    编译编译 Tina Linux失败
    7771
      CunJiang LV 3 最后由 编辑
      我看到东山pi的官网有说输入以下命令可以解决,但我试了还是不行
      book@100ask:~/workspace/tina-v853$ chmod 755 /home/book/workspace/tina-v853/openwrt/target/v851s/v851s-lizard/busybox-init-base-files_generate/mk_extra_dir.sh
      root@myUbuntu:/home/cunjiang/tina-v853# make V=s -j1
      ===There is tina environment.===
       Note: make is the shell functon in envsetup.sh.
      == action: openwrt_build, action_args: V=s -j1 ==
      ========ACTION List: build_linuxdev V=s -j1;========
      options :
      INFO: build linuxdev ...
      INFO: chip: sun8iw21p1
      INFO: platform: linux
      INFO: kernel: linux-4.9
      INFO: board: lizard
      INFO: output: /home/cunjiang/tina-v853/out/v851s/lizard/openwrt
      INFO: don't build dtbo ...
      INFO: build arisc
      INFO: build_bootloader: brandy_path= /home/cunjiang/tina-v853/brandy/brandy-2.0
      INFO: skip build brandy.
      INFO: build kernel ...
      INFO: Prepare toolchain ...
      Building kernel
      /home/cunjiang/tina-v853/kernel/linux-4.9/output/lib/modules/4.9.191
        CHK     include/config/kernel.release
        CHK     include/generated/uapi/linux/version.h
        CHK     include/generated/utsrelease.h
        CHK     scripts/mod/devicetable-offsets.h
        CHK     include/generated/timeconst.h
        CHK     include/generated/bounds.h
        CHK     include/generated/asm-offsets.h
        CALL    scripts/checksyscalls.sh
        CHK     include/generated/compile.h
        DTC     arch/arm/boot/dts/board.dtb
        Kernel: arch/arm/boot/Image is ready
        Building modules, stage 2.
        MODPOST 16 modules
        Kernel: arch/arm/boot/zImage is ready
        Kernel: arch/arm/boot/uImage is ready
      'arch/arm/boot/Image' -> 'output/bImage'
      'arch/arm/boot/uImage' -> 'output/uImage'
      'arch/arm/boot/zImage' -> 'output/zImage'
      Copy rootfs.cpio.gz for arm
      Building modules
      [GPU]: No GPU type is configured in /home/cunjiang/tina-v853/kernel/linux-4.9/.config.
      INFO: build dts ...
      removed '/home/cunjiang/tina-v853/out/v851s/lizard/openwrt/.board.dtb.d.dtc.tmp'
      removed '/home/cunjiang/tina-v853/out/v851s/lizard/openwrt/.board.dtb.dts.tmp'
      '/home/cunjiang/tina-v853/kernel/linux-4.9/arch/arm/boot/dts/.board.dtb.d.dtc.tmp' -> '/home/cunjiang/tina-v853/out/v851s/lizard/openwrt/.board.dtb.d.dtc.tmp'
      '/home/cunjiang/tina-v853/kernel/linux-4.9/arch/arm/boot/dts/.board.dtb.dts.tmp' -> '/home/cunjiang/tina-v853/out/v851s/lizard/openwrt/.board.dtb.dts.tmp'
      INFO: build rootfs ...
      ==mkcmd.sh: build_openwrt_rootfs V=s -j1==
      make: Entering directory '/home/cunjiang/tina-v853/openwrt/openwrt'
      make[1]: Entering directory '/home/cunjiang/tina-v853/openwrt/openwrt'
      CreateSoftLink  /home/cunjiang/tina-v853/openwrt/openwrt/tmp link to  /home/cunjiang/tina-v853/out/v851s/lizard/openwrt/tmp
      CreateSoftLink  /home/cunjiang/tina-v853/openwrt/openwrt/staging_dir link to  /home/cunjiang/tina-v853/out/v851s/lizard/openwrt/staging_dir
      make[2]: Entering directory '/home/cunjiang/tina-v853/openwrt/openwrt'
      make[2]: Leaving directory '/home/cunjiang/tina-v853/openwrt/openwrt'
      Check Vendor Package...
