    F133启动之后,/sys/class目录下找不到rfkill
      shz18877605430 LV 6 最后由 编辑
      大佬们,F133启动之后,/sys/class目录下找不到rfkill文件,配置已经开启,内核已经打开驱动,但是就是找不到rfkill目录。
      内核日志如下:
      U-Boot 2018.05-g24521d6-dirty (Mar 10 2023 - 20:31:27 +0800) Allwinner Technology
      [00.354]DRAM:  64 MiB
      [00.356]Relocation Offset is: 01ee7000
      [00.361]secure enable bit: 0
      [00.364]CPU=720 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.370]flash init start
      [00.372]workmode = 0,storage type = 0
      [BCC] 0x4025038 = 0x20000000, [DMA] 0x4025088 = 0x000000e5
      [00.421]sunxi-spinand-phy: not detect any munufacture from id table
      [00.427]sunxi-spinand-phy: get spi-nand Model from fdt fail
      [00.433]sunxi-spinand-phy: get phy info from fdt fail
      defaults:
      mtdids  : nand0=nand
      [00.547]ubi0: attaching mtd4
      [00.643]ubi0: scanning is finished
      [00.650]ubi0: attached mtd4 (name "sys", size 123 MiB)
      [00.655]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [00.661]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [00.667]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [00.674]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
      [00.679]ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
      [00.686]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
      [00.693]ubi0: available PEBs: 0, total reserved PEBs: 492, PEBs reserved for bad PEB handling: 20
      [00.702]sunxi flash init ok
      [00.704]line:703 init_clocks
      [00.708]drv_disp_init
      fdt_getprop_u32 s_pwm.pwm-base fail
      [00.728]drv_disp_init finish
      [00.730]boot_gui_init:start
      [00.733]set disp.dev2_output_type fail. using defval=0
      [00.740]boot_gui_init:finish
      [00.871]bmp_name=bootlogo.bmp size 38454
      38454 bytes read in 3 ms (12.2 MiB/s)
      [00.920]LCD open finish
      [00.995]Loading Environment from SUNXI_FLASH... OK
      [01.018]out of usb burn from boot: not need burn key
      [01.024]Item0 (Map) magic is bad
      [01.052]update bootcmd
      [01.065]change working_fdt 0x42aa6da0 to 0x42a86da0
      [01.101]update dts
      noncached_alloc(): addr = 0x42ca5080
      noncached_alloc(): addr = 0x42ca50c0
      noncached_alloc(): addr = 0x42ca5100
      noncached_alloc(): addr = 0x42ca5940
      geth_sys_init fail!
      [01.121]Board Net Initialization Failed
      [01.125]No ethernet found.
      [02.528]no vendor_boot partition is found
      Android's image name: d1s-nezha
      Detect comp none
      [02.547]
      Starting kernel ...
      ** 4 printk messages dropped **
      Movable zone start for each node
      Early memory node ranges
        node   0: [mem 0x0000000040000000-0x0000000043ffffff]
      On node 0 totalpages: 16384
        DMA32 zone: 0 pages reserved
      elf_hwcap is 0x20112d
      pcpu-alloc: [0] 0
      Kernel command line: ubi.mtd=sys ubi.block=0,rootfs earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/ubiblock0_5 rootfstype=squashfs init=/pseudo_init partitions=mbr@ubi0_0:boot-resource@ubi0_1:env@ubi0_2:env-redund@ubi0_3:boot@ubi0_4:rootfs@ubi0_5:recovery@ubi0_6:rootfs_data@ubi0_7:UDISK@ubi0_8: cma=0M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun20iw1p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.05-g24521d6-dirty(03
      Sorting __ex_table...
      Memory: 54564K/65536K available (5087K kernel code, 497K rwdata, 1868K rodata, 144K init, 331K bss, 10972K reserved, 0K cma-reserved)
      SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
      rcu: Preemptible hierarchical RCU implementation.
