    T5 lvds 双屏同显问题
    5277
    • F
      Flork LV 4 最后由 编辑
      使用的是T507芯片,利用PD0-PD9作为第一路LVDS输出,PD10-PD19作为lvds的第二路输出。
      上电之后显示绿屏
      设备树配置如下
      disp: disp@01000000 {
      			dev1_output_type         = <1>;
      			dev1_output_mode         = <4>;
      			fb0_width                = <1024>;
      			fb0_height               = <600>;
      			fb0_buffer_num		 = <3>;
      			fb1_width                = <1024>;
      			fb1_height               = <600>;
      			/* VCC-LCD */
      			dc1sw-supply = <&reg_sw>;
      			/* VCC-LVDS and VCC-HDMI */
      			bldo1-supply = <&reg_bldo1>;
      			/* VCC-TV */
      			cldo4-supply = <&reg_cldo4>;
      lcd0: lcd0@01c0c000 {
      			lcd_used            = <1>;
      			lcd_backlight       = <50>;
      			lcd_if              = <3>;
      			lcd_x               = <1024>;
      			lcd_y               = <600>;
      			lcd_width           = <154>;
      			lcd_height          = <86>;
      			lcd_dclk_freq       = <51>;
      			lcd_pwm_used        = <0>;
      			lcd_pwm_ch          = <0>;
      			lcd_pwm_pol         = <1>;
      			lcd_pwm_max_limit   = <255>;
      			lcd_hbp             = <20>;
      			lcd_ht              = <1344>;
      			lcd_hspw            = <10>;
      			lcd_vbp             = <10>;
      			lcd_vt              = <635>;
      			lcd_vspw            = <5>;
      			lcd_lvds_if         = <0>;
      			lcd_lvds_colordepth = <0>;
      			lcd_lvds_mode       = <0>;
      			lcd_frm             = <0>;
      			lcd_hv_clk_phase    = <0>;
      			lcd_hv_sync_polarity= <0>;
      			lcd_gamma_en        = <1>;
      			lcd_bright_curve_en = <0>;
      			lcd_cmap_en         = <0>;
      			lcd_fsync_en        = <0>;
      			lcd_fsync_act_time  = <1000>;
      			lcd_fsync_dis_time  = <1000>;
      			lcd_fsync_pol       = <0>;
      			deu_mode            = <0>;
      			lcdgamma4iep        = <22>;
      			smart_color         = <90>;
      			lcd_pin_power = "bldo1";
      			lcd_power = "dc1sw";
      			lcd_bl_en        	= <&pio PE 3 1 2 3 1>;
      			pinctrl-0 = <&lvds0_pins_a>;
      			pinctrl-1 = <&lvds0_pins_b>;
      lcd0 与 lcd1配置除了后面的pin都一样
      是需要更改disp驱动的内容吗
      • F
        Flork LV 4 最后由 编辑
        demsg中DISP部分信息如下
        [    0.420596] Bluetooth: SCO socket layer initialized
        [    0.421454] [DISP]disp_module_init
        [    0.495499] enable lcd_gamma_table success!
        [    0.495880] enable lcd_gamma_table success!
