    请教各位大佬全志V3S从SPI FLASH启动失败问题
    4338
    • R
      RySz123 LV 2 最后由 whycan 编辑
      请教各位大佬全志V3S从SPI FLASH启动失败,FLASH芯片是W25Q128JVSIQ
      报错如下: rootfs根文件系统有尝试更换几次 均无效果
      linux内核版本也有更换过
      [    1.122629] VFS: Cannot open root device "31:03" or unknown-block(31,3): error -19
      [    1.130324] Please append a correct "root=" boot option; here are the available partitions:
      [    1.138704] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,3)
      下面是完整启动信息
      U-Boot SPL 2017.01-rc2-00073-gdd6e8740dc-dirty (Dec 02 2022 - 10:23:41)
      DRAM: 64 MiB
      Trying to boot from sunxi SPI
      U-Boot 2017.01-rc2-00073-gdd6e8740dc-dirty (Dec 02 2022 - 10:23:41 +0800) Allwinner Technology
      CPU:   Allwinner V3s (SUN8I 1681)
      Model: Lichee Pi Zero
      DRAM:  64 MiB
      MMC:   SUNXI SD/MMC: 0
      SF: Detected w25q128bv with page size 256 Bytes, erase size 4 KiB, total 16 MiB
      *** Warning - bad CRC, using default environment
      Setting up a 800x480 lcd console (overscan 0x0)
      dotclock: 33000kHz = 33000kHz: (1 * 3MHz * 66) / 6
      In:    serial@01c28000
      Out:   serial@01c28000
      Err:   serial@01c28000
      DRAM:  64 MiB
      In:    serial@01c28000
      Net:   No ethernet found.
      starting USB...
      No controllers found
      device 0 offset 0x100000, size 0x10000
      SF: 65536 bytes @ 0x100000 Read: OK
      device 0 offset 0x110000, size 0x400000
      SF: 4194304 bytes @ 0x110000 Read: OK
      ## Flattened Device Tree blob at 41800000
         Booting using the fdt blob at 0x41800000
         Loading Device Tree to 42dfa000, end 42dff4bf ... OK
      Starting kernel ...
      [    0.000000] Linux version 4.10.15-licheepi-zero+ (root@ymc-virtual-machine) (gcc version 4.9.4 (Linaro GCC 4.9-2017.01) ) #1 SMP Thu Dec 1 10:52:28 CST 2022
      [    0.000000] OF: fdt:Machine model: Lichee Pi Zero with Dock
      [    0.000000] percpu: Embedded 14 pages/cpu @c3dea000 s24768 r8192 d24384 u57344
      [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 15883
      [    0.000000] Kernel command line: console=ttyS0,115200 earlyprintk panic=5 rootwait mtdparts=spi32766.0:1M(uboot)ro,64k(dtb)ro,4M(kernel)ro,-(rootfs) root=31:03 rw rootfstype=jffs2
      [    0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
      [    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
      [    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
      [    0.000000] Memory: 53644K/64036K available (6144K kernel code, 199K rwdata, 1392K rodata, 1024K init, 260K bss, 10392K reserved, 0K cma-reserved, 0K highmem)
      [    0.000000]     vmalloc : 0xc4000000 - 0xff800000   ( 952 MB)
      [    0.000000]     lowmem  : 0xc0000000 - 0xc3e89000   (  62 MB)
      [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      [    0.000000]       .text : 0xc0008000 - 0xc0700000   (7136 kB)
      [    0.000000]       .init : 0xc0900000 - 0xc0a00000   (1024 kB)
      [    0.000000]       .data : 0xc0a00000 - 0xc0a31ec0   ( 200 kB)
      [    0.000000]        .bss : 0xc0a33000 - 0xc0a7405c   ( 261 kB)
      [    0.000000] Hierarchical RCU implementation.
