    aclocal-1.16: error: aclocal: file 'm4/lt~obsolete.m4' does not exist
    • P
      PLwl20220517 LV 3 最后由 编辑
      CDPATH="${ZSH_VERSION+.}:" && cd . && /usr/bin/env bash /home/tanyb/share/V85X_SDK/V85X_SDK/out/v851s-fastboot/compile_dir/host/erofs-utils-1.2/config/missing aclocal-1.16 -I m4
      Action Install Finished
      make[3]: Leaving directory '/home/tanyb/share/V85X_SDK/V85X_SDK/tools/squashfskit4'
      make[3]: Entering directory '/home/tanyb/share/V85X_SDK/V85X_SDK/tools/lzop'
      Makefile:380: recipe for target 'aclocal.m4' failed
      make[4]: *** [aclocal.m4] Error 1
      make[4]: Leaving directory '/home/tanyb/share/V85X_SDK/V85X_SDK/out/v851s-fastboot/compile_dir/host/erofs-utils-1.2'
      Makefile:41: recipe for target '/home/tanyb/share/V85X_SDK/V85X_SDK/out/v851s-fastboot/compile_dir/host/erofs-utils-1.2/.built' failed
      make[3]: *** [/home/tanyb/share/V85X_SDK/V85X_SDK/out/v851s-fastboot/compile_dir/host/erofs-utils-1.2/.built] Error 2
      make[3]: Leaving directory '/home/tanyb/share/V85X_SDK/V85X_SDK/tools/erofs-utils'
      tools/Makefile:137: recipe for target 'tools/erofs-utils/compile' failed
      make[2]: *** [tools/erofs-utils/compile] Error 2
      make[2]: *** Waiting for unfinished jobs....
      Action Compile Finished
      make[3]: Leaving directory '/home/tanyb/share/V85X_SDK/V85X_SDK/tools/lzop'
      make[2]: Leaving directory '/home/tanyb/share/V85X_SDK/V85X_SDK'
      tools/Makefile:136: recipe for target '/home/tanyb/share/V85X_SDK/V85X_SDK/out/v851s-fastboot/staging_dir/target/stamp/.tools_install_yyyynyyyynyyyyyyynnnyyyyyyyyyyynnyyyyyyyynyyynyyyyy' failed
      make[1]: *** [/home/tanyb/share/V85X_SDK/V85X_SDK/out/v851s-fastboot/staging_dir/target/stamp/.tools_install_yyyynyyyynyyyyyyynnnyyyyyyyyyyynnyyyyyyyynyyynyyyyy] Error 2
      make[1]: Leaving directory '/home/tanyb/share/V85X_SDK/V85X_SDK'
      Build failed - please re-run with -j1 to see the real error message
      P 1 条回复 最后回复 回复 引用 分享 0
      • P
        PLwl20220517 LV 3 @PLwl20220517 最后由 编辑
        @plwl20220517 在 aclocal-1.16: error: aclocal: file 'm4/lt~obsolete.m4' does not exist 中说:
        erofs-utils
        编译的时候,不编erofs-utils这个可以编过去
