    关于Maix-II-Dock(v831)的一些问题
    11545
      joeydeng LV 4 最后由 编辑
      我买了一个Maix-II-Dock(v831),我想为它重新编译系统,能提供一下资料吗
      官方默认给的v831-m2dock-maixhub-0.5.2-20220726.img能改默认启动项吗,我想关闭一开机就启动的demo
        @whycan 晕哥我编译成功了
        6c278ed6-4fca-44ae-967a-4c459fb2c816-image.png 并且成功启动了,但是我遇到了“Read-only file system” 的报错 8fad213c-9b11-486d-81bc-4e45e71912d3-image.png 该怎么解决呀😅
          whycan晕哥 LV 9 @joeydeng 最后由 编辑
          @joeydeng
          贴全部日志看看
            @whycan
            log:
            log.txt
            能提供一下官方的defconfig吗,我需要maixpy但是我不知道该怎么配置和添加
              @joeydeng
              [    3.010332] EXT4-fs warning (device mmcblk0p3): ext4_clear_journal_err:4767: Filesystem error recorded from previous mount: IO failure
              [    3.024011] EXT4-fs warning (device mmcblk0p3): ext4_clear_journal_err:4768: Marking fs in need of filesystem check.
              [    3.063979] EXT4-fs (mmcblk0p3): recovery complete
              [    3.076097] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
              [    3.085300] VFS: Mounted root (ext4 filesystem) readonly on device 179:3.
              [    3.093196] Freeing unused kernel memory: 140K
              [    3.098223] This architecture does not have kernel memory protection.
              [    3.208242] EXT4-fs (mmcblk0p3): warning: mounting fs with errors, running e2fsck is recommended
              [    3.228256] EXT4-fs error (device mmcblk0p3): ext4_has_uninit_itable:3049: comm mount: Inode table for bg 0 marked as needing zeroing
              [    3.251344] Aborting journal on device mmcblk0p3-8.
              [    3.266356] EXT4-fs (mmcblk0p3): Remounting filesystem read-only
              [    3.273151] EXT4-fs (mmcblk0p3): re-mounted. Opts: data=ordered
              [    3.290857] EXT4-fs error (device mmcblk0p3): ext4_journal_check_start:56: Detected aborted journal
              Maix-II-Dock的v831镜像如何挂载 /dev/root 为可读写模式
              https://bbs.aw-ol.com/topic/1215/share/6
                但是这篇文章没有写得太详细能讲详细点吗,谢谢
                  @joeydeng
                  在D1的tina上整上overlayfs
                  https://bbs.aw-ol.com/topic/1000/share/1
                    @whycan 全志d1的overlayfs和v831是完全一样的吗,完完全全一样的吗
                    这篇文章基本能看懂但是df80751e-8e30-4a51-9c41-b2691178ee30-image.png e2fsprogs是什么东西呀,v831也必须要加吗?
                      @whycan 我已经在menuconfig里面加了e2fsprogs3b64bbaf-1bb7-4266-8a72-b70a9193e8d7-image.png
                        @whycan 晕哥我运行了mm e2fsprogs并且成功编译了😊,但是还是遇到了问题。文章中说“这个显然,menuconfig 得开起来呀” 要改那些menuconfig呢?51dc8353-4d0b-49a5-8481-c6e21d54cac1-c41f8d1531c047e706f14e9248db53ac.png
                          @whycan 我已经成功加上overlayfs并测试成功了,但是我在opkg安装时出现了问题
                            @joeydeng 在 关于Maix-II-Dock(v831)的一些问题 中说:
                            加上overlayfs并测试成功了
                            这个是怎么成功的?
                              @whycan 还是有一点没有搞懂自己是怎么成功的,等我整理完后发一篇文章出来☺️
                                大家在docker root环境里编译时一定要加上环境变量!!!
                                export FORCE_UNSAFE_CONFIGURE=1
                                  @whycan 我成功为v831写了墨水屏驱动!!!等会儿公开😃😃😃IMG_2155.MOV
                                    @whycan d1168494-3c5a-4e94-9256-99983bb75512-image.png 晕哥,请问官方的sdk获取流程具体是怎么样的呀?🤔
                                      坐等
                                        全志客户服务平台
                                        有获取流程的,你仔细找找.
