    参照大佬的教程在Tina下适配 i80 LCD 显示屏,一接屏幕就报错重启
    6
    4386
    • B
      bigfly LV 5 最后由 编辑
      参照大佬的教程来做的:https://www.gloomyghost.com/live/20220424.aspx
      然后一装上屏幕就会报以下错误
      1sdcja15
      然后就重启了,是 板子的io没有配制好还是 电路有问题?
      • bayche
        bayche LV 6 最后由 编辑
        触发thermal的过温保护了
        看看是不是真的温度很高,如果不是排查thermal驱动,一般是adc读的值
        B 1 条回复 最后回复 回复 引用 分享 0
        • B
          bigfly LV 5 @bayche 最后由 编辑
          @bayche 谢谢大佬,还有个问题
          disp_al_manager_apply ouput_type:0 怎么把 ouput_type:改为1,是修改board.dts的disp么 ?
          • B
            bigfly LV 5 最后由 编辑
            改个i8080要吐血了,大佬给分析下是不是驱动没加载
              D1s 驱动 st7789 i80 8bit 模式,
              board.dts 仅供参考:
              /dts-v1/;
              /memreserve/ 0x41B00000 0x00100000;
              /* DSP used 1MB */
              /*/memreserve/ 0x42000000 0x00100000;*/
              #include "sun8iw20p1.dtsi"
                      model = "sun8iw20";
                      reg_vdd_cpu: vdd-cpu {
                              pwms = <&pwm 3 5000 0>;
                              regulator-name = "vdd_cpu";
                              regulator-ramp-delay = <25>;
                              regulator-always-on;
                              regulator-boot-on;
                      reg_usb1_vbus: usb1-vbus {
                              regulator-name = "usb1-vbus";
                              /* gpio = <&pio PB 3 GPIO_ACTIVE_HIGH>; */
                              enable-active-high;
              &cpu0 {
                      cpu-supply = <&reg_vdd_cpu>;
              &pio {
                              I80_ST7789V_pins_a: I8080_8bit@0{
                              allwinner,pins = "PD1", "PD2", "PD3", "PD4", "PD5", \
                                              "PD6", "PD7", "PD8", \
                              allwinner,pname = "PD1", "PD2", "PD3", "PD4", "PD5",\
                                               "PD6", "PD7", "PD8",\
                              allwinner,function = "lcd0";
                              allwinner,muxsel = <2>;
                              allwinner,drive = <1>;
                              allwinner,pull = <0>;
                              I80_ST7789V_pins_b: I8080_8bit@1{
                              allwinner,pname = "PD1", "PD2", "PD3", "PD4", "PD5", \
                              allwinner,muxsel = <7>;
                      sdc0_pins_a: sdc0@0 {
                                               "PF3", "PF4", "PF5";
                              allwinner,function = "sdc0";
                              allwinner,drive = <3>;
                              allwinner,pull = <1>;
                              function = "sdc0";
                              drive-strength = <30>;
                              bias-pull-up;
                              power-source = <3300>;
                      sdc0_pins_b: sdc0@1 {
                              function = "sdc0";
                              bias-pull-up;
                              power-source = <1800>;
                      sdc0_pins_c: sdc0@2 {
                              function = "gpio_in";
                      /* TODO: add jtag pin */
                      sdc0_pins_d: sdc0@3 {
                              pins = "PF2", "PF4";
                              function = "uart0";
                              drive-strength = <10>;
                              bias-pull-up;
                      sdc0_pins_e: sdc0@4 {
                              pins = "PF0", "PF1", "PF3",
                                      "PF5";
                              function = "jtag";
                              bias-pull-up;
                      sdc1_pins_a: sdc1@0 {
                              pins = "PG0", "PG1", "PG2",
                                     "PG3", "PG4", "PG5";
                              function = "sdc1";
                              bias-pull-up;
                      sdc1_pins_b: sdc1@1 {
                      sdc2_pins_a: sdc2@0 {
                                               "PC5", "PC6", "PC7";
                              allwinner,function = "sdc2";
                              allwinner,muxsel = <3>;
                              function = "sdc2";
                              bias-pull-up;
                      sdc2_pins_b: sdc2@1 {
                      wlan_pins_a:wlan@0 {
                              pins = "PG11";
                              function = "clk_fanout1";
                      function = "uart0";
                      bias-pull-up;
                              function = "uart1";
                              bias-pull-up;
                              pins = "PC0", "PC1";
                              function = "uart2";