      [    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
      [    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
      [    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
      [    0.000018] Switching to timer-based delay loop, resolution 41ns
      [    0.000144] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
      [    0.000357] Console: colour dummy device 80x30
      [    0.000393] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.000409] pid_max: default: 32768 minimum: 301
      [    0.000548] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
      [    0.000559] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
      [    0.001269] CPU: Testing write buffer coherency: ok
      [    0.001682] /cpus/cpu@0 missing clock-frequency property
      [    0.001706] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [    0.002081] Setting up static identity map for 0x40100000 - 0x40100058
      [    0.002834] smp: Bringing up secondary CPUs ...
      [    0.002851] smp: Brought up 1 node, 1 CPU
      [    0.002860] SMP: Total of 1 processors activated (48.00 BogoMIPS).
      [    0.002867] CPU: All CPU(s) started in SVC mode.
      [    0.003651] devtmpfs: initialized
      [    0.006597] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [    0.006899] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.006929] futex hash table entries: 256 (order: 2, 16384 bytes)
      [    0.007085] pinctrl core: initialized pinctrl subsystem
      [    0.008070] NET: Registered protocol family 16
      [    0.008564] DMA: preallocated 256 KiB pool for atomic coherent allocations
      [    0.009813] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
      [    0.009834] hw-breakpoint: maximum watchpoint size is 8 bytes.
      [    0.021963] SCSI subsystem initialized
      [    0.022256] usbcore: registered new interface driver usbfs
      [    0.022339] usbcore: registered new interface driver hub
      [    0.022441] usbcore: registered new device driver usb
      [    0.022677] pps_core: LinuxPPS API ver. 1 registered
      [    0.022687] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
      [    0.022709] PTP clock support registered
      [    0.022916] Advanced Linux Sound Architecture Driver Initialized.
      [    0.024755] clocksource: Switched to clocksource arch_sys_counter
      [    0.025619] simple-framebuffer 43e89000.framebuffer: framebuffer at 0x43e89000, 0x177000 bytes, mapped to 0xc4080000
      [    0.025642] simple-framebuffer 43e89000.framebuffer: format=x8r8g8b8, mode=800x480x32, linelength=3200
      [    0.032515] Console: switching to colour frame buffer device 100x30
      [    0.038676] simple-framebuffer 43e89000.framebuffer: fb0: simplefb registered!
      [    0.048592] NET: Registered protocol family 2
      [    0.049237] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
      [    0.049267] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
      [    0.049290] TCP: Hash tables configured (established 1024 bind 1024)
      [    0.049382] UDP hash table entries: 256 (order: 1, 8192 bytes)
      [    0.049431] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
      [    0.049657] NET: Registered protocol family 1
      [    0.050264] RPC: Registered named UNIX socket transport module.
      [    0.050282] RPC: Registered udp transport module.
      [    0.050287] RPC: Registered tcp transport module.
      [    0.050293] RPC: Registered tcp NFSv4.1 backchannel transport module.
      [    0.052577] workingset: timestamp_bits=30 max_order=14 bucket_order=0
      [    0.061740] NFS: Registering the id_resolver key type
      [    0.061791] Key type id_resolver registered
      [    0.061798] Key type id_legacy registered
      [    0.065960] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
      [    0.065983] io scheduler noop registered
      [    0.065990] io scheduler deadline registered
      [    0.066173] io scheduler cfq registered (default)
      [    0.070393] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
      [    0.140254] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
      [    0.143494] console [ttyS0] disabled
      [    0.163780] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 34, base_baud = 1500000) is a U6_16550A
      [    0.756084] console [ttyS0] enabled