              Tasks RCU enabled.
      rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
      Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      devtmpfs: initialized
      random: get_random_u32 called from bucket_table_alloc.isra.27+0xfe/0x120 with crng_init=0
      clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      NET: Registered protocol family 16
      cpuidle: using governor menu
      rtc_ccu: sunxi ccu init OK
      clock: sunxi ccu init OK
      sunxi iommu: irq = 4
      SCSI subsystem initialized
      videodev: Linux video capture interface: v2.00
      Advanced Linux Sound Architecture Driver Initialized.
      Bluetooth: Core ver 2.22
      NET: Registered protocol family 31
      Bluetooth: HCI device and connection manager initialized
      Bluetooth: HCI socket layer initialized
      Bluetooth: L2CAP socket layer initialized
      Bluetooth: SCO socket layer initialized
      pwm module init!
      G2D: rcq version initialized.major:252
      sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
      NET: Registered protocol family 2
      tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
      TCP established hash table entries: 512 (order: 0, 4096 bytes, linear)
      TCP bind hash table entries: 512 (order: 0, 4096 bytes, linear)
      TCP: Hash tables configured (established 512 bind 512)
      UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
      UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
      sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
      sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
      sunxi_spi_resource_get()2189 - Failed to get sample mode
      sunxi_spi_resource_get()2194 - Failed to get sample delay
      sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_delay:-1431633921
      sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
      sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base ffffffd004058000, irq 31
      io scheduler kyber registered
      [DISP]disp_module_init
      [DISP] parser_disp_init_para,line:1430:
      of_property_read fb0_width fail
      [DISP] disp_init,line:2386:
      display_fb_request,fb_id:0
      Freeing logo buffer memory: 1500K
      sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
      [DISP]disp_module_init finish
      sunxi_sid_init()551 - insmod ok
      uart uart0: get regulator failed
      uart uart0: uart0 supply uart not found, using dummy regulator
      uart0: ttyS0 at MMIO 0x2500000 (irq = 18, base_baud = 1500000) is a SUNXI
      sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
      printk: console [ttyS0] enabled
      uart uart1: get regulator failed
      uart uart1: uart1 supply uart not found, using dummy regulator
      uart1: ttyS1 at MMIO 0x2500400 (irq = 19, base_baud = 1500000) is a SUNXI
      misc dump reg init
      sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
      sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
      sunxi-rfkill soc@3000000:rfkill@0: get gpio wlan_regon failed
      sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
      sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
      sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
      sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
      sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=210 assert=0
      sunxi-spinand: AW SPINand MTD Layer Version: 2.0 20201228
      sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
      sunxi-spinand-phy: not detect munufacture from fdt
      sunxi-spinand-phy: detect munufacture from id table: GD
      sunxi-spinand-phy: detect spinand id: ffff51c8 ffffffff
      sunxi-spinand-phy: ========== arch info ==========
      sunxi-spinand-phy: Model:               GD5F1GQ5UEYIG
      sunxi-spinand-phy: Munufacture:         GD
      sunxi-spinand-phy: DieCntPerChip:       1
      sunxi-spinand-phy: BlkCntPerDie:        1024
      sunxi-spinand-phy: PageCntPerBlk:       64
      sunxi-spinand-phy: SectCntPerPage:      4
      sunxi-spinand-phy: OobSizePerPage:      64
      sunxi-spinand-phy: BadBlockFlag:        0x0
      sunxi-spinand-phy: OperationOpt:        0x7
      sunxi-spinand-phy: MaxEraseTimes:       50000
      sunxi-spinand-phy: EccFlag:             0x1
      sunxi-spinand-phy: EccType:             7
