    VFS: Cannot open root device "ubiblock0_4" or unknown-block(0,0): error -6
    4481
      逗 LV 5 最后由 编辑
      • 使用sd刷入 spinand 方式
      • 无法进行系统,内核报错报错日志如下
      [    3.634270]   #1: snddaudio0
      [    3.637901] VFS: Cannot open root device "ubiblock0_4" or unknown-block(0,0): error -6
      [    3.646806] Please append a correct "root=" boot option; here are the available partitions:
      [    3.656260] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
      [    3.665527] CPU: 0 PID: 1 Comm: swapper Not tainted 4.9.191 #66
      [    3.672156] Hardware name: sun8iw21
      [    3.676085] [<c010d3cc>] (unwind_backtrace) from [<c010a51c>] (show_stack+0x10/0x14)
      [    3.684769] [<c010a51c>] (show_stack) from [<c016ff58>] (panic+0xac/0x2b0)
      [    3.692479] [<c016ff58>] (panic) from [<c0901270>] (mount_block_root+0x208/0x2f4)
      [    3.700869] [<c0901270>] (mount_block_root) from [<c0901504>] (prepare_namespace+0x138/0x178)
      [    3.710427] [<c0901504>] (prepare_namespace) from [<c0900e80>] (kernel_init_freeable+0x11c/0x178)
      [    3.720374] [<c0900e80>] (kernel_init_freeable) from [<c067bfa8>] (kernel_init+0x8/0x108)
      [    3.729545] [<c067bfa8>] (kernel_init) from [<c0106ca8>] (ret_from_fork+0x14/0x2c)
      [    3.738031] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
      完整日志文件如下:
      新建文本文档 (2).txt
      Q 1 条回复 最后回复 回复 引用 分享 0
        WhycanService LV 8 最后由 编辑
        使用nand作为启动介质需要配置ubifs
          逗 LV 5 @WhycanService 最后由 编辑
          @whycanservice 在 VFS: Cannot open root device "ubiblock0_4" or unknown-block(0,0): error -6 中说:
          ubif
          你好:
          # flash
          CONFIG_SUNXI_SDMMC=y
          CONFIG_MMC=y
          CONFIG_SUNXI_FLASH=y
          CONFIG_SUNXI_NAND=y
          CONFIG_SUNXI_UBIFS=y
          CONFIG_SUNXI_COMM_NAND_V1=y
          CONFIG_SUNXI_SPINOR=y
          • Q
            quanzhi111 LV 5 @likehengall 最后由 编辑
            @likehengall 大佬 这个问题解决了吗???
