    7寸RGB显示屏问题求助
    • B
      B_MoFi LV 2 最后由 编辑
      求助lcd一直在闪,err数字一直在增加
      也调试了dts部分的值也没有效果
      root@TinaLinux:/# cat /sys/class/disp/disp/attr/sys
      screen 0:
      de_rate 300000000 hz, ref_fps:59
      mgr0: 1024x600 fmt[rgb] cs[0x204] range[full] eotf[0x4] bits[8bits] err[0] force_sync[0] unblank direct_show[false] iommu[1]
      dmabuf: cache[0] cache max[0] umap skip[0] umap skip max[0]
              lcd output      backlight( 10)  fps:59.1        1024x 600
              err:38362       skip:0  irq:38362       vsync:0 vsync_skip:0
         BUF    enable ch[1] lyr[0] z[16] prem[N] a[pixel 255] fmt[  0] fb[1024, 600;1024, 600;1024, 600] crop[   0,   0,1024, 600] frame[   0,   0, 800,1280] addr[ff800000,       0,       0] flags[0x       0] trd[0,0]
      depth[ 0] root@TinaLinux:/#
      dts的配置
      &lcd0 {
      	lcd_used        = <1>;
      	lcd_driver_name = "hx8282";
      	lcd_if          = <0>;
      	lcd_hv_if       = <0>;
      	lcd_width       = <154>;
      	lcd_height      = <85>;
      	lcd_x           = <1024>;
      	lcd_y           = <600>;
      	lcd_dclk_freq   = <50>;
      	lcd_hbp         = <160>;
      	lcd_ht          = <1344>;
      	lcd_hspw        = <6>;
      	lcd_vbp         = <23>;
      	lcd_vt          = <635>;
      	lcd_vspw        = <6>;
      	lcd_backlight   = <10>;
      	lcd_pwm_used    = <1>;
      	lcd_pwm_ch      = <7>;
      	lcd_pwm_freq    = <20000>;
      	lcd_pwm_pol     = <1>;
      	lcd_bright_curve_en = <0>;
      	lcd_frm         = <1>;
      	lcd_io_phase    = <0x0000>;
      	lcd_gamma_en    = <0>;
      	lcd_cmap_en     = <0>;
      	lcd_hv_clk_phase= <0>;
      	lcd_hv_sync_polarity= <0>;
      	lcd_rb_swap          = <0>;
      	lcd_power       = "vcc-lcd";
      	lcd_pin_power   = "vcc-pd";
      	pinctrl-0       = <&rgb18_pins_a>;
      	pinctrl-1       = <&rgb18_pins_b>;
