    系统突然起不来了
    • jinxiangwzh
      jinxiangwzh LV 7 最后由 编辑
      最后停留在
      end Kernel panic - not syncing: Requested init /pseudo_init failed (error -2).
      我也没修改什么,看不懂啥意思,怎么会出现这个错误
      详细启动log如下
      [    0.000000] Linux version 4.9.118 (jamo@bm-wuzhaohua) (gcc version 6.4.1 (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) ) #44 SMP PREEMPT Mon Jan 9 02:52:08 UTC 2023
      [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
      [    0.000000] OF: fdt:Machine model: sun8iw16
      [    0.000000] cma: Reserved 384 MiB at 0x48000000
      [    0.000000] On node 0 totalpages: 131072
      [    0.000000] free_area_init_node: node 0, pgdat c0422a80, node_mem_map c7b38000
      [    0.000000]   Normal zone: 1024 pages used for memmap
      [    0.000000]   Normal zone: 131072 pages, LIFO batch:31
      [    0.000000] percpu: Embedded 12 pages/cpu @c7ae0000 s20428 r8192 d20532 u49152
      [    0.000000] pcpu-alloc: s20428 r8192 d20532 u49152 alloc=12*4096
      [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 130048
      [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x05000c00 initcall_debug=0 console=ttyS4,115200 loglevel=8 root=/dev/mmcblk0p7 rw rootwait init=/pseudo_init partitions=boot-resource@mmcblk0p2:env@mmcblk0p5:boot@mmcblk0p6:rootfs@mmcblk0p7:recovery@mmcblk0p8:rootfs_data@mmcblk0p9:misc@mmcblk0p10:private@mmcblk0p11:UDISK@mmcblk0p1 cma=384M disp_reserve=38454,0x5fc00000
      [    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
      [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
      [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
      [    0.000000] Memory: 120896K/524288K available (2686K kernel code, 182K rwdata, 1028K rodata, 156K init, 114K bss, 10176K reserved, 393216K cma-reserved, 0K highmem)
      [    0.000000]     vmalloc : 0xe0800000 - 0xff800000   ( 496 MB)
      [    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
      [    0.000000]     modules : 0xbf800000 - 0xbfe00000   (   6 MB)
      [    0.000000]       .text : 0xc0008000 - 0xc02a7cac   (2688 kB)
      [    0.000000]       .init : 0xc03cf000 - 0xc03f6000   ( 156 kB)
      [    0.000000]       .data : 0xc03f6000 - 0xc0423960   ( 183 kB)
      [    0.000000]        .bss : 0xc0423960 - 0xc04402cc   ( 115 kB)
      [    0.000019] Switching to timer-based delay loop, resolution 41ns
      [    0.000058] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.000071] pid_max: default: 4096 minimum: 301
      [    0.000220] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
      [    0.000230] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
      [    0.000881] CPU: Testing write buffer coherency: ok
      [    0.001322] CPU0: update cpu_capacity 1024
      [    0.001335] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [    0.001368] Setting up static identity map for 0x40008240 - 0x4000828c
      [    0.170594] CPU1: update cpu_capacity 1024
      [    0.170601] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [    0.170689] Brought up 2 CPUs
      [    0.170709] SMP: Total of 2 processors activated (96.00 BogoMIPS).
      [    0.170716] CPU: All CPU(s) started in SVC mode.
      [    0.171376] devtmpfs: initialized
      [    0.193420] OF: Duplicate name in regulator@0, renamed to "regulator2#1"
      [    0.193462] OF: Duplicate name in regulator@0, renamed to "regulator3#1"
      [    0.193504] OF: Duplicate name in regulator@0, renamed to "regulator7#1"
      [    0.198890] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [    0.199394] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.199416] futex hash table entries: 16 (order: -2, 1024 bytes)
      [    0.212685] pinctrl core: initialized pinctrl subsystem
      [    0.214086] NET: Registered protocol family 16
      [    0.215144] DMA: preallocated 256 KiB pool for atomic coherent allocations
      [    0.216549] dump_class_init,862, success
      [    0.220622] sun8iw16p1-r-pinctrl r_pio: initialized sunXi PIO driver
      [    0.233571] sun8iw16p1-pinctrl pio: initialized sunXi PIO driver
      [    0.235138] sunxi hwspinlock vbase:0xe0858000
      [    0.274291] pwm module init!