                              bias-pull-up;
                      uart3_pins_a: uart3_pins@0 {  /* For awol nezha board */
                              pins = "PB6", "PB7";
                              function = "uart3";
                              muxsel = <7>;
                              bias-pull-up;
                      uart3_pins_b: uart3_pins@1 {  /* For awol nezha board */
                      twi0_pins_a: twi0@0 {
                              pins = "PB10", "PB11";  /*sck sda*/
                              function = "twi0";
                      twi0_pins_b: twi0@1 {
                      twi0_pins_c: twi0@2 {
                              pins = "PB2", "PB3";
                              function = "twi0";
                      twi0_pins_d: twi0@3 {
                      twi1_pins_a: twi1@0 {
                              pins = "PB4", "PB5";
                              function = "twi1";
                      twi1_pins_b: twi1@1 {
                      twi2_pins_a: twi2@0 {
                              pins = "PE12", "PE13";
                              function = "twi2";
                      twi2_pins_b: twi2@1 {
                      twi3_pins_a: twi3@0 {
                              pins = "PE6", "PE7";
                              function = "twi3";
                      twi3_pins_b: twi3@1 {
                      gmac_pins_a: gmac@0 {
                                     "PE4", "PE5", "PE6", "PE7",
                                     "PE8", "PE9";
                              function = "gmac0";
                      gmac_pins_b: gmac@1 {
                                     "PE8", "PE9";
                      dmic_pins_a: dmic@0 {
                              function = "dmic";
                              drive-strength = <20>;
                              bias-disable;
                      dmic_pins_b: dmic@1 {
                              function = "io_disabled";
                              bias-disable;
                      daudio0_pins_a: daudio0@0 {
                              function = "i2s0";
                              bias-disable;
                              bias-disable;
                      daudio1_pins_a: daudio1@0 {
                              function = "i2s1";
                              bias-disable;
                      daudio1_pins_b: daudio1_sleep@0 {
                              bias-disable;
                      daudio2_pins_a: daudio2@0 {
                              pins = "PF6", "PF3", "PF5";
                              function = "i2s2";
                              bias-disable;
                      daudio2_pins_b: daudio2@1 {
                              /* I2S_PIN: DOUT0 */
                              pins = "PF1";
                              function = "i2s2_dout";
                              bias-disable;
                      daudio2_pins_c: daudio2@2 {
                              /* I2S_PIN: DIN0 */
                              pins = "PF0";
                              function = "i2s2_din";
                              bias-disable;
                              pins = "PF6", "PF3", "PF5", "PF1", "PF0";
                              bias-disable;
                      spdif_pins_a: spdif@0 {
                              /* SPDIF_PIN: SPDIF_OUT */
                              pins = "PG18";
                              function = "spdif";
                              bias-disable;
                      spdif_pins_b: spdif_sleep@0 {
                              pins = "PG18";
                              bias-disable;
                      spi0_pins_a: spi0@0 {
                              function = "spi0";
                              muxsel = <2>;
                      spi0_pins_b: spi0@1 {
                              pins = "PC3", "PC7", "PC6";
                              function = "spi0";
                              muxsel = <2>;
                      spi0_pins_c: spi0@2 {
                              muxsel = <0>;
                      spi1_pins_a: spi1@0 {
                              function = "spi1";
                      spi1_pins_b: spi1@1 {
                              function = "spi1";
                      spi1_pins_c: spi1@2 {
                      ledc_pins_a: ledc@0 {
                              pins = "PG13";
                              function = "ledc";
                      ledc_pins_b: ledc@1 {
                              pins = "PG13";
                      pwm0_pin_a: pwm0@0 {
                              pins = "PD16";
                              function = "pwm0";
                              bias-pull-up;
                      pwm0_pin_b: pwm0@1 {
                              pins = "PD16";
