    f1c200s LCD错误 Err01: Violate "lcd_hbp > lcd_hspw"
    • Q
      feelsigh LV 5 最后由 编辑
      [ 0.000000] Booting Linux on physical CPU 0x0
      [ 0.000000] Initializing cgroup subsys cpuset
      [ 0.000000] Initializing cgroup subsys cpuacct
      [ 0.000000] Linux version 3.10.65 (cq@cq) (gcc version 6.4.1 (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) ) #33 Fri Nov 18 13:05:52 UTC 2022
      [ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
      [ 0.000000] CPU: VIVT data cache, VIVT instruction cache
      [ 0.000000] Machine: Allwinner A1X (Device Tree), model: sun3iw1p1
      [ 0.000000] bootconsole [earlycon0] enabled
      [ 0.000000] cma: CMA: failed to reserve 32 MiB
      [ 0.000000] Memory policy: ECC disabled, Data cache writeback
      [ 0.000000] On node 0 totalpages: 8192
      [ 0.000000] free_area_init_node: node 0, pgdat c055d36c, node_mem_map c058b000
      [ 0.000000] Normal zone: 64 pages used for memmap
      [ 0.000000] Normal zone: 0 pages reserved
      [ 0.000000] Normal zone: 8192 pages, LIFO batch:0
      [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
      [ 0.000000] pcpu-alloc: [0] 0
      [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
      [ 0.000000] Kernel command line: enforcing=1 earlyprintk=sunxi-uart,0x01c25000 initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mtdblock4 init=/pseudo_init rdinit=/rdinit partitions=bootlogo@mtdblock1:env@mtdblock2:boot@mtdblock3:rootfs@mtdblock4:rootfs_data@mtdblock5:misc@mtdblock6:private@mtdblock7:UDISK@mtdblock8 cma=32M fb_base=0x81f00000 androidboot.serialno=<NULL> boot_type=3
      [ 0.000000] PID hash table entries: 128 (order: -3, 512 bytes)
      [ 0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
      [ 0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
      [ 0.000000] Memory: 32MB = 32MB total
      [ 0.000000] Memory: 26656k/26656k available, 6112k reserved, 0K highmem
      [ 0.000000] Virtual kernel memory layout:
      [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
      [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
      [ 0.000000] vmalloc : 0xc2800000 - 0xff000000 ( 968 MB)
      [ 0.000000] lowmem : 0xc0000000 - 0xc2000000 ( 32 MB)
      [ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
      [ 0.000000] .text : 0xc0008000 - 0xc0453f84 (4400 kB)
      [ 0.000000] .init : 0xc0454000 - 0xc0472390 ( 121 kB)
      [ 0.000000] .data : 0xc0474000 - 0xc055dc88 ( 936 kB)
      [ 0.000000] .bss : 0xc055dc88 - 0xc058aba0 ( 180 kB)
      [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
      [ 0.000000] NR_IRQS:256
      [ 0.000000] of_sunxi_clocks_init : sunxi_clk_base[0xf1c20000]
      [ 0.000000] pll_cpu-set_default_rate=552000000 success!
      [ 0.000000] pll_video-set_default_rate=297000000 success!
      [ 0.000000] pll_ddr-set_default_rate=312000000 success!
      [ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
      [ 0.000000] Console: colour dummy device 80x30
      [ 0.005328] Calibrating delay loop... 275.25 BogoMIPS (lpj=1376256)
      [ 0.075252] pid_max: default: 32768 minimum: 301
      [ 0.080430] Mount-cache hash table entries: 512
      [ 0.086412] CPU: Testing write buffer coherency: ok
      [ 0.092201] Setting up static identity map for 0xc0350938 - 0xc0350990
      [ 0.101472] devtmpfs: initialized
      [ 0.107009] pinctrl core: initialized pinctrl subsystem
      [ 0.112862] NET: Registered protocol family 16
      [ 0.118049] DMA: failed to allocate 256 KiB pool for atomic coherent allocation
      [ 0.126087] dump_class_init,844, success
      [ 0.134952] sun3iw1p1-pinctrl pio: initialized sunXi PIO driver
      [ 0.160666] bio: create slab <bio-0> at 0
      [ 0.166174] pwm module init!