      CreateSoftLink  /home/cunjiang/tina-v853/openwrt/openwrt/package/subpackage link to  /home/cunjiang/tina-v853/openwrt/package
      end
      WARNING: Makefile 'package/subpackage/allwinner/multimedia/tina_multimedia_demo/decodertest/Makefile' has a dependency on 'libcedarx', which does not exist
      WARNING: Makefile 'package/subpackage/allwinner/multimedia/tina_multimedia_demo/encoderStressTest/Makefile' has a dependency on 'libcedarx', which does not exist
      WARNING: Makefile 'package/subpackage/allwinner/multimedia/tina_multimedia_demo/encodertest/Makefile' has a dependency on 'libcedarx', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-libav/Makefile' has a build dependency on 'libgstreamer1', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-libav/Makefile' has a build dependency on 'gstreamer1-plugins-base', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-omx/Makefile' has a dependency on 'libcedarx', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-omx/Makefile' has a dependency on 'libgst1gl', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-aw/Makefile' has a build dependency on 'libgstreamer1', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-aw/Makefile' has a build dependency on 'gstreamer1-plugins-base', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-aw/Makefile' has a build dependency on 'gstreamer1-plugins-good', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a dependency on 'wayland', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a dependency on 'wayland-protocols', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a dependency on 'opencv', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a dependency on 'libgst1badvideo', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a dependency on 'libgst1gl', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a build dependency on 'libgstreamer1', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a build dependency on 'gstreamer1-plugins-base', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-base/Makefile' has a build dependency on 'libgstreamer1', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-good/Makefile' has a build dependency on 'libgstreamer1', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-good/Makefile' has a build dependency on 'gstreamer1-plugins-base', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-ugly/Makefile' has a build dependency on 'libgstreamer1', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-ugly/Makefile' has a build dependency on 'gstreamer1-plugins-base', which does not exist
      WARNING: Makefile 'package/subpackage/allwinner/multimedia/tina_multimedia_demo/jpegdecodedemo/Makefile' has a dependency on 'libcedarx', which does not exist
      WARNING: Makefile 'package/kernel/linux/Makefile' has a dependency on 'kmod-sunxi-rf-wlan', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/gui/lvgl-8/lv_monitor/Makefile' has a dependency on 'libcedarx', which does not exist
      WARNING: Makefile 'package/subpackage/allwinner/multimedia/tina_multimedia_demo/moduledemo/Makefile' has a dependency on 'libcedarx', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/gui/minigui/multimedia-test/Makefile' has a dependency on 'libcedarx', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/gui/qt/qt5/Makefile' has a dependency on 'weston', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/gui/qt/qt5/Makefile' has a dependency on 'wayland', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/gui/qt/qt5/Makefile' has a dependency on 'qt5-multimediawidgets', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/gui/qt/qt5/Makefile' has a build dependency on 'libstdcpp', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/gui/minigui/smart-music-player/Makefile' has a dependency on 'libcedarx', which does not exist
      WARNING: Makefile 'package/subpackage/allwinner/multimedia/tina_multimedia_demo/tmetadataretrieverdemo/Makefile' has a dependency on 'libcedarx', which does not exist
      WARNING: Makefile 'package/subpackage/allwinner/multimedia/tina_multimedia_demo/tplayerdemo/Makefile' has a dependency on 'libcedarx', which does not exist
      WARNING: Makefile 'package/subpackage/allwinner/multimedia/tina_multimedia_demo/trecorderdemo/Makefile' has a dependency on 'libcedarx', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/gui/minigui/washing-machine/Makefile' has a dependency on 'libcedarx', which does not exist
      WARNING: Makefile 'package/subpackage/allwinner/multimedia/tina_multimedia_demo/xplayerdemo/Makefile' has a dependency on 'libcedarx', which does not exist
      WARNING: Makefile 'package/subpackage/allwinner/testtools/testapk/__trecordertest/Makefile' has a dependency on 'libcedarx', which does not exist
      make[2]: Entering directory '/home/cunjiang/tina-v853/openwrt/openwrt/scripts/config'
      make[2]: 'conf' is up to date.
      make[2]: Leaving directory '/home/cunjiang/tina-v853/openwrt/openwrt/scripts/config'
      copy from /home/cunjiang/tina-v853/openwrt/target/v851s/v851s-lizard/defconfig
      target/linux/generic/image/Config.in:12:warning: choice default symbol 'uImage' is not contained in the choice
      target/linux/generic/image/Config.in:47:warning: choice default symbol 'uImage' is not contained in the choice
      target/linux/generic/image/Config.in:72:warning: choice default symbol 'CONFIG_BOOT_IMAGE_NAME_SUFFIX_NONE' is not contained in the choice
      target/linux/generic/image/Config.in:89:warning: choice default symbol 'CONFIG_ROOTFS_IMAGE_NAME_SUFFIX_NONE' is not contained in the choice
      # No change to .config
      copy to /home/cunjiang/tina-v853/openwrt/target/v851s/v851s-lizard/defconfig
      Makefile:29: "NOTE: Will skip kernel build."
      The command image-prereq(include/kernel-build.mk) execute.
      time: target/linux/prereq#0.09#0.05#0.17
      make[1]: Leaving directory '/home/cunjiang/tina-v853/openwrt/openwrt'
      make[2]: Entering directory '/home/cunjiang/tina-v853/openwrt/target/v851s'
      /home/cunjiang/tina-v853/openwrt/openwrt/include/target.mk:248: CPU_TYPE "xscale" doesn't correspond to a known type
      Parse error at /home/cunjiang/tina-v853/openwrt/openwrt/scripts/kconfig.pl line 144.