                              bias-disable;
                      pwm2_pin_a: pwm2@0 {
                              pins = "PD18";
                              function = "pwm2";
                              bias-pull-up;
                      pwm2_pin_b: pwm2@1 {
                              pins = "PD18";
                              function = "gpio_out";
                      pwm7_pin_a: pwm7@0 {
                              pins = "PD22";
                              function = "pwm7";
                              bias-pull-up;
                      pwm7_pin_b: pwm7@1 {
                              pins = "PD22";
                      s_cir0_pins_a: s_cir@0 {
                              pins = "PB7";
                              function = "ir";
                              bias-pull-up;
                      s_cir0_pins_b: s_cir@1 {
                              pins = "PB7";
                      ir1_pins_a: ir1@0 {
                              pins = "PB0";
                              function = "ir";
                              bias-pull-up;
                      ir1_pins_b: ir1@1 {
                              pins = "PB0";
              &uart0 {
                      pinctrl-0 = <&uart0_pins_a>;
                      pinctrl-1 = <&uart0_pins_b>;
                      status = "disabled";
              &uart1 {
                      pinctrl-0 = <&uart1_pins_a>;
                      pinctrl-1 = <&uart1_pins_b>;
              &uart2 {
                      pinctrl-0 = <&uart2_pins_a>;
                      pinctrl-1 = <&uart2_pins_b>;
              /* for debug */
              &uart3 {
                      pinctrl-0 = <&uart3_pins_a>;
                      pinctrl-1 = <&uart3_pins_b>;
              /* for dsp debug
              &uart3 {
              &soc {
                      card0_boot_para@2 {
                              reg = <0x0 0x2 0x0 0x0>;
                              card_ctrl = <0x0>;
                              card_high_speed = <0x1>;
                              card_line = <0x4>;
                              pinctrl-0 = <&sdc0_pins_a>;
                      card2_boot_para@3 {
                              reg = <0x0 0x3 0x0 0x0>;
                              card_ctrl = <0x2>;
                              card_line = <0x4>;
                              pinctrl-0 = <&sdc2_pins_a>;
                              /*sdc_ex_dly_used = <0x2>;*/
                              sdc_io_1v8 = <0x1>;
                              /*sdc_type = "tm4";*/
                              sdc_ex_dly_used = <2>;
                              /*sdc_tm4_win_th = <8>;*/
                      rfkill: rfkill@0 {
                              chip_en;
                              power_en;
                              pinctrl-0 = <&wlan_pins_a>;
                              pinctrl-names = "default";
                              status        = "okay";
                              wlan: wlan@0 {
                                      clock-names = "32k-fanout1";
                                      wlan_busnum    = <0x1>;
                                      /*interrupt-parent = <&pio>;
                                      wakeup-source;
                              bt: bt@0 {
                                      /*bt_power_num = <0x01>;*/
                                      /*bt_io_vol = <3300000>;*/
                                      /*bt_power_vol = <330000>;*/
                                      bt_rst_n      = <&pio PE 13 GPIO_ACTIVE_LOW>;
                                      status        = "okay";
                      btlpm: btlpm@0 {
                              uart_index  = <0x1>;
                              bt_wake     = <&pio PG 14 GPIO_ACTIVE_HIGH>;
                              bt_hostwake = <&pio PG 15 GPIO_ACTIVE_HIGH>;
                              status      = "okay";
                      addr_mgt: addr_mgt@0 {
                              type_addr_wifi = <0x0>;
                              type_addr_bt   = <0x0>;
                              type_addr_eth  = <0x0>;
                              status         = "okay";
              &sdc2 {
                      non-removable;
                      bus-width = <4>;
                      mmc-ddr-1_8v;
                      mmc-hs200-1_8v;
                      no-sdio;
                      no-sd;
                      ctl-spec-caps = <0x308>;
                      cap-mmc-highspeed;
                      sunxi-power-save-mode;
                      sunxi-dis-signal-vol-sw;
                      mmc-bootpart-noacc;
                      max-frequency = <150000000>;
                      /*emmc io vol 3.3v*/
