    V853开发板调试串口改到UART3没有成功,各位大佬帮我瞅瞅 (问题已解决)
    v853
    4900
    • U
      uuuuid LV 6 最后由 whycan 编辑
      ① configs/vision/sys_config.fex
      diff --git a/configs/vision/sys_config.fex b/configs/vision/sys_config.fex
      index f5ef249..4e92ba5 100644
      --- a/configs/vision/sys_config.fex
      +++ b/configs/vision/sys_config.fex
      @@ -95,9 +95,13 @@ twi_scl         = port:PI01<6><1><default><default>
       twi_sda         = port:PI02<6><1><default><default>
       [uart_para]
      -uart_debug_port = 0
      -uart_debug_tx   = port:PH09<5><1><default><default>
      -uart_debug_rx   = port:PH10<5><1><default><default>
      +;uart_debug_port = 0
      +;uart_debug_tx   = port:PH09<5><1><default><default>
      +;uart_debug_rx   = port:PH10<5><1><default><default>
      +uart_debug_port = 3
      +uart_debug_tx   = port:PH00<5><1><default><default>
      +uart_debug_rx   = port:PH01<5><1><default><default>
       [jtag_para]
       jtag_enable     = 0
      ② configs/vision/env.cfg
      diff --git a/configs/vision/env.cfg b/configs/vision/env.cfg
      index 9fa229d..e84f386 100644
      --- a/configs/vision/env.cfg
      +++ b/configs/vision/env.cfg
      @@ -1,8 +1,8 @@
       #kernel command arguments
      -earlyprintk=sunxi-uart,0x02500000
      +earlyprintk=sunxi-uart,0x02500C00
       initcall_debug=0
      -console=ttyS0,115200
      +console=ttyS3,115200
       nand_root=/dev/ubiblock0_4
       mmc_root=/dev/mmcblk0p4
       nor_root=/dev/mtdblock3
      ③ configs/sun8iw21p1_defconfig
      --- a/configs/sun8iw21p1_defconfig
      +++ b/configs/sun8iw21p1_defconfig
      @@ -232,4 +232,4 @@ CONFIG_LCD_SUPPORT_ICN6202=y
       # CONFIG_SUNXI_TV_FASTLOGO is not set
       # CONFIG_SUNXI_FASTLOGO_JPEG is not set
      +CONFIG_CONS_INDEX=4
      改完之后烧录 img,uart3输出:
      [64]HELLO! BOOT0 is starting!T
      [67]BOOT0 commit : 2a3ec52022
      [70]set pll start
      [71]periph0 has been enabled
      [74]set pll end
      [77]PMU: AXP21
      [80]board init ok
      [81]rtc[0] value = 0x80000002
      [84]key press :
      [86]DRAM use external ZQ!!
      [89]chip id check OK
      [91]DRAM_VCC set to 1500 mv
      [93]DRAM BOOT DRIVE INFO: V0.16
      [96]DRAM CLK = 936 MHz
      [99]DRAM Type = 3 (2:DDR2,3:DDR3)
      [102]DRAMC ZQ value: 0x7b7bfb
      [105]DRAM ODT value: 0x42.
      [108]DRAM SIZE =512 M
      [110]dram_tpr4:0x0
      [117]DRAM simple test OK.
      [120]rtc standby flag is 0x0, super standby flag is 0x0
      [125]dram size =512
      [128]audio:avcc calibration
      [130]card no is 2
      [132]sdcard 2 line count 8
      [135][mmc]: mmc driver ver 2021-12-27 10:07
      [144][mmc]: Wrong media type 0x0, but host sdc2, try mmc first
      [150][mmc]: ***Try MMC card 2***
      [165][mmc]: RMCA OK!
      [167][mmc]: bias 100
      [169][mmc]: mmc 2 bias 100
      [172][mmc]: MMC 5.1
      [174][mmc]: HSSDR52/SDR25 8 bit
      [177][mmc]: 50000000 Hz
      [179][mmc]: 7400 MB
      [181][mmc]: ***SD/MMC 2 init OK!!!***
      [234]Loading boot-pkg Succeed(index=0).
      [237]Entry_name        = optee
      [241]Entry_name        = u-boot
      [247]Entry_name        = dtb
      [250]tunning data addr:0x430003e8
      [254]Jump to second Boot.