      [    0.279331] sunxi-pm debug v3.10
      [    0.280532] G2D: Module initialized.major:253
      [    0.281596] usbcore: registered new interface driver usbfs
      [    0.281721] usbcore: registered new interface driver hub
      [    0.281866] usbcore: registered new device driver usb
      [    0.282087] media: Linux media interface: v0.10
      [    0.282188] Linux video capture interface: v2.00
      [    0.283617] ion_parse_dt_heap_common: id 0 type 0 name sys_user align 1000
      [    0.283871] ion_parse_dt_heap_common: id 1 type 1 name sys_contig align 1000
      [    0.284096] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
      [    0.284788] Advanced Linux Sound Architecture Driver Initialized.
      [    0.286125] [axp2101] chip id detect 0x4a !
      [    0.286258] [axp2101] enable dcdc2 dvm.
      [    0.306890] clocksource: Switched to clocksource arch_sys_counter
      [    0.310551] get androidboot.mode fail
      [    0.310569] sunxi_i2c_adap_init()2494 - init
      [    0.311022] [i2c0] twi_regulator: vcc-pi
      [    0.311097] sunxi_i2c_probe()2253 - [i2c0] twi_drv_used = 1
      [    0.311194] twi_request_gpio()450 - [i2c0] init name: twi0
      [    0.312287] sunxi_i2c_dma_request()1104 - [i2c0] using dma0chan0 (tx) and dma0chan1 (rx)for DMA transfers
      [    0.312638] [i2c1] twi_regulator: vcc-io
      [    0.312712] sunxi_i2c_probe()2253 - [i2c1] twi_drv_used = 1
      [    0.312789] twi_request_gpio()450 - [i2c1] init name: twi1
      [    0.313215] sunxi_i2c_dma_request()1104 - [i2c1] using dma0chan2 (tx) and dma0chan3 (rx)for DMA transfers
      [    0.315184] NET: Registered protocol family 2
      [    0.315818] TCP established hash table entries: 16 (order: -6, 64 bytes)
      [    0.315833] TCP bind hash table entries: 16 (order: -5, 128 bytes)
      [    0.315841] TCP: Hash tables configured (established 16 bind 16)
      [    0.315894] UDP hash table entries: 128 (order: 0, 4096 bytes)
      [    0.315915] UDP-Lite hash table entries: 128 (order: 0, 4096 bytes)
      [    0.316088] NET: Registered protocol family 1
      [    0.316377] sunxi budget cooling probe start !
      [    0.316402] CPU freq cooling register Success
      [    0.316418] CPU hotplug cooling register Success
      [    0.316779] CPU budget cooling register Success
      [    0.319124] workingset: timestamp_bits=30 max_order=17 bucket_order=0
      [    0.330956] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
      [    0.330972] io scheduler noop registered
      [    0.330980] io scheduler deadline registered
      [    0.331218] io scheduler cfq registered (default)
      [    0.333794] uart0: ttyS0 at MMIO 0x5000000 (irq = 297, base_baud = 1500000) is a SUNXI
      [    0.334726] uart1: ttyS1 at MMIO 0x5000400 (irq = 298, base_baud = 1500000) is a SUNXI
      [    0.335572] uart4: ttyS4 at MMIO 0x5001000 (irq = 299, base_baud = 1500000) is a SUNXI
      [    0.335596] sw_console_setup()1777 - console setup baud 115200 parity n bits 8, flow n
      [    1.151131] console [ttyS4] enabled
      [    1.156159] misc dump reg init
      [    1.159943] pwmleds debug gpio driver init
      [    1.164549] [pwm_leds]: backlight_ctrl_init: 123===into
      [    1.170450] [pwm_leds] pwm_request pwm1 success!
