    T113-S3 LONGAN SDC2接XR829 内核无法启动
    3951
      Steelen LV 4 最后由 whycan 编辑
      非常奇怪的现象
      T113-S3 SDC0 接EMMC
      SDC2 接 XR829
      在board.dts中一旦使能 (okay)SDC2,内核就无法启动了,disabled可以正常启动
      启动的时候SDIO CLK引脚会有一个短暂的时钟信号,CMD引脚也有短暂的时钟信号,然后内核就挂了
      M/TC: OP-TEE version: 53fe17e2-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3
      -2016.05)) #6 Fri Feb 18 08:54:51 UTC 2022 arm
      ** 60 printk messages dropped **
      [    0.006685] 001: devtmpfs: initialized
      ** 2 printk messages dropped **
      [    0.025421] 000: futex hash table entries: 512 (order: 3, 32768 bytes, linear
      [    0.026213] 000: pinctrl core: initialized pinctrl subsystem
      [    0.028186] 000: NET: Registered protocol family 16
      [    0.032121] 000: DMA: preallocated 256 KiB pool for atomic coherent allocatio
      ns
      ** 9 printk messages dropped **
      [    0.142015] 000: videodev: Linux video capture interface: v2.00
      ** 16 printk messages dropped **
      [    0.188719] 000: sunxi_spi_resource_get()2177 - [spi1] SPI MASTER MODE
      [    0.243086] 000: [DISP]disp_module_init finish
      ** 1 printk message dropped **
      [    0.245782] 000: sun8iw20-pinctrl pio: pio supply vcc-pg not found, using dum
      my regulator
      [    0.246181] 000: uart uart1: get regulator failed
      [    0.246202] 000: uart uart1: uart1 supply uart not found, using dummy regulat
      or
      [    0.246742] 000: uart1: ttyS1 at MMIO 0x2500400 (irq = 34, base_baud = 150000
      0) is a SUNXI
      [    0.252255] 000: uart uart5: get regulator failed
      [    0.252837] 000: uart5: ttyS5 at MMIO 0x2501400 (irq = 38, base_baud = 150000
      0) is a SUNXI
      [    0.252865] 000: sw_console_setup()1808 - console setup baud 115200 parity n
      bits 8, flow n
      [    0.252931] 000: printk: console [ttyS5] enabled
      [    0.254287] 000: misc dump reg init
      [    0.258222] 001: libphy: Fixed MDIO Bus: probed
      ** 5 printk messages dropped **
      [    0.259262] 001: usbcore: registered new interface driver cdc_ncm
      [    0
      我觉得是DTS文件有关SDC2的部分配置有问题,但是找不出问题在哪里
      /dts-v1/;
      /memreserve/ 0x41900000 0x00100000;
      /* DSP used 1MB */
      /* /memreserve/ 0x42000000 0x00100000; */
      #include "sun8iw20p1.dtsi"
      	model = "sun8iw20";
      	reg_vdd_cpu: vdd-cpu {
      		compatible = "pwm-regulator";
      		pwms = <&pwm 3 5000 0>;
      		regulator-name = "vdd_cpu";
      		regulator-settling-time-us = <4000>;
      		regulator-always-on;
      		regulator-boot-on;
      	reg_usb1_vbus: usb1-vbus {
      		regulator-name = "usb1-vbus";
      		gpio = <&pio PD 19 GPIO_ACTIVE_HIGH>;
      		enable-active-high;
      	can0: can@0x0 {
      		#address-cells = <1>;
      		#size-cells = <0>;
      		compatible = "allwinner,sun8i-can";
      		pinctrl-0 = <&can0_pins_a>;
      		pinctrl-1 = <&can0_pins_b>;
      		device_type = "can0";
      		id = <0>;
      	can1: can@0x1 {
      		#size-cells = <0>;
      		pinctrl-0 = <&can1_pins_a>;
      		pinctrl-1 = <&can1_pins_b>;
      		device_type = "can1";
      		id = <1>;
      &cpu0 {
      	cpu-supply = <&reg_vdd_cpu>;
      &pio {
