    V853 LVGL app添加slider change调节屏幕亮度回调事件
      diff --git a/demos/widgets/lv_demo_widgets.c b/demos/widgets/lv_demo_widgets.c
      index 839b999c0..d2a6f4ac5 100644
      --- a/demos/widgets/lv_demo_widgets.c
      +++ b/demos/widgets/lv_demo_widgets.c
      @@ -304,6 +304,8 @@ static void profile_create(lv_obj_t * parent)
           lv_obj_add_style(experience_label, &style_text_muted, 0);
           lv_obj_t * slider1 = lv_slider_create(panel3);
      +    lv_slider_set_range(slider1, 0, 255);
      +    lv_slider_set_value(slider1, 255, LV_ANIM_ON);
           lv_obj_set_width(slider1, LV_PCT(95));
           lv_obj_add_event_cb(slider1, slider_event_cb, LV_EVENT_ALL, NULL);
           lv_obj_refresh_ext_draw_size(slider1);
      @@ -1275,14 +1277,24 @@ static void calendar_event_cb(lv_event_t * e)
       static void slider_event_cb(lv_event_t * e)
      +    char cmd[512];
           lv_event_code_t code = lv_event_get_code(e);
           lv_obj_t * obj = lv_event_get_target(e);
      +    int32_t value = lv_slider_get_value(obj);
           if(code == LV_EVENT_REFR_EXT_DRAW_SIZE) {
               lv_coord_t * s = lv_event_get_param(e);
               *s = LV_MAX(*s, 60);
      +    else if(code == LV_EVENT_VALUE_CHANGED)
      +       memset(cmd, sizeof(cmd), 0);
      +       snprintf(cmd, sizeof(cmd)-1, "cd /sys/kernel/debug/dispdbg; echo lcd0 > name; echo setbl > command; echo %d > param; echo 1 > start\n", value);
      +       system(cmd);
      +       printf(cmd);
           else if(code == LV_EVENT_DRAW_PART_END) {
               lv_obj_draw_part_dsc_t * dsc = lv_event_get_param(e);
               if(dsc->part == LV_PART_KNOB && lv_obj_has_state(obj, LV_STATE_PRESSED)) {
                   char buf[8];
        演示视频: https://www.bilibili.com/video/BV1ye411N7um/
        • Referenced by  G gzxooo