      make[2]: Leaving directory '/home/cunjiang/tina-v853/openwrt/target/v851s'
      time: target/linux/check#0.01#0.00#0.02
      + mkdir -p /home/cunjiang/tina-v853/openwrt/openwrt/staging_dir/target
      + cd /home/cunjiang/tina-v853/openwrt/openwrt/staging_dir/target
      + mkdir -p bin lib stamp usr/include usr/lib
      mkdir -p /home/cunjiang/tina-v853/out/v851s/lizard/openwrt/build_dir/target/stamp
      touch /home/cunjiang/tina-v853/openwrt/openwrt/staging_dir/target/.prepared
      + mkdir -p /home/cunjiang/tina-v853/openwrt/openwrt/staging_dir/host
      + cd /home/cunjiang/tina-v853/openwrt/openwrt/staging_dir/host
      mkdir -p /home/cunjiang/tina-v853/out/v851s/lizard/openwrt/build_dir/host/stamp /home/cunjiang/tina-v853/openwrt/openwrt/staging_dir/host/include/sys
      install -m0644 /home/cunjiang/tina-v853/openwrt/openwrt/tools/include/*.h /home/cunjiang/tina-v853/openwrt/openwrt/staging_dir/host/include/
      install -m0644 /home/cunjiang/tina-v853/openwrt/openwrt/tools/include/sys/*.h /home/cunjiang/tina-v853/openwrt/openwrt/staging_dir/host/include/sys/
      ln -snf lib /home/cunjiang/tina-v853/openwrt/openwrt/staging_dir/host/lib64
      touch /home/cunjiang/tina-v853/openwrt/openwrt/staging_dir/host/.prepared
      make[3]: Entering directory '/home/cunjiang/tina-v853/openwrt/openwrt/tools/flock'
      make[3]: Leaving directory '/home/cunjiang/tina-v853/openwrt/openwrt/tools/flock'
      time: tools/flock/compile#0.05#0.01#0.05
      make[3]: Entering directory '/home/cunjiang/tina-v853/openwrt/openwrt/tools/xz'
      make[3]: Leaving directory '/home/cunjiang/tina-v853/openwrt/openwrt/tools/xz'
      time: tools/xz/compile#0.05#0.01#0.06
      make[3]: Entering directory '/home/cunjiang/tina-v853/openwrt/openwrt/tools/sed'
      make[3]: Leaving directory '/home/cunjiang/tina-v853/openwrt/openwrt/tools/sed'
      time: tools/sed/compile#0.06#0.01#0.06
      make[3]: Entering directory '/home/cunjiang/tina-v853/openwrt/openwrt/tools/tar'
      (cd /home/cunjiang/tina-v853/out/v851s/lizard/openwrt/build_dir/host/tar-1.32/; if [ -x configure ]; then cp -fpR /home/cunjiang/tina-v853/openwrt/openwrt/scripts/config.{guess,sub} /home/cunjiang/tina-v853/out/v851s/lizard/openwrt/build_dir/host/tar-1.32// && CC="gcc" CFLAGS="-O2 -I/home/cunjiang/tina-v853/openwrt/openwrt/staging_dir/host/include " CXX="g++" CPPFLAGS="-I/home/cunjiang/tina-v853/openwrt/openwrt/staging_dir/host/include " LDFLAGS="-L/home/cunjiang/tina-v853/openwrt/openwrt/staging_dir/host/lib " CONFIG_SHELL="/usr/bin/env bash"  bash ./configure --target=x86_64-pc-linux-gnu --host=x86_64-pc-linux-gnu --build=x86_64-pc-linux-gnu --program-prefix="" --program-suffix="" --prefix=/home/cunjiang/tina-v853/openwrt/openwrt/staging_dir/host --exec-prefix=/home/cunjiang/tina-v853/openwrt/openwrt/staging_dir/host --sysconfdir=/home/cunjiang/tina-v853/openwrt/openwrt/staging_dir/host/etc --localstatedir=/home/cunjiang/tina-v853/openwrt/openwrt/staging_dir/host/var --sbindir=/home/cunjiang/tina-v853/openwrt/openwrt/staging_dir/host/bin --without-posix-acls --without-selinux --without-xattrs --disable-acl --disable-nls ; fi )
      checking for a BSD-compatible install... /usr/bin/install -c
      checking whether build environment is sane... yes
      checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
      checking for gawk... gawk
      checking whether make sets $(MAKE)... yes
      checking whether make supports nested variables... yes
      checking whether UID '0' is supported by ustar format... yes
      checking whether GID '0' is supported by ustar format... yes
      checking how to create a ustar tar archive... gnutar
      checking whether make supports nested variables... (cached) yes
      checking for style of include used by make... GNU
      checking for x86_64-pc-linux-gnu-gcc... gcc
      checking whether the C compiler works... yes
      checking for C compiler default output file name... a.out
      checking for suffix of executables...
