAND用的华邦的,温度也是-40-85。然后重新上电,spl,uboot也没反应,
            xiaogcc23333 1 条回复 最后回复 回复 引用 分享 0
              linsen LV 7 @xiaogcc23333 最后由 编辑
              @xiaogcc23333 squashfs
              • xiaogcc23333
                xiaogcc23333 LV 4 @lansecd 最后由 编辑
                @lansecd 谢谢你的答复,如果只用squashfs,怎么读写文件呢?比如说需要存储日志和配置文件。
                • xiaogcc23333
                  @lansecd 我感觉可以查一下nand芯片规格书,上面会有支持的宽温范围。
                    @xiaogcc23333 计划这样,贴个SD NAND做数据盘
