    tina d1 开机屏上下反
    49
    28204
      chdeng1 LV 5 最后由 编辑
      d1系列 屏幕旋转问题,要求在开机uboot旋转,因为屏幕反了,rgb屏,在触摸校准方面,也是上下反,我把uboot下面文件删除,屏不亮,如下,
      看看哪位专家帮忙看看,感谢
        chdeng1 LV 5 @chdeng1 最后由 编辑
        修改这里,开机前,后都没变化
          WhycanService LV 8 最后由 编辑
          勾选显示驱动的旋转功能
          C 3 条回复 最后回复 回复 引用 分享 0
            chdeng1 LV 5 @WhycanService 最后由 编辑
            @whycanservice 显示驱动勾选, make menuconfig 哪里入口,具体怎样进入?我刚才尝试了,不确定怎样操作
              chdeng1 LV 5 @WhycanService 最后由 whycan 编辑
              @whycanservice
              Symbol: BUSYBOX_CONFIG_FEATURE_ROTATE_LOGFILE [=n]        │
                │ Type  : boolean        │
                │ Prompt: Rotate message files        │
                │   Location:        │
                │     -> Base system        │
                │       -> busybox................................ Core utilities for embedded Linux (PACKAGE_busybox [=y])                  │
                │         -> System Logging Utilities        │
                │ (1)       -> syslogd (BUSYBOX_CONFIG_SYSLOGD [=n])        │
                │   Defined at package/utils/busybox/config/sysklogd/Config.in:82                                                            │
                │   Depends on: PACKAGE_busybox [=y] && BUSYBOX_CUSTOM [=y] && BUSYBOX_CONFIG_SYSLOGD [=n]                                   │
              Symbol: BUSYBOX_DEFAULT_FEATURE_ROTATE_LOGFILE [=y]        │
                │ Type  : boolean        │
                │   Defined at package/utils/busybox/Config-defaults.in:2959        │
                │   Depends on: PACKAGE_busybox [=y] && SYSTEM_INIT_PROCD [=n]
              Symbol: FBM_ROTATE_USED [=]        │
                │ Type  : integer        │
                │ Prompt: FBM numer rotate used        │
                │   Location:        │
                │     -> Allwinner        │
                │       -> libcedarx....................................... libcedarx  for allwinner (PACKAGE_libcedarx [=y])                │
                │         -> Select Cedarx memory options        │
                │ (2)       -> Set FBM number by customer (CUSTOM_FBM_NUM_ENABLE [=n])                                                       │
                │   Defined at package/allwinner/tina_multimedia/Config.in:658                                                               │
                │   Depends on: PACKAGE_libcedarx [=y] && CUSTOM_FBM_NUM_ENABLE [=n]                                                         │
              Symbol: G2D_ROTATE [=n]        │
                │ Type  : boolean        │
                │ Prompt: sunxi g2d rotation support        │
                │   Location:        │
                │     -> Multimedia        │
                │ (3)   -> gstreamer1-plugins-aw.................. GStreamer plugins collection (aw) (PACKAGE_gstreamer1-plugins-aw [=n])    │
                │         -> Select GStreamer aw modules        │
                │           -> GStreamer sunxifbsink module (PACKAGE_gst1-mod-sunxifbsink [=n])                                              │
                │   Defined at tmp/.config-package.in:39345        │
                │   Depends on: PACKAGE_gstreamer1-plugins-aw [=n] && PACKAGE_gst1-mod-sunxifbsink [=n]
              Symbol: LVGL8_USE_SUNXIFB_G2D_ROTATE [=n]        │
                │ Type  : boolean        │
                │ Prompt: lvgl-8.0.1 use sunxifb g2d rotate        │
                │   Location:        │
                │     -> Gui        │
                │ (4)   -> Littlevgl        │
                │   Defined at tmp/.config-package.in:4075        │
