    SDK TINA-D1-H 勾选systemd报错,请问怎么配置
    • G
      GONGWEIJIE LV 3 最后由 编辑
      勾选后make
      [2] 13169
      ./scripts/Makefile.asm-generic:25: redundant generic-y found in arch/riscv/include/asm/Kbuild: device.h
      In file included from ./include/linux/kernel.h:11,
                       from ./include/linux/skbuff.h:13,
                       from ./include/linux/if_ether.h:19,
                       from ./drivers/net/wireless/xr829/include/linux/ieee80211.h:19,
                       from drivers/net/wireless/xr829/umac/ht.c:16:
      drivers/net/wireless/xr829/umac/ht.c: In function 'mac80211_send_smps_action':
      ./include/linux/compiler.h:78:22: warning: this statement may fall through [-Wimplicit-fallthrough=]
       # define unlikely(x) __builtin_expect(!!(x), 0)
      ./include/asm-generic/bug.h:116:2: note: in expansion of macro 'unlikely'
        unlikely(__ret_warn_on);     \
      drivers/net/wireless/xr829/umac/ht.c:272:3: note: in expansion of macro 'WARN_ON'
         WARN_ON(1);
      drivers/net/wireless/xr829/umac/ht.c:273:2: note: here
        case IEEE80211_SMPS_OFF:
                       from ./include/linux/delay.h:22,
                       from drivers/net/wireless/xr829/umac/work.c:16:
      drivers/net/wireless/xr829/umac/work.c: In function 'ieee80211_add_ht_ie':
      drivers/net/wireless/xr829/umac/work.c:156:3: note: in expansion of macro 'WARN_ON'
         WARN_ON(1);
      drivers/net/wireless/xr829/umac/work.c:157:2: note: here
      drivers/net/wireless/xr829/umac/cfg.c: In function 'ieee80211_scan':
      drivers/net/wireless/xr829/umac/cfg.c:1965:6: warning: this statement may fall through [-Wimplicit-fallthrough=]
         if (sdata->local->ops->hw_scan)
      drivers/net/wireless/xr829/umac/cfg.c:1972:2: note: here
        case NL80211_IFTYPE_AP:
      drivers/net/wireless/xr829/umac/tx.c: In function 'ieee80211_tx_h_select_key':
      drivers/net/wireless/xr829/umac/tx.c:596:7: warning: this statement may fall through [-Wimplicit-fallthrough=]
          if (ieee80211_is_auth(hdr->frame_control))
      drivers/net/wireless/xr829/umac/tx.c:598:3: note: here
         case WLAN_CIPHER_SUITE_TKIP:
      drivers/net/wireless/xr829/umac/wme.c: In function 'mac80211_select_queue':
      drivers/net/wireless/xr829/umac/wme.c:74:6: warning: this statement may fall through [-Wimplicit-fallthrough=]
         if (sta) {
      drivers/net/wireless/xr829/umac/wme.c:78:2: note: here
      cp: cannot stat '/home/allwinner/tina-2/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/sysroot//./riscv64-unknown-linux-gnu/lib64xthead/lp64d/libgomp.so*': No such file or directory
      cp: cannot stat '/home/allwinner/tina-2/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/sysroot//./usr/lib64xthead/lp64d/libssp.so.*': No such file or directory
      make[3]: [/home/allwinner/tina-2/out/d1-h-nezha/compile_dir/target/linux-d1-h-nezha/iptables-1.4.21/.configured_yyy_ab06bf2b3e81dec99f57886236317abc] Error 123 (ignored)
      autoreconf: Entering directory `.'
