    A64求助大佬帮看看日志,进不去,
      abedong LV 2 最后由 whycan 编辑
      U-Boot 2014.07 (Mar 17 2016 - 16:44:15) Allwinner Technology
      uboot commit : 032f6839aa6b7a6513226ee4bc08d7ca5ae71569
      reg=0xffffffff
      normal mode: with secure monitor
      rsb: secure monitor exist
      [      0.327]pmbus:   ready
      [      0.330][ARISC] :arisc initialize
      [      0.454][ARISC] :arisc_dvfs_cfg_vf_table: support only one vf_table
      [      0.522][ARISC] :arisc para ok
      [SCP] :sunxi-arisc driver begin startup 2
      [SCP] :arisc_para size:240
      [SCP] :arisc version: [v0.1.94]
      [SCP] :sunxi-arisc driver v1.10 is starting
      [      0.539][ARISC] :sunxi-arisc driver startup succeeded
      [      0.571]PMU: AXP81X
      [      0.573]PMU: read AXP81X 84H=0xf2
      [      0.577]PMU: write AXP81X 84H=0xf6
      [      0.580]PMU: AXP81X found
      bat_vol=272, ratio=100
      [      0.587]PMU: dcdc2 1100
      [      0.590]PMU: cpux 1008 Mhz,AXI=336 Mhz
      PLL6=600 Mhz,AHB1=200 Mhz, APB1=100Mhz AHB2=300Mhz MBus=400Mhz
      device_type = 3253, onoff=1
      dcdc1_vol = 3000, onoff=1
      dcdc2_vol = 1100, onoff=1
      dcdc5_vol = 1500, onoff=1
      dcdc6_vol = 1100, onoff=1
      aldo1_vol = 3300, onoff=1
      aldo2_vol = 3300, onoff=1
      aldo3_vol = 3000, onoff=1
      dldo1_vol = 3300, onoff=0
      dldo2_vol = 3300, onoff=0
      dldo3_vol = 2800, onoff=0
      dldo4_vol = 3300, onoff=1
      eldo1_vol = 1800, onoff=1
      eldo2_vol = 1800, onoff=0
      eldo3_vol = 1800, onoff=0
      fldo2_vol = 1100, onoff=1
      gpio0_vol = 3100, onoff=0
      vbus exist
      no battery, limit to dc
      DRAM:  1008 MiB
      fdt addr: 0x76ea8300
      Relocation Offset is: 35efa000
      In:    serial
      Out:   serial
      Err:   serial
      gic: sec monitor mode
      [      0.819]start
      drv_disp_init
      init_clocks: finish init_clocks.
      unable to map dsi registers
      boot_disp.output_disp=0
      boot_disp.output_type=1
      boot_disp.output_type=4
      fetch script data boot_disp.auto_hpd fail
      disp0 device type(1) enable
      disp_ioctl, display not init yet
      [      0.992]end
      workmode = 17,storage type = 1
      [      0.996]NB1 : enter phy init
      [      0.999]nand_physic_init
      [      1.090]Reset NDFC start 0  0
      [      1.093]Reset NDFC end 0  0
      [      1.096]nand not support! channel 0 chip 0: 00 00 00 00 00 00 00 00
      [      1.102]nand not support! channel 0 chip 1: 00 00 00 00 00 00 00 00
      [      1.109]nand not support! channel 0 chip 2: 00 00 00 00 00 00 00 00
      [      1.115]nand not support! channel 0 chip 3: 00 00 00 00 00 00 00 00
      [      1.121] no nand found !
      [      1.124]nand_physic_init nand_build_nsi error
      [      1.129]nand_physic_init error -1
      NB1 : nand phy init fail
      [      1.134]NB1 : enter phy Exit
      [      1.137]nand_physic_exit
      try nand fail
      try nand fail
      try card 2
      [mmc]: mmc driver ver 2015-12-07 18:31:00
      [mmc]: get sdc_ex_dly_used 2, use auto tuning sdly
      [mmc]: current is product mode, it will tune sdly later
      SUNXI SD/MMC: 2
      [mmc]: start mmc_calibrate_delay_unit, don't access device...
      [mmc]: delay chain cal done, sample: 200(ps)
      [mmc]: delay chain cal done, ds: 200(ps)
      [mmc]: ************Try SD card 2************
      [mmc]: mmc send if cond failed
      [mmc]: send app cmd failed
      [mmc]: ************Try MMC card 2************
      [mmc]: host caps: 0x6f
      [mmc]: MID 000015 PSN 84708f1d
      [mmc]: PNM 8GME4R -- 0x38-47-4d-45-34
      [mmc]: PRV 0.1
      [mmc]: MDT m-1 y-2018
      [mmc]: MMC v5.1
      [mmc]: speed mode     : HSSDR52/SDR25
      [mmc]: clock          : 50000000 Hz
      [mmc]: bus_width      : 8 bit
      [mmc]: user capacity  : 7456 MB
      [mmc]: boot capacity  : 4096 KB
      [mmc]: rpmb capacity  : 512 KB
      [mmc]: ************SD/MMC 2 init OK!!!************
      [mmc]: EOL Info(Rev blks): Urgent!!
      [mmc]: Wear out(type A): Exceeded its max estimated life time
      [mmc]: Wear out(type B): Exceeded its max estimated life time
      [mmc]: gen_tuning_blk_bus8: total blk 10
      [mmc]: gen_tuning_blk_bus4: total blk 6
      [mmc]: write_tuning_try_freq: write ok
      [mmc]: Pattern compare ok
      [mmc]: Write tuning pattern ok
      [mmc]: ================== start tuning HSSDR52_SDR25...
      [mmc]: already at HSSDR52_SDR25 mode
      [mmc]: skip current freq 400000
      [mmc]: skip current freq 25000000
      [mmc]: start tuning freq: 2-50000000
      [mmc]: s0-255 e0-0 s1-0 e1-0
      [mmc]: s0-0 e0-4 s1-255 e1-0
      [mmc]: ================== start tuning HSDDR52_DDR50...
      [mmc]: mmc switch failed
      [mmc]: mmc swtich status error
      [mmc]: mmc switch bus width failed
      [mmc]: switch bus width fail
      [mmc]: switch to HSDDR52/DDR50 fail
      [mmc]: tuning fail at HSDDR52_DDR50
      [mmc]: switch back to HSSDR52_SDR25 8bit fail
      [mmc]: bus tuning fail, err -6
      [mmc]: mmc_init: mmc init fail, err -6
      MMC init failed
      try emmc fail
      try spinor fail
      initcall sequence 7ff9d3b4 failed at call 4a00c918
        whycan晕哥 LV 9 @abedong 最后由 编辑
        @abedong 在 A64求助大佬帮看看日志,进不去, 中说:
        try card 2
        SUNXI SD/MMC: 2
        [mmc]: Try SD card 2
        [mmc]: Try MMC card 2
        [mmc]: PRV 0.1
        [mmc]: MMC v5.1
        [mmc]: SD/MMC 2 init OK!!!
        检查eMMC