      [    1.175639] pwm_backlight_init is ok==============
      [    1.181649] libphy: Fixed MDIO Bus: probed
      [    1.187050] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
      [    1.195870] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
      [    1.204712] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
      [    1.213542] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
      [    1.222370] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
      [    1.231196] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
      [    1.240024] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
      [    1.248851] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:ephy_25m
      [    1.258016] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
      [    1.266830] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
      [    1.275659] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
      [    1.284485] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
      [    1.293318] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
      [    1.302145] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:rgmii
      [    1.310970] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:mad
      [    1.319599] sun8iw16p1-pinctrl pio: expect_func as:gmac0, but muxsel(3) is func:mdio
      [    1.329113] gmac-power1: NULL
      [    1.332451] gmac-power2: NULL
      [    1.337013] Failed to alloc md5
      [    1.340553] eth0: Use random mac address
      [    1.345330] usbcore: registered new interface driver asix
      [    1.351552] usbcore: registered new interface driver ax88179_178a
      [    1.358534] usbcore: registered new interface driver cdc_ether
      [    1.365196] usbcore: registered new interface driver net1080
      [    1.371689] usbcore: registered new interface driver cdc_subset
      [    1.378470] usbcore: registered new interface driver zaurus
      [    1.384874] usbcore: registered new interface driver cdc_ncm
      [    1.391263] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    1.398616] ehci-platform: EHCI generic platform driver
      [    1.404999] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    1.411996] ohci-platform: OHCI generic platform driver
      [    1.418342] usb_serial_number:20080411
      [    1.423086] foot sw gpio irq:113
      [    1.427126] input: foot_sw_event as /devices/virtual/input/input0
      [    1.434283] evbug: Connected device: input0 (foot_sw_event at unknown)
      [    1.441652] foot sw: init success
      [    1.446065] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
      [    1.452997] sunxi-rtc rtc: RTC enabled
      [    1.457626] i2c /dev entries driver
      [    1.462124] google_vp9: sunxi google vp9 version 0.1
      [    1.468478] bat_param node not found
      [    1.481851] input: axp2101-powerkey as /devices/platform/soc/pmu0/axp2101-powerkey/input/input1
      [    1.494173] evbug: Connected device: input1 (axp2101-powerkey at m1kbd/input2)
      [    1.507782] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      [    1.517095] sunxi_cpufreq_init: only one opp_table
      [    1.526101] [cpu_freq] ERR: DEBUG: get cpu 0 device
      [    1.534066] sunxi-mmc sdc2: SD/MMC/SDIO Host Controller Driver(v3.32 2019-9-24 15:55)
      [    1.543019] sunxi-mmc sdc2: regulator prop vmmc,str vcc-emmc
      [    1.553011] sunxi-mmc sdc2: regulator prop vqmmc,str vcc-pc
      [    1.559304] sunxi-mmc sdc2: regulator prop vdmmc,str none
      [    1.565375] sunxi-mmc sdc2: Can't get vdmmc33sw regulator string
      [    1.575701] sunxi-mmc sdc2: Can't get vdmmc18sw regulator string
      [    1.582475] sunxi-mmc sdc2: Can't get vqmmc33sw regulator string
      [    1.589239] sunxi-mmc sdc2: Can't get vqmmc18sw regulator string
      [    1.596956] get() with no identifier
      [    1.601010] get() with no identifier
      [    1.605026] get() with no identifier
      [    1.609073] get() with no identifier
      [    1.613092] sunxi-mmc sdc2: No vmmc regulator found
      [    1.618607] sunxi-mmc sdc2: No vqmmc regulator found
      [    1.624188] sunxi-mmc sdc2: No vdmmc regulator found
      [    1.629781] sunxi-mmc sdc2: No vd33sw regulator found
      [    1.635486] sunxi-mmc sdc2: No vd18sw regulator found
      [    1.641200] sunxi-mmc sdc2: No vq33sw regulator found
      [    1.646867] sunxi-mmc sdc2: No vq18sw regulator found
      [    1.652616] sunxi-mmc sdc2: Cann't get uart0 pinstate,check if needed
      [    1.660397] sunxi-mmc sdc2: set host busy
      [    1.664956] mmc:failed to get gpios
      [    1.670011] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.706910] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.756915] sunxi-mmc sdc2: detmode:alway in(non removable)
      [    1.763482] sun8iw16p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
      [    1.772876] sun8iw16p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
      [    1.773673] sunxi-mmc sdc2: smc 0 p2 err, cmd 52, RTO !!