      autoreconf: configure.ac: not using Gettext
      autoreconf: running: /home/allwinner/tina-2/out/host/bin/aclocal -I /home/allwinner/tina-2/out/d1-h-nezha/staging_dir/target/host/share/aclocal -I /home/allwinner/tina-2/out/d1-h-nezha/staging_dir/target/usr/share/aclocal -I m4 -I . --force -I m4
      autoreconf: configure.ac: tracing
      autoreconf: running: /home/allwinner/tina-2/out/host/bin/libtoolize --force
      autoreconf: running: /home/allwinner/tina-2/out/host/bin/autoconf --include=/home/allwinner/tina-2/out/d1-h-nezha/staging_dir/target/host/share/aclocal --include=/home/allwinner/tina-2/out/d1-h-nezha/staging_dir/target/usr/share/aclocal --include=m4 --include=. --prepend-include=/home/allwinner/tina-2/out/host/share/aclocal --force
      autoreconf: running: /home/allwinner/tina-2/out/host/bin/autoheader --include=/home/allwinner/tina-2/out/d1-h-nezha/staging_dir/target/host/share/aclocal --include=/home/allwinner/tina-2/out/d1-h-nezha/staging_dir/target/usr/share/aclocal --include=m4 --include=. --prepend-include=/home/allwinner/tina-2/out/host/share/aclocal --force
      autoreconf: running: /home/allwinner/tina-2/out/host/bin/automake --add-missing --force-missing
      autoreconf: Leaving directory `.'
      configure: WARNING: you should use --build, --host, --target
      configure: WARNING: unrecognized options: --disable-nls
      configure: WARNING: using cross tools not prefixed with host triplet
      In file included from libiptc.c:40,
                       from libip4tc.c:113:
      libiptc.c: In function 'iptcc_chain_index_build':
      linux_list.h:381:59: warning: right-hand operand of comma expression has no effect [-Wunused-value]
        for (pos = list_entry((head)->next, typeof(*pos), member), \
      libiptc.c:552:2: note: in expansion of macro 'list_for_each_entry'
        list_for_each_entry(c, &h->chains, list) {
      linux_list.h:384:63: warning: right-hand operand of comma expression has no effect [-Wunused-value]
             pos = list_entry(pos->member.next, typeof(*pos), member), \
      libiptc.c: In function 'iptcc_get_rule_num':
      libiptc.c:655:2: note: in expansion of macro 'list_for_each_entry'
        list_for_each_entry(r, &c->rules, list) {
      libiptc.c: In function 'iptcc_get_rule_num_reverse':
      linux_list.h:394:59: warning: right-hand operand of comma expression has no effect [-Wunused-value]
        for (pos = list_entry((head)->prev, typeof(*pos), member), \
      libiptc.c:670:2: note: in expansion of macro 'list_for_each_entry_reverse'
        list_for_each_entry_reverse(r, &c->rules, list) {
      linux_list.h:397:63: warning: right-hand operand of comma expression has no effect [-Wunused-value]
             pos = list_entry(pos->member.prev, typeof(*pos), member), \
      libiptc.c: In function 'iptcc_find_chain_by_offset':
      linux_list.h:339:25: warning: right-hand operand of comma expression has no effect [-Wunused-value]
        for (pos = (head)->next, prefetch(pos->next); pos != (head); \
      libiptc.c:698:2: note: in expansion of macro 'list_for_each'
        list_for_each(pos, list_start_pos->prev) {
      linux_list.h:340:25: warning: right-hand operand of comma expression has no effect [-Wunused-value]
                pos = pos->next, prefetch(pos->next))
      libiptc.c: In function 'iptcc_find_label':
      libiptc.c:723:2: note: in expansion of macro 'list_for_each'
        list_for_each(pos, &handle->chains) {
      libiptc.c:763:2: note: in expansion of macro 'list_for_each'
      libiptc.c: In function 'iptc_insert_chain':
      libiptc.c:866:3: note: in expansion of macro 'list_for_each_entry'
         list_for_each_entry(tmp, list_start_pos->prev, list) {
      libiptc.c: In function 'parse_table':
      libiptc.c:1060:2: note: in expansion of macro 'list_for_each_entry'
      libiptc.c:1062:3: note: in expansion of macro 'list_for_each_entry'