      checking whether we are cross compiling... no
      checking for suffix of object files... o
      checking whether we are using the GNU C compiler... yes
      checking whether gcc accepts -g... yes
      checking for gcc option to accept ISO C89... none needed
      checking whether gcc understands -c and -o together... yes
      checking dependency style of gcc... gcc3
      checking for gcc option to accept ISO C99... none needed
      checking for gcc option to accept ISO Standard C... (cached) none needed
      checking for x86_64-pc-linux-gnu-ranlib... no
      checking for ranlib... ranlib
      checking for bison... bison -y
      checking how to run the C preprocessor... gcc -E
      checking for grep that handles long lines and -e... /home/cunjiang/tina-v853/openwrt/openwrt/staging_dir/host/bin/grep
      checking for egrep... /home/cunjiang/tina-v853/openwrt/openwrt/staging_dir/host/bin/grep -E
      checking for ANSI C header files... yes
      checking for sys/types.h... yes
      checking for sys/stat.h... yes
      checking for stdlib.h... yes
      checking for string.h... yes
      checking for memory.h... yes
      checking for strings.h... yes
      checking for inttypes.h... yes
      checking for stdint.h... yes
      checking for unistd.h... yes
      checking minix/config.h usability... no
      checking minix/config.h presence... no
      checking for minix/config.h... no
      checking whether it is safe to define __EXTENSIONS__... yes
      checking whether _XOPEN_SOURCE should be defined... no
      checking for Minix Amsterdam compiler... no
      checking for x86_64-pc-linux-gnu-ar... no
      checking for ar... ar
      checking for _LARGEFILE_SOURCE value needed for large files... no
      checking for special C compiler options needed for large files... no
      checking for _FILE_OFFSET_BITS value needed for large files... no
      checking for x86_64-pc-linux-gnu-ar... ar
      checking for special C compiler options needed for large files... (cached) no
      checking for _FILE_OFFSET_BITS value needed for large files... (cached) no
      checking for inline... inline
      checking for fcntl.h... yes
      checking for linux/fd.h... yes
      checking for memory.h... (cached) yes
      checking for net/errno.h... no
      checking for sgtty.h... yes
      checking for string.h... (cached) yes
      checking for sys/param.h... yes
      checking for sys/device.h... no
      checking for sys/gentape.h... no
      checking for sys/inet.h... no
      checking for sys/io/trioctl.h... no
      checking for sys/mtio.h... yes
      checking for sys/time.h... yes
      checking for sys/tprintf.h... no
      checking for sys/tape.h... no
      checking for unistd.h... (cached) yes
      checking for locale.h... yes
      checking for sys/types.h... (cached) yes
      checking for features.h... yes
      checking for linewrap.h... no
      checking for sys/socket.h... yes
      checking for dirent.h... yes
      checking for fnmatch.h... yes
      checking for wctype.h... yes
      checking for stdio_ext.h... yes
      checking for sys/stat.h... (cached) yes
      checking for getopt.h... yes
      checking for sys/cdefs.h... yes
      checking for limits.h... yes
      checking for wchar.h... yes
      checking for stdint.h... (cached) yes
      checking for inttypes.h... (cached) yes
      checking for crtdefs.h... no
      checking for langinfo.h... yes
      checking for xlocale.h... no
      checking for sys/mman.h... yes
      checking for priv.h... no
      checking for malloc.h... yes
      checking for selinux/selinux.h... no
      checking for strings.h... (cached) yes
      checking for sysexits.h... yes
      checking for utime.h... yes
      checking for netdb.h... yes
      checking for sys/wait.h... yes
      checking for pwd.h... yes
      checking for grp.h... yes
      checking for sys/buf.h... no
      checking sys/mkdev.h usability... no
      checking sys/mkdev.h presence... no
      checking for sys/mkdev.h... no
      checking sys/sysmacros.h usability... yes
      checking sys/sysmacros.h presence... yes
      checking for sys/sysmacros.h... yes
      checking for st_fstype string in struct stat... no
      checking for mode_t... yes
      checking for pid_t... yes
      checking for off_t... yes
      checking for uid_t in sys/types.h... yes
      checking for major_t... no
      checking for minor_t... no
      checking for dev_t... yes
      checking for ino_t... yes
      checking for ssize_t... yes
      checking for fchmod... yes
      checking for flockfile... yes
      checking for funlockfile... yes
      checking for pathconf... yes
      checking for btowc... yes
      checking for canonicalize_file_name... yes
      checking for getcwd... yes
      checking for readlink... yes
      checking for realpath... yes
      checking for readlinkat... yes
      checking for chown... yes
      checking for fchown... yes
      checking for _set_invalid_parameter_handler... no
      checking for fchdir... yes
      checking for fdopendir... yes
      checking for faccessat... yes
      checking for fchmodat... yes
      checking for lchmod... no
      checking for fcntl... yes
      checking for symlink... yes
      checking for mempcpy... yes
      checking for fnmatch... yes
      checking for isblank... yes
      checking for iswctype... yes
      checking for mbsrtowcs... yes
      checking for wmemchr... yes
      checking for wmemcpy... yes
      checking for wmempcpy... yes
      checking for fstatat... yes
      checking for futimens... yes
      checking for getdelim... yes
      checking for getdtablesize... yes
      checking for getprogname... no
      checking for getexecname... no
      checking for gettimeofday... yes
      checking for iswcntrl... yes
      checking for iswblank... yes
      checking for link... yes
      checking for openat... yes
      checking for linkat... yes
      checking for lstat... yes
      checking for mbsinit... yes
      checking for mbrtowc... yes
      checking for mprotect... yes
      checking for mkdirat... yes
      checking for mkfifoat... yes
      checking for mknodat... yes
      checking for mknod... yes
      checking for tzset... yes
      checking for nl_langinfo... yes
      checking for renameat... yes
      checking for renameat2... yes
      checking for setenv... yes
      checking for sleep... yes
      checking for snprintf... yes
      checking for strdup... yes
      checking for strndup... yes
