    系统无法启动
    4730
    • jinxiangwzh
      jinxiangwzh LV 7 最后由 编辑
      系统:TinaLinux,平台V536H,
      开发板厂家提供的SDK是V1.2,我下载了最新的SDK通过beyond compare比对合并,编译打包下载之后,系统无法启动,看log是卡在了挂载flash,哪位大哥指点一下看看哪里的问题
      [    2.694297] sid_get_phy_base()317 - Failed to find "" in dts.
      [    2.702988] Registering SWP/SWPB emulation handler
      [    2.714148] sunxi-rtc rtc: setting system clock to 1970-01-01 00:01:04 UTC (64)
      [    2.723153] axp2101_dcdc2: incomplete constraints, leaving on
      [    2.729710] axp2101_dcdc4: incomplete constraints, leaving on
      [    2.736172] axp2101_rtc1: incomplete constraints, leaving on
      [    2.742625] axp2101_aldo3: incomplete constraints, leaving on
      [    2.749305] axp2101_cpuldos: incomplete constraints, leaving on
      [    2.756162] ALSA device list:
      [    2.759506]   #0: audiocodec
      [    2.762739]   #1: sndhdmi
      [    2.765897] Waiting for root device /dev/mmcblk0p7...
      代码位置
      void __init prepare_namespace(void)
      	int is_floppy;
      	if (root_delay) {
      		printk(KERN_INFO "Waiting %d sec before mounting root device...\n",
      		       root_delay);
      		ssleep(root_delay);
      	 * wait for the known devices to complete their probing
      	 * Note: this is a potential source of long boot delays.
      	 * For example, it is not atypical to wait 5 seconds here
      	 * for the touchpad of a laptop to initialize.
      	wait_for_device_probe();
      	md_run_setup();
      	dm_run_setup();
      	if (saved_root_name[0]) {
      		root_device_name = saved_root_name;
      		if (!strncmp(root_device_name, "mtd", 3) ||
      		    !strncmp(root_device_name, "ubi", 3)) {
      			mount_block_root(root_device_name, root_mountflags);
      			goto out;
      		ROOT_DEV = name_to_dev_t(root_device_name);
      		if (strncmp(root_device_name, "/dev/", 5) == 0)
      			root_device_name += 5;
      	if (initrd_load())
      		goto out;
      	/* wait for any asynchronous scanning to complete */
      	if ((ROOT_DEV == 0) && root_wait) {
      		printk(KERN_INFO "Waiting for root device %s...\n",
      			saved_root_name);
      		while (driver_probe_done() != 0 ||
      			(ROOT_DEV = name_to_dev_t(saved_root_name)) == 0)
      			msleep(100);
      		async_synchronize_full();
      	is_floppy = MAJOR(ROOT_DEV) == FLOPPY_MAJOR;
      	if (is_floppy && rd_doload && rd_load_disk(0))
      		ROOT_DEV = Root_RAM0;
      	mount_root();
      out:
      	devtmpfs_mount("dev");
      	sys_mount(".", "/", NULL, MS_MOVE, NULL);
      	sys_chroot(".");
        用的是eMMC吗?
        • jinxiangwzh
          jinxiangwzh LV 7 @whycan 最后由 编辑
          @whycan 是的
            whycan晕哥 LV 9 @jinxiangwzh 最后由 编辑
            @jinxiangwzh 看下前面的日志,是不是没有生成eMMC分区?
            • jinxiangwzh
              @whycan 这是完整测日志
              [330]HELLO! BOOT0 is starting!