                      /*emmc io vol 1.8v*/
              &sdc0 {
                      bus-width = <4>;
                      /*non-removable;*/
                      /*broken-cd;*/
                      /*cd-inverted;*/
                      /*data3-detect;*/
                      cd-used-24M;
                      cap-sd-highspeed;
                      /*sd-uhs-sdr50;*/
                      /*sd-uhs-ddr50;*/
                      /*sd-uhs-sdr104;*/
                      no-sdio;
                      no-mmc;
                      /*sunxi-dis-signal-vol-sw;*/
                      ctl-spec-caps = <0x8>;
              &sdc1 {
                      bus-width = <4>;
                      no-mmc;
                      no-sd;
                      cap-sd-highspeed;
                      /*sd-uhs-sdr12*/
                      /*sd-uhs-sdr25;*/
                      /*sd-uhs-sdr50;*/
                      /*sd-uhs-ddr50;*/
                      /*sd-uhs-sdr104;*/
                      /*sunxi-power-save-mode;*/
                      cap-sdio-irq;
                      keep-power-in-suspend;
                      ignore-pm-notify;
              tvd configuration
                                     mode,mean enable)
              &tvd {
                      tvd_sw          = <1>;
                      tvd_interface   = <0>;
                      tvd_format      = <0>;
                      tvd_system      = <1>;
                      tvd_row         = <1>;
                      tvd_column      = <1>;
                      tvd_channel0_en = <1>;
                      tvd_channel1_en = <0>;
                      tvd_channel2_en = <0>;
                      tvd_channel3_en = <0>;
                      /*      dc1sw-supply = <&reg_dc1sw>;*/
                      /*      eldo3-supply = <&reg_eldo3>;*/
                      /*tvd_power0      = "dc1sw"*/
                      /*tvd_power1      = "eldo3"*/
              &tvd0 {
              /* Audio Driver modules */
              &sunxi_rpaf_dsp0 {
              &codec {
                      mic1gain        = <0x1F>;
                      mic2gain        = <0x1F>;
                      mic3gain        = <0x1F>;
                      adcdrc_cfg      = <0x0>;
                      adchpf_cfg      = <0x1>;
                      dacdrc_cfg      = <0x0>;
                      dachpf_cfg      = <0x0>;
                      /* Volume about */
                      digital_vol     = <0x00>;
                      lineout_vol     = <0x1a>;
                      headphonegain   = <0x03>;
                      /* Pa enabled about */
                      pa_level        = <0x01>;
                      pa_pwr_level    = <0x01>;
                      pa_msleep_time  = <0x78>;
                      /* gpio-spk     = <&pio PF 2 GPIO_ACTIVE_HIGH>;*/
                      /* gpio-spk-pwr = <&pio PF 4 GPIO_ACTIVE_HIGH>; */
                      /* CMA config about */
                      playback_cma    = <128>;
                      capture_cma     = <256>;
                      /* regulator about */
                      /* avcc-supply  = <&reg_aldo1>; */
                      /* hpvcc-supply = <&reg_eldo1>; */
              &sndcodec {
                      hp_detect_case  = <0x00>;
                      jack_enable     = <0x01>;
              &dummy_cpudai {
              &dmic {
              &dmic_codec {
              &sounddmic {
               * pcm_lrck_period      16/32/64/128/256
               * slot_width_select    16bits/20bits/24bits/32bits
               * frametype            0 --> short frame = 1 clock width;
               *                      1 --> long frame = 2 clock width;
               * tdm_config           0 --> pcm
               *                      1 --> i2s
               * mclk_div             0 --> not output
               *                      1/2/4/6/8/12/16/24/32/48/64/96/128/176/192
               *                      (set mclk as external codec clk source, freq is pll_audio/mclk_div)
               * pinctrl_used         0 --> I2S/PCM use for internal
               *                      1 --> I2S/PCM use for external audio
               * daudio_type:         0 --> external audio type
              &daudio0 {
                      mclk_div        = <0x01>;
                      frametype       = <0x00>;
                      tdm_config      = <0x01>;
                      sign_extend     = <0x00>;
                      msb_lsb_first   = <0x00>;
                      pcm_lrck_period = <0x80>;
                      slot_width_select = <0x20>;
                      pinctrl_used    = <0x0>;
               * simple-audio-card,name       name of sound card, e.g.