      [    1.783011] sunxi-mmc sdc2: smc 0 p2 err, cmd 52, RTO !!
      [    1.788192] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.796277] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.806890] sunxi-mmc sdc2: smc 0 p2 err, cmd 8, RTO !!
      [    1.817678] sunxi-mmc sdc2: smc 0 p2 err, cmd 5, RTO !!
      [    1.818517] sunxi-mmc sdc2: smc 0 p2 err, cmd 5, RTO !!
      [    1.819393] sunxi-mmc sdc2: smc 0 p2 err, cmd 5, RTO !!
      [    1.825221] sunxi-mmc sdc2: smc 0 p2 err, cmd 5, RTO !!
      [    1.831125] sunxi-mmc sdc2: smc 0 p2 err, cmd 55, RTO !!
      [    1.837007] sunxi-mmc sdc2: smc 0 p2 err, cmd 55, RTO !!
      [    1.842904] sunxi-mmc sdc2: smc 0 p2 err, cmd 55, RTO !!
      [    1.848772] sunxi-mmc sdc2: smc 0 p2 err, cmd 55, RTO !!
      [    1.853942] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.860001] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.860057] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.868091] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.918214] sun8iw16p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
      [    1.927540] sun8iw16p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
      [    1.936823] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.947670] sun8iw16p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
      [    1.956987] sun8iw16p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
      [    1.966554] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.32 2019-9-24 15:55)
      [    1.975538] sunxi-mmc sdc0: regulator prop vmmc,str vcc-sdc
      [    1.981840] sunxi-mmc sdc0: Can't get vqmmc regulator string
      [    1.988243] sunxi-mmc sdc0: Can't get vdmmc regulator string
      [    1.994623] sunxi-mmc sdc0: regulator prop vdmmc33sw,str vcc33-pf
      [    2.001473] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 8 timing LEGACY(SDR12) dt B
      [    2.012364] sunxi-mmc sdc0: regulator prop vdmmc18sw,str vcc18-pf
      [    2.019213] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS200 dt B
      [    2.029644] sunxi-mmc sdc2: sdc set ios:clk 100000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS200 dt B
      [    2.040472] sunxi-mmc sdc2: sdc set ios:clk 100000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS(SDR20) dt B
      [    2.040521] sunxi-mmc sdc2: sdc set ios:clk 52000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS(SDR20) dt B
      [    2.062576] sunxi-mmc sdc0: regulator prop vqmmc33sw,str vcc33-pf
      [    2.069432] sunxi-mmc sdc0: regulator prop vqmmc18sw,str vcc18-pf
      [    2.076279] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS400 dt B
      [    2.076338] sunxi-mmc sdc2: sdc set ios:clk 100000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS400 dt B
      [    2.097785] get() with no identifier
      [    2.097805] mmc0: new HS400 MMC card at address 0001
      [    2.107416] get() with no identifier
      [    2.107525] sunxi-mmc sdc0: No vmmc regulator found
      [    2.107529] sunxi-mmc sdc0: No vqmmc regulator found
      [    2.107533] sunxi-mmc sdc0: No vdmmc regulator found
      [    2.108069] sunxi-mmc sdc0: set host busy
      [    2.108135] sunxi-mmc sdc0: Got CD GPIO
      [    2.108222] sunxi-mmc sdc0: filter speed is 7340032 B/s
      [    2.108228] sunxi-mmc sdc0: filter sector is 8 sector
      [    2.108233] sunxi-mmc sdc0: Perf function is enable
      [    2.108410] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.137922] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.176158] sunxi-mmc sdc0: detmode:gpio irq
      [    2.181420] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.32 2019-9-24 15:55)
      [    2.190706] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    2.190776] sunxi-mmc sdc1: Can't get vmmc regulator string
      [    2.190781] sunxi-mmc sdc1: Can't get vqmmc regulator string
      [    2.190786] sunxi-mmc sdc1: Can't get vdmmc regulator string
      [    2.190791] sunxi-mmc sdc1: Can't get vdmmc33sw regulator string
      [    2.190796] sunxi-mmc sdc1: Can't get vdmmc18sw regulator string
      [    2.190801] sunxi-mmc sdc1: Can't get vqmmc33sw regulator string
      [    2.190806] sunxi-mmc sdc1: Can't get vqmmc18sw regulator string
      [    2.190809] get() with no identifier
      [    2.190810] get() with no identifier