      	sdc0_pins_a: sdc0@0 {
      				 "PF3", "PF4", "PF5";
      		allwinner,function = "sdc0";
      		allwinner,muxsel = <2>;
      		allwinner,drive = <3>;
      		allwinner,pull = <1>;
      		function = "sdc0";
      		drive-strength = <30>;
      		bias-pull-up;
      		power-source = <3300>;
      	sdc0_pins_b: sdc0@1 {
      		function = "sdc0";
      		bias-pull-up;
      		power-source = <1800>;
      	sdc0_pins_c: sdc0@2 {
      		function = "gpio_in";
      	/* TODO: add jtag pin */
      	sdc0_pins_d: sdc0@3 {
      		pins = "PF2", "PF4";
      		function = "uart0";
      		drive-strength = <10>;
      		bias-pull-up;
      	sdc0_pins_e: sdc0@4 {
      		pins = "PF0", "PF1", "PF3",
      			"PF5";
      		function = "jtag";
      		bias-pull-up;
      	sdc1_pins_a: sdc1@0 {
      		pins = "PG0", "PG1", "PG2",
      		       "PG3", "PG4", "PG5";
      		function = "sdc1";
      		bias-pull-up;
      	sdc1_pins_b: sdc1@1 {
      			function = "sdc1";
      	sdc2_pins_a: sdc2@0 {
      				 "PC5", "PC6", "PC7";
      		allwinner,function = "sdc2";
      		allwinner,muxsel = <3>;
      		function = "sdc2";
      		bias-pull-up;
      	sdc2_pins_b: sdc2@1 {
      	wlan_pins_a:wlan@0 {
      		pins = "PG11";
      		function = "clk_fanout1";
      	lvds0_pins_a: lvds0@0 {
      		allwinner,pins  = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9";
      		allwinner,pname = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9";
      		allwinner,function = "lvds0";
      		allwinner,pull = <0>;
      	lvds0_pins_b: lvds0@1 {
      		allwinner,muxsel = <7>;
      		function = "uart0";
      		bias-pull-up;
      		function = "uart1";
      		bias-pull-up;
                      pins = "PD1", "PD2", "PD3", "PD4";
                      function = "uart2";
                      bias-pull-up;
      	uart3_pins_a: uart3_pins@0 {  /* For t113_evb */
      		pins = "PG0", "PG1", "PG2", "PG3";
      		function = "uart3";
      		bias-pull-up;
      	uart3_pins_b: uart3_pins@1 {  /* For t113_evb */
      	uart4_pins_a: uart4_pins@0 {  /* For t113_evb */
      		pins = "PD7", "PD8";
      		function = "uart4";
      		bias-pull-up;
      	uart4_pins_b: uart4_pins@1 {  /* For t113_evb */
      	uart5_pins_a: uart5_pins@0 {  /* For t113_evb */
      		pins = "PD5", "PD6";
      		function = "uart5";
      		bias-pull-up;
      	uart5_pins_b: uart5_pins@1 {  /* For t113_evb */
      	twi0_pins_a: twi0@0 {
      		pins = "PB2", "PB3";
      		function = "twi0";
      	twi0_pins_b: twi0@1 {
      	twi1_pins_a: twi1@0 {
      		pins = "PE14", "PE15";
      		function = "twi1";
      	twi1_pins_b: twi1@1 {
      	twi2_pins_a: twi2@0 {
      		pins = "PG14", "PG15";
      		function = "twi2";
      	twi2_pins_b: twi2@1 {
      	twi3_pins_a: twi3@0 {
      		/* pins = "PE16", "PE17"; */
      		/* pins = "PG10", "PG11"; */
      		pins = "PB6", "PB7";
      		function = "twi3";
      	twi3_pins_b: twi3@1 {
      	s_cir0_pins_a: s_cir0@0 {
      		pins = "PB1";
      		function = "ir";
      		bias-pull-up;
      	s_cir0_pins_b: s_cir0@1 {
      		pins = "PB1";
      	ir1_pins_a: ir1@0 {
      		pins = "PB0";
      		function = "ir";
      		bias-pull-up;
