    D1 SD卡启动失败,概率100%
    10235
      YiXinTai LV 5 最后由 xiaowenge 编辑
      log如下:
      [69]HELLO! BOOT0 is starting!
      [72]BOOT0 commit : 88480af
      [75]set pll start
      [76]fix vccio detect value:0xc0
      [79]periph0 has been enabled
      [82]set pll end
      [84][pmu]: bus read error
      [86]board init ok
      [88]get_pmu_exist() = -1
      [90]ddr_efuse_type: 0x0
      [93]trefi:7.8ms
      [95][AUTO DEBUG] single rank and full DQ!
      [99]ddr_efuse_type: 0x0
      [101]trefi:7.8ms
      [104][AUTO DEBUG] rank 0 row = 15
      [107][AUTO DEBUG] rank 0 bank = 8
      [110][AUTO DEBUG] rank 0 page size = 2 KB
      [114]DRAM BOOT DRIVE INFO: V0.33
      [117]DRAM CLK = 480 MHz
      [119]DRAM Type = 3 (2:DDR2,3:DDR3)
      [122]DRAMC ZQ value: 0x7b7bfb
      [125]DRAM ODT value: 0x42.
      [128]ddr_efuse_type: 0x0
      [131]DRAM SIZE =512 M
      [133]dram_tpr4:0x0
      [134]PLL_DDR_CTRL_REG:0xf8002700
      [137]DRAM_CLK_REG:0xc0000000
      [140][TIMING DEBUG] MR2= 0x18
      [145]DRAM simple test OK.
      [147]dram size =512
      [149]card no is 0
      [151]sdcard 0 line count 4
      [153][mmc]: mmc driver ver 2021-04-2 16:45
      [163][mmc]: Wrong media type 0x0
      [165][mmc]: ***Try SD card 0***
      [175][mmc]: HSSDR52/SDR25 4 bit
      [178][mmc]: 50000000 Hz
      [181][mmc]: 14916 MB
      [182][mmc]: ***SD/MMC 0 init OK!!!***
      [233]Loading boot-pkg Succeed(index=0).
      [236]Entry_name        = opensbi
      [239]Entry_name        = u-boot
      [243]Entry_name        = dtb
      [246]mmc not para
      [247]Jump to second Boot.
              |_|
      Platform Max HARTs     : 1
      Current Hart           : 0
      Runtime SBI Version    : 0.2
      MIDELEG : 0x0000000000000222
      MEDELEG : 0x000000000000b1ff
      PMP3    : 0x0000000000020000-0x0000000000027fff (A,[00.328][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
      [00.334][mmc]: get sdc_type fail and use default host:tm1.
      [00.340][mmc]: can't find node "mmc0",will add new node
      [00.345][mmc]: fdt err returned <no error>
      [00.349][mmc]: Using default timing para
      [00.352][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.370][mmc]: card_caps:0x30000002
      [00.373][mmc]: host_caps:0x3000003f
      [00.427]set disp.dev2_output_type fail. using defval=0
      [00.453]set disp.fb0_rot_used fail. using defval=0
      [00.458]set disp.fb0_rot_degree fail. using defval=0
      [00.642]out of usb burn from boot: not need burn key
      [00.647]Item0 (Map) magic is bad
      [00.650]the secure storage item0 copy0 magic is bad
      [00.656]Item0 (Map) magic is bad
      [00.658]the secure storage item0 copy1 magic is bad
      [00.663]Item0 (Map) magic is bad
      [00.674]The storage not support sample function
      [00.749]dts_get_dsp_memory: no /reserved-memory/dsp0 in fdt
      [00.754]dts_get_dsp_memory fail
      [01.099]no vendor_boot partition is found
      [01.311]
      Starting kernel ...