      [ 0.170971] SCSI subsystem initialized
      [ 0.175297] usbcore: registered new interface driver usbfs
      [ 0.181095] usbcore: registered new interface driver hub
      [ 0.186986] usbcore: registered new device driver usb
      [ 0.194568] gpio=0,mul_sel=0,pull=0,drv_level=0,data=0
      [ 0.200039] twi_start()387 - [i2c0] START can't sendout!
      [ 0.205837] twi_start()387 - [i2c0] START can't sendout!
      [ 0.211543] twi_start()387 - [i2c0] START can't sendout!
      [ 0.217166] pcf857x 0-0020: retry commucation.7
      [ 0.221984] twi_start()387 - [i2c0] START can't sendout!
      [ 0.227715] twi_start()387 - [i2c0] START can't sendout!
      [ 0.233436] twi_start()387 - [i2c0] START can't sendout!
      [ 0.239026] pcf857x 0-0020: retry commucation.6
      [ 0.243860] twi_start()387 - [i2c0] START can't sendout!
      [ 0.249562] twi_start()387 - [i2c0] START can't sendout!
      [ 0.255282] twi_start()387 - [i2c0] START can't sendout!
      [ 0.260869] pcf857x 0-0020: retry commucation.5
      [ 0.265703] twi_start()387 - [i2c0] START can't sendout!
      [ 0.271405] twi_start()387 - [i2c0] START can't sendout!
      [ 0.277125] twi_start()387 - [i2c0] START can't sendout!
      [ 0.282729] pcf857x 0-0020: retry commucation.4
      [ 0.287541] twi_start()387 - [i2c0] START can't sendout!
      [ 0.293262] twi_start()387 - [i2c0] START can't sendout!
      [ 0.298964] twi_start()387 - [i2c0] START can't sendout!
      [ 0.304567] pcf857x 0-0020: retry commucation.3
      [ 0.309380] twi_start()387 - [i2c0] START can't sendout!
      [ 0.315101] twi_start()387 - [i2c0] START can't sendout!
      [ 0.320802] twi_start()387 - [i2c0] START can't sendout!
      [ 0.326406] pcf857x 0-0020: retry commucation.2
      [ 0.331219] twi_start()387 - [i2c0] START can't sendout!
      [ 0.336942] twi_start()387 - [i2c0] START can't sendout!
      [ 0.342662] twi_start()387 - [i2c0] START can't sendout!
      [ 0.348249] pcf857x 0-0020: retry commucation.1
      [ 0.353080] twi_start()387 - [i2c0] START can't sendout!
      [ 0.358782] twi_start()387 - [i2c0] START can't sendout!
      [ 0.364500] twi_start()387 - [i2c0] START can't sendout!
      [ 0.370117] pcf857x: probe of 0-0020 failed with error -121
      [ 0.379799] Linux video capture interface: v2.00
      [ 0.385201] Advanced Linux Sound Architecture Driver Initialized.
      [ 0.393397] cfg80211: Calling CRDA to update world regulatory domain
      [ 0.400818] Switching to clocksource sun3i high-res couter
      [ 0.425986] get det_vbus is fail, 84
      [ 0.431475] NET: Registered protocol family 2
      [ 0.438146] TCP established hash table entries: 512 (order: 0, 4096 bytes)
      [ 0.445258] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
      [ 0.451920] TCP: Hash tables configured (established 512 bind 512)
      [ 0.458476] TCP: reno registered
      [ 0.461874] UDP hash table entries: 256 (order: 0, 4096 bytes)
      [ 0.467989] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
      [ 0.475074] NET: Registered protocol family 1
      [ 0.493134] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [ 0.499830] jffs2: version 2.2. © 2001-2006 Red Hat, Inc.
      [ 0.506270] msgmni has been set to 52
      [ 0.513372] io scheduler noop registered
      [ 0.517665] io scheduler cfq registered (default)
      [ 0.522539] [pm]aw_pm_init!