      checking for strtoimax... yes
      checking for strtoumax... yes
      checking for symlinkat... yes
      checking for localtime_r... yes
      checking for timegm... yes
      checking for pipe... yes
      checking for unlinkat... yes
      checking for utime... yes
      checking for futimes... yes
      checking for futimesat... yes
      checking for utimensat... yes
      checking for lutimes... yes
      checking for vasnprintf... no
      checking for wcrtomb... yes
      checking for wcwidth... yes
      checking for mkfifo... yes
      checking for setlocale... yes
      checking for fsync... yes
      checking for size_t... yes
      checking for working alloca.h... yes
      checking for alloca... yes
      checking for C/C++ restrict keyword... __restrict
      checking whether clearerr_unlocked is declared... yes
      checking whether feof_unlocked is declared... yes
      checking whether ferror_unlocked is declared... yes
      checking whether fflush_unlocked is declared... yes
      checking whether fgets_unlocked is declared... yes
      checking whether fputc_unlocked is declared... yes
      checking whether fputs_unlocked is declared... yes
      checking whether fread_unlocked is declared... yes
      checking whether fwrite_unlocked is declared... yes
      checking whether getc_unlocked is declared... yes
      checking whether getchar_unlocked is declared... yes
      checking whether putc_unlocked is declared... yes
      checking whether putchar_unlocked is declared... yes
      checking whether strerror_r is declared... yes
      checking for strerror_r... yes
      checking whether strerror_r returns char *... yes
      checking build system type... x86_64-pc-linux-gnu
      checking host system type... x86_64-pc-linux-gnu
      checking for d_ino member in directory struct... yes
      checking for long file names... yes
      checking whether <wchar.h> uses 'inline' correctly... yes
      checking for nl_langinfo and CODESET... yes
      checking for a traditional french locale... none
      checking whether // is distinct from /... no
      checking whether realpath works... yes
      checking for working chown... yes
      checking whether chown dereferences symlinks... yes
      checking whether chown honors trailing slash... yes
      checking whether chown always updates ctime... yes
      checking whether the preprocessor supports include_next... yes
      checking whether system header files limit the line length... no
      checking if environ is properly declared... yes
      checking for complete errno.h... yes
      checking type of array argument to getgroups... gid_t
      checking whether lstat correctly handles trailing slash... yes
      checking whether fchdir is declared... yes
      checking for working fcntl.h... yes
      checking for promoted mode_t type... mode_t
      checking for mbstate_t... yes
      checking whether stdin defaults to large file offsets... yes
      checking whether fseeko is declared... yes
      checking for fseeko... yes
      checking whether stat file-mode macros are broken... no
      checking for nlink_t... yes
      checking whether getcwd (NULL, 0) allocates memory for result... yes
      checking for getcwd with POSIX signature... yes
      checking whether getcwd is declared... yes
      checking whether getdelim is declared... yes
      checking whether getdtablesize is declared... yes
      checking whether getline is declared... yes
      checking for getopt.h... (cached) yes
      checking for getopt_long_only... yes
      checking whether getopt is POSIX compatible... yes
      checking for working GNU getopt function... yes
      checking for working GNU getopt_long function... yes
      checking for struct timeval... yes
      checking for wide-enough struct timeval.tv_sec member... yes
      checking whether limits.h has LLONG_MAX, WORD_BIT, ULLONG_WIDTH etc.... yes
      checking for wint_t... yes
      checking whether wint_t is too small... no
      checking for unsigned long long int... yes
      checking for long long int... yes
      checking whether stdint.h conforms to C99... yes
      checking whether stdint.h predates C++11... no
      checking whether stdint.h has UINTMAX_WIDTH etc.... yes
      checking whether the inttypes.h PRIxNN macros are broken... no
      checking whether iswcntrl works... yes
      checking for towlower... yes
      checking for wctype_t... yes
      checking for wctrans_t... yes
      checking for O_CLOEXEC... yes
      checking for wchar_t... yes
      checking for good max_align_t... yes
      checking whether NULL can be used in arbitrary expressions... yes
      checking whether malloc, realloc, calloc are POSIX compliant... yes
      checking for stdlib.h... (cached) yes
      checking for GNU libc compatible malloc... yes
      checking for a traditional japanese locale... none
      checking for a transitional chinese locale... none
      checking for a french Unicode locale... none
      checking for mmap... yes
      checking for MAP_ANONYMOUS... yes
      checking whether memchr works... yes
      checking whether memrchr is declared... yes
      checking whether <limits.h> defines MIN and MAX... no
      checking whether <sys/param.h> defines MIN and MAX... yes
      checking whether time_t is signed... yes
      checking whether alarm is declared... yes
      checking for working mktime... yes
      checking whether struct tm is in sys/time.h or time.h... time.h
      checking for struct tm.tm_zone... yes
      checking for struct tm.tm_gmtoff... yes
      checking for stdbool.h that conforms to C99... yes
      checking for _Bool... yes
      checking for compound literals... yes
      checking whether we are using the GNU C Library >= 2.1 or uClibc... yes
      checking whether setenv is declared... yes
      checking search.h usability... yes
      checking search.h presence... yes
      checking for search.h... yes
      checking for tsearch... yes
      checking for sigset_t... yes
      checking whether snprintf returns a byte count as in C99... yes
      checking whether snprintf is declared... yes
      checking whether strdup is declared... yes
      checking whether strerror(0) succeeds... yes
      checking whether strndup is declared... yes
      checking whether strnlen is declared... yes
      checking whether strtoimax is declared... yes
      checking whether strtoumax is declared... yes
      checking for struct timespec in <time.h>... yes
