    尝试mq-r驱动mipi屏遇到问题
    3946
      soso90 LV 7 最后由 whycan 编辑
      使用mq-r,d1s板子,驱动7701s的mipi屏。修改了dts之后,系统启动到sd卡部分就卡主了。
      [    3.377416] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.19 2021-03-24 19:50)
      [    3.394561] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
      [    3.400738] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
      [    3.424297] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
      [    3.430709] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
      [    3.454296] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
      [    3.460803] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
      [    3.474297] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
      [    3.480804] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
      以下是dts
      &lcd0 {
      	lcd_used        = <1>;
      	lcd_driver_name = "tft08006";
      	lcd_if          = <4>;
      	lcd_hv_if       = <0>;
      	lcd_width       = <70>;
      	lcd_height      = <72>;
      	lcd_x           = <480>;
      	lcd_y           = <480>;
      	lcd_dclk_freq   = <9>;
      	lcd_hbp         = <20>;
      	lcd_ht          = <526>;
      	lcd_hspw        = <6>;
      	lcd_vbp         = <10>;
      	lcd_vt          = <510>;
      	lcd_vspw        = <4>;
      lcd_dsi_if=<0>;
      lcd_dsi_lane=<2>;
      lcd_lvds_if=<0>;
      lcd_lvds_colordepth=<0>;
      	lcd_lvds_mode       = <0>;
      	lcd_frm             = <0>;
      	lcd_hv_clk_phase    = <0>;
      	lcd_hv_sync_polarity= <0>;
      	lcd_gamma_en        = <0>;
      	lcd_bright_curve_en = <0>;
      	lcd_cmap_en         = <0>;
      	lcd_fsync_en        = <0>;
      	lcd_fsync_act_time  = <1000>;
      	lcd_fsync_dis_time  = <1000>;
      	lcd_fsync_pol       = <0>;
      	lcd_backlight   = <50>;
      	lcd_pwm_used    = <1>;
      	lcd_pwm_ch      = <7>;
      	lcd_pwm_freq    = <20000>;
      	lcd_pwm_pol     = <1>;
      	deu_mode            = <0>;
      	lcdgamma4iep        = <22>;
      	smart_color         = <90>;
      	lcd_frm         = <1>;
      	lcd_gamma_en    = <0>;
      	lcd_cmap_en     = <0>;
      	lcd_hv_clk_phase= <0>;
      	lcd_rb_swap          = <1>;
      	lcd_power       = "vcc-lcd";
      	lcd_pin_power   = "vcc-pd";
      	lcd_gpio_0      = <&pio PE 0 GPIO_ACTIVE_HIGH>;
      	lcd_gpio_1      = <&pio PE 1 GPIO_ACTIVE_HIGH>;
      	lcd_gpio_2      = <&pio PE 2 GPIO_ACTIVE_HIGH>;
      	lcd_gpio_3      = <&pio PE 3 GPIO_ACTIVE_HIGH>;
      //	pinctrl-0       = <&rgb18_pins_a>;
      //	pinctrl-1       = <&rgb18_pins_b>;
      board.dts
      这个dts驱动rgb屏,是能正常启动,改了lcd0相关就挂了,高手指导以下~~sdk应该比较旧,是晕哥之前的网盘版本~
        whycan晕哥 LV 9 @soso90 最后由 编辑
        @soso90
        修改之前和修改之后的完整日志都发一下。
        • mangogeek
          mangogeek LV 8 最后由 编辑
          除了去修改LCM_setting_table lcm_tft08006_setting适配特定的初始化指令外,dts部分参考如下:
          800*480,3.1寸,ips,mipi:
          &lcd0 {
              lcd_used            = <1>;
              lcd_backlight       = <100>;
              lcd_if              = <4>;
              lcd_x               = <480>;
              lcd_y               = <800>;
              lcd_width           = <48>;
              lcd_height          = <80>;
              lcd_dclk_freq       = <27>;
              lcd_pwm_used        = <1>;
              lcd_pwm_ch          = <2>;
              lcd_pwm_freq        = <1000>;
              lcd_pwm_pol         = <0>;
              lcd_pwm_max_limit   = <255>;
              lcd_hbp             = <70>;
              lcd_ht              = <600>;
              lcd_hspw            = <10>;
              lcd_vbp             = <36>;
              lcd_vt              = <956>;
              lcd_vspw            = <4>;
              lcd_dsi_if          = <0>;
              lcd_dsi_lane        = <2>;
              lcd_lvds_if         = <0>;
              lcd_lvds_colordepth = <0>;
              lcd_frm             = <0>;
              lcd_gamma_en        = <0>;
              lcd_cmap_en         = <0>;
              lcd_fsync_en        = <0>;
              deu_mode            = <0>;
              smart_color         = <90>;
          • F
            fantasya LV 4 最后由 编辑
            请问楼主解决了吗,目前我也是遇到一样的问题