      libiptc.c: In function 'iptcc_compile_chain':
      libiptc.c:1159:2: note: in expansion of macro 'list_for_each_entry'
      libiptc.c: In function 'iptcc_compile_chain_offsets':
      libiptc.c:1199:2: note: in expansion of macro 'list_for_each_entry'
      libiptc.c: In function 'iptcc_compile_table_prep':
      libiptc.c:1226:2: note: in expansion of macro 'list_for_each_entry'
      libiptc.c: In function 'iptcc_compile_table':
      libiptc.c:1248:2: note: in expansion of macro 'list_for_each_entry'
      libiptc.c: In function 'delete_entry':
      libiptc.c:1993:2: note: in expansion of macro 'list_for_each_entry'
        list_for_each_entry(i, &c->rules, list) {
      libiptc.c: In function 'iptc_zero_entries':
      libiptc.c:2131:2: note: in expansion of macro 'list_for_each_entry'
      libiptc.c: In function 'iptc_commit':
      libiptc.c:2608:2: note: in expansion of macro 'list_for_each_entry'
        list_for_each_entry(c, &handle->chains, list) {
      libiptc.c:2636:3: note: in expansion of macro 'list_for_each_entry'
                       from libip6tc.c:111:
      libiptc.c: In function 'ip6tc_zero_entries':
      libiptc.c: In function 'ip6tc_commit':
      xtables.c:304:14: warning: 'get_modprobe' defined but not used [-Wunused-function]
       static char *get_modprobe(void)
      libxt_conntrack.c:1092:13: warning: 'state_ct1_parse' defined but not used [-Wunused-function]
       static void state_ct1_parse(struct xt_option_call *cb)
      libxt_conntrack.c:1082:13: warning: 'state_parse' defined but not used [-Wunused-function]
       static void state_parse(struct xt_option_call *cb)
      libxt_conntrack.c:1012:1: warning: 'conntrack1_mt6_save' defined but not used [-Wunused-function]
       conntrack1_mt6_save(const void *ip, const struct xt_entry_match *match)
      libxt_conntrack.c:1002:1: warning: 'conntrack1_mt4_save' defined but not used [-Wunused-function]
       conntrack1_mt4_save(const void *ip, const struct xt_entry_match *match)
      libxt_conntrack.c:995:13: warning: 'conntrack2_mt6_save' defined but not used [-Wunused-function]
       static void conntrack2_mt6_save(const void *ip,
      libxt_conntrack.c:989:13: warning: 'conntrack2_mt_save' defined but not used [-Wunused-function]
       static void conntrack2_mt_save(const void *ip,
      libxt_conntrack.c:972:13: warning: 'conntrack_save' defined but not used [-Wunused-function]
       static void conntrack_save(const void *ip, const struct xt_entry_match *match)
      libxt_conntrack.c:952:1: warning: 'conntrack2_mt6_print' defined but not used [-Wunused-function]
       conntrack2_mt6_print(const void *ip, const struct xt_entry_match *match,
      libxt_conntrack.c:945:1: warning: 'conntrack2_mt_print' defined but not used [-Wunused-function]
       conntrack2_mt_print(const void *ip, const struct xt_entry_match *match,
      libxt_conntrack.c:934:1: warning: 'conntrack1_mt6_print' defined but not used [-Wunused-function]
       conntrack1_mt6_print(const void *ip, const struct xt_entry_match *match,
      libxt_conntrack.c:923:1: warning: 'conntrack1_mt4_print' defined but not used [-Wunused-function]
       conntrack1_mt4_print(const void *ip, const struct xt_entry_match *match,
      libxt_conntrack.c:916:13: warning: 'conntrack_print' defined but not used [-Wunused-function]
       static void conntrack_print(const void *ip, const struct xt_entry_match *match,
      libxt_conntrack.c:538:13: warning: 'conntrack2_mt_parse' defined but not used [-Wunused-function]
       static void conntrack2_mt_parse(struct xt_option_call *cb)
      libxt_conntrack.c:515:13: warning: 'conntrack1_mt_parse' defined but not used [-Wunused-function]
       static void conntrack1_mt_parse(struct xt_option_call *cb)
      libxt_conntrack.c:337:13: warning: 'conntrack_parse' defined but not used [-Wunused-function]