              [333]boot0 commit : e2f593e6bf6f822b1e4fef278a4016aa2a51c5b6
              [350]rsb_send_initseq: rsb clk 400Khz -> 3Mhz
              [354]PMU: AXP2101
              [356]set pll start
              [359]set pll end
              [9090]DRAM BOOT DRIVE INFO: V0.41
              [9093]the chip id is 0x00000004
              [9096]the chip id is 0x00000004
              [9100]the chip id is 0x00000004
              [9103]the chip id is 0x00000004
              [9106]the chip id is 0x00000004
              [9109]chip id check OK
              [9111]DRAM_VCC set to 1500 mv
              [9114]DRAM CLK =792 MHZ
              [9117]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
              [9154]Training result is = 00000007
              [9158]Actual DRAM SIZE =512 M
              [9161]DRAM SIZE =512 MBytes, para1 = 000030fa, para2 = 02000001, dram_tpr13 = 08006843
              [9178]DRAM simple test OK.
              [9181]dram size =512
              [9184]card no is 2
              [9186]sdcard 2 line count 8
              [9189][mmc]: mmc driver ver 2020-5-8 14:16
              [9193][mmc]: mmc 2 bias 00000000
              [9202][mmc]: ***Try MMC card %u***
              [9214][mmc]: MMC 5.1
              [9216][mmc]: HSDDR52/DDR50 %u bit
              [9220][mmc]: %u Hz
              [9222][mmc]: %u MB
              [9223][mmc]: ***SD/MMC %u init OK!!!***
              [9351]Loading boot-pkg Succeed(index=0).
              [9355]Entry_name        = scp
              [9365]set arisc reset to de-assert state
              [9369]Entry_name        = optee
              [9373]Entry_name        = u-boot
              [9398]Entry_name        = soc-cfg
              [9402]Entry_name        = dtb
              [9406]Ready to disable icache.
              [9409]0xffffffff 0xffffffff
              [9412]0xff17ffff 0xffffffff
              [9414]0xff0d14ff 0xffffffff
              [9417]0x1716ffff 0xffff09ff
              [9420]0x0d1effff 0xffffffff
              [9423]0x1918ffff 0xffffff29
              [9425]Jump to secend Boot.
              [    0.000000] Linux version 4.9.118 (jamo@bm-wuzhaohua) (gcc version 6.4.1 (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) ) #12 SMP PREEMPT Wed Dec 28 08:29:13 UTC 2022
              [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
              [    0.000000] OF: fdt:Machine model: sun8iw16
              [    0.000000] cma: Reserved 384 MiB at 0x48000000
              [    0.000000] On node 0 totalpages: 131072
              [    0.000000] free_area_init_node: node 0, pgdat c04a5dc0, node_mem_map c7b38000
              [    0.000000]   Normal zone: 1024 pages used for memmap
              [    0.000000]   Normal zone: 131072 pages, LIFO batch:31
              [    0.000000] percpu: Embedded 13 pages/cpu @c7ade000 s24524 r8192 d20532 u53248
              [    0.000000] pcpu-alloc: s24524 r8192 d20532 u53248 alloc=13*4096
              [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 130048
              [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x05000c00 initcall_debug=0 console=ttyS4,115200 loglevel=8 root=/dev/mmcblk0p7 rw rootwait init=/pseudo_init partitions=boot-resource@mmcblk0p2:env@mmcblk0p5:boot@mmcblk0p6:rootfs@mmcblk0p7:recovery@mmcblk0p8:rootfs_data@mmcblk0p9:misc@mmcblk0p10:private@mmcblk0p11:UDISK@mmcblk0p1 cma=384M disp_reserve=38454,0x5fc00000
              [    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
              [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
              [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
              [    0.000000] Memory: 120352K/524288K available (3018K kernel code, 211K rwdata, 1176K rodata, 168K init, 125K bss, 10720K reserved, 393216K cma-reserved, 0K highmem)
              [    0.000000]     vmalloc : 0xe0800000 - 0xff800000   ( 496 MB)
              [    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
              [    0.000000]     modules : 0xbf800000 - 0xbfe00000   (   6 MB)
              [    0.000000]       .text : 0xc0008000 - 0xc02fae2c   (3020 kB)
              [    0.000000]       .init : 0xc0448000 - 0xc0472000   ( 168 kB)
              [    0.000000]       .data : 0xc0472000 - 0xc04a6ca0   ( 212 kB)
              [    0.000000]        .bss : 0xc04a6ca0 - 0xc04c634c   ( 126 kB)
              [    0.000018] Switching to timer-based delay loop, resolution 41ns
              [    0.000055] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
              [    0.000069] pid_max: default: 4096 minimum: 301
              [    0.000218] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
              [    0.000229] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
              [    0.000880] CPU: Testing write buffer coherency: ok
              [    0.001318] CPU0: update cpu_capacity 1024
              [    0.001332] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
              [    0.001361] Setting up static identity map for 0x40008240 - 0x4000828c
              [    0.170593] CPU1: update cpu_capacity 1024
              [    0.170600] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
              [    0.170688] Brought up 2 CPUs
              [    0.170708] SMP: Total of 2 processors activated (96.00 BogoMIPS).
