    D1H开机启动项拉不起来
    8467
      lgkgkfg LV 6 最后由 编辑
      我在D1H 的/etc/init.d/文件夹下面添加了启动项,添加了一个自己写的QT界面,发现没法启动,但是换成别的写的C程序,开机启动能实现,而且我用终端直接./qt程序运行,也能启动,请教下可能是啥原因,造成的qt程序无法开机启动?
        whycan晕哥 LV 9 @lgkgkfg 最后由 编辑
        @lgkgkfg 在 D1H开机启动项拉不起来 中说:
        /etc/init.d/
        是不是有一个 /etc/init.d/adbd 文件?
        找到这个文件, 把需要启动的命令行写到 start_service( ) 里面试一试
          lgkgkfg LV 6 @whycan 最后由 编辑
          @whycan 我这么改的,还是起不来
          start_service() {
                  [ -e /bin/setusbconfig ] && {
                          /bin/setusbconfig adb
                  [ -d /sys/kernel/config/usb_gadget ] || {
                          mount -t configfs none /sys/kernel/config
                          mkdir /sys/kernel/config/usb_gadget/g1
                          echo "0x18d1" > /sys/kernel/config/usb_gadget/g1/idVendor
                          echo "0xD002" > /sys/kernel/config/usb_gadget/g1/idProduct
                          mkdir /sys/kernel/config/usb_gadget/g1/strings/0x409
                          echo "Allwinner" > /sys/kernel/config/usb_gadget/g1/strings/0x409/manufacturer
                          echo "Tina" > /sys/kernel/config/usb_gadget/g1/strings/0x409/product
                  [ -d /sys/kernel/config/usb_gadget/g1/configs/c.1 ] || {
                          mkdir /sys/kernel/config/usb_gadget/g1/configs/c.1
                          echo 0xc0 > /sys/kernel/config/usb_gadget/g1/configs/c.1/bmAttributes
                          echo 500 > /sys/kernel/config/usb_gadget/g1/configs/c.1/MaxPower
                          mkdir /sys/kernel/config/usb_gadget/g1/configs/c.1/strings/0x409
                  [ -d /sys/kernel/config/usb_gadget/g1/functions/ffs.adb ] || {
                          mkdir /sys/kernel/config/usb_gadget/g1/functions/ffs.adb
                  [ -e /sys/kernel/config/usb_gadget/g1/configs/c.1/ffs.adb ] || {
                          ln -s /sys/kernel/config/usb_gadget/g1/functions/ffs.adb/ /sys/kernel/config/usb_gadget/g1/configs/c.1/f        }        [ -d /dev/usb-ffs/adb ] || {        mkdir /dev/usb-ffs        mkdir /dev/usb-ffs/adb        mount -o uid=2000,gid=2000 -t functionfs adb /dev/usb-ffs/adb/
            }        get_serialnumber        echo $SERIALNUMBER > /sys/kernel/config/usb_gadget/g1/strings/0x409/serialnumber                                        procd_open_instance        procd_set_param oom_score_adj $OOM_ADJ        [ -n $ADB_TRANSPORT_PORT ] && {        procd_set_param env ADB_TRANSPORT_PORT="$ADB_TRANSPORT_PORT"                                                    }        /lgkgkfg/gui        procd_set_param command $PROG -D        procd_close_instance
          这行就是QT页面,还是拉不起来,
          /lgkgkfg/gui
          • aldfaaa
            whycan矿工-小叶 LV 7 最后由 编辑
            想开机配置网络和WiFi, 可以修改/etc/init.d/wpa_supplicant文件第48行左右....
            参考:
            Tina通过命令行连接WiFi
            https://bbs.aw-ol.com/topic/396/share/1
              start_service() {
              /lgkgkfg/gui &&
              插到这个位置
                @whycan 还是不行啊,改到这个位置还是起不来,崩溃了😧
                  @lgkgkfg
                  怎么奔溃的?
                  L 3 条回复 最后回复 回复 引用 分享 0
                    @whycan 人崩溃了😫
                      @whycan 分析是,启动之前没把QT环境变量导进去,qt环境变量放/etc/profile.d/qt.sh这个脚本里面,进入终端之后应该是加载,不进入终端好像是加载不了,开机启动就不行。但是现在依旧起不来...
                        @whycan 解决了,先source 加载脚本里面任务,在执行开机加载就行了
                          @lgkgkfg
                          可以把环境变量写到同一行,这样或许不用 source