      checking whether unsetenv is declared... yes
      checking whether the utimes function works... yes
      checking for intmax_t... yes
      checking where to find the exponent in a 'double'... word 1 bit 20
      checking for snprintf... (cached) yes
      checking for strnlen... yes
      checking for wcslen... yes
      checking for wcsnlen... yes
      checking for mbrtowc... (cached) yes
      checking for wcrtomb... (cached) yes
      checking whether _snprintf is declared... no
      checking whether vsnprintf is declared... yes
      checking for alloca as a compiler built-in... yes
      checking whether program_invocation_name is declared... yes
      checking whether program_invocation_short_name is declared... yes
      checking whether program_invocation_name is defined... yes
      checking whether program_invocation_short_name is defined... yes
      checking whether btowc(0) is correct... yes
      checking whether btowc(EOF) is correct... guessing yes
      checking for __builtin_expect... yes
      checking whether this system has an arbitrary file name length limit... yes
      checking for library containing clock_gettime... none required
      checking for clock_gettime... yes
      checking for clock_settime... yes
      checking for closedir... yes
      checking for d_ino member in directory struct... (cached) yes
      checking for dirfd... yes
      checking whether dirfd is declared... yes
      checking whether dirfd is a macro... no
      checking whether // is distinct from /... (cached) no
      checking whether dup works... yes
      checking whether dup2 works... yes
      checking for error_at_line... yes
      checking for euidaccess... yes
      checking for fchownat... yes
      checking whether fchownat works with AT_SYMLINK_NOFOLLOW... yes
      checking whether fchownat works with an empty file name... yes
      checking whether fcntl handles F_DUPFD correctly... yes
      checking whether fcntl understands F_DUPFD_CLOEXEC... needs runtime check
      checking whether fdopendir is declared... yes
      checking whether fdopendir works... yes
      checking for struct stat.st_blocks... yes
      checking for flexible array member... yes
      checking whether conversion from 'int' to 'long double' works... yes
      checking for working GNU fnmatch... yes
      checking for __fpending... yes
      checking whether __fpending is declared... yes
      checking for fseeko... (cached) yes
      checking whether fstatat (..., 0) works... yes
      checking whether futimens works... yes
      checking whether getcwd handles long file names properly... yes
      checking for getpagesize... yes
      checking whether getcwd aborts when 4k < cwd_length < 16k... no
      checking for working getdelim function... yes
      checking whether getdtablesize works... yes
      checking for getgroups... yes
      checking for working getgroups... yes
      checking whether getgroups handles negative values... yes
      checking for getline... yes
      checking for working getline function... yes
      checking for getpagesize... (cached) yes
      checking whether getpagesize is declared... yes
      checking whether program_invocation_name is declared... (cached) yes
      checking whether program_invocation_short_name is declared... (cached) yes
      checking whether __argv is declared... no
      checking whether gettimeofday clobbers localtime buffer... no
      checking for gettimeofday with POSIX signature... yes
      checking for group_member... yes
      checking whether INT32_MAX < INTMAX_MAX... yes
      checking whether INT64_MAX == LONG_MAX... yes
      checking whether UINT32_MAX < UINTMAX_MAX... yes
      checking whether UINT64_MAX == ULONG_MAX... yes
      checking whether iswblank is declared... yes
      checking whether langinfo.h defines CODESET... yes
      checking whether langinfo.h defines T_FMT_AMPM... yes
      checking whether langinfo.h defines ALTMON_1... yes
      checking whether langinfo.h defines ERA... yes
      checking whether langinfo.h defines YESEXPR... yes
      checking for lchown... yes
      checking whether the compiler supports the __inline keyword... yes
      checking whether link obeys POSIX... yes
      checking for __xpg4... no
      checking whether link(2) dereferences a symlink... no
      checking whether linkat() can link symlinks... yes
      checking whether linkat handles trailing slash correctly... yes
      checking whether locale.h conforms to POSIX:2001... yes
      checking whether struct lconv is properly defined... yes
      checking whether lseek detects pipes... yes
      checking for GNU libc compatible malloc... (cached) yes
      checking whether mbrtowc handles incomplete characters... guessing yes
      checking whether mbrtowc works as well as mbtowc... guessing yes
      checking whether mbrtowc handles a NULL pwc argument... guessing yes
      checking whether mbrtowc handles a NULL string argument... guessing yes
      checking whether mbrtowc has a correct return value... guessing yes
      checking whether mbrtowc returns 0 when parsing a NUL character... guessing yes
      checking whether mbrtowc works on empty input... yes
      checking whether the C locale is free of encoding errors... no
      checking whether mbrtowc handles incomplete characters... (cached) guessing yes
      checking whether mbrtowc works as well as mbtowc... (cached) guessing yes
      checking whether mbsrtowcs works... guessing yes
      checking for mempcpy... (cached) yes
      checking for memrchr... yes
      checking whether mkdir handles trailing slash... yes
      checking whether mkdir handles trailing dot... yes
      checking for mkdtemp... yes
      checking whether mkfifo rejects trailing slashes... yes
      checking whether mknod can create fifo without root privileges... configure: error: in `/home/cunjiang/tina-v853/out/v851s/lizard/openwrt/build_dir/host/tar-1.32':
      configure: error: you should not run configure as root (set FORCE_UNSAFE_CONFIGURE=1 in environment to bypass this check)
      See `config.log' for more details
      Makefile:31: recipe for target '/home/cunjiang/tina-v853/out/v851s/lizard/openwrt/build_dir/host/tar-1.32/.configured' failed
      make[3]: *** [/home/cunjiang/tina-v853/out/v851s/lizard/openwrt/build_dir/host/tar-1.32/.configured] Error 1
      make[3]: Leaving directory '/home/cunjiang/tina-v853/openwrt/openwrt/tools/tar'
      time: tools/tar/compile#9.67#3.07#15.57
          ERROR: tools/tar failed to build.