        [    0.497696] [DISP] config_fb_by_screen,line:2636:
        [    0.497709] config_fb_by_screen fb[0] res[1024x600],size in mm[1024x600]
        [    0.501168] [DISP] bind_fb_to_screen,line:2664:
        [    0.501180] fb-->scr 0->0,fb_mode=0,addr=0xff800000
        [    0.501190] [DISP] config_fb_create_info_by_screen,line:2594:
        [    0.501198] config_fb_create_info_by_screen buf:3,fb_mode:0,[1024x600],output[1024x600]
        [    0.501217] [DISP] Fb_copy_boot_fb,line:2049:
        [    0.501222] no boot_fb0
        [    0.501231] [DISP] bind_fb_to_screen,line:2792:
        [    0.501241] bind_fb_to_screen fb[0],size[1024x600],crop(0:0)[4398046511104x2576980377600],screen[1024x600]
        [    0.501955] [DISP] config_fb_by_screen,line:2636:
        [    0.501963] config_fb_by_screen fb[1] res[1024x600],size in mm[1024x600]
        [    0.505393] [DISP] bind_fb_to_screen,line:2664:
        [    0.505402] fb-->scr 1->0,fb_mode=0,addr=0xff000000
        [    0.505410] [DISP] config_fb_create_info_by_screen,line:2594:
        [    0.505419] config_fb_create_info_by_screen buf:3,fb_mode:0,[1024x600],output[1024x600]
        [    0.505428] [DISP] bind_fb_to_screen,line:2792:
        [    0.505438] bind_fb_to_screen fb[1],size[1024x600],crop(0:0)[4398046511104x2576980377600],screen[1024x600]
        [    0.506125] [DISP] config_fb_by_screen,line:2636:
        [    0.506134] config_fb_by_screen fb[2] res[1024x600],size in mm[1024x600]
        [    0.509542] [DISP] bind_fb_to_screen,line:2664:
        [    0.509552] fb-->scr 2->0,fb_mode=0,addr=0xfe800000
        [    0.509560] [DISP] config_fb_create_info_by_screen,line:2594:
        [    0.509567] config_fb_create_info_by_screen buf:3,fb_mode:0,[1024x600],output[1024x600]
        [    0.509576] [DISP] bind_fb_to_screen,line:2792:
        [    0.509585] bind_fb_to_screen fb[2],size[1024x600],crop(0:0)[4398046511104x2576980377600],screen[1024x600]
        [    0.511361] [DISP] disp_lcd_is_interlace,line:874:
        [    0.511370] disp_lcd_is_interlace lcd_interlace=0
        [    0.511711] [DISP] lcd_clk_config,line:722:
        [    0.511724] disp 0, clk: pll(357000000),clk(357000000),dclk(51000000) dsi_rate(357000000)
        [    0.511724]      clk real:pll(360000000),clk(360000000),dclk(51428571) dsi_rate(0)
        [    0.511745] [DISP] disp_sys_pwm_set_polarity,line:637:
        [    0.511751] disp_sys_pwm_Set_Polarity, handle is NULL!
        [    0.512551] [DISP]disp_module_init finish
        目前是第一路都直接显示绿屏,第二路还没有测试,想先把lvds0调通
        • F
          Flork LV 4 最后由 编辑
          [root@/]$ cat /sys/class/disp/disp/attr/sys
          screen 0:
          de_rate 696000000 hz, ref_fps:60
          mgr0: 1024x600 fmt[rgb] cs[0x204] range[full] eotf[0x4] bits[8bits] err[0] force_sync[0] unblank direct_show[false]
                  lcd output      backlight( 50)  fps:60.8        1024x 600
                  err:0   skip:3  irq:17286       vsync:17286     vsync_skip:0
             BUF    enable ch[0] lyr[0] z[5] prem[N] a[pixel   0] fmt[  0] fb[1024, 600;1024, 600;1024, 600] crop[   0,   0,1024, 600] frame[   0,   0,1024, 600] addr[ff800000,       0,       0] flags[0x       0] trd[0,0]
          depth[ 0] transf[0]
             BUF    enable ch[1] lyr[0] z[3] prem[N] a[pixel   0] fmt[  0] fb[1024, 600;1024, 600;1024, 600] crop[   0,   0,1024, 600] frame[   0,   0,1024, 600] addr[ff000000,       0,       0] flags[0x       0] trd[0,0]
          depth[ 0] transf[0]
             BUF    enable ch[2] lyr[0] z[1] prem[N] a[pixel   0] fmt[  0] fb[1024, 600;1024, 600;1024, 600] crop[   0,   0,1024, 600] frame[   0,   0,1024, 600] addr[fe800000,       0,       0] flags[0x       0] trd[0,0]
          depth[ 0] transf[0]
            whycan晕哥 LV 9 @Flork 最后由 编辑
            @flork
            同显只要给 lcd0 参数即可。
            F 1 条回复 最后回复 回复 引用 分享 0
            • F
              Flork LV 4 @whycan 最后由 编辑
              @whycan
              谢谢晕哥!lvds能显示了
              我还想问下如果我想要lvds输出标准74.25MHz的720P30该怎么配置呢