      [01.314][mmc]: MMC Device 2 not found
      [01.317][mmc]: mmc 2 not find, so not exit
      [    0.210646] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
      [    0.218056] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
      [    0.294604] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    0.302321] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    0.314643] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    0.322283] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    0.329918] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    0.337553] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    0.382203] sunxi-i2c sunxi-i2c2: Address + Read bit transmitted, ACK not received
      [    0.390657] sunxi-i2c sunxi-i2c2: engine mode: I2C BUS error state is 0x48
      [    0.398485] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x38)
      [    0.416829] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
      [    0.426055] CPU: 0 PID: 1 Comm: swapper Not tainted 5.4.61 #1
      [    0.432454] Call Trace:
      [    0.435198] [<ffffffe00002a3ee>] walk_stackframe+0x0/0xa0
      [    0.441216] [<ffffffe00002a5d0>] show_stack+0x2a/0x34
      [    0.446850] [<ffffffe0004f52a8>] dump_stack+0x20/0x28
      [    0.452482] [<ffffffe00002f396>] panic+0xee/0x2b6
      [    0.457727] [<ffffffe000000ed6>] mount_block_root+0x1ee/0x28a
      [    0.464131] [<ffffffe000000ff8>] mount_root+0x86/0x90
      [    0.469761] [<ffffffe000001112>] prepare_namespace+0x110/0x152
      [    0.476263] [<ffffffe000000b74>] kernel_init_freeable+0x17e/0x19a
      [    0.483060] [<ffffffe000508bb6>] kernel_init+0x12/0xee
      [    0.488788] [<ffffffe000029038>] ret_from_exception+0x0/0xc
      [    0.495007] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
        @yixintai 在 D1 SD卡启动失败,概率100% 中说:
        这张卡烧官方固件正常吗?
        Y 1 条回复 最后回复 回复 引用 分享 0
          YiXinTai LV 5 @whycan 最后由 编辑
          @whycan 卡是正常的,使用其他固件都可以。也换过很多卡,都遇到这种问题。都是使用PhonenixCrad制作启动卡
          whycan L 2 条回复 最后回复 回复 引用 分享 0
            whycan晕哥 LV 9 @YiXinTai 最后由 编辑
            @yixintai
            那SDK你改过什么呢?
              @whycan 默认编译,什么都不改d1-h-nezha_min
                @yixintai
                那先换张卡吧
                  @whycan 上面说过,换过很多卡了,跟卡无关。
                    @yixintai
                    那麻烦把 img 固件传上来,我烧一个看看。
                      @whycan tina_d1-h-nezha_min_uart0-ddr480.img
                        [87]HELLO! BOOT0 is starting!
                        [90]BOOT0 commit : 88480af
                        [92]set pll start
                        [94]fix vccio detect value:0xc0
                        [97]periph0 has been enabled
                        [100]set pll end
                        [101][pmu]: bus read error
                        [104]board init ok
                        [106]get_pmu_exist() = -1
                        [108]ddr_efuse_type: 0x0
                        [111]trefi:7.8ms
                        [113][AUTO DEBUG] two rank and full DQ!
                        [117]ddr_efuse_type: 0x0
                        [119]trefi:7.8ms
                        [122][AUTO DEBUG] rank 0 row = 15
                        [125][AUTO DEBUG] rank 0 bank = 8
                        [128][AUTO DEBUG] rank 0 page size = 2 KB
                        [132][AUTO DEBUG] rank 1 row = 15
                        [135][AUTO DEBUG] rank 1 bank = 8
                        [138][AUTO DEBUG] rank 1 page size = 2 KB
                        [142]rank1 config same as rank0
                        [145]DRAM BOOT DRIVE INFO: V0.33
                        [148]DRAM CLK = 480 MHz
                        [150]DRAM Type = 3 (2:DDR2,3:DDR3)
                        [153]DRAMC ZQ value: 0x7b7bfb
                        [156]DRAM ODT value: 0x42.
                        [159]ddr_efuse_type: 0x0
                        [162]DRAM SIZE =1024 M
                        [164]dram_tpr4:0x0
                        [166]PLL_DDR_CTRL_REG:0xf8002700
                        [169]DRAM_CLK_REG:0xc0000000
                        [171][TIMING DEBUG] MR2= 0x18
                        [176]DRAM simple test OK.
                        [179]dram size =1024
                        [181]card no is 0
                        [182]sdcard 0 line count 4
                        [185][mmc]: mmc driver ver 2021-04-2 16:45
                        [194][mmc]: Wrong media type 0x0
                        [197][mmc]: ***Try SD card 0***
                        [210][mmc]: HSSDR52/SDR25 4 bit
                        [212][mmc]: 50000000 Hz
                        [215][mmc]: 1876 MB
                        [217][mmc]: ***SD/MMC 0 init OK!!!***
                        [276]Loading boot-pkg Succeed(index=0).