      	ir1_pins_b: ir1@1 {
      		pins = "PB0";
      	dmic_pins_a: dmic@0 {
      		function = "dmic";
      		drive-strength = <20>;
      		bias-disable;
      	dmic_pins_b: dmic@1 {
      		bias-disable;
      	daudio0_pins_a: daudio0@0 {
      		pins = "PB29", "PB23", "PB24",
      		       "PB25", "PB26", "PB27", "PB28",
      		       "PB22";
      		function = "i2s0";
      		bias-disable;
      		       "PB22";
      		bias-disable;
      	daudio1_pins_a: daudio1@0 {
      		/* MCLK, LRCK, BCLK */
      		pins = "PG12", "PG13";
      		function = "i2s1";
      		bias-disable;
      	daudio1_pins_b: daudio1@1 {
      		/* DIN0 */
      		pins = "PG14";
      		function = "i2s1_din";
      		bias-disable;
      	daudio1_pins_c: daudio1@2 {
      		/* DOUT0 */
      		pins = "PG15";
      		function = "i2s1_dout";
      		bias-disable;
      	daudio1_pins_d: daudio1_sleep@0 {
      		pins = "PG12", "PG13", "PG14", "PG15";
      		bias-disable;
      	daudio2_pins_a: daudio2@0 {
      		pins = "PB7", "PB6", "PB5";
      		function = "i2s2";
      		bias-disable;
      	daudio2_pins_b: daudio2@1 {
      		/* I2S_PIN: DIN0 */
      		pins = "PB3";
      		function = "i2s2_din";
      		bias-disable;
      	daudio2_pins_c: daudio2@2 {
      		/* I2S_PIN: DOUT0 */
      		pins = "PB4";
      		function = "i2s2_dout";
      		bias-disable;
      		pins = "PB7", "PB6", "PB5", "PB4", "PB3";
      		bias-disable;
      	spdif_pins_a: spdif@0 {
      		/* SPDIF_PIN: SPDIF_OUT */
      		pins = "PG18";
      		function = "spdif";
      		bias-disable;
      	spdif_pins_b: spdif_sleep@0 {
      		pins = "PG18";
      		bias-disable;
      	gmac0_pins_a: gmac@0 {
      		allwinner,pins = "PE0", "PE1", "PE2", "PE3", "PE4",
      				 "PE5", "PE6", "PE7","PE8", "PE9", "PE10";
      		allwinner,function = "gmac0";
      		allwinner,muxsel = <8>;
      		allwinner,drive = <1>;
      	gmac0_pins_b: gmac@1 {
      		allwinner,function = "gpio_in";
      		allwinner,muxsel = <0>;
      	spi0_pins_a: spi0@0 {
      		pins = "PC2", "PC4", "PC5","PC7", "PC6";
      		function = "spi0";
      	spi0_pins_b: spi0@1 {
      		pins = "PC3";
      		function = "spi0";
      		bias-pull-up;
      	spi0_pins_c: spi0@2 {
      	spi1_pins_a: spi1@0 {
      		pins = "PD11", "PD12", "PD13";
      		function = "spi1";
      	spi1_pins_b: spi1@1 {
      		pins = "PD10";
      		function = "spi1";
      		bias-pull-up;   // only CS should be pulled up
      	spi1_pins_c: spi1@2 {
      		allwinner,pins = /*"PD10",*/ "PD11", "PD12", "PD13";
      	pwm3_pin_a: pwm3@0 {
      		pins = "PB0";
      		function = "pwm3";
      		bias-pull-up;
      	pwm3_pin_b: pwm3@1 {
      		pins = "PB0";
      	pwm7_pin_a: pwm7@0 {
      		pins = "PD22";
      		function = "pwm7";
      		bias-pull-up;
      	pwm7_pin_b: pwm7@1 {
      		pins = "PD22";
      	can0_pins_a: can0@0 {
      		function = "can0";
      	can0_pins_b: can0@1 {
      	can1_pins_a: can1@0 {
      		pins = "PB4", "PB5";
      		function = "can1";
      	can1_pins_b: can1@1 {
      	ledc_pins_a: ledc@0 {
      		pins = "PG13";
      		function = "ledc";
      	ledc_pins_b: ledc@1 {
      		pins = "PG13";