              [    0.170715] CPU: All CPU(s) started in SVC mode.
              [    0.171383] devtmpfs: initialized
              [    0.193576] OF: Duplicate name in regulator@0, renamed to "regulator2#1"
              [    0.193618] OF: Duplicate name in regulator@0, renamed to "regulator3#1"
              [    0.193659] OF: Duplicate name in regulator@0, renamed to "regulator7#1"
              [    0.199035] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
              [    0.199539] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
              [    0.199561] futex hash table entries: 16 (order: -2, 1024 bytes)
              [    0.212789] pinctrl core: initialized pinctrl subsystem
              [    0.214171] NET: Registered protocol family 16
              [    0.215244] DMA: preallocated 256 KiB pool for atomic coherent allocations
              [    0.216644] dump_class_init,862, success
              [    0.220781] sun8iw16p1-r-pinctrl r_pio: initialized sunXi PIO driver
              [    0.233692] sun8iw16p1-pinctrl pio: initialized sunXi PIO driver
              [    0.235227] sunxi hwspinlock vbase:0xe0858000
              [    0.275986] pwm module init!
              [    0.281110] sunxi-pm debug v3.10
              [    0.282261] G2D: Module initialized.major:253
              [    0.282773] SCSI subsystem initialized
              [    0.283797] usbcore: registered new interface driver usbfs
              [    0.283939] usbcore: registered new interface driver hub
              [    0.284072] usbcore: registered new device driver usb
              [    0.284295] media: Linux media interface: v0.10
              [    0.284399] Linux video capture interface: v2.00
              [    0.285839] ion_parse_dt_heap_common: id 0 type 0 name sys_user align 1000
              [    0.286092] ion_parse_dt_heap_common: id 1 type 1 name sys_contig align 1000
              [    0.286323] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
              [    0.286999] Advanced Linux Sound Architecture Driver Initialized.
              [    0.288359] [axp2101] chip id detect 0x4a !
              [    0.288493] [axp2101] enable dcdc2 dvm.
              [    0.320437] clocksource: Switched to clocksource arch_sys_counter
              [    0.323239] get androidboot.mode fail
              [    0.323258] sunxi_i2c_adap_init()2494 - init
              [    0.323708] [i2c0] twi_regulator: vcc-pi
              [    0.323780] sunxi_i2c_probe()2253 - [i2c0] twi_drv_used = 1
              [    0.323864] twi_request_gpio()450 - [i2c0] init name: twi0
              [    0.330324] sunxi_i2c_dma_request()1104 - [i2c0] using dma0chan0 (tx) and dma0chan1 (rx)for DMA transfers
              [    0.330713] [i2c1] twi_regulator: vcc-io
              [    0.330785] sunxi_i2c_probe()2253 - [i2c1] twi_drv_used = 1
              [    0.330864] twi_request_gpio()450 - [i2c1] init name: twi1
              [    0.331193] sunxi_i2c_dma_request()1104 - [i2c1] using dma0chan2 (tx) and dma0chan3 (rx)for DMA transfers
              [    0.332834] NET: Registered protocol family 2
              [    0.333423] TCP established hash table entries: 16 (order: -6, 64 bytes)
              [    0.333437] TCP bind hash table entries: 16 (order: -5, 128 bytes)
              [    0.333446] TCP: Hash tables configured (established 16 bind 16)
              [    0.333495] UDP hash table entries: 128 (order: 0, 4096 bytes)
              [    0.333519] UDP-Lite hash table entries: 128 (order: 0, 4096 bytes)
              [    0.333684] NET: Registered protocol family 1
              [    0.333976] sunxi budget cooling probe start !
