    V85X_ARTMOS v0.98 insmod xr806驱动失败
      htujun LV 3 最后由 编辑
      执行到 insmod /lib/modules/4.9.191/xr806.ko 命令时会造成堵塞.
      428a4f29-f0df-48e9-897a-329f2c477518-企业微信截图_16762683931540.png [图片]
      dmsg 信息如下:
      [   13.688369] [xradio_hwio_read,147][HWIO_ERR] read request failed
      [   23.698368] [xradio_hwio_write,104][HWIO_ERR] write data wait dev read state faild
      [   23.698377] [xradio_txrx_thread,437][TXRX_ERR] hwio exception, reset it
      [   23.698381] [xradio_gpio_deinit,160][SPI] xradio rxrd gpio deinit.
      [   23.698436] [xradio_spi_deinit,230][SPI] Spi unregister driver.
      [   23.698476] [xradio_spi_dev_remove,192][SPI] spi remove.
      [   25.698647] [xradio_spi_init,218][SPI] Spi register driver.
      [   25.698733] [xradio_spi_dev_probe,177][SPI] spi probe, setup spi.
      [   25.699326] [xradio_gpio_init,107][SPI] wlan gpio rw:117, irq:116
      [   25.699335] [xradio_reg_rx_ind,124][SPI] Register irq callback:116
      [   25.699381] [xradio_txrx_thread,418][TXRX] xradio tx rx thread exit!
      [   25.699414] [xradio_gpio_deinit,160][SPI] xradio rxrd gpio deinit.
      [   25.699451] [xradio_spi_deinit,230][SPI] Spi unregister driver.
      [   25.699485] [xradio_spi_dev_remove,192][SPI] spi remove.
      [   25.728467] [xradio_core_init,124][XRADIO_ERR] xradio core init Failed
      [   25.729565] [xradio_core_init,47][XRADIO] xradio wlan version:XR_V1.002.2023.02.09
      [   25.729574] [xradio_core_init,49][XRADIO] add wlan interface dev
      [   25.730384] [xradio_core_init,63][XRADIO] xradio queue init
      [   25.730400] [xradio_core_init,74][XRADIO] hardware io init
      [   25.730405] [xradio_spi_init,218][SPI] Spi register driver.
      [   25.730487] [xradio_spi_dev_probe,177][SPI] spi probe, setup spi.
      [   25.731108] [xradio_gpio_init,107][SPI] wlan gpio rw:117, irq:116
      [   25.731117] [xradio_reg_rx_ind,124][SPI] Register irq callback:116
      [   25.731163] [xradio_core_init,79][XRADIO] register tx and rx task
      [   25.731271] [xradio_core_init,84][XRADIO] up cmd init
      [   25.731328] [xradio_core_init,89][XRADIO] low cmd init
      [   27.768378] [xraido_low_cmd_dev_hand_way,226][TXRX_ERR] Host hand way dev failed:0
      [   27.768414] [xradio_unregister_trans,451][TXRX] txrx thread unregister.
      [   35.738370] [xradio_hwio_read,147][HWIO_ERR] read request failed
      [   45.748366] [xradio_hwio_write,104][HWIO_ERR] write data wait dev read state faild
      [   45.748372] [xradio_txrx_thread,437][TXRX_ERR] hwio exception, reset it
      [   45.748377] [xradio_gpio_deinit,160][SPI] xradio rxrd gpio deinit.
      [   45.748428] [xradio_spi_deinit,230][SPI] Spi unregister driver.
      [   45.748466] [xradio_spi_dev_remove,192][SPI] spi remove.
      [   47.748638] [xradio_spi_init,218][SPI] Spi register driver.
      [   47.748727] [xradio_spi_dev_probe,177][SPI] spi probe, setup spi.
      [   47.749310] [xradio_gpio_init,107][SPI] wlan gpio rw:117, irq:116
      [   47.749319] [xradio_reg_rx_ind,124][SPI] Register irq callback:116
      [   47.749366] [xradio_txrx_thread,418][TXRX] xradio tx rx thread exit!
      [   47.749396] [xradio_gpio_deinit,160][SPI] xradio rxrd gpio deinit.
      [   47.749433] [xradio_spi_deinit,230][SPI] Spi unregister driver.
      [   47.749467] [xradio_spi_dev_remove,192][SPI] spi remove.
