    采用GPADC的查询模式总是不能获得电压
      zealsoft LV 3 最后由 编辑
      在裸机环境按照手册的说明设置GPADC0为查询模式,但总是得不到电压值。
      在设置连续转换模式之后和使能ADC之后读取GP_CTRL,发现总是默认值0x800000,和设置啥无关。
      哪些帮忙看看,谢谢。
      程序大致如下:
      unsigned int ra;
      unsigned int x, d;
      /* init GPADC */
      /* 1. Write 0x1 to the bit[16] of GPADC_BGR_REG (Offset: 0x09EC) to dessert reset. */
      PUT32(GPADC_BGR, 1 << 16);
      /* 2. Write 0x1 to the bit[0] of GPADC_BGR_REG (Offset: 0x09EC) to enable the GPADC clock. */
      PUT32(GPADC_BGR, 1);
      /* 3. Write 0x2F to the bit[15:0] of GP_SR_CON (Offset: 0x0000) to set the acquiring time of ADC.
         4. Write 0x1DF to the bit[31:16] of GP_SR_CON (Offset: 0x0000) to set the ADC sample frequency divider. */
      PUT32(GP_SR_CON, 0x1df002f);
      /* 5. Write 0x2 to the bit[19:18] of GP_CTRL (Offset: 0x0004 ) to set the continuous conversion mode.*/
      ra = GET32(GP_CTRL) & ~(0x03 << 18);
      PUT32(GP_CTRL, ra | (0x02 << 18));
      /* 6. Write 0x1 to the bit[0] of GP_CS_EN (Offset: 0x0008) to enable the analog input channel. */
      ra = GET32(GP_CS_EN);
      PUT32(GP_CS_EN, ra | 1);
      /* 7. Write 0x1 to the bit[16] of GP_CTRL (Offset: 0x0004) to enable the ADC function.*/
      ra = GET32(GP_CTRL);
      ra = GET32(GP_CTRL) & ~(0x09 << 16);
      PUT32(GP_CTRL, ra | (0x09 << 16));
      /* queue the key states */
      while(1)
          /* 8. Read the bit[0] of GP_DATA_INTS (Offset: 0x0038), if the bit is 1, then data conversion is complete.*/
          x = GET32(GP_DATA_INTS);
      if(x & 1)
         d = GET32(GP_CH0_DATA) & 0xfff;
         hexstring(d);
          DELAY(0x1000000);