      tools/Makefile:157: recipe for target 'tools/tar/compile' failed
      make[2]: *** [tools/tar/compile] Error 1
      tools/Makefile:155: recipe for target '/home/cunjiang/tina-v853/openwrt/openwrt/staging_dir/host/stamp/.tools_compile_yyynyynnyyynnyyyyynynnnnyyynyyyyyynnyyyyyyyynynnyyyyyyyy' failed
      make[1]: *** [/home/cunjiang/tina-v853/openwrt/openwrt/staging_dir/host/stamp/.tools_compile_yyynyynnyyynnyyyyynynnnnyyynyyyyyynnyyyyyyyynynnyyyyyyyy] Error 2
      /home/cunjiang/tina-v853/openwrt/openwrt/include/toplevel.mk:236: recipe for target 'world' failed
      make: *** [world] Error 2
      make: Leaving directory '/home/cunjiang/tina-v853/openwrt/openwrt'
      INFO: build_openwrt_rootfs failed
        @cunjiang 在 编译编译 Tina Linux失败 中说:
        不建议用 root 用户编译.
          CunJiang LV 3 @whycan 最后由 编辑
          @whycan 如果我不用root也编译不了
          cunjiang@myUbuntu:~/tina-v853$ make
          == action: openwrt_build, action_args:  ==
          ========ACTION List: build_linuxdev ;========
          options :
          INFO: board: lizard
          cp: cannot create regular file '/home/cunjiang/tina-v853/out/v851s/lizard/openwrt/.buildconfig': Permission denied
          INFO: build arisc
          Building kernel
          rm: cannot remove 'output/bImage': Permission denied
          rm: cannot remove 'output/rootfs.cpio.gz': Permission denied
          rm: cannot remove 'output/uImage': Permission denied
          rm: cannot remove 'output/zImage': Permission denied
          rm: cannot remove 'output/lib/modules/4.9.191/Module.symvers': Permission denied
          rm: cannot remove 'output/lib/modules/4.9.191/drbg.ko': Permission denied
          rm: cannot remove 'output/lib/modules/4.9.191/hmac.ko': Permission denied
          rm: cannot remove 'output/lib/modules/4.9.191/echainiv.ko': Permission denied
          rm: cannot remove 'output/lib/modules/4.9.191/xradio_mac.ko': Permission denied
          rm: cannot remove 'output/lib/modules/4.9.191/jitterentropy_rng.ko': Permission denied
          rm: cannot remove 'output/lib/modules/4.9.191/arc4.ko': Permission denied
          rm: cannot remove 'output/lib/modules/4.9.191/xradio_core.ko': Permission denied
          rm: cannot remove 'output/lib/modules/4.9.191/xradio_wlan.ko': Permission denied
          rm: cannot remove 'output/vmlinux.tar.bz2': Permission denied
          rm: cannot remove 'output/.config': Permission denied
          ERROR: build  Failed
          INFO: build kernel failed
          cunjiang@myUbuntu:~/tina-v853$ sudo make
          [sudo] cunjiang 的密码:
          make: *** 没有指明目标并且找不到 makefile。 停止。
            whycan晕哥 LV 9 @CunJiang 最后由 编辑
            @cunjiang
            用chown命令先把这个文件夹的权限递归改成当前用户。
            C 3 条回复 最后回复 回复 引用 分享 0
              @whycan 具体应该怎么做?
              我按照之前报错的提示输入了这条命令,编译似乎再进一步,但最后还是有报错,这次是ERROR: package/kernel/linux failed to build.
              export FORCE_UNSAFE_CONFIGURE=1
              root@myUbuntu:/home/cunjiang/tina-v853# make -j10
              == action: openwrt_build, action_args: -j10 ==
              ========ACTION List: build_linuxdev -j10;========
              options :
              INFO: board: lizard
              INFO: build arisc
              Building kernel
                MODPOST 8 modules
              Building modules
              INFO: build dts ...