       static void conntrack_parse(struct xt_option_call *cb)
      libxt_conntrack.c:119:37: warning: 'conntrack2_mt_opts' defined but not used [-Wunused-const-variable=]
       static const struct xt_option_entry conntrack2_mt_opts[] = {
      libxt_conntrack.c:96:37: warning: 'conntrack_mt_opts_v0' defined but not used [-Wunused-const-variable=]
       static const struct xt_option_entry conntrack_mt_opts_v0[] = {
      libxt_id.c: In function 'id_print':
      libxt_id.c:27:18: warning: format '%lx' expects argument of type 'long unsigned int', but argument 2 has type '__u32' {aka 'unsigned int'} [-Wformat=]
        printf(" ID:%08lx", idinfo->id);
                    %08x
      libxt_id.c: In function 'id_save':
      libxt_id.c:37:20: warning: format '%lx' expects argument of type 'long unsigned int', but argument 2 has type '__u32' {aka 'unsigned int'} [-Wformat=]
        printf(" --id 0x%lx", idinfo->id);
                        %x
      In file included from /home/allwinner/tina-2/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/sysroot/usr/include/bits/libc-header-start.h:33,
                       from /home/allwinner/tina-2/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/sysroot/usr/include/math.h:27,
                       from libxt_limit.c:8:
      /home/allwinner/tina-2/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/sysroot/usr/include/features.h:185:3: warning: #warning "_BSD_SOURCE and _SVID_SOURCE are deprecated, use _DEFAULT_SOURCE" [-Wcpp]
       # warning "_BSD_SOURCE and _SVID_SOURCE are deprecated, use _DEFAULT_SOURCE"
      libxt_multiport.c:416:13: warning: 'multiport_save6' defined but not used [-Wunused-function]
       static void multiport_save6(const void *ip_void,
      libxt_multiport.c:409:13: warning: 'multiport_save' defined but not used [-Wunused-function]
       static void multiport_save(const void *ip_void,
      libxt_multiport.c:321:13: warning: 'multiport_print6' defined but not used [-Wunused-function]
       static void multiport_print6(const void *ip_void,
      libxt_multiport.c:314:13: warning: 'multiport_print' defined but not used [-Wunused-function]
       static void multiport_print(const void *ip_void,
      libxt_multiport.c:203:13: warning: 'multiport_parse6' defined but not used [-Wunused-function]
       static void multiport_parse6(struct xt_option_call *cb)
      libxt_multiport.c:196:13: warning: 'multiport_parse' defined but not used [-Wunused-function]
       static void multiport_parse(struct xt_option_call *cb)
      libxt_multiport.c:22:13: warning: 'multiport_help' defined but not used [-Wunused-function]
       static void multiport_help(void)
      libxt_CT.c:285:13: warning: 'notrack_ct2_tg_init' defined but not used [-Wunused-function]
       static void notrack_ct2_tg_init(struct xt_entry_target *target)
      libxt_CT.c:278:13: warning: 'notrack_ct1_tg_init' defined but not used [-Wunused-function]
       static void notrack_ct1_tg_init(struct xt_entry_target *target)
      libxt_CT.c:271:13: warning: 'notrack_ct0_tg_init' defined but not used [-Wunused-function]
       static void notrack_ct0_tg_init(struct xt_entry_target *target)
      libxt_CT.c:219:13: warning: 'ct_save' defined but not used [-Wunused-function]
       static void ct_save(const void *ip, const struct xt_entry_target *target)
      libxt_CT.c:172:13: warning: 'ct_print' defined but not used [-Wunused-function]
       static void ct_print(const void *ip, const struct xt_entry_target *target, int numeric)
      libxt_CT.c:132:13: warning: 'ct_parse' defined but not used [-Wunused-function]
       static void ct_parse(struct xt_option_call *cb)
      libxt_CT.c:46:37: warning: 'ct_opts' defined but not used [-Wunused-const-variable=]
       static const struct xt_option_entry ct_opts[] = {
      libxt_CT.c:11:13: warning: 'ct_help' defined but not used [-Wunused-function]