                │   Selects: LVGL8_USE_SUNXIFB_G2D [=n]
              Symbol: MINIGUI_G2D_ROTATE_SUPPORT [=n]        │
                │ Type  : boolean        │
                │ Prompt: Enabel g2drotate support for MiniGUI        │
                │   Location:        │
                │     -> Gui        │
                │       -> Minigui        │
                │ (5)     -> libminigui-gpl............................................ libminigui-gpl (PACKAGE_libminigui-gpl [=n])         │
                │   Defined at package/gui/minigui/libminigui-gpl/Config.in:33                                                               │
                │   Depends on: PACKAGE_libminigui-gpl [=n]        │
                │   Selects: MINIGUI_G2D_SUPPORT [=n]
              Symbol: MINIGUI_GPU_ROTATE_SUPPORT [=n]        │
                │ Type  : boolean        │
                │ Prompt: Enabel gpurotate support for MiniGUI        │
                │   Location:        │
                │     -> Gui        │
                │       -> Minigui        │
                │ (6)     -> libminigui-gpl............................................ libminigui-gpl (PACKAGE_libminigui-gpl [=n])         │
                │   Defined at package/gui/minigui/libminigui-gpl/Config.in:44                                                               │
                │   Selects: MINIGUI_GPU_SUPPORT [=n]        │
              Symbol: PACKAGE_logrotate [=n]        │
                │ Type  : tristate        │
                │ Prompt: logrotate..................... rotates, compresses, and mails system logs                                          │
                │   Location:        │
                │ (7) -> Utilities        │
                │   Defined at tmp/.config-package.in:52527        │
                │   Selects: PACKAGE_libpopt [=n] && PACKAGE_libpthread [=y] && PACKAGE_librt [=y] && PACKAGE_libssp [=y] && PACKAGE_libc [= │
              Symbol: TEXT_ROTATE_SUPPORT [=n]        │
                │ Type  : boolean        │
                │ Prompt: Enabel text rotate support for MiniGUI        │
                │   Location:        │
                │     -> Gui        │
                │       -> Minigui        │
                │ (8)     -> libminigui-gpl............................................ libminigui-gpl (PACKAGE_libminigui-gpl [=n])         │
                │   Defined at package/gui/minigui/libminigui-gpl/Config.in:60                                                               │
                @whycanservice
                屏资料
                驱动是default_pannel.c
                whycan 2 条回复 最后回复 回复 引用 分享 0
                  whycan晕哥 LV 9 @chdeng1 最后由 whycan 编辑
                  @chdeng1
                  是 AT070TN83 吗 ?
                  如果是的话,调整显示屏的39、40两个引脚电平即可。
                  C 6 条回复 最后回复 回复 引用 分享 0
                    chdeng1 LV 5 @whycan 最后由 编辑
                    @whycan ,您说调整两个脚的电平,关键是我烧写客户给的img,显示没有反,
                      @whycan 在 tina d1 开机屏上下反 中说:
                      AT070TN83
                      是这个屏,AT070TN83 ,您说调整两个脚的电平是修改软件还是硬件?我不明白您意思
                        @whycan ,调整电平,我明白您意思了,谢谢
                          @whycan 想请教下 39 40 两个脚是和tp相关,调整后会对屏有影响?
                            @whycan ,您好,这两个脚对应芯片如下,
                            e4db8a99-47a2-467e-b1a1-496f4f2456e7-image.png 代码修改是在哪里?需要调整两个脚的电平
                              @whycan ,在哪里修改两个脚电平?
                              whycan A 2 条回复 最后回复 回复 引用 分享 0
                                whycan晕哥 LV 9 @chdeng1 最后由 编辑
                                @chdeng1
                                我发现我猜的那个资料不对, 你自己把显示屏资料发上来吧.