      [ 0.525812] [pm]valid
      [ 0.528305] [pm]valid
      [ 0.531050] [DISP]disp_module_init
      [ 0.586703] pll_freq=297000000HZ, lcd_dclk_freq=29000000HZ, clk_div=10
      [ 0.594086] *******************************
      [ 0.598511] ***
      [ 0.600385] *** LCD Panel Parameter Check
      [ 0.604541] ***
      [ 0.606407] *** by guozhenjie
      [ 0.610601] ***
      [ 0.612471] ********************************
      [ 0.616922] ***
      [ 0.618790] *** Interface:
      [ 0.621361] *** Parallel HV Panel
      [ 0.625086] *** Lcd Frm to RGB666
      [ 0.628579] ***
      [ 0.630448] *** Timing:
      [ 0.633022] *** lcd_x: 800
      [ 0.636298] *** lcd_y: 480
      [ 0.639607] *** lcd_ht: 1056
      [ 0.642972] *** lcd_hbp: 16
      [ 0.646160] *** lcd_vt: 525
      [ 0.649465] *** lcd_vbp: 10
      [ 0.652654] *** lcd_hspw: 30
      [ 0.655842] *** lcd_vspw: 13
      [ 0.659058] *** lcd_frame_frq: 52Hz
      [ 0.662773] ***
      [ 0.664640] *** Err01: Violate "lcd_hbp > lcd_hspw"
      [ 0.669702] *** Err02: Violate "lcd_vbp > lcd_vspw"
      [ 0.674738] ***
      [ 2.675139] *** Try new parameters,you can make it pass!
      [ 2.680648] *** LCD Panel Parameter Check End
      [ 2.685158] *******************************
      [ 2.689638] num_screens=1
      [ 2.692398] screen_id=0
      [ 2.694973] para->mclk[MOD_CLK_LCD1CH0]=0xc180c300
      [ 2.699990] para->mclk[MOD_CLK_LCD1CH1]=0xc180c400
      [ 2.704943] disp tv init
      [ 2.707652] tcon_clk=0xc180c300, tcon_clk_parent=0x0
      [ 2.712784] tcon_clk=0xc180c300, tcon_clk_parent=0xc18043c0
      [ 2.718565] tve_clk=0xc180c400, tve_clk_parent=0xc18043c0
      [ 2.724132] disp al tv init
      [ 2.729858] fetch script datadisp.screen2_output_type fail
      [ 2.735835] fetch script datadisp.screen2_output_mode fail
      [ 2.744240] fetch script datadisp.fb2_format fail
      [ 2.749508] fetch script datadisp.fb2_scaler_mode_enable fail
      [ 2.755744] fetch script datadisp.fb2_width fail
      [ 2.760910] fetch script datadisp.fb2_height fail
      [ 2.765812] disp_malloc fail, size=0x2ee000
      [ 2.770216] disp_malloc fail!
      [ 2.773652] Unable to handle kernel paging request at virtual address 0005dfc0
      [ 2.781211] pgd = c0004000
      [ 2.784058] [0005dfc0] *pgd=00000000
      [ 2.787858] Internal error: Oops: 805 [#1] ARM
      [ 2.792460] Modules linked in:
      [ 2.795672] CPU: 0 PID: 1 Comm: swapper Not tainted 3.10.65 #33
      [ 2.801778] task: c1832000 ti: c1834000 task.ti: c1834000
      [ 2.807371] PC is at memcpy+0x244/0x330
      [ 2.811359] LR is at 0xadc8ff9e
      [ 2.814648] pc : [<c0125564>] lr : [<adc8ff9e>] psr: 20000013
      [ 2.814648] sp : c1835c40 ip : ff9eaec8 fp : c1835d7c
      [ 2.826473] r10: 000000ef r9 : ff9dacc8 r8 : ff99a8c7
      [ 2.831868] r7 : ff97a6c6 r6 : ff96a5c7 r5 : ff94a2c4 r4 : ff93a2c4
      [ 2.838583] r3 : ff9ca7c2 r2 : 00000460 r1 : c2854b58 r0 : 0005dfc0
      [ 2.845300] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
      [ 2.852807] Control: 0005317f Table: 80004000 DAC: 00000017
