    兄弟们,你们有碰到过屏幕触摸坐标不准的问题吗
    • F
      fanfan LV 6 最后由 编辑
      &lcd0 {
          /* part 1 */
          lcd_used            = <1>;
          lcd_backlight	    = <100>;
          /* part 2 */
          lcd_if = <0>;
          lcd_hv_if = <0>;
          /* part 3 */
          lcd_x               = <1024>;
          lcd_y               = <600>;
          lcd_width           = <154>;
          lcd_height          = <85>;
          lcd_dclk_freq       = <51>;
          lcd_hbp             = <140>;
          lcd_ht              = <1344>;
          lcd_hspw            = <20>;
          lcd_vbp             = <20>;
          lcd_vt              = <635>;
          lcd_vspw            = <3>;
          lcd_pwm_used        = <1>;
          lcd_pwm_ch          = <7>;
          lcd_pwm_freq        = <500>;
          lcd_pwm_pol         = <1>;
          /* part 5 */
          lcd_frm = <1>;
          lcd_io_phase = <0x0000>;
          lcd_gamma_en = <0>;
          lcd_cmap_en = <0>;
          lcd_hv_clk_phase = <0>;
          lcd_hv_sync_polarity= <0>;
          /* part 6 */
          lcd_power = "vcc-lcd";
          lcd_pin_power = "vcc-pd";
          pinctrl-0 = <&rgb18_pins_a>;
          pinctrl-1 = <&rgb18_pins_b>;
      触摸节点
      &twi2 {
              /* goodix {
               *         status = "okay";
               *         compatible = "goodix,gt911";
               *         reg = <0x5d>;
               *         int-gpios = <&pio PH 7 0 0 1 0>;
               *         reset-gpios = <&pio PH 8 0 0 1 0>;
               *         touchscreen-size-x = <720>;
               *         touchscreen-size-y = <1280>;
              ctp@14 {
                      device_type = "ctp";
                      reg = <0x14>;
                      ctp_name = "gt9xxnew_ts";
                      ctp_twi_id = <0x2>;
                      ctp_twi_addr = <0x14>;
                      ctp_screen_max_x = <0x400>;
                      ctp_screen_max_y = <0x258>;
                      ctp_revert_x_flag = <0x0>;
                      ctp_revert_y_flag = <0x0>;
                      ctp_int_port = <&pio PH 7 6 1 3 0xffffffff>;
                      ctp_wakeup   = <&pio PH 8 1 1 3 0xffffffff>;
                      /* ctp-supply = <&reg_aldo2>;*/
                      /* ctp_power_ldo = <&reg_dldo1>; */
                      /* ctp_power_ldo_vol = <3300>; */
      屏幕可以触摸,但是不准
        WhycanService LV 8 最后由 xiaowenge 编辑
        gt911和gsl的一样需要下载固件,固件不对就会导致偏移。例如gsl的这个补丁
        固件具体可以询问屏厂看看他们能不能提供
          whycan晕哥 LV 9 @fanfan 最后由 编辑
          @fanfan
          问厂家要固件,否则要自己做一个:下单买了一个 汇顶 GT911/GT9xx 电容触摸屏产测工具