                                C 2 条回复 最后回复 回复 引用 分享 0
                                  anruliu LV 6 @chdeng1 最后由 编辑
                                  @chdeng1 可以拍照看下是怎么相反的,如果只是需要旋转屏幕的功能,可以在应用层旋转。
                                  RGB的LCD一般是通过default_pannel.c点亮,去掉当然不行了。一般uboot和kernel显示开机log,可以自己把开机log旋转后再打包放进去,应用层的旋转一般是用UI框架来旋转。如果是用lvgl,那么就可以选上LVGL8_USE_SUNXIFB_G2D_ROTATE 这个配置,应用初始化的时候调用sunxifb_init(rotated),rotated就是要旋转的角度
                                  C whycan 3 条回复 最后回复 回复 引用 分享 0
                                    chdeng1 LV 5 @anruliu 最后由 编辑
                                    @anruliu 感谢,我现在也是这个思路,不过我现在请假回家了,晚些时候验证,非常感谢,验证时有问题再请教您,感谢
                                      @anruliu 我有个疑问,用tslib校准时,这个也是上下反的,代码工程,make menuconfig 打开 tslib 发现也是反的,上下反,回到公司再拍照您看,谢谢
                                        @chdeng1 tslib 这个怎样旋转?这个我不知道
                                          @chdeng1 tslib印象中不带旋转功能,你想要tp旋转,有几种方式。
                                          1、tp驱动自己旋转,如drivers/input/touchscreen/gt9xxnew/gt9xx.c中revert_x_flag,revert_y_flag,exchange_x_y_flag
                                          2、使用ui框架中的tp旋转,如果用的是lvgl,那么设置disp_drv.rotated = rotated;后,lvgl会自动旋转tp坐标
                                          C 4 条回复 最后回复 回复 引用 分享 0
                                            @anruliu 感谢,明白了,谢谢
                                              @anruliu 使用ui框架中的tp旋转 这个具体在哪个文件修改?
                                                @chdeng1 看你用的什么UI框架
                                                • Moved from 其它全志芯片讨论区 by  q1215200171 q1215200171
                                                  @anruliu 就是tina-d1s系统原始代码,开机就反,没跑lvgl,这个怎样修改?
                                                    @anruliu tina 系统代码,没用lvgl,开机就是上下反,执行tslib校准界面也是反的
                                                      @anruliu
                                                      我打开 make menuconfig
                                                      结果如下图
                                                      原来为0 现在修改为1,开机卡死
                                                      串口log定在 starting kerner 。。。。
                                                        @anruliu ,上述修改会卡死,log如下
                                                          @anruliu
                                                          上下反如下
                                                            @anruliu
                                                            上下反
                                                              @whycan 传屏资料AT070TN94(1).pdf
                                                              麻烦帮忙看看,谢谢,应该是修改两个脚电平,具体修改哪里
        @whycan AT070TN94(1).pdf
        @chdeng1
        先搞清楚你的屏到底是50个腿还是40个腿,我想没有人比你更清楚了。
        如果确定是 AT070TN94,那就是调整 39、40这两个腿的电平:
        @whycan 39 40这两个腿电平在哪里调整,在sunxi-ts.c?还是哪个文件,tp和屏都确认了的,型号没错,
        @whycan 我的屏是50脚的,不是40脚
        @whycan 再请教下,39 40 做屏反转,是不是同时也是控制tp?
        @chdeng1
        要么拉低,要么拉低,就四种组合。
        @whycan
        是不是做gpio控制拉低?
        @chdeng1
        一步一步来,先直接用电阻控制吧。
        @whycan 感谢,
        我看芯片原理图,
        0e36de72-0a65-4659-8aeb-79deca81fb6e-image.png 这几个脚没有介绍做gpio具体哪个脚,有写做i/o,整个芯片手册没写做具体哪个脚
        @whycan
        @whycan ,应该是这4个脚,这个没说可以做gpio呀,该怎样控制呢
        @chdeng1
        这个原理图,有点稀里糊涂。
        显示屏的39/40 接10K电阻 拉高或者拉低
        这几个脚是做输入的,直接连tp,怎样拉低?
        @chdeng1
        这几个脚不是GPIO,你用电阻吧。
        @whycan
        现在我调试的机器,烧写客户的img,是完全正常的,应该不会需要改电阻
        @chdeng1
        所以说你的原理图和屏资料对不上,你自己先捋一捋吧。
        @whycan 硬件上确实是让屏幕反的接法,现在想软件让屏旋转过来,我们机器不修改电阻,这块的思路,还请帮忙,这块会有难度吗?
        whycan晕哥 LV 9 @anruliu 最后由 编辑
        @anruliu 在 tina d1 开机屏上下反 中说:
        @chdeng1
        sunxifb_init
        发现sunxifb_init lvgl 调用,其他地方都没调用,开机log我可以换图片logo旋转,但是tslib 校准界面这个怎样旋转呢
        @whycan
        sunxifb_init(rotated) 这个函数定义在lvgl,开机校准这个界面不能用这个函数,还是没法旋转这个校准界面,