      [    2.190812] get() with no identifier
      [    2.190814] get() with no identifier
      [    2.190815] get() with no identifier
      [    2.190816] get() with no identifier
      [    2.190818] get() with no identifier
      [    2.190822] sunxi-mmc sdc1: No vmmc regulator found
      [    2.190826] sunxi-mmc sdc1: No vqmmc regulator found
      [    2.190830] sunxi-mmc sdc1: No vdmmc regulator found
      [    2.190834] sunxi-mmc sdc1: No vd33sw regulator found
      [    2.190838] sunxi-mmc sdc1: No vd18sw regulator found
      [    2.190842] sunxi-mmc sdc1: No vq33sw regulator found
      [    2.190846] sunxi-mmc sdc1: No vq18sw regulator found
      [    2.190859] sunxi-mmc sdc1: Cann't get uart0 pinstate,check if needed
      [    2.207497] sunxi-mmc sdc1: set host busy
      [    2.207500] mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
      [    2.207614] mmc:failed to get gpios
      [    2.207870] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.207897] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
      [    2.220433] mmcblk0boot0: mmc0:0001 8GTF4R partition 1 4.00 MiB
      [    2.234171] mmcblk0boot1: mmc0:0001 8GTF4R partition 2 4.00 MiB
      [    2.240146] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.248378]  mmcblk0: p1 p2 p3 < p5 p6 p7 p8 p9 p10 p11 >
      [    2.248403] mmcblk0: p1 size 13090816 extends beyond EOD, truncated
      [    2.266933] sunxi-mmc sdc1: detmode:manually by software
      [    2.269487] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [    2.269930] [sunxi_hdmi_codec_init] driver and deivce register finished.
      [    2.271059] sun8iw16p1-pinctrl pio: pin PH7 already requested by uart0; cannot claim for dmic
      [    2.271067] sun8iw16p1-pinctrl pio: pin-231 (dmic) status -22
      [    2.271073] sun8iw16p1-pinctrl pio: could not request pin 231 (PH7) from group PH7  on device pio
      [    2.271078] sunxi-dmic dmic: Error applying setting, reverse things back
      [    2.271099] sunxi-dmic: probe of dmic failed with error -22
      [    2.272186] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
      [    2.273316] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.277231] gpio-spk setting ok
      [    2.277232] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.279146] sunxi-mmc sdc1: smc 2 p1 err, cmd 8, RTO !!
      [    2.280563] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INL_VIR
      [    2.280570] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INL_VIR -> AIF2 DACL Switch -> AIF1 AD0L Mixer
      [    2.280580] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INR_VIR
      [    2.280585] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INR_VIR -> AIF2 DACR Switch -> AIF1 AD0L Mixer
      [    2.280594] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INR_VIR
      [    2.280599] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INR_VIR -> AIF2 DACR Switch -> AIF1 AD0R Mixer
      [    2.280608] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INL_VIR
      [    2.280614] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INL_VIR -> AIF2 DACL Switch -> AIF1 AD0R Mixer
      [    2.280620] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INL_VIR
      [    2.280625] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INL_VIR -> AIF2 DACL Switch -> AIF1 AD1L Mixer
      [    2.280635] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INR_VIR
      [    2.280641] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INR_VIR -> AIF2 DACR Switch -> AIF1 AD1R Mixer
      [    2.280674] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INL_VIR
      [    2.280680] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INL_VIR -> AIF2DACL Switch -> DACL Mixer
      [    2.280695] sunxi-internal-codec codec: ASoC: no source widget found for AIF2INR_VIR
      [    2.280701] sunxi-internal-codec codec: ASoC: Failed to add route AIF2INR_VIR -> AIF2DACR Switch -> DACR Mixer
      [    2.280927] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [    2.284857] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [    2.285686] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [    2.286506] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
      [    2.287332] sunxi-mmc sdc1: smc 2 p1 err, cmd 55, RTO !!
