    v851s使用yolo3 demo错误 ,如何优化,如何处理
    5173
      super0759 LV 5 最后由 q1215200171 编辑
      这个能否优化,如何处理,看是内存不够,如何优化?
      root@TinaLinux:/mnt/UDISK# ls
      416.jpg  overlay
      root@TinaLinux:/mnt/UDISK# yolov3 /etc/models/yolov3_model.nb 416.jpg
      [0xb6f0d560]vip_init[104], [  415.175677] npu[3fd][3fd] vipcore, device init..
      The version of Viplite is: 1.8[  415.183082] set_vip_power_clk ON
      .0-0-AW-2022-04-21
      [  415.191511] enter aw vip mem alloc size 52428800
      [  415.196750] ion_alloc failed!!npu[3fd][3fd] gckvip_drv_init  kernel logical phy address=0        x0  virtual =0x0
      [  415.207929] Unable to handle kernel paging request at virtual address 031f3810
      [  415.216136] pgd = c1d8c000
      [  415.219189] [031f3810] *pgd=00000000
      [  415.223248] Internal error: Oops: 805 [#1] PREEMPT ARM
      [  415.228995] Modules linked in: vin_v4l2 gc2053_mipi vin_io videobuf2_v4l2 videobuf2_dma_c        ontig videobuf2_memops videobuf2_core xradio_wlan xradio_core xradio_mac
      [  415.245199] CPU: 0 PID: 1021 Comm: yolov3 Not tainted 4.9.191 #1
      [  415.251918] Hardware name: sun8iw21
      [  415.255819] task: c37403c0 task.stack: c1d6c000
      [  415.260896] PC is at gckvip_heap_construct+0x8c/0x11c
      [  415.266548] LR is at 0x14
      [  415.269476] pc : [<c03a77f8>]    lr : [<00000014>]    psr: 80000013
      [  415.269476] sp : c1d6dca8  ip : 00000000  fp : 00000ab8
      [  415.282325] r10: 00000000  r9 : 02800000  r8 : 00000a00
      [  415.288171] r7 : 00000000  r6 : c0a64b44  r5 : 031f3800  r4 : 00000a00
      [  415.295470] r3 : 00000001  r2 : 031f3800  r1 : cdcdcdcd  r0 : c0a64b40
      [  415.302776] Flags: Nzcv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
      [  415.310761] Control: 10c5387d  Table: 41d8c059  DAC: 00000051
      [  415.317185] Process yolov3 (pid: 1021, stack limit = 0xc1d6c208)
      [  415.323902] Stack: (0xc1d6dca8 to 0xc1d6e000)
      [  415.328780] dca0:                   c0a64b40 00000000 03200000 c0a64aa0 00000000 c03a7dd0
      [  415.337936] dcc0: 00000000 00000000 00000a00 c03ace80 c0a64aa0 00000001 c2364000 c0a64aa0
      [  415.347087] dce0: 00000000 00000000 00000000 000014c8 000003fd c03a3630 00000018 c2365000
      [  415.356243] dd00: 00000000 c1d6dd98 bef718a0 00000004 00000051 bef718a0 c1d6c000 00000036
      [  415.365394] dd20: 00000000 c03a3bf8 00000000 c340c000 00000001 c1d6ddb8 0000000a c0147370
      [  415.374545] dd40: c35d4e00 00000000 c35d4e00 bef718a0 00000004 00000051 c1d6dd98 bef718a0
      [  415.383696] dd60: 00000004 00000051 bef718a0 c03ab194 c0a17160 00000000 c340c000 00000000
      [  415.392853] dd80: 00000000 b6f0c2b8 00000004 b6f0e1a0 bef71964 00000000 03200000 c1d6ded8
      [  415.402004] dda0: c0a146f0 ffffe000 c0a146f0 c1d6ddc8 c0a4965c 60000013 00000000 c36aed80
      [  415.411155] ddc0: c0a29278 ffffe000 c0a29278 c1d6dde8 c0a4965c 60000013 c1d90a80 c1d90a88