      U-Boot 2018.05-g3a34d5f-dirty (Dec 13 2022 - 12:36:04 +0800) Allwinner Technology
      [00.425]CPU:   Allwinner Family
      [00.428]Model: sun8iw21
      I2C:   ready
      [00.454]DRAM:  512 MiB
      [00.457]Relocation Offset is: 1ced0000
      [00.481]secure enable bit: 0
      [00.496]PMU: AXP21
      [00.498]BMU: AXP21
      FDT ERROR:fdt_get_regulator_name:get property handle twi-supply error:FDT_ERR_INTERNAL
      bias_name:pc_bias        bias_vol:1800
      bias_name:pi_bias        bias_vol:1800
      [00.522]CPU=900 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=24Mhz  MBus=300Mhz
      [00.528]gic: sec monitor mode
      sunxi flash map init
      [00.532]flash init start
      [00.535]workmode = 0,storage type = 2
      [00.538][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
      [00.543][mmc]: get sdc_type fail and use default host:tm4.
      [00.550][mmc]: SUNXI SDMMC Controller Version:0x50400
      [00.578][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 8
      [00.584]sunxi flash init ok
      [00.587]line:724 init_clocks
      [00.590]drv_disp_init
      request pwm success, pwm9:pwm9:0x2000c00.
      [00.604]drv_disp_init finish
      [00.608]Loading Environment from SUNXI_FLASH... backup env check CRC fail
      Now update backup env
      Saving Environment to SUNXI_FLASH... Writing to env...
      OK
      OK
      [00.646]boot_gui_init:start
      [00.649]set disp.dev2_output_type fail. using defval=0
      [00.654][ICN6202 TO LVDS] LINE:0146-->lcd_open_flow:
      [00.659][ICN6202 TO LVDS] LINE:0167-->lcd_power_on:
      [00.676]boot_gui_init:finish
      54 bytes read in 0 ms
      [00.686]bmp_name=bootlogo.bmp size 38454
      [00.690][ICN6202 TO LVDS] LINE:0575-->lcd_panel_init:
      [00.855][ICN6202 TO LVDS] LINE:0620-->lcd_panel_init:initialization:icn6202 init reg from mipi
      38454 bytes read in 188 ms (199.2 KiB/s)
      [00.897]Item0 (Map) magic is bad
      [00.900]the secure storage item0 copy0 magic is bad
      [00.917]Item0 (Map) magic is bad
      [00.919]the secure storage item0 copy1 magic is bad
      [00.924]Item0 (Map) magic is bad
      [00.927]out of usb burn from boot: not need burn key
      root_partition is rootfs
      set root to /dev/mmcblk0p4
      [00.936]update part info
      [00.939]update bootcmd
      [00.941]change working_fdt 0x5de8fe70 to 0x5de6fe70
      [00.948][mmc]: delete mmc-hs400-1_8v from dtb
      [00.952][mmc]: delete mmc-hs200-1_8v from dtb
      [00.956][mmc]: get max-frequency ok 50000000 Hz
      [00.969]The storage not support sample function
      [00.976]## error: update_fdt_dram_para : FDT_ERR_NOTFOUND
      [00.985]update dts
      [00.989][ICN6202 TO LVDS] LINE:0203-->lcd_bl_open:
      [00.996]LCD open finish
      [02.113]no vendor_boot partition is found
      [02.161]Starting kernel ...
      [02.163][mmc]: mmc exit start
      [02.182][mmc]: mmc 2 exit ok
      然后就没有然后了.
      J 1 条回复 最后回复 回复 引用 分享 0
        jr_online LV 7 @uuuuid 最后由 whycan 编辑
        @uuuuid
        看看这个精华帖?
        https://bbs.aw-ol.com/topic/1673/全志芯片tina-linux-修改-uart-引脚-uart端口
        U 1 条回复 最后回复 回复 引用 分享 1
        • U
          uuuuid LV 6 @jr_online 最后由 编辑
          @jr_online
          谢谢你, 改好了
          缺这一步:
          ④ make kernel_menuconfig 找到 Kernel low-level debugging functions,修改寄存器地址
            jr_online LV 7 @uuuuid 最后由 编辑
            @uuuuid 在 V853开发板调试串口改到UART3没有成功,各位大佬帮我瞅瞅 中说:
            @jr_online
            谢谢你, 改好了
            缺这一步:
            不客气,应该感谢贴主大佬哇。
            • U
              我把修改打了一个patch包:v853_sdk_visiom_uart3_patch.tar
              tar cvf v853_sdk_visiom_uart3_patch.tar \
              brandy/brandy-2.0/u-boot-2018/configs/sun8iw21p1_uart3_defconfig                             \
              device/config/chips/v853/configs/visiom/                                                     \
              kernel/linux-4.9/drivers/input/touchscreen/gslx680new/gslX680_3680.h                         \
              openwrt/target/v853/v853-visiom/                                                             \
              prebuilt/rootfsbuilt/arm/toolchain-sunxi-glibc-gcc-830/toolchain/usr/include/linux/version.h \
              有兴趣的朋友可以试一试,我把板级目录名改为了visiom,不影响原来的vision