       static void ct_help(void)
                       from libxt_hashlimit.c:15:
      OpenWrt-libtool: install: warning: relinking `libiptc.la'
      OpenWrt-libtool: install: warning: remember to run `libtool --finish /usr/lib'
      OpenWrt-libtool: install: warning: `../libiptc/libip4tc.la' has not been installed in `/usr/lib'
      OpenWrt-libtool: install: warning: `../libiptc/libip6tc.la' has not been installed in `/usr/lib'
      OpenWrt-libtool: install: warning: `../libxtables/libxtables.la' has not been installed in `/usr/lib'
      find: '/home/allwinner/tina-2/target/allwinner/d1-common/base-files': No such file or directory
      make[3]: [/home/allwinner/tina-2/out/d1-h-nezha/compile_dir/target/procd-2016-02-08/.configured_ynnnnynnyyy_8e081b74cf069e1e6800a5bbcbb282f0] Error 123 (ignored)
      grep: /home/allwinner/tina-2/out/d1-h-nezha/compile_dir/target/linux-d1-h-nezha/base-files/ipkg-sunxi/base-files/CONTROL/conffiles: No such file or directory
      /home/allwinner/tina-2/out/host/bin/find: '/home/allwinner/tina-2/out/d1-h-nezha/compile_dir/target/linux-d1-h-nezha/base-files/ipkg-sunxi/base-files/etc/config/network': No such file or directory
      /home/allwinner/tina-2/out/host/bin/find: '/home/allwinner/tina-2/out/d1-h-nezha/compile_dir/target/linux-d1-h-nezha/base-files/ipkg-sunxi/base-files/etc/dropbear/': No such file or directory
      grep: /home/allwinner/tina-2/out/d1-h-nezha/staging_dir/target/rootfs/tmp-base-files/CONTROL/conffiles: No such file or directory
      --2022-11-29 05:16:21--  https://kernel.org/pub/linux/libs/security/linux-privs/libcap2/libcap-2.51.tar.gz
      Resolving kernel.org (kernel.org)... 139.178.84.217, 2604:1380:4641:c500::1
      Connecting to kernel.org (kernel.org)|139.178.84.217|:443... connected.
      WARNING: cannot verify kernel.org's certificate, issued by '/C=US/O=Let\'s Encrypt/CN=R3':
        Issued certificate has expired.
      HTTP request sent, awaiting response... 301 Moved Permanently
      Location: https://mirrors.edge.kernel.org/pub/linux/libs/security/linux-privs/libcap2/libcap-2.51.tar.gz [following]
      --2022-11-29 05:16:26--  https://mirrors.edge.kernel.org/pub/linux/libs/security/linux-privs/libcap2/libcap-2.51.tar.gz
      Resolving mirrors.edge.kernel.org (mirrors.edge.kernel.org)... 147.75.80.249, 2604:1380:4601:e00::3
      Connecting to mirrors.edge.kernel.org (mirrors.edge.kernel.org)|147.75.80.249|:443... connected.
      WARNING: cannot verify mirrors.edge.kernel.org's certificate, issued by '/C=US/O=Let\'s Encrypt/CN=R3':
      HTTP request sent, awaiting response... 200 OK
      Length: 198414 (194K) [application/x-gzip]
      Saving to: 'STDOUT'
           0K .......... .......... .......... .......... .......... 25% 15.3K 9s
          50K .......... .......... .......... .......... .......... 51% 6.46K 10s
         100K .......... .......... .......... .......... .......... 77% 13.1K 4s
         150K .......... .......... .......... .......... ...       100% 10.3K=19s
      2022-11-29 05:16:50 (10.2 KB/s) - written to stdout [198414/198414]
      autoreconf: running: /home/allwinner/tina-2/out/host/bin/aclocal -I m4 -I . --force
      autoreconf: configure.ac: not using Libtool
      autoreconf: running: /home/allwinner/tina-2/out/host/bin/autoconf --include=m4 --include=. --prepend-include=/home/allwinner/tina-2/out/host/share/aclocal --force
      autoreconf: configure.ac: not using Autoheader
      autoreconf: running: /home/allwinner/tina-2/out/host/bin/aclocal -I /home/allwinner/tina-2/out/d1-h-nezha/staging_dir/target/host/share/aclocal -I /home/allwinner/tina-2/out/d1-h-nezha/staging_dir/target/usr/share/aclocal -I m4 -I . --force -I m4 ${ACLOCAL_FLAGS}
      configure: WARNING:
        You will not be able to create source packages with 'make dist'
        because gtk-doc >= 1.14 is not found.