              [    0.334000] CPU freq cooling register Success
              [    0.334016] CPU hotplug cooling register Success
              [    0.334278] CPU budget cooling register Success
              [    0.346078] workingset: timestamp_bits=30 max_order=17 bucket_order=0
              [    0.355066] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
              [    0.355082] io scheduler noop registered
              [    0.355090] io scheduler deadline registered
              [    0.355267] io scheduler cfq registered (default)
              [    0.357539] uart0: ttyS0 at MMIO 0x5000000 (irq = 297, base_baud = 1500000) is a SUNXI
              [    0.358374] uart1: ttyS1 at MMIO 0x5000400 (irq = 298, base_baud = 1500000) is a SUNXI
              [    0.359131] uart4: ttyS4 at MMIO 0x5001000 (irq = 299, base_baud = 1500000) is a SUNXI
              [    0.359154] sw_console_setup()1777 - console setup baud 115200 parity n bits 8, flow n
              [    1.179224] console [ttyS4] enabled
              [    1.184030] misc dump reg init
              [    1.210694] loop: module loaded
              [    1.214356] [NAND]NOT support panic nand
              [    1.219886] [NAND]SPIC0_BASE_ADDR e0864000
              [    1.224896] Failed to get dragonboard_flag
              [    1.229503] [NAND]nand init start
              [    1.233252] SpiNandHwInit: Start Nand Hardware initializing Jul  6 2021 01:57:53.....
              [    1.242083] kernel: nand version: 4 6023 20210913 851
              [    1.247765] print_level is no used
              [    1.251602] request spi gpio  ok!
              [    1.255326] request tx DMA
              [    1.258369] request general tx dma channel ok!
              [    1.263377] request rx DMA
              [    1.266419] request general rx dma channel ok!
              [    1.271423] NAND_ClkRequest
              [    1.274621] NAND_ClkRequest: get pll6 rate 600000000HZ
              [    1.280506] SPI nand ID: 0 0
              [    1.283754] SPI nand ID: 0 0
              [    1.286989] _SearchNandArchi fail
              [    1.290738] [ERR]SpiNandHwInit: SCN_AnalyzeNandSystem() failed!
              [    1.297398] SpiNandHwInit: End Nand Hardware initializing ..... FAIL!
              [    1.305240] sunxi-wlan wlan: wlan_busnum (1)
              [    1.310052] sunxi-wlan wlan: wlan_power_num (-1)
              [    1.315269] sunxi-wlan wlan: io_regulator_name (vcc-pg)
              [    1.321169] sunxi-wlan wlan: request pincrtl handle for device [wlan] failed
              [    1.329139] sunxi-wlan wlan: wlan_regon gpio=203  mul-sel=1  pull=-1  drv_level=-1  data=0
              [    1.338474] sunxi-wlan wlan: get gpio chip_en failed
              [    1.344091] sunxi-wlan wlan: wlan_hostwake gpio=357  mul-sel=6  pull=-1  drv_level=-1  data=0
              [    1.353710] sunxi-wlan wlan: wakeup source is disabled!
