    Package libnl-tiny is missing dependencies for the following libraries: libc.so.6
    • EveRYouNg
      EveRYouNg LV 3 最后由 编辑
      make[3]: Leaving directory '/home/neo/Tina/Tina-Linux/package/libs/toolchain'
      make[3]: Entering directory '/home/neo/Tina/Tina-Linux/package/libs/libnl-tiny'
      mkdir -p /home/neo/Tina/Tina-Linux/out/d1-mq_pro/packages /home/neo/Tina/Tina-Linux/out/d1-mq_pro/compile_dir/target/libnl-tiny-0.1/ipkg-sunxi/libnl-tiny/CONTROL /home/neo/Tina/Tina-Linux/out/d1-mq_pro/staging_dir/target/pkginfo
      install -d -m0755 /home/neo/Tina/Tina-Linux/out/d1-mq_pro/compile_dir/target/libnl-tiny-0.1/ipkg-sunxi/libnl-tiny/usr/lib
      cp -fpR /home/neo/Tina/Tina-Linux/out/d1-mq_pro/compile_dir/target/libnl-tiny-0.1/libnl-tiny.so /home/neo/Tina/Tina-Linux/out/d1-mq_pro/compile_dir/target/libnl-tiny-0.1/ipkg-sunxi/libnl-tiny/usr/lib/
      find /home/neo/Tina/Tina-Linux/out/d1-mq_pro/compile_dir/target/libnl-tiny-0.1/ipkg-sunxi/libnl-tiny -name 'CVS' -o -name '.svn' -o -name '.#*' -o -name '*~'| xargs -r rm -rf
      libc.so.6
      Makefile:55: recipe for target '/home/neo/Tina/Tina-Linux/out/d1-mq_pro/packages/base/libnl-tiny_0.1-5_sunxi.ipk' failed
      make[3]: *** [/home/neo/Tina/Tina-Linux/out/d1-mq_pro/packages/base/libnl-tiny_0.1-5_sunxi.ipk] Error 1
      make[3]: Leaving directory '/home/neo/Tina/Tina-Linux/package/libs/libnl-tiny'
      package/Makefile:192: recipe for target 'package/libs/libnl-tiny/compile' failed
      make[2]: *** [package/libs/libnl-tiny/compile] Error 2
      make[2]: Leaving directory '/home/neo/Tina/Tina-Linux'
      package/Makefile:189: recipe for target '/home/neo/Tina/Tina-Linux/out/d1-mq_pro/staging_dir/target/stamp/.package_compile' failed
      make[1]: *** [/home/neo/Tina/Tina-Linux/out/d1-mq_pro/staging_dir/target/stamp/.package_compile] Error 2
      make[1]: Leaving directory '/home/neo/Tina/Tina-Linux'
      /home/neo/Tina/Tina-Linux/build/toplevel.mk:304: recipe for target 'world' failed
      make: *** [world] Error 2
      [2]+  Done                    $T/tools/build/buildserver --path $T 2> /dev/null 1>&2
      #### make failed to build some targets (18 seconds) ####
      neo@MatrixUbuntu:~/Tina/Tina-Linux$
      请问这个问题怎么解决呢?😢 😢 😢
        whycan晕哥 LV 9 @EveRYouNg 最后由 编辑
        @everyoung
        f133编译报错 缺少libatomic.so.1 Package harfbuzz is missing dependencies for the following libraries: libatomic.so.1
        https://bbs.aw-ol.com/topic/2709/share/3
