    T113 100ASK-PRO板子无法烧录镜像
    • K
      kelsey LV 6 最后由 编辑
      我使用的是百问网的100ASK T113板子,
      SDK也是百问网提供的,之后打上T113的板级配置补丁,但是使用编译出来的固件始终无法烧录,log如下
      [662]fes begin commit:2c94b33
      [665]set pll start
      [670]periph0 has been enabled
      [673]set pll end
      [675][pmu]: bus read error
      [677]board init ok
      [679]beign to init dram
      [682]ZQ value = 0x31***********
      [684]get_pmu_exist() = -1
      [687]ddr_efuse_type: 0xa
      [690][AUTO DEBUG] single rank and full DQ!
      [694]ddr_efuse_type: 0xa
      [697][AUTO DEBUG] rank 0 row = 13
      [700][AUTO DEBUG] rank 0 bank = 8
      [703][AUTO DEBUG] rank 0 page size = 2 KB
      [707]DRAM BOOT DRIVE INFO: V0.24
      [710]DRAM CLK = 792 MHz
      [712]DRAM Type = 3 (2:DDR2,3:DDR3)
      [716]DRAMC read ODT  off.
      [718]DRAM ODT value: 0x42.
      [721]ddr_efuse_type: 0xa
      [724]DRAM SIZE =128 M
      [726]PLL_DDR_CTRL_REG:0xf8004100
      [728]DRAM_CLK_REG:0xc0000000
      [732]DRAM simple test OK.
      [735]rtc standby flag is 0x0, super standby flag is 0x0
      [740]init dram ok
      U-Boot 2018.05-g5b4bafa (Oct 18 2021 - 01:53:36 +0000) Allwinner Technology
      [02.308]CPU:   Allwinner Family
      [02.311]Model: sun8iw20
      [02.313]DRAM:  128 MiB
      [02.317]Relocation Offset is: 04ec6000
      [02.344]secure enable bit: 0
      [02.346]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [02.352]gic: normal mode
      [02.355]flash init start
      [02.357]workmode = 16,storage type = 0
      try card 2
      set card number 2
      get card number 2
      [02.365][mmc]: mmc driver ver uboot2018:2021-09-07 19:43:00
      [02.371][mmc]: Is not Boot mode!
      [02.374][mmc]: SUNXI SDMMC Controller Version:0x50310
      [02.385][mmc]: ************Try SD card 2************
      [02.390][mmc]: mmc 2 cmd timeout 100 status 100
      [02.394][mmc]: smc 2 err, cmd 8,  RTO
      [02.398][mmc]: mmc 2 close bus gating and reset
      [02.403][mmc]: mmc 2 cmd timeout 100 status 100
      [02.407][mmc]: smc 2 err, cmd 55,  RTO
      [02.410][mmc]: mmc 2 close bus gating and reset
      [02.415][mmc]: ************Try MMC card 2************
      [02.424][mmc]: mmc 2 cmd timeout 100 status 100
      [02.428][mmc]: smc 2 err, cmd 1,  RTO
      [02.431][mmc]: mmc 2 close bus gating and reset
      [02.435][mmc]: Card did not respond to voltage select!
      [02.440][mmc]: ************SD/MMC 2 init error!************
      [02.445][mmc]: mmc init product failed
      MMC init failed
      try emmc fail
      [02.452]sunxi-spinand: AW SPINand MTD Layer Version: 1.5 20200407
      [02.458]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.9 20200306
      [02.466]sunxi-spinand-phy: request spi0 gpio ok
      [02.470]sunxi-spinand-phy: request general tx dma channel ok!
      [02.475]sunxi-spinand-phy: request general rx dma channel ok!
      [02.481]sunxi-spinand-phy: set spic0 clk to 20 Mhz
      [02.485]sunxi-spinand-phy: init spic0 clk ok
      [02.531]sunxi-spinand-phy: not detect any munufacture from id table
      [02.537]sunxi-spinand-phy: get spi-nand Model from fdt fail
      [02.542]sunxi-spinand-phy: get phy info from fdt fail
      [02.547]sunxi-spinand-phy: not detect munufacture from fdt
      [02.552]sunxi-spinand-phy: detect munufacture from id table: Mxic
      [02.558]sunxi-spinand-phy: detect spinand id: ffff12c2 ffffffff
      [02.563]sunxi-spinand-phy: ========== arch info ==========
      [02.569]sunxi-spinand-phy: Model:               MX35LF1GE4AB
      [02.574]sunxi-spinand-phy: Munufacture:         Mxic
      [02.579]sunxi-spinand-phy: DieCntPerChip:       1
      [02.583]sunxi-spinand-phy: BlkCntPerDie:        1024
      [02.588]sunxi-spinand-phy: PageCntPerBlk:       64
      [02.592]sunxi-spinand-phy: SectCntPerPage:      4
      [02.597]sunxi-spinand-phy: OobSizePerPage:      64
      [02.601]sunxi-spinand-phy: BadBlockFlag:        0x1
      [02.606]sunxi-spinand-phy: OperationOpt:        0x7
      [02.610]sunxi-spinand-phy: MaxEraseTimes:       65000
      [02.615]sunxi-spinand-phy: EccFlag:             0x2
      [02.620]sunxi-spinand-phy: EccType:             4
      [02.624]sunxi-spinand-phy: EccProtectedType:    3
      [02.629]sunxi-spinand-phy: ========================================
      [02.635]sunxi-spinand-phy:
      [02.637]sunxi-spinand-phy: ========== physical info ==========
      [02.643]sunxi-spinand-phy: TotalSize:    128 M
      [02.647]sunxi-spinand-phy: SectorSize:   512 B
      [02.651]sunxi-spinand-phy: PageSize:     2 K
      [02.655]sunxi-spinand-phy: BlockSize:    128 K
      [02.659]sunxi-spinand-phy: OOBSize:      64 B
      [02.663]sunxi-spinand-phy: ========================================
      [02.669]sunxi-spinand-phy:
      [02.672]sunxi-spinand-phy: ========== logical info ==========
      [02.677]sunxi-spinand-phy: TotalSize:    128 M
      [02.681]sunxi-spinand-phy: SectorSize:   512 B
      [02.685]sunxi-spinand-phy: PageSize:     4 K
      [02.689]sunxi-spinand-phy: BlockSize:    256 K
      [02.694]sunxi-spinand-phy: OOBSize:      128 B
      [02.698]sunxi-spinand-phy: ========================================
      [02.704]sunxi-spinand-phy: MX35LF1GE4AB reset rx bit width to 1
      [02.710]sunxi-spinand-phy: MX35LF1GE4AB reset tx bit width to 1
      [02.715]sunxi-spinand-phy: set spic0 clk to 100 Mhz
      [02.720]sunxi-spinand-phy: block lock register: 0x00
      [02.724]sunxi-spinand-phy: feature register: 0x11
      [02.729]sunxi-spinand-phy: sunxi physic nand init end
      [02.734]Loading Environment from SUNXI_FLASH... OK
      [02.738]try to burn key
      [02.740]out of usb burn from boot: not boot mode
      sunxi work mode=0x10
      run usb efex
      buf queue page size = 16384
      delay time 2500
      weak:otg_phy_config
      usb init ok
      set address 0x13
      set address 0x13 ok
      一直卡这个地方
      感觉是我USB问题?
      注:板子验证过,之前是OK的,但是我重新拉了一个SDK之后,就没有办法烧录了