              [    1.359590] sunxi-wlan wlan: clk_name ()
              [    1.364330] pwmleds debug gpio driver init
              [    1.368942] [pwm_leds]: backlight_ctrl_init: 123===into
              [    1.374842] [pwm_leds] pwm_request pwm1 success!
              [    1.380033] pwm_backlight_init is ok==============
              [    1.386065] libphy: Fixed MDIO Bus: probed
              [    1.391243] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
              [    1.400062] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
              [    1.408903] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
              [    1.417730] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
              [    1.426563] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
              [    1.435388] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
              [    1.444214] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
              [    1.453040] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:ephy_25m
              [    1.462200] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
              [    1.471032] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
              [    1.479845] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
              [    1.488673] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
              [    1.497501] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
              [    1.506328] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
              [    1.515154] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:mad
              [    1.523784] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:mdio
              [    1.533294] gmac-power1: NULL
              [    1.536633] gmac-power2: NULL
              [    1.541035] Failed to alloc md5
              [    1.544580] eth0: Use random mac address
              [    1.549250] usbcore: registered new interface driver asix
              [    1.555438] usbcore: registered new interface driver ax88179_178a
              [    1.562379] usbcore: registered new interface driver cdc_ether
              [    1.568995] usbcore: registered new interface driver net1080
              [    1.575439] usbcore: registered new interface driver cdc_subset
              [    1.582177] usbcore: registered new interface driver zaurus
              [    1.588534] usbcore: registered new interface driver cdc_ncm
              [    1.594934] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
              [    1.602298] ehci-platform: EHCI generic platform driver
              [    1.608627] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
              [    1.615628] ohci-platform: OHCI generic platform driver
              [    1.621905] usb_serial_number:20080411
              [    1.626283] sunxi_gpadc_init,1773, success
              [    1.631661] input: sunxi-gpadc0 as /devices/virtual/input/input0
              [    1.639489] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
              [    1.646447] sunxi-rtc rtc: RTC enabled
              [    1.650995] i2c /dev entries driver
              [    1.655358] google_vp9: sunxi google vp9 version 0.1
              [    1.661676] bat_param node not found
              [    1.691739] input: axp2101-powerkey as /devices/platform/soc/pmu0/axp2101-powerkey/input/input1
              [    1.711451] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
              [    1.720858] sunxi_cpufreq_init: only one opp_table
              [    1.726251] [cpu_freq] ERR: DEBUG: get cpu 0 device
              [    1.734979] sun8iw16p1-pinctrl pio: pin PC0 already requested by spinand; cannot claim for sdc2
              [    1.744805] sun8iw16p1-pinctrl pio: pin-64 (sdc2) status -22
              [    1.751188] sun8iw16p1-pinctrl pio: could not request pin 64 (PC0) from group PC0  on device pio
              [    1.761123] sunxi-mmc sdc2: Error applying setting, reverse things back
              [    1.768586] sunxi-mmc: probe of sdc2 failed with error -22
              [    1.774958] sun8iw16p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
              [    1.784275] sun8iw16p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
              [    1.793584] sun8iw16p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
              [    1.802893] sun8iw16p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
              [    1.812200] sun8iw16p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
              [    1.821514] sun8iw16p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
              [    1.831057] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.32 2019-9-24 15:55)
              [    1.839965] sunxi-mmc sdc0: regulator prop vmmc,str vcc-sdc
              [    1.846251] sunxi-mmc sdc0: Can't get vqmmc regulator string