      [  415.420306] dde0: 00000000 c06848e4 00000001 c1d6dde8 00000001 c0a29278 c1d90a80 c36aed80
      [  415.429463] de00: c3719028 c03aafa4 c0a292bc 00000000 c2812c8c 00000000 00000000 c02f11c0
      [  415.438614] de20: c27f2d00 00000000 00000000 c01d34c4 c1d6ded8 00000000 00000018 ffffff9c
      [  415.447770] de40: c1d6ded8 c01beefc 00000000 c1d6ded8 c1d90a80 c01c3b9c 00000001 00000001
      [  415.456921] de60: c1d6df7c 00000000 c1d6c000 00020002 c28023b8 00000001 00000041 00000006
      [  415.466072] de80: 00000000 00000000 c1d2bcc0 c037bfe8 c037f99c 00000002 00000002 c3719028
      [  415.475223] dea0: c27f2d10 c2812c38 c1d2bcc0 00000001 c037c04c 00000003 c1d6df7c 00000001
      [  415.484375] dec0: ffffff9c c0106f48 c1d6c000 00000005 00000000 c01c3c70 c27f2d10 c2812c38
      [  415.493526] dee0: 32504bcc 00000007 c370c015 82737029 00000000 c28a8220 c3719028 bef718a0
      [  415.502677] df00: c3719028 c1d90a80 00007530 c01c5b48 bef718a0 c01c6434 b6e36c4b 00000001
      [  415.511828] df20: 00024000 00025000 00100873 c019f4fc c1d90cc0 c1d90a80 00000000 c01d1878
      [  415.520980] df40: 00000003 c1d90cc0 c3401b80 c370c000 00000000 00000003 c1d90a80 c370c000
      [  415.530123] df60: ffffff9c c0106f48 c1d6c000 00000003 c1d90a80 c1d90a80 00007530 bef718a0
      [  415.539274] df80: c1d6c000 00000036 00000000 c01c65bc 00000000 b6e49fa0 b6e0f818 00000036
      [  415.548425] dfa0: c0106f48 c0106d20 00000000 b6e49fa0 00000003 00007530 bef718a0 bef71890
      [  415.557576] dfc0: 00000000 b6e49fa0 b6e0f818 00000036 bef71964 00000000 00000020 00000000
      [  415.566727] dfe0: b6e2049c bef71878 b6e0df3c b6ec0870 80000010 00000003 00000000 00000000
      [  415.575891] [<c03a77f8>] (gckvip_heap_construct) from [<c03a7dd0>] (gckvip_mem_heap_init+        0xe0/0x118)
      [  415.586114] [<c03a7dd0>] (gckvip_mem_heap_init) from [<c03a3630>] (do_init+0x4b8/0x700)
      [  415.595077] [<c03a3630>] (do_init) from [<c03a3bf8>] (gckvip_kernel_call+0xa0/0x9ec)
      [  415.603751] [<c03a3bf8>] (gckvip_kernel_call) from [<c03ab194>] (drv_ioctl+0x10c/0x38c)
      [  415.612716] [<c03ab194>] (drv_ioctl) from [<c01c5b48>] (vfs_ioctl+0x18/0x3c)
      [  415.620611] [<c01c5b48>] (vfs_ioctl) from [<c01c6434>] (do_vfs_ioctl+0x794/0x8e8)
      [  415.628989] [<c01c6434>] (do_vfs_ioctl) from [<c01c65bc>] (SyS_ioctl+0x34/0x5c)
      [  415.637176] [<c01c65bc>] (SyS_ioctl) from [<c0106d20>] (ret_fast_syscall+0x0/0x54)
      [  415.645655] Code: e1530004 15902028 1022239e 12833001 (15821010)
      [  415.652746] ---[ end trace bbd8e339bc884c65 ]---
        WhycanService LV 8 最后由 编辑
        内存不够,可以换用yolov3-tiny
        yolov3: 50M
        yolov3 tiny:17M
        S 1 条回复 最后回复 回复 引用 分享 0
          super0759 LV 5 @WhycanService 最后由 编辑
          @whycanservice 你那有 yolov3-tiny 的模型吗
            mysteryli LV 7 最后由 编辑
            怎么把yolov3的demo编译进镜像中呢?
              super0759 LV 5 @mysteryli 最后由 编辑
              @mysteryli
              你就按照1 这个 一步步
              https://v853.docs.aw-ol.com/npu/npu_demo/