      	rgb24_pins_a: rgb24@0 {
      		allwinner,pins = "PB2", "PB3", "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", \
      			"PB4", "PB5", "PD6", "PD7", "PD8", "PD9", "PD10", "PD11", \
      			"PB6", "PB7", "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", \
      		allwinner,pname = "lcdd0", "lcdd1", "lcdd2", "lcdd3", "lcdd4", "lcdd5", "lcdd6", "lcdd7", \
      			"lcdd8", "lcdd9", "lcdd10", "lcdd11", "lcdd12", "lcdd13", "lcdd14", "lcdd15", \
      			"lcdd16", "lcdd17", "lcdd18", "lcdd19", "lcdd20", "lcdd21", "lcdd22", "lcdd23", \
      			"lcdclk", "lcdde", "lcdhsync", "lcdvsync";
      		allwinner,function = "lcd0";
      	rgb24_pins_b: rgb24@1 {
      	dsi4lane_pins_a: dsi4lane@0 {
              allwinner,function = "dsi4lane";
              allwinner,muxsel = <4>;
      	dsi4lane_pins_b: dsi4lane@1 {
              allwinner,function = "dsi4lane_suspend";
      &uart0 {
      	pinctrl-0 = <&uart0_pins_a>;
      	pinctrl-1 = <&uart0_pins_b>;
      	status = "disabled";
      &uart1 {
      	pinctrl-0 = <&uart1_pins_a>;
      	pinctrl-1 = <&uart1_pins_b>;
      &uart2 {
              pinctrl-0 = <&uart2_pins_a>;
              pinctrl-1 = <&uart2_pins_b>;
      &uart3 {
      	pinctrl-0 = <&uart3_pins_a>;
      	pinctrl-1 = <&uart3_pins_b>;
      &uart4 {
      	pinctrl-0 = <&uart4_pins_a>;
      	pinctrl-1 = <&uart4_pins_b>;
      &uart5 {
      	pinctrl-0 = <&uart5_pins_a>;
      	pinctrl-1 = <&uart5_pins_b>;
      &sdc2 {
      	non-removable;
      	bus-width = <4>;
      	mmc-hs200-3_3v;
       /* mmc-ddr-1_8v;     mmc-hs200-3_3v;  */
       /*	no-sdio;  */
          no-mmc;
      	no-sd;
      	ctl-spec-caps = <0x8>;
      /*	cap-mmc-highspeed; */
      /*	sunxi-power-save-mode;*/
          keep-power-in-suspend;
      	ignore-pm-notify;
      /*	sunxi-dis-signal-vol-sw;*/
      /*	mmc-bootpart-noacc; */
      	max-frequency = <50000000>;
      	/*emmc io vol 3.3v*/
      	/*emmc io vol 1.8v*/
      &sdc0 {
      	bus-width = <4>;
      	/*cd-gpios = <&pio PF 6 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>;*/
      	non-removable;
      	broken-cd;
      	/*cd-inverted*/
      	/*data3-detect;*/
      	/*cd-used-24M;*/
      	cap-mmc-highspeed;
      	/*sd-uhs-sdr50;*/
      	/*sd-uhs-ddr50;*/
      	/*sd-uhs-sdr104;*/
      	no-sdio;
      	no-sd;
      	mmc-bootpart-noacc;
      	ctl-spec-caps = <0x308>;
      	sdc_tm4_sm0_freq0 = <0>;
      	sdc_tm4_sm0_freq1 = <0>;
      	sdc_tm4_sm1_freq1 = <0>;
      	sdc_tm4_sm2_freq1 = <0>;
      	sdc_tm4_sm4_freq0_cmd = <0>;
      	sdc_tm4_sm4_freq1_cmd = <0>;
      	/delete-property/ cap-sd-highspeed;
      	/delete-property/ cap-wait-while-busy;
      	/delete-property/ no-mmc;
      &sdc1 {
      	bus-width = <4>;
      	no-mmc;
      	no-sd;
      	cap-sd-highspeed;
      	/*sd-uhs-sdr12*/
      	/*sd-uhs-sdr25;*/
      	/*sd-uhs-sdr50;*/
      	/*sd-uhs-ddr50;*/
      	/*sd-uhs-sdr104;*/
      	/*sunxi-power-save-mode;*/
      	/*sunxi-dis-signal-vol-sw;*/
      	cap-sdio-irq;
      	ignore-pm-notify;
      	max-frequency = <150000000>;
      &twi0 {
      	clock-frequency = <400000>;
      	pinctrl-0 = <&twi0_pins_a>;
      	pinctrl-1 = <&twi0_pins_b>;