               *                              "snddaudio0" --> use for external audio
               * sound-dai                    "snd-soc-dummy" --> use for I2S
               *                              "ac108" --> use for external audio of ac108
              &sounddaudio0 {
                              /* sound-dai = <&ac108>; */
              &daudio1 {
                      mclk_div        = <0x01>;
                      frametype       = <0x00>;
                      pinctrl-0       = <&daudio1_pins_a>;
                      pinctrl-1       = <&daudio1_pins_b>;
              &sounddaudio1 {
              &daudio2 {
                      mclk_div        = <0x01>;
                      frametype       = <0x00>;
                      tx_data_mode    = <0x00>;
                      rx_data_mode    = <0x00>;
                      asrc_function_en  = <0x00>;
                      pinctrl_used    = <0x1>;
                      daudio_type     = <0x0>;
              &sounddaudio2 {
              &spdif {
              &soundspdif {
              &usbc0 {
                      device_type = "usbc0";
                      usb_port_type = <0x2>;
                      usb_detect_type = <0x1>;
                      usb_detect_mode = <0>;
                      usb_id_gpio = <&pio PE 12 GPIO_ACTIVE_HIGH>;
                      enable-active-high;
                      usb_det_vbus_gpio = <&pio PB 0 GPIO_ACTIVE_LOW>;
                      usb_wakeup_suspend = <0>;
                      usb_serial_unique = <0>;
                      rndis_wceis = <1>;
              &ehci0 {
              &ohci0 {
              &usbc1 {
                      device_type = "usbc1";
                  usb_port_type = <0x01>;
                      usb_regulator_io = "nocare";
              &ehci1 {
              &ohci1 {
              &twi0 {
                      clock-frequency = <400000>;
                      pinctrl-0 = <&twi0_pins_c>;
                      pinctrl-1 = <&twi0_pins_d>;
                      dmas = <&dma 45>, <&dma 45>;
                      dma-names = "tx", "rx";
                      eeprom@50 {
                              compatible = "atmel,24c16";
                              reg = <0x50>;
                      ctp@14 {
                              device_type = "ctp";
                              reg = <0x14>;
                              ctp_name = "gt9xxnew_ts";
                              ctp_twi_id = <0x2>;
                              ctp_twi_addr = <0x14>;
                              ctp_screen_max_x = <720>;
                              ctp_screen_max_y = <1440>;
                              ctp_revert_x_flag = <0x0>;
                              ctp_revert_y_flag = <0x0>;
                              ctp_int_port = <&pio PB 5 GPIO_ACTIVE_HIGH>;
                              ctp_wakeup = <&pio PB 4 GPIO_ACTIVE_HIGH>;
              &twi1 {
                      pinctrl-0 = <&twi1_pins_a>;
                      pinctrl-1 = <&twi1_pins_b>;
              &twi2 {
                      pinctrl-0 = <&twi2_pins_a>;
                      pinctrl-1 = <&twi2_pins_b>;
                      /* pcf8574-usage:
                       * pin set:
                       * interrupt set:
                      pcf8574: gpio@38 {
                              compatible = "nxp,pcf8574";
                              reg = <0x38>;
                              gpio_base = <2020>;
                              gpio-controller;
                              #gpio-cells = <2>;
                              interrupt-controller;
                              #interrupt-cells = <2>;
                      ctp@14 {
                      reg = <0x14>;
                      ctp_twi_id = <0x2>;
                      ctp_screen_max_x = <0x320>;
                      ctp_screen_max_y = <0x1e0>;
                      /*ctp-supply = <&reg_aldo2>;*/
                      /*ctp_power_ldo = <&reg_aldo2>;*/
                      /*ctp_power_ldo_vol = <3300>;*/
              &twi3 {
                      pinctrl-0 = <&twi3_pins_a>;
                      pinctrl-1 = <&twi3_pins_b>;
              &gmac0 {
                      phy-mode = "rmii";
                      use_ephy25m = <0>;
                      pinctrl-0 = <&gmac_pins_a>;
                      pinctrl-1 = <&gmac_pins_b>;
                      phy-rst = <&pio PE 10 GPIO_ACTIVE_HIGH>;
              &spi0 {
                      pinctrl-1 = <&spi0_pins_c>;
                      spi_slave_mode = <0>;
                      spi0_cs_number = <1>;
                  spi0_cs_bitmap = <1>;
                      spi-nand@0 {
                              compatible = "spi-nand";
                              spi-max-frequency=<100000000>;
                              reg = <0x0>;
                              spi-rx-bus-width=<0x04>;
                              spi-tx-bus-width=<0x04>;
                              status="okay";
                      spi-nor@0 {
                              compatible = "jedec,spi-nor";
                              spi-max-frequency=<30000000>;
                              reg = <0x0>;
                              spi-rx-bus-width=<0x01>;
                              spi-tx-bus-width=<0x01>;
                              status="disabled";
              &spi1 {
                      pinctrl-1 = <&spi1_pins_c>;
                      spi_board1@0 {
                              device_type = "spi_board1";
                              compatible = "rohm,dh2228fv";
                              reg = <0x0>;
                              spi-rx-bus-width = <0x4>;
                              spi-tx-bus-width = <0x4>;
              &ledc {
                      pinctrl-0 = <&ledc_pins_a>;
                      pinctrl-1 = <&ledc_pins_b>;
                      led_count = <3>;
                      output_mode = "GRB";
                      reset_ns = <84>;
                      t1h_ns = <800>;
                      t1l_ns = <320>;
                      t0h_ns = <300>;
                      t0l_ns = <800>;
                      wait_time0_ns = <84>;
                      wait_time1_ns = <84>;
                      wait_data_time_ns = <600000>;
                      status  = "okay";
              &keyboard0 {
                      key0 = <210 0x160>;
                      wakeup-source;
              disp init configuration
              set fbX_height to lcd_x)
                                 in display.