      sunxi-spinand-phy: EccProtectedType:    2
      sunxi-spinand-phy: ========================================
      sunxi-spinand-phy:
      sunxi-spinand-phy: ========== physical info ==========
      sunxi-spinand-phy: TotalSize:    128 M
      sunxi-spinand-phy: SectorSize:   512 B
      sunxi-spinand-phy: PageSize:     2 K
      sunxi-spinand-phy: BlockSize:    128 K
      sunxi-spinand-phy: OOBSize:      64 B
      sunxi-spinand-phy:
      sunxi-spinand-phy: ========== logical info ==========
      sunxi-spinand-phy: PageSize:     4 K
      sunxi-spinand-phy: BlockSize:    256 K
      sunxi-spinand-phy: OOBSize:      128 B
      sunxi-spinand-phy: GD5F1GQ5UEYIG reset rx bit width to 1
      sunxi-spinand-phy: GD5F1GQ5UEYIG reset tx bit width to 1
      sunxi-spinand-phy: block lock register: 0x00
      sunxi-spinand-phy: feature register: 0x11
      sunxi-spinand-phy: sunxi physic nand init end
      Creating 4 MTD partitions on "sunxi_mtd_nand":
      0x000000000000-0x000000100000 : "boot0"
      0x000000100000-0x000000500000 : "uboot"
      random: fast init done
      0x000000500000-0x000000600000 : "secure_storage"
      0x000000600000-0x000008000000 : "sys"
      RTL871X: module init start
      RTL871X: rtl8189fs v4.3.24.8_22657.20170607
      RTL871X: module init ret=0
      sunxi-ehci: EHCI SUNXI driver
      [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xffffffe00079b9c0, 0x:ffffffd004071000, irq_no:31
      hub 1-0:1.0: USB hub found
      hub 1-0:1.0: 1 port detected
      sunxi-ohci: OHCI SUNXI driver
      [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xffffffe00079bd88
      hub 2-0:1.0: USB hub found
      hub 2-0:1.0: 1 port detected
      sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
      sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:04 UTC (4)
      i2c /dev entries driver
      uvcvideo: Unable to create debugfs directory
      usbcore: registered new interface driver uvcvideo
      USB Video Class driver (1.1.1)
      sunxi cedar version 1.1
      VE: install start!!!
      VE: cedar-ve the get irq is 6
      VE: install end!!!
      VE: sunxi_cedar_probe
      sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
      ashmem: initialized
      exFAT: Version 1.3.0
      [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
      [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
      [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
      sid_rd_ver_reg()254 - ver >= 4, soc ver:5
      sunxi-mmc 4021000.sdmmc: card claims to support voltages below defined range
      input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input0
      Segment Routing with IPv6
      [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
      Bluetooth: RFCOMM TTY layer initialized
      Bluetooth: RFCOMM socket layer initialized
      sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      Bluetooth: RFCOMM ver 1.11
      sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      sunxi-i2c sunxi-i2c2: sunxi-i2c2 supply twi not found, using dummy regulator
      sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      mmc0: new high speed SDIO card at address 0001
      input: fts_ts as /devices/platform/soc@3000000/sunxi-i2c2/i2c-2/2-0038/input/input1
      sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
      sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x38)
      fts_ts 2-0038: 2-0038 supply  not found, using dummy regulator
      sunxi-i2c sunxi-i2c2: probe success
      reg-fixed-voltage usb1-vbus: nonexclusive access to GPIO for usb1-vbus
      [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe00079b230, 0x:ffffffd0040f4000, irq_no:2e
      [sunxi-ehci0]: Not init ehci0
      [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe00079b5f8
      [sunxi-ohci0]: Not init ohci0
      ubi0: attaching mtd3
      ubi0: attached mtd3 (name "sys", size 122 MiB)
      ubi0: good PEBs: 488, bad PEBs: 0, corrupted PEBs: 0
      ubi0: available PEBs: 6, total reserved PEBs: 482, PEBs reserved for bad PEB handling: 10
      ubi0: background thread "ubi_bgt0d" started, PID 62
      block ubiblock0_5: created from ubi0:5(rootfs)
      ERR: det_vbus gpio_request failed
      ALSA device list:
        #0: audiocodec
      alloc_fd: slot 0 not NULL!
      VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
      devtmpfs: mounted
      Freeing unused kernel memory: 144K
      This architecture does not have kernel memory protection.
      Run /pseudo_init as init process
      random: crng init done
      UBIFS (ubi0:7): Mounting in unauthenticated mode
      UBIFS (ubi0:7): background thread "ubifs_bgt0_7" started, PID 90
      UBIFS (ubi0:7): recovery needed
      UBIFS (ubi0:7): recovery completed
      UBIFS (ubi0:7): UBIFS: mounted UBI device 0, volume 7, name "rootfs_data"
      UBIFS (ubi0:7): LEB size: 258048 bytes (252 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
      UBIFS (ubi0:7): FS size: 3096576 bytes (2 MiB, 12 LEBs), journal size 1806337 bytes (1 MiB, 5 LEBs)
      UBIFS (ubi0:7): reserved for root: 146258 bytes (142 KiB)
      UBIFS (ubi0:7): media format: w5/r0 (latest is w5/r0), UUID EF7D946C-F15A-4E7A-8105-8B255A805796, small LPT model
      UBIFS (ubi0:8): Mounting in unauthenticated mode
      UBIFS (ubi0:8): background thread "ubifs_bgt0_8" started, PID 119
      UBIFS (ubi0:8): recovery needed
      UBIFS (ubi0:8): recovery completed
      UBIFS (ubi0:8): UBIFS: mounted UBI device 0, volume 8, name "UDISK"
      UBIFS (ubi0:8): LEB size: 258048 bytes (252 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
      UBIFS (ubi0:8): FS size: 47738880 bytes (45 MiB, 185 LEBs), journal size 2322432 bytes (2 MiB, 9 LEBs)
      UBIFS (ubi0:8): reserved for root: 2254825 bytes (2201 KiB)
      UBIFS (ubi0:8): media format: w5/r0 (latest is w5/r0), UUID 26DCDA98-CAB6-4A6D-B43F-4EC2345931D8, small LPT model
      usbcore: registered new interface driver usb-storage
      sunxi_gpadc_init,2151, success
      sunxi_gpadc_setup: get channel scan data failed
      input: sunxi-gpadc0 as /devices/virtual/input/input2
      sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
      sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
      ------run rc.final file-----
        : values=on
      file system registered
      configfs-gadget 4100000.udc-controller: failed to start g1: -19
      read descriptors
      read strings
      insmod_host_driver
      [ehci0-controller]: sunxi_usb_enable_ehci
      sunxi-ehci 4101000.ehci0-controller: 4101000.ehci0-controller supply hci not found, using dummy regulator
      sunxi-ehci 4101000.ehci0-controller: EHCI Host Controller
      sunxi-ehci 4101000.ehci0-controller: new USB bus registered, assigned bus number 3
      sunxi-ehci 4101000.ehci0-controller: irq 46, io mem 0x04101000
      sunxi-ehci 4101000.ehci0-controller: USB 2.0 started, EHCI 1.00
      hub 3-0:1.0: USB hub found
      hub 3-0:1.0: 1 port detected
      [ohci0-controller]: sunxi_usb_enable_ohci
      sunxi-ohci 4101400.ohci0-controller: 4101400.ohci0-controller supply hci not found, using dummy regulator
      sunxi-ohci 4101400.ohci0-controller: OHCI Host Controller
      sunxi-ohci 4101400.ohci0-controller: new USB bus registered, assigned bus number 4
      sunxi-ohci 4101400.ohci0-controller: irq 47, io mem 0x04101400
      hub 4-0:1.0: USB hub found
      hub 4-0:1.0: 1 port detected
      host_chose finished!
      IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
      ------run profile file-----
      nice: can't execute '/usr/bin/story_bin': No such file or directory
      root@TinaLinux:/#
        8723ds的wlan0是能正常使用的,已经连接网络,能ping通。