      fatal: Not a git repository (or any of the parent directories): .git
      shared/util.c: In function 'read_str_safe':
      shared/util.c:211:24: warning: logical 'or' of equal expressions [-Wlogical-op]
          if (errno == EAGAIN || errno == EWOULDBLOCK ||
      shared/util.c: In function 'write_str_safe':
      shared/util.c:237:24: warning: logical 'or' of equal expressions [-Wlogical-op]
      configure.ac:33: installing 'build-aux/compile'
      configure.ac:39: installing 'build-aux/config.guess'
      configure.ac:39: installing 'build-aux/config.sub'
      configure.ac:37: installing 'build-aux/install-sh'
      configure.ac:37: installing 'build-aux/missing'
      Makefile.am: installing 'build-aux/depcomp'
      parallel-tests: installing 'build-aux/test-driver'
      configure: WARNING: unrecognized options: --disable-gtk-doc, --disable-gtk-doc-html, --disable-introspection, --disable-gudev, --disable-chkconfig
      configure: WARNING: *** Using Google NTP servers.
                              Do not ship OSes or devices with these default settings.
                              See DISTRO_PORTING for details!
      ./configure: line 19928: cd: /usr/lib/../lib64xthead/lp64d: No such file or directory
      In file included from <command-line>:
      ./src/basic/missing.h:583:6: error: #error "neither secure_getenv nor __secure_getenv are available"
       #    error "neither secure_getenv nor __secure_getenv are available"
      In file included from ./src/basic/util.h:46,
                       from src/libsystemd/sd-bus/sd-bus.c:30:
      ./src/basic/missing.h:1030:19: error: static declaration of 'renameat2' follows non-static declaration
       static inline int renameat2(int oldfd, const char *oldname, int newfd, const char *newname, unsigned flags) {
      In file included from ./src/basic/util.h:31,
      /home/allwinner/tina-2/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/sysroot/usr/include/stdio.h:164:12: note: previous declaration of 'renameat2' was here
       extern int renameat2 (int __oldfd, const char *__old, int __newfd,
      make[6]: *** [src/libsystemd/sd-bus/libsystemd_la-sd-bus.lo] Error 1
      make[5]: *** [all-recursive] Error 1
      make[4]: *** [all] Error 2
      make[3]: *** [/home/allwinner/tina-2/out/d1-h-nezha/compile_dir/target/systemd-225/.built] Error 2
      make[2]: *** [package/system/systemd/compile] Error 2
      make[1]: *** [/home/allwinner/tina-2/out/d1-h-nezha/staging_dir/target/stamp/.package_compile] Error 2
      make: *** [world] Error 2
      [2]+  Done                    $T/tools/build/buildserver --path $T 2> /dev/null 1>&2
      $cd package/system/systemd
      $mm -B
      make[5]: *** [src/libsystemd/sd-bus/libsystemd_la-sd-bus.lo] Error 1
      make[4]: *** [all-recursive] Error 1
      make[3]: *** [all] Error 2
      make[2]: *** [/home/allwinner/tina-2/out/d1-h-nezha/compile_dir/target/systemd-225/.built] Error 2
      make[1]: *** [package/system/systemd/install] Error 2
      make: *** [package/system/systemd/install] Error 2
