    mq-dual , mq-r T113 tina gt911适配
    6
    6918
    • mangogeek
      mangogeek LV 8 最后由 编辑
      硬件连接
      首先,查原理图,GT911触摸挂在TWI2上(PE12,PE13),CTP中断PB3,CTP复位控制:PB2
      DTS
      然后修改对应dts的twi2部分(Tina-Linux/device/config/chips/t113/configs/mq_r/linux-5.4/board.dts),修改好如下:
      配置内核驱动
      make kernel_menuconfig
      Device Drivers --->
          Input device support --->
              [*] Touchscreens --->
                    [M] gt9xxnew touchscreen driver
      配置文件系统部分
      检查启动模块加载控制:Tina-Linux/target/allwinner/t113-mq_r/busybox-init-base-files/etc/init.d/rc.modules
      文件内容如下,这里我们重点将gt9xxnew_ts.ko前的注释去掉,同时根据实际mangopi板子选择需要加载的wifi驱动模块。
      #!/bin/sh
      echo "------run rc.modules file-----"
      #export boot_partition=$(fw_printenv -n boot_partition 2>/dev/null)
      # if [ x${boot_partition} == xboot ];then
      	/sbin/insmod /lib/modules/5.4.61/usb-storage.ko
      	/sbin/insmod /lib/modules/5.4.61/sunxi_gpadc.ko
      	/sbin/insmod /lib/modules/5.4.61/gt9xxnew_ts.ko
      	echo 0x07090160 0x083F10F7 > /sys/class/sunxi_dump/write
      #	/sbin/insmod /lib/modules/5.4.61/8723ds.ko
      	/sbin/insmod /lib/modules/5.4.61/8189fs.ko
      	sleep 4
      	wpa_supplicant  -Dnl80211 -iwlan0 -c /etc/wifi/wpa_supplicant.conf -B
      # fi
      然后编译打包:make;pack
      上电信息
      [    6.076660] sunxi_gpadc_init,2151, success
      [    6.081641] sunxi_gpadc_setup: get channel scan data failed
      [    6.088244] input: sunxi-gpadc0 as /devices/virtual/input/input1
      [    6.100435] get ctp_power is fail, -22
      [    6.104646] get ctp_power_ldo_vol is fail, -22
      [    6.109692] sunxi_ctp_startup: ctp_power_io is invalid.
      [    6.115586] get ctp_gesture_wakeup fail, no gesture wakeup
      [    6.121812] gt9xxnew_ts 2-0014: 2-0014 supply ctp not found, using dummy regulator
      [    6.329053] input: gt9xxnew_ts as /devices/virtual/input/input2
      此时得到gt911的设备节点是event2:
      root@TinaLinux:/# ls /dev/input/event*
      /dev/input/event0 /dev/input/event1 /dev/input/event2
      修改自带lvgl8中的input配置部分,实现lvgl触摸功能
      因为我们的tina-linux默认勾选了lvgl8,所以直接修改文件461行即可:/home/mango/1/Tina-Linux/package/gui/littlevgl-8/lv_examples/src/lv_drv_conf.h
      重新打包编译:m;p
      启动进入shell后,运行lv demo
      root@TinaLinux:/# lv_examples 0
      wh=800x480, vwh=800x480, bpp=32, rotated=0
      mangogeek 1 条回复 最后回复 回复 引用 分享 3
      • mangogeek
        mangogeek LV 8 @mangogeek 最后由 编辑
        固件T113+8189F:2356.img
        F 1 条回复 最后回复 回复 引用 分享 0
        • mangogeek
          • F
            fanfan LV 6 @mangogeek 最后由 编辑
            @mangogeek 谢谢大佬
              wuzhujian LV 6 最后由 编辑
              我试了一下,电阻屏的效果也不差,很流畅.
              • Q
                Qiao15839037953 LV 3 最后由 编辑
                你好,我使用的MQ-R在添加触摸的时候touchscreens里面没有触摸设备列表,请问怎么解决啊?214fc3da-e7f0-40c6-8124-fe536a7040b9-image.png
