    t113-S3的wifi驱动问题,RTL8723DU
    6126
    • how0723
      how0723 LV 5 最后由 whycan 编辑
      由RTL8723BU换成RTL8723DU,就驱动不起来
        4.978620] rtk_btusb: Realtek Bluetooth USB driver ver 3.1.981c756.20211102-175222
      [    5.022481] rtk_btusb: btusb_probe intf->cur_altsetting->desc.bInterfaceNumber 0
      [    5.030838] rtk_btusb: btusb_probe can_wakeup 1, may wakeup 0
      [    5.037302] rtk_btusb: patch_add
      [    5.040933] rtk_btusb: auto suspend is disabled
      [    5.046015] rtk_btusb: pid = 0xd723
      [    5.049973] rtk_btusb: patch_add: Reset gEVersion to 0xff
      [    5.056060] rtk_btusb: set_bit(HCI_QUIRK_RESET_ON_CLOSE, &hdev->quirks);
      [    5.068458] rtk_btusb: btusb_probe: done
      [    5.072425] rtk_btusb: btusb_open start
      [    5.073136] usbcore: registered new interface driver rtk_btusb
      [    5.077168] rtk_btusb: btusb_open hdev->promisc ==0
      [    5.099514] rtk_btusb: download_patch start
      [    5.104220] rtk_btusb: chip type value: 0x71
      [    5.115795] rtk_btusb: HCI reset.
      [    5.169212] rtk_btusb: read_ver_rsp->lmp_subver = 0x8723
      [    5.175177] rtk_btusb: read_ver_rsp->hci_rev = 0xd
      [    5.175181] rtk_btusb: patch_entry->lmp_sub = 0x8723
      [    5.175184] rtk_btusb: load_firmware start
      [    5.175188] rtk_btusb: lmp_version = 0x8723
      [    5.175191] rtk_btusb: config filename rtl8723du_config
      [    5.175412] usb 1-1.1: Direct firmware load for rtl8723du_config failed with error -2
      [    5.175424] rtk_btusb: fw name is  rtl8723du_fw
      [    5.179453] usb 1-1.1: Direct firmware load for rtl8723du_fw failed with error -2
      [    5.219000] rtk_btusb: load firmware failed!
      [    5.232288] rtk_btusb: Rtk patch end -1
      [    5.257784] rtk_btusb: btusb_open failed
        whycan晕哥 LV 9 @how0723 最后由 编辑
        @how0723
        看起来是缺这几个文件:
        https://github.com/edision-open/LINUX_BT_DRIVER_RTL8723D/tree/master/rtkbt-firmware/lib/firmware
        how0723 2 条回复 最后回复 回复 引用 分享 0
        • how0723
          how0723 LV 5 @whycan 最后由 编辑
          @whycan 怎么使用
          • how0723
            @whycan
            系统中有个文件
            whycan how0723 2 条回复 最后回复 回复 引用 分享 0
              @how0723
              应该是复制到文件系统的 /lib/firmware/ 这个目录下面。
              • how0723
                how0723 LV 5 @how0723 最后由 编辑
                @how0723 @whycan