              &disp {
                      screen0_output_mode      = <0>;
                      /*VCC-LCD*/
                      /*VCC-DSI*/
                      /*VCC-PD*/
              /*      dcdc1-supply = <&reg_dcdc1>;*/
              ;lcd0 configuration
              ;Pin setting for gpio:
              ;fsync setting, pulse to csi
              &lcd0 {
              /* part 1 */
              lcd_used = <1>;
              //lcd_driver_name = "s2003t46g";
              lcd_driver_name = "st7789v_cpu";
              /* part 2 */
              lcd_if = <1>;
              lcd_cpu_if = <14>;
              /* part 3 */
              lcd_width = <23>;
              lcd_height = <43>;
              lcd_x = <240>;
              lcd_y = <320>;
              lcd_dclk_freq = <14>;
              lcd_hbp = <60>;
              lcd_ht = <400>;
              lcd_hspw = <10>;
              lcd_vbp = <60>;
              lcd_vt = <370>;
              lcd_vspw = <10>;
              //lcd_hv_clk_phase =<0>;
              //lcd_hv_if =<0>;
              /* part 4 */
              lcd_backlight = <50>;
              lcd_pwm_used = <1>;
              lcd_pwm_ch = <7>;
              lcd_pwm_freq = <2000>;
              lcd_pwm_pol = <1>;
              lcd_bright_curve_en = <1>;
              //lcd_fsync_en =<1>;
              //lcd_fsync_dis_time=<169>;
              //lcd_fsync_act_time=<169>;
              /* part 5 */
              lcd_cpu_mode= <1>;
              deu_mode =<0>;
              //lcd_fsync_en=<1>;
              lcd_cpu_te= <0>;
              lcd_frm = <2>;
              lcd_gamma_en = <0>;
              lcd_cmap_en = <0>;
              lcd_rb_swap= <0>;
              /* part 6 */
              //lcd_power = "vcc-lcd";
              //lcd_pin_power = "vcc-pd";
              lcd_gpio_0 = <&pio PD 17 1 0 3 0>;
              pinctrl-0 = <&I80_ST7789V_pins_a>;
              pinctrl-1 = <&I80_ST7789V_pins_b>;
                      lcd_gpio_0 = <&pio PD 20 1 0 3 1>;
              &pwm0 {
                      pinctrl-0 = <&pwm0_pin_a>;
                      pinctrl-1 = <&pwm0_pin_b>;
              &pwm2 {
                      pinctrl-0 = <&pwm2_pin_a>;
                      pinctrl-1 = <&pwm2_pin_b>;
              &pwm7 {
                      pinctrl-0 = <&pwm7_pin_a>;
                      pinctrl-1 = <&pwm7_pin_b>;
              &rtp {
                      allwinner,ts-attached;
              &tpadc {
                      key_cnt = <5>;
                      key1 = <420 115>;
                      key2 = <870 114>;
                      key3 = <1290 119>;
                      key4 = <1630 373>;
                      key5 = <1950 28>;
              &gpadc {
                      channel_num = <1>;
                      channel_select = <0x01>;
                      channel_data_select = <0>;
                      channel_cld_select = <0x01>;
                      channel_chd_select = <0>;
                      channel0_compare_lowdata = <1600000>;
                      key_cnt = <4>;
                      key0_vol = <207>;
                      key0_val = <103>;
                      key1_vol = <404>;
                      key1_val = <108>;
                      key2_vol = <587>;
                      key2_val = <139>;
                      key3_vol = <741>;
                      key3_val = <0x160>;
                      wakeup-source;
              &s_cir0 {
                      pinctrl-0 = <&s_cir0_pins_a>;
                      pinctrl-1 = <&s_cir0_pins_b>;
                      ir_protocol_used                = <0>;
                      ir_addr_code0                   = <0x0>;
              &ir1 {
                      pinctrl-0 = <&ir1_pins_a>;
                      pinctrl-1 = <&ir1_pins_b>;
                cfxcfx LV 5 最后由 编辑
                @whycan 在 参照大佬的教程在Tina下适配 i80 LCD 显示屏,一接屏幕就报错重启 中说:
                t7789 i80 8bit 模式,
                board.dts 仅供参考:
                多谢