              [    1.852623] sunxi-mmc sdc0: Can't get vdmmc regulator string
              [    1.858988] sunxi-mmc sdc0: regulator prop vdmmc33sw,str vcc33-pf
              [    1.865852] sunxi-mmc sdc0: regulator prop vdmmc18sw,str vcc18-pf
              [    1.872714] sunxi-mmc sdc0: regulator prop vqmmc33sw,str vcc33-pf
              [    1.879567] sunxi-mmc sdc0: regulator prop vqmmc18sw,str vcc18-pf
              [    1.886456] get() with no identifier
              [    1.890484] get() with no identifier
              [    1.894630] sunxi-mmc sdc0: No vmmc regulator found
              [    1.900114] sunxi-mmc sdc0: No vqmmc regulator found
              [    1.905708] sunxi-mmc sdc0: No vdmmc regulator found
              [    1.911391] random: fast init done
              [    1.915439] sunxi-mmc sdc0: set host busy
              [    1.920012] sunxi-mmc sdc0: Got CD GPIO
              [    1.925187] sunxi-mmc sdc0: filter speed is 7340032 B/s
              [    1.931107] sunxi-mmc sdc0: filter sector is 8 sector
              [    1.936786] sunxi-mmc sdc0: Perf function is enable
              [    1.942599] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    1.980457] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    2.020609] sunxi-mmc sdc0: detmode:gpio irq
              [    2.020632] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
              [    2.037247] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.32 2019-9-24 15:55)
              [    2.046153] sunxi-mmc sdc1: Can't get vmmc regulator string
              [    2.052434] sunxi-mmc sdc1: Can't get vqmmc regulator string
              [    2.058797] sunxi-mmc sdc1: Can't get vdmmc regulator string
              [    2.065169] sunxi-mmc sdc1: Can't get vdmmc33sw regulator string
              [    2.071932] sunxi-mmc sdc1: Can't get vdmmc18sw regulator string
              [    2.078686] sunxi-mmc sdc1: Can't get vqmmc33sw regulator string
              [    2.085448] sunxi-mmc sdc1: Can't get vqmmc18sw regulator string
              [    2.092208] get() with no identifier
              [    2.096222] get() with no identifier
              [    2.100236] get() with no identifier
              [    2.104258] get() with no identifier
              [    2.108272] get() with no identifier
              [    2.112315] get() with no identifier
              [    2.116330] get() with no identifier
              [    2.120348] sunxi-mmc sdc1: No vmmc regulator found
              [    2.125839] sunxi-mmc sdc1: No vqmmc regulator found
              [    2.131428] sunxi-mmc sdc1: No vdmmc regulator found
              [    2.137006] sunxi-mmc sdc1: No vd33sw regulator found
              [    2.142692] sunxi-mmc sdc1: No vd18sw regulator found
              [    2.148370] sunxi-mmc sdc1: No vq33sw regulator found
              [    2.154061] sunxi-mmc sdc1: No vq18sw regulator found
              [    2.159750] sunxi-mmc sdc1: Cann't get uart0 pinstate,check if needed
              [    2.167407] sunxi-mmc sdc1: set host busy
              [    2.171983] mmc:failed to get gpios
              [    2.176188] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    2.186510] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
              [    2.220453] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    2.260456] sunxi-mmc sdc1: detmode:manually by software
              [    2.261285] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
              [    2.267266] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
              [    2.272453] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    2.280495] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    2.282351] sunxi-mmc sdc1: smc 1 p1 err, cmd 8, RTO !!
              [    2.293130] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
              [    2.303905] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
              [    2.309782] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
              [    2.315668] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
              [    2.321561] sunxi-mmc sdc1: smc 1 p1 err, cmd 55, RTO !!
              [    2.327437] sunxi-mmc sdc1: smc 1 p1 err, cmd 55, RTO !!
              [    2.333325] sunxi-mmc sdc1: smc 1 p1 err, cmd 55, RTO !!
              [    2.339302] sunxi-mmc sdc1: smc 1 p1 err, cmd 55, RTO !!
              [    2.344485] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    2.345342] sunxi-mmc sdc1: smc 1 p1 err, cmd 1, RTO !!
              [    2.350530] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
              [    2.385150] usbcore: registered new interface driver usbhid
              [    2.391473] usbhid: USB HID core driver
              [    2.396988] [sunxi_hdmi_codec_init] driver and deivce register finished.