      	twi_drv_used = <0>;
      	dmas = <&dma 43>, <&dma 43>;
      	dma-names = "tx", "rx";
              ctp@14 {
                      device_type = "ctp";
                      reg = <0x14>;
                      ctp_name = "gt9xxnew_ts";
                      ctp_twi_id = <0x2>;
                      ctp_twi_addr = <0x14>;
                      ctp_screen_max_x = <0x320>;
                      ctp_screen_max_y = <0x1e0>;
                      ctp_revert_x_flag = <0x0>;
                      ctp_revert_y_flag = <0x0>;
                      ctp_int_port = <&pio PB 6 GPIO_ACTIVE_HIGH>;
                      ctp_wakeup = <&pio PB 7 GPIO_ACTIVE_HIGH>;
                      /*ctp-supply = <&reg_aldo2>;*/
                      /*ctp_power_ldo = <&reg_aldo2>;*/
                      /*ctp_power_ldo_vol = <3300>;*/
      &twi1 {
      	pinctrl-0 = <&twi1_pins_a>;
      	pinctrl-1 = <&twi1_pins_b>;
      &twi2 {
      	pinctrl-0 = <&twi2_pins_a>;
      	pinctrl-1 = <&twi2_pins_b>;
      	twi_drv_used = <1>;
      	dmas = <&dma 45>, <&dma 45>;
      	rtc@51 {
      		compatible = "nxp,pcf8563";
      		reg = <0x51>;
      &twi3 {
      	pinctrl-0 = <&twi3_pins_a>;
      	pinctrl-1 = <&twi3_pins_b>;
      	ac108: ac108@3B {
      		#sound-dai-cells = <0>;
      		compatible = "Allwinner,MicArray_0";
      		device_type = "MicArray_0";
      		reg = <0x3B>;
      		regulator_used = <0x0>;
      		power_voltage = <3300000>;
      		regulator_name = "vcc-3v3";
      		power_gpio_used = <0x0>;
      		reset_gpio_used = <0x0>;
      		twi_bus = <0x1>;
      		pga_gain = <0x1F>;
      		slot_width = <0x20>;
      		lrck_period = <0x80>;
      		ref_pga_used = <0x1>;
      		ref_pga_gain = <0x10>;
      		ref_channel = <0x3>;
      		debug_mode = <0x0>;
      &spi0 {
      	clock-frequency = <10000000>;
      	pinctrl-1 = <&spi0_pins_c>;
      	spi_slave_mode = <0>;
      	spi0_cs_number = <1>;
          spi0_cs_bitmap = <1>;
      &spi1 {
      	pinctrl-0 = <&spi1_pins_a /*&spi1_pins_b*/>;
      	pinctrl-1 = <&spi1_pins_c>;
      	spi1_cs_number = <1>;
              spi1_cs_bitmap = <1>;
      	spi_board1@0 {
      		device_type = "spi_board1";
      		compatible = "rohm,dh2228fv";
      		spi-max-frequency = <16000000>;
      		reg = <0x0>;
      		spi-rx-bus-width = <0x4>;
      		spi-tx-bus-width = <0x4>;
      &ledc {
      	pinctrl-0 = <&ledc_pins_a>;
      	pinctrl-1 = <&ledc_pins_b>;
      	led_count = <48>;
      	output_mode = "GRB";
      	reset_ns = <84>;
      	t1h_ns = <800>;
      	t1l_ns = <450>;
      	t0h_ns = <400>;
      	t0l_ns = <850>;
      	wait_time0_ns = <84>;
      	wait_time1_ns = <84>;
      	wait_data_time_ns = <600000>;
      	status	= "okay";
      &s_cir0 {
      	pinctrl-names = "default";
      	pinctrl-0 = <&s_cir0_pins_a>;
      &ir1 {
      	pinctrl-0 = <&ir1_pins_a>;
      S 1 条回复 最后回复 回复 引用 分享 0
        Steelen LV 4 @Steelen 最后由 whycan 编辑
          三天饿九顿 LV 3 最后由 编辑
          您好。请问找到原因了嘛?我也遇见了类似的问题。
            WhycanService LV 8 @shanhai8372 最后由 WhycanService 编辑
            @shanhai8372 SDC2使用的是v4p6x驱动,这个驱动是eMMC专用的,WIFI请使用v5p3x 驱动
            参考硬件 https://oshwhub.com/gloomyghost/yuzuki-rv-router