                        [279]Entry_name        = opensbi
                        [282]Entry_name        = u-boot
                        [286]Entry_name        = dtb
                        [289]mmc not para
                        [290]Jump to second Boot.
                                |_|
                        Current Hart           : 0
                        PMP3    : 0x0000000000020000-0x0000000000027fff (A,▒[00.371][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
                        [00.377][mmc]: get sdc_type fail and use default host:tm1.
                        [00.383][mmc]: can't find node "mmc0",will add new node
                        [00.388][mmc]: fdt err returned <no error>
                        [00.392][mmc]: Using default timing para
                        [00.395][mmc]: SUNXI SDMMC Controller Version:0x50310
                        [00.416][mmc]: card_caps:0x3000000a
                        [00.419][mmc]: host_caps:0x3000003f
                        [00.464]set disp.dev2_output_type fail. using defval=0
                        [00.491]set disp.fb0_rot_used fail. using defval=0
                        [00.495]set disp.fb0_rot_degree fail. using defval=0
                        [00.685]out of usb burn from boot: not need burn key
                        [00.695]Item0 (Map) magic is bad
                        [00.698]the secure storage item0 copy0 magic is bad
                        [00.708]Item0 (Map) magic is bad
                        [00.711]the secure storage item0 copy1 magic is bad
                        [00.716]Item0 (Map) magic is bad
                        [01.563]The storage not support sample function
                        [01.620]dts_get_dsp_memory: no /reserved-memory/dsp0 in fdt
                        [01.625]dts_get_dsp_memory fail
                        [01.830]no vendor_boot partition is found
                        [02.043]
                        Starting kernel ...
                        [02.046][mmc]: MMC Device 2 not found
                        [02.049][mmc]: mmc 2 not find, so not exit
                        [    0.212672] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
                        [    0.220084] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
                        [    0.301259] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
                        [    0.309005] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
                        [    0.321264] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                        [    0.328932] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                        [    0.336517] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                        [    0.344171] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                        formating /dev/by-name/UDISK to ext4
                        /etc/preinit: line 1: mkfs.ext4: not found
                        [    7.286489] block: extroot: cannot find device UDISK
                        [    9.408310] configfs-gadget 4100000.udc-controller: failed to start g1: -19
                        [   12.891002] ======== XRADIO WIFI OPEN ========
                        [   12.897389] [XRADIO] Driver Label:XR_V02.16.85_P2P_HT40_01.31
                        [   12.904585] [XRADIO] Allocated hw_priv @ (____ptrval____)
                        [   13.246950] [XRADIO] Detect SDIO card 1
                        [   13.283677] [SBUS] XRadio Device:sdio clk=50000000
                        [   13.291391] [XRADIO] XRADIO_HW_REV 1.0 detected.
                        [   13.397745] [XRADIO] xradio_update_dpllctrl: DPLL_CTRL Sync=0x00c00000.
                        [   13.483530] [XRADIO] Bootloader complete
                        [   13.676308] [XRADIO] Firmware completed.
                        [   13.682888] [WSM] Firmware Label:XR_C09.08.52.73_DBG_02.122 2GHZ HT40 May 18 2021 13:36:09
                        [   13.700485] [XRADIO] Firmware Startup Done.
                        [   13.705712] [XRADIO_WRN] enable Multi-Rx!
                        kmodloader done
                        [   14.564957] ieee80211_do_open: vif_type=2, p2p=0, ch=3, addr=8c:3b:fb:a2:39:ce
                        [   14.600626] [STA] !!!xradio_vif_setup: id=0, type=2, p2p=0, addr=8c:3b:fb:a2:39:ce
                        [   14.621872] [AP_WRN] BSS_CHANGED_ASSOC but driver is unjoined.
                        root@TinaLinux:/#
                        root@TinaLinux:/#
                        我这里一切正常.
                          lovexulu LV 8 @YiXinTai 最后由 编辑
                          @yixintai 注意烧卡时候选择烧启动卡。你这是烧了量产卡吧
                            YiXinTai LV 5 @lovexulu 最后由 编辑
                            @lovexulu 是启动卡,@whycan晕哥 谢谢,我检查一下板子