              [    2.405613] sun8iw16p1-pinctrl pio: pin PH7 already requested by uart0; cannot claim for dmic
              [    2.415257] sun8iw16p1-pinctrl pio: pin-231 (dmic) status -22
              [    2.421751] sun8iw16p1-pinctrl pio: could not request pin 231 (PH7) from group PH7  on device pio
              [    2.431751] sunxi-dmic dmic: Error applying setting, reverse things back
              [    2.439313] sunxi-dmic: probe of dmic failed with error -22
              [    2.447006] gpio-spk setting ok
              [    2.451095] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INL_VIR
              [    2.460019] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INL_VIR -> AIF2 DACL Switch -> AIF1 AD0L Mixer
              [    2.471904] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INR_VIR
              [    2.480639] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INR_VIR -> AIF2 DACR Switch -> AIF1 AD0L Mixer
              [    2.492499] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INR_VIR
              [    2.501225] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INR_VIR -> AIF2 DACR Switch -> AIF1 AD0R Mixer
              [    2.513079] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INL_VIR
              [    2.521807] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INL_VIR -> AIF2 DACL Switch -> AIF1 AD0R Mixer
              [    2.533658] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INL_VIR
              [    2.542383] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INL_VIR -> AIF2 DACL Switch -> AIF1 AD1L Mixer
              [    2.554242] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INR_VIR
              [    2.562967] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INR_VIR -> AIF2 DACR Switch -> AIF1 AD1R Mixer
              [    2.574848] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INL_VIR
              [    2.583574] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INL_VIR -> AIF2DACL Switch -> DACL Mixer
              [    2.594847] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INR_VIR
              [    2.603570] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INR_VIR -> AIF2DACR Switch -> DACR Mixer
              [    2.615553] sunxi-codec-machine sndcodec: codec-aif1 <-> i2s mapping ok
              [    2.625589] sndhdmi sndhdmi: audiohdmi-dai <-> audiohdmi mapping ok
              [    2.633332] sndhdmi sndhdmi: [sunxi_sndhdmi_dev_probe] register card finished.
              [    2.642183] snddmic snddmic: ASoC: CPU DAI (null) not registered
              [    2.648956] snddmic snddmic: snd_soc_register_card() fail: -517
              [    2.655732] snddmic: probe of snddmic failed with error -16
              [    2.662512] NET: Registered protocol family 17
              [    2.667587] 8021q: 802.1Q VLAN Support v1.8
              [    2.673234] sid_get_phy_base()317 - Failed to find "" in dts.
              [    2.679749] sid_get_phy_base()317 - Failed to find "" in dts.
              [    2.686716] sid_get_phy_base()317 - Failed to find "" in dts.
              [    2.693565] sid_efuse_key_is_readable()757 - The key thermal_sensor write protect bit not burned!
              [    2.703629] sid_get_phy_base()317 - Failed to find "" in dts.
              [    2.710473] sid_get_phy_base()317 - Failed to find "" in dts.
              [    2.717299] sid_get_phy_base()317 - Failed to find "" in dts.
              [    2.726097] Registering SWP/SWPB emulation handler
              [    2.737506] sunxi-rtc rtc: setting system clock to 1970-01-01 00:00:14 UTC (14)
              [    2.746538] axp2101_dcdc2: incomplete constraints, leaving on
              [    2.753101] axp2101_dcdc4: incomplete constraints, leaving on
              [    2.759570] axp2101_rtc1: incomplete constraints, leaving on
              [    2.766034] axp2101_aldo3: incomplete constraints, leaving on
              [    2.772727] axp2101_cpuldos: incomplete constraints, leaving on
              [    2.779595] ALSA device list:
              [    2.782946]   #0: audiocodec
              [    2.786183]   #1: sndhdmi
              [    2.789341] Waiting for root device /dev/mmcblk0p7...
                @jinxiangwzh
                eMMC接sdc0,还是sdc1?dts配置有没有冲突?