      [   47.778439] [xradio_core_init,124][XRADIO_ERR] xradio core init Failed
      [   47.948765] [sound 1158][DAUDIO snd_sunxi_regulator_init] regulator missing or invalid
      [   47.959127] sunxi-snd-mach soc@03000000:codec_mach: sunxi-snd-codec <-> soc@03000000:codec_plat mapping ok
      [   47.960904] sunxi-snd-mach soc@03000000:daudio0_mach: snd-soc-dummy-dai <-> 2032000.daudio0_plat mapping ok
      [   48.058800] udevd (452): /proc/452/oom_adj is deprecated, please use /proc/452/oom_score_adj instead.
      [   48.059035] udev: starting version 142
      [   49.232414] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.30 2022-7-20 15:45)
      [   49.232627] sunxi-mmc sdc0: ***ctl-spec-caps*** 408
      [   49.232644] sunxi-mmc sdc0: Can't get vmmc regulator string
      [   49.232651] sunxi-mmc sdc0: Can't get vqmmc regulator string
      [   49.232657] sunxi-mmc sdc0: Can't get vdmmc regulator string
      [   49.232662] sunxi-mmc sdc0: Can't get vdmmc33sw regulator string
      [   49.232668] sunxi-mmc sdc0: Can't get vdmmc18sw regulator string
      [   49.232673] sunxi-mmc sdc0: Can't get vqmmc33sw regulator string
      [   49.232679] sunxi-mmc sdc0: Can't get vqmmc18sw regulator string
      [   49.232685] sunxi-mmc sdc0: Failed getting OCR mask: 0
      [   49.233287] sunxi-mmc sdc0: set host busy
      [   49.233296] sunxi-mmc sdc0: ***set host ocr***
      [   49.233376] sunxi-mmc sdc0: Got CD GPIO
      [   49.234402] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   49.478472] sunxi-mmc sdc0: Switching to 3.3V signalling voltage ok
      [   49.508394] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   49.538578] sunxi-mmc sdc0: detmode:gpio irq
      [   49.539963] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   49.543933] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   49.547158] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   49.551194] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   49.647778] mmc0: host does not support reading read-only switch, assuming write-enable
      [   49.651205] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [   49.651301] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [   49.651478] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      [   49.651542] mmc0: new high speed SDHC card at address aaaa
      [   49.653966] mmcblk0: mmc0:aaaa SA32G 29.7 GiB
      [   49.657607]  mmcblk0: p1
      [   49.672298] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
      [   51.805329] usbcore: registered new interface driver usbfs
      [   51.805758] usbcore: registered new interface driver hub
      [   51.806162] usbcore: registered new device driver usb
      [   51.821188] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [   51.821580] get drv_vbus is fail, 84
      [   51.821587] get ehci0-controller, regulator_io is no nocare
      [   51.821591] get ehci0-controller wakeup-source is fail.
      [   51.821796] sunxi ehci0-controller don't init wakeup source
      [   51.821809] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xbf8c6700, 0x:c6cd8000, irq_no:12e
      [   51.821813] [sunxi-ehci0]: Not init ehci0
      [   51.870157] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [   51.870554] get drv_vbus is fail, 84
      [   51.870562] get ohci0-controller, regulator_io is no nocare
      [   51.870566] get ohci0-controller wakeup-source is fail.
      [   51.870775] sunxi ohci0-controller don't init wakeup source
      [   51.870862] [sunxi-ohci0]: probe, pdev->name: 4101000.ohci0-controller, sunxi_ohci: 0xbf8c6d6c
      [   51.870867] [sunxi-ohci0]: Not init ohci0
      [   51.930357] usb_serial_number:20080411
      [   51.978756] get androidboot.mode fail
      [   52.042669] get id is fail, 84
      [   53.128441]
      [   53.128441] insmod_device_driver
      [   53.128441]
      [   53.258673] file system registered
      [   53.272263] configfs-gadget 4100000.udc-controller: failed to start g1: -19
      [   53.344178] read descriptors
      [   53.344196] read strings
      [   53.544713] android_work: sent uevent USB_STATE=CONNECTED
      [   53.563914] configfs-gadget gadget: high-speed config #1: c
      [   53.564044] android_work: sent uevent USB_STATE=CONFIGURED
        WhycanService LV 8 最后由 编辑
        xr806 wifi驱动载入失败导致多次重试阻塞,检查硬件与固件配置