              ==mkcmd.sh: build_openwrt_rootfs -j10==
              end
              time: target/linux/prereq#0.09#0.03#0.15
               make[1] world
               make[2] -C /home/cunjiang/tina-v853/openwrt/target/v851s check
               make[2] package/cleanup
               make[2] target/compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/target/v851s compile
               make[2] buildinfo
               make[2] package/compile
               make[3] -C package/libs/libiconv host-compile
               make[3] -C package/libs/toolchain compile
               make[3] -C package/system/usign host-compile
               make[3] -C package/libs/libjson-c host-compile
               make[3] -C package/libs/ncurses host-compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/libs/expat host-compile
               make[3] -C package/utils/bzip2 host-compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/libs/libffi host-compile
               make[3] -C package/libs/gettext-full host-compile
               make[3] diffconfig buildversion feedsversion
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/thirdparty/gui/directfb/flux host-compile
               make[3] -C package/utils/e2fsprogs host-compile
               make[3] -C package/libs/libubox host-compile
               make[3] -C package/libs/libjson-c compile
               make[3] -C package/firmware/prism54-firmware compile
               make[3] -C package/firmware/linux-firmware compile
               make[3] -C package/utils/lua compile
               make[3] -C package/libs/zlib compile
               make[3] -C package/firmware/wireless-regdb compile
               make[3] -C package/libs/libnl-tiny compile
               make[3] -C package/libs/libpcap compile
               make[3] -C package/libs/openssl compile
               make[3] -C package/libs/uclibc++ compile
               make[3] -C package/libs/sysfsutils compile
               make[3] -C package/libs/mbedtls compile
               make[3] -C package/libs/gettext compile
               make[3] -C package/libs/libiconv compile
               make[3] -C package/libs/libtool compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/allwinner/display/libuapi compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/allwinner/system/busybox-init-base-files compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/allwinner/testtools/testapk/rwcheck compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/libs/libev compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/allwinner/vision/camerademo compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/allwinner/wireless/common compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/lang/python/python-pip-conf compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/lang/python/python3 host-compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/libs/libxml2 compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/libs/gdbm compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/libs/libffi compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/libs/sqlite3 compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/utils/xz compile
               make[3] -C package/utils/bzip2 compile
               make[3] -C package/system/ca-certificates compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/libs/alsa-lib compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/libs/ell compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/libs/expat compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/libs/libpng compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/libs/glib2 host-compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/utils/attr compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/libs/libconfig compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/libs/libical compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/libs/libjpeg-turbo compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/libs/libsndfile compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/libs/lzo compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/libs/tinyalsa compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/libs/tslib compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/sound/fdk-aac compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/utils/dbus compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/utils/i2c-tools compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/utils/memtester compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/utils/rftest compile
               make[3] -C package/utils/adb compile
               make[3] -C package/libs/libsepol compile
               make[3] -C package/libs/musl-fts compile
               make[3] -C package/system/opkg host-compile
               make[3] -C package/kernel/linux compile
               make[3] -C package/libs/libubox compile
               make[3] -C package/libs/ncurses compile
               make[3] -C package/libs/libunwind compile
               make[3] -C package/libs/pcre compile
               make[3] -C package/libs/wolfssl compile
               make[3] -C package/network/utils/iw compile
               make[3] -C package/network/utils/tcpdump compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/allwinner/usb/adbd compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/allwinner/wireless/wifimanager compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/libs/db47 compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/libs/freetype compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/libs/glib2 compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/libs/sbc compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/feeds/sound/alsa-utils compile
               make[3] -C package/libs/libselinux compile
               make[3] -C package/utils/jsonfilter compile
               make[3] -C package/system/ubus compile
               make[3] -C package/system/uci compile
               make[3] -C package/utils/util-linux compile
               make[3] -C package/libs/readline compile
               make[3] -C package/libs/ustream-ssl compile
               make[3] -C /home/cunjiang/tina-v853/openwrt/package/thirdparty/gui/directfb/libdirectfb compile
              make -r world: build failed. Please re-run make with -j1 V=s or V=sc for a higher verbosity level to see what's going on
              make: *** [world] Error 1
                @whycan 我文件夹的权限是这样的
                替代文字
                  @whycan 我用以下命令编译成功了,还没烧写到开发板上,明天下班我试试能不能用
                  root@myUbuntu:/home/cunjiang/tina-v853# export FORCE_UNSAFE_CONFIGURE=1
                  root@myUbuntu:/home/cunjiang/tina-v853# source build/envsetup.sh
                  root@myUbuntu:/home/cunjiang/tina-v853# lunch
                  root@myUbuntu:/home/cunjiang/tina-v853# make -j1 -i V=s
                  doniyor_khalilov99 1 条回复 最后回复 回复 引用 分享 1
                  • doniyor_khalilov99
                    doniyor_khalilov LV 5 @CunJiang 最后由 编辑
                    @cunjiang 在那之后会起作用吗?
