    f1c100s tina pwm背光亮度调整
    • U
      ubuntu LV 7 最后由 whycan 编辑
      sys_config.fex
      [lcd0]
      lcd_used            = 1
      lcd_pwm_used        = 1
      lcd_pwm_ch          = 1
      lcd_pwm_freq        = 50000
      lcd_pwm_pol         = 0
      lcd_pwm_max_limit   = 255
      [disp]
      disp_init_enable         = 1
      lcd0_backlight           = 255
      lcd1_backlight           = 255
      lcd0_bright              = 255
      lcd0_contrast            = 50
      lcd0_saturation          = 57
      lcd0_hue                 = 50
      lcd1_bright              = 255
      lcd1_contrast            = 50
      lcd1_saturation          = 57
      lcd1_hue                 = 50
      [pwm1_para]
      pwm_used            = 1
      pwm_positive        = port:PE06<3><0><default><default>
      用户层调整亮度:
      #include <sys/types.h>
      #include <sys/stat.h>
      #include <fcntl.h>
      #include <sys/ioctl.h>
      #include <unistd.h>
      #define DISP_CMD_LCD_SET_BRIGHTNESS  0x102
      int dispfd;
      void main()
              unsigned long arg[3];
              unsigned int bl = 0;
              arg[0] = 0;//显示通道0
              arg[1] = bl;
              dispfd                 = open("/dev/disp", O_RDWR);
              if(dispfd <0)
                      printf("open disp error\n");
              ioctl(dispfd, DISP_CMD_LCD_SET_BRIGHTNESS, (void*)arg);
              close(dispfd);
              printf("end\n");
      • U
        ubuntu LV 7 最后由 编辑
        https://www.cnblogs.com/dakewei/p/13323567.html
        或者用pwm直接调整亮度:
        echo 1 > /sys/class/pwm/pwmchip0/export
        echo 10000 > /sys/class/pwm/pwmchip0/pwm1/period
        echo 5000 > /sys/class/pwm/pwmchip0/pwm1/duty_cycle
        echo 'normal' > /sys/class/pwm/pwmchip0/pwm1/polarity
        echo 1 > /sys/class/pwm/pwmchip0/pwm1/enable