      [    2.288156] sunxi-mmc sdc1: smc 2 p1 err, cmd 55, RTO !!
      [    2.288976] sunxi-mmc sdc1: smc 2 p1 err, cmd 55, RTO !!
      [    2.289796] sunxi-mmc sdc1: smc 2 p1 err, cmd 55, RTO !!
      [    2.289815] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.290726] sunxi-mmc sdc1: smc 2 p1 err, cmd 1, RTO !!
      [    2.290793] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    2.730026] sunxi-codec-machine sndcodec: codec-aif1 <-> i2s mapping ok
      [    2.740275] sndhdmi sndhdmi: audiohdmi-dai <-> audiohdmi mapping ok
      [    2.748173] sndhdmi sndhdmi: [sunxi_sndhdmi_dev_probe] register card finished.
      [    2.760820] snddmic snddmic: ASoC: CPU DAI (null) not registered
      [    2.771444] snddmic snddmic: snd_soc_register_card() fail: -517
      [    2.778245] snddmic: probe of snddmic failed with error -16
      [    2.785001] NET: Registered protocol family 17
      [    2.790125] 8021q: 802.1Q VLAN Support v1.8
      [    2.795749] sid_get_phy_base()317 - Failed to find "" in dts.
      [    2.802328] sid_get_phy_base()317 - Failed to find "" in dts.
      [    2.809306] sid_get_phy_base()317 - Failed to find "" in dts.
      [    2.816126] sid_efuse_key_is_readable()757 - The key thermal_sensor write protect bit not burned!
      [    2.826212] sid_get_phy_base()317 - Failed to find "" in dts.
      [    2.833138] sid_get_phy_base()317 - Failed to find "" in dts.
      [    2.840039] sid_get_phy_base()317 - Failed to find "" in dts.
      [    2.848770] Registering SWP/SWPB emulation handler
      [    2.861718] sunxi-rtc rtc: setting system clock to 1970-01-01 00:00:14 UTC (14)
      [    2.870716] axp2101_dcdc2: incomplete constraints, leaving on
      [    2.877243] axp2101_dcdc4: incomplete constraints, leaving on
      [    2.883707] axp2101_rtc1: incomplete constraints, leaving on
      [    2.890157] axp2101_aldo3: incomplete constraints, leaving on
      [    2.896685] axp2101_aldo4: incomplete constraints, leaving on
      [    2.903290] axp2101_cpuldos: incomplete constraints, leaving on
      [    2.910166] ALSA device list:
      [    2.913498]   #0: audiocodec
      [    2.916731]   #1: sndhdmi
      [    2.920678] EXT4-fs (mmcblk0p7): couldn't mount as ext3 due to feature incompatibilities
      [    2.930368] EXT4-fs (mmcblk0p7): couldn't mount as ext2 due to feature incompatibilities
      [    2.942017] EXT4-fs (mmcblk0p7): warning: mounting unchecked fs, running e2fsck is recommended
      [    2.952730] EXT4-fs (mmcblk0p7): mounted filesystem without journal. Opts: (null)
      [    2.961217] VFS: Mounted root (ext4 filesystem) on device 179:7.
      [    2.968503] devtmpfs: mounted
      [    2.972062] Freeing unused kernel memory: 156K
      [    2.977111] This architecture does not have kernel memory protection.
      [    2.984358] Kernel panic - not syncing: Requested init /pseudo_init failed (error -2).