      [    0.760276] [drm] Initialized
      [    0.766437] m25p80 spi32766.0: w25q128 (16384 Kbytes)
      [    0.773005] libphy: Fixed MDIO Bus: probed
      [    0.777564] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    0.784093] ehci-platform: EHCI generic platform driver
      [    0.789497] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    0.795730] ohci-platform: OHCI generic platform driver
      [    0.801447] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
      [    0.810985] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
      [    0.820015] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
      [    0.826926] sun6i-rtc 1c20400.rtc: RTC enabled
      [    0.831469] i2c /dev entries driver
      [    0.836411] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input1
      [    0.846075] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      [    0.914787] sunxi-mmc 1c0f000.mmc: base:0xc4061000 irq:23
      [    0.974777] sunxi-mmc 1c10000.mmc: base:0xc4065000 irq:24
      [    0.981150] usbcore: registered new interface driver usbhid
      [    0.986807] usbhid: USB HID core driver
      [    0.992245] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01c23000 not registered
      [    1.000306] sun4i-codec 1c22c00.codec: Failed to register our card
      [    1.007495] NET: Registered protocol family 17
      [    1.012055] Key type dns_resolver registered
      [    1.016594] Registering SWP/SWPB emulation handler
      [    1.029988] usb_phy_generic.0.auto supply vcc not found, using dummy regulator
      [    1.037990] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
      [    1.043753] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
      [    1.052996] hub 1-0:1.0: USB hub found
      [    1.056988] hub 1-0:1.0: 1 port detected
      [    1.061658] using random self ethernet address
      [    1.066240] using random host ethernet address
      [    1.071734] usb0: HOST MAC c6:47:e1:59:9a:2e
      [    1.076185] usb0: MAC 3a:5d:ee:2f:6e:85
      [    1.080074] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
      [    1.087592] g_cdc gadget: g_cdc ready
      [    1.093773] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
      [    1.102395] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:00:06 UTC (6)
      [    1.110646] vcc5v0: disabling
      [    1.113619] ALSA device list:
      [    1.116643]   #0: V3s Audio Codec
      [    1.147048] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.10.15-licheepi-zero+ #1
      [    1.154344] Hardware name: Allwinner sun8i Family
      [    1.159083] [<c010e308>] (unwind_backtrace) from [<c010b10c>] (show_stack+0x10/0x14)
      [    1.166828] [<c010b10c>] (show_stack) from [<c0333380>] (dump_stack+0x94/0xa8)
      [    1.174052] [<c0333380>] (dump_stack) from [<c01a53f0>] (panic+0xdc/0x254)
      [    1.180929] [<c01a53f0>] (panic) from [<c0901180>] (mount_block_root+0x18c/0x260)
      [    1.188408] [<c0901180>] (mount_block_root) from [<c0901370>] (mount_root+0x11c/0x124)
      [    1.196318] [<c0901370>] (mount_root) from [<c09014d0>] (prepare_namespace+0x158/0x19c)
      [    1.204314] [<c09014d0>] (prepare_namespace) from [<c0900e50>] (kernel_init_freeable+0x1e8/0x1f8)
      [    1.213181] [<c0900e50>] (kernel_init_freeable) from [<c0642940>] (kernel_init+0x8/0x114)
      [    1.221355] [<c0642940>] (kernel_init) from [<c0107678>] (ret_from_fork+0x14/0x3c)
      [    1.228925] Rebooting in 5 seconds..
      R 2 条回复 最后回复 回复 引用 分享 0
      • R
        RySz123 LV 2 @RySz123 最后由 编辑
        @rysz123 还请各位大佬不吝赐教 感激不尽🙏
        • R
          @rysz123
          配置uboot默认环境变量如下
          在文件 include/configs/sun8i.h
          #define CONFIG_BOOTCOMMAND "sf probe 0; "
          "sf read 0x41800000 0x100000 0x10000; "
          "sf read 0x41000000 0x110000 0x400000; "
          "bootz 0x41000000 - 0x41800000"
          #define CONFIG_BOOTARGS "console=ttyS0,115200 earlyprintk panic=5 rootwait "
          "mtdparts=spi32766.0:1M(uboot)ro,64k(dtb)ro,4M(kernel)ro,-(rootfs) root=31:03 rw rootfstype=jffs2"
          R 1 条回复 最后回复 回复 引用 分享 0
            看日志, 是没有生成 mtd 分区:
            参考这个帖子: V3s开发板smallwitpi lite u-boot/linux/buildroot测试
            • R
              @rysz123
              制作烧录镜像步骤如下
              烧录指令
              sudo sunxi-fel -p spiflash-write 0 flashimg.bin