      [    2.993264] CPU0: stopping
      [    2.996309] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.9.118 #44
      [    3.003157] Hardware name: sun8iw16
      [    3.007102] [<c0012501>] (unwind_backtrace) from [<c000ff37>] (show_stack+0xb/0xc)
      [    3.015624] [<c000ff37>] (show_stack) from [<c01365c3>] (dump_stack+0x5b/0x70)
      [    3.023752] [<c01365c3>] (dump_stack) from [<c0011b21>] (handle_IPI+0x8d/0x104)
      [    3.031977] [<c0011b21>] (handle_IPI) from [<c000930b>] (gic_handle_irq+0x4b/0x54)
      [    3.040492] [<c000930b>] (gic_handle_irq) from [<c00105e5>] (__irq_svc+0x65/0xac)
      [    3.048904] Exception stack(0xc03f7f60 to 0xc03f7fa8)
      [    3.054585] 7f60: 00000000 000004d2 c7ae2304 c00161e1 c03f6000 c03f8fec 00000001 c03f903c
      [    3.063783] 7f80: c7fff740 c03e88c0 00000000 00000000 c03f8d00 c03f7fb0 c000deb5 c000deac
      [    3.072977] 7fa0: 40000133 ffffffff
      [    3.076901] [<c00105e5>] (__irq_svc) from [<c000deac>] (arch_cpu_idle+0xc/0x20)
      [    3.085128] [<c000deac>] (arch_cpu_idle) from [<c003d339>] (cpu_startup_entry+0xa1/0xb8)
      [    3.094236] [<c003d339>] (cpu_startup_entry) from [<c03cf8dd>] (start_kernel+0x21d/0x26c)
      [    3.103436] ---[ end Kernel panic - not syncing: Requested init /pseudo_init failed (error -2).
        https://mariadb.com/kb/en/operating-system-error-codes/
        error 2 ENOENT No such file or directory
        Y 1 条回复 最后回复 回复 引用 分享 0
          yubeer LV 5 @whycan 最后由 编辑
          @whycan 晕哥我也遇到类似的问题了,检查了root.squash里面有/ pesduo_init文件。之前编译都是没问题的,存储用的GD SPINAND,编译OTA包总是出问题,make distclean后,再编译就有这个问题了。怎么查找问题,解决呀~
             2.947099] ubi0: scanning is finished
          [    2.961308] ubi0: attached mtd3 (name "sys", size 251 MiB)
          [    2.967483] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
          [    2.975148] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
          [    2.982759] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
          [    2.990532] ubi0: good PEBs: 1004, bad PEBs: 0, corrupted PEBs: 0
          [    2.997338] ubi0: user volume: 10, internal volumes: 1, max. volumes count: 128
          [    3.005488] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
          [    3.014812] ubi0: available PEBs: 0, total reserved PEBs: 1004, PEBs reserved for bad PEB handling: 40
          [    3.025216] ubi0: background thread "ubi_bgt0d" started, PID 71
          [    3.032999] block ubiblock0_5: created from ubi0:5(rootfs)
          [    3.041649] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
          [    3.051330] cfg80211: failed to load regulatory.db
          [    3.051344] clk: Not disabling unused clocks
          [    3.064495] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
          [    3.074573] devtmpfs: mounted
          [    3.079868] Freeing unused kernel memory: 1024K
          [    3.106684] Run /pseudo_init as init process
          [    3.138822] Kernel panic - not syncing: Requested init /pseudo_init failed (error -2).
          [    3.147709] CPU1: stopping
          [    3.150729] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 5.4.61 #188
          [    3.157546] Hardware name: Generic DT based system
          [    3.162909] [<c010dee8>] (unwind_backtrace) from [<c010a678>] (show_stack+0x10/0x14)
          [    3.171551] [<c010a678>] (show_stack) from [<c0694810>] (dump_stack+0x88/0xa4)
          [    3.179641] [<c0694810>] (dump_stack) from [<c010c2b4>] (handle_IPI+0xe4/0x180)
          [    3.187828] [<c010c2b4>] (handle_IPI) from [<c0341b18>] (gic_handle_irq+0x70/0x78)
          [    3.196274] [<c0341b18>] (gic_handle_irq) from [<c01021cc>] (__irq_svc+0x6c/0xa8)
          [    3.204648] Exception stack(0xc745df80 to 0xc745dfc8)
          [    3.210283] df80: 00013a20 c7ac8374 00000000 c0114800 00000002
