    D1s上电uboot启动过程30%概率卡住,不往下执行
      litengos LV 4 最后由 q1215200171 编辑
      U-Boot 2018.05-g24521d6-dirty (Mar 27 2023 - 17:32:51 +0800) Allwinner Technology
      [00.312]DRAM:  64 MiB
      [00.315]Relocation Offset is: 01ee5000
      [00.319]secure enable bit: 0
      [00.322]CPU=720 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.328]flash init start
      [00.331]workmode = 0,storage type = 0
      [00.335]sunxi-spinand: AW SPINand MTD Layer Version: 1.5 20200407
      [00.340]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.9 20200306
      [00.350]sunxi-spinand-phy: request spi0 gpio ok
      [00.354]sunxi-spinand-phy: request general tx dma channel ok!
      [00.359]sunxi-spinand-phy: request general rx dma channel ok!
      [00.365]sunxi-spinand-phy: set spic0 clk to 20 Mhz
      [00.369]sunxi-spinand-phy: init spic0 clk ok
      [BCC] 0x4025038 = 0x20000000, [DMA] 0x4025088 = 0x000000e5
      [00.415]sunxi-spinand-phy: not detect any munufacture from id table
      [00.421]sunxi-spinand-phy: get spi-nand Model from fdt fail
      [00.427]sunxi-spinand-phy: get phy info from fdt fail
      [00.431]sunxi-spinand-phy: not detect munufacture from fdt
      [00.437]sunxi-spinand-phy: detect munufacture from id table: Winbond
      [00.443]sunxi-spinand-phy: detect spinand id: ff21aaef ffffffff
      [00.448]sunxi-spinand-phy: ========== arch info ==========
      [00.453]sunxi-spinand-phy: Model:               W25N01GVZEIG
      [00.459]sunxi-spinand-phy: Munufacture:         Winbond
      [00.464]sunxi-spinand-phy: DieCntPerChip:       1
      [00.468]sunxi-spinand-phy: BlkCntPerDie:        1024
      [00.473]sunxi-spinand-phy: PageCntPerBlk:       64
      [00.477]sunxi-spinand-phy: SectCntPerPage:      4
      [00.482]sunxi-spinand-phy: OobSizePerPage:      64
      [00.486]sunxi-spinand-phy: BadBlockFlag:        0x0
      [00.491]sunxi-spinand-phy: OperationOpt:        0x7
      [00.495]sunxi-spinand-phy: MaxEraseTimes:       65000
      [00.500]sunxi-spinand-phy: EccFlag:             0x0
      [00.505]sunxi-spinand-phy: EccType:             2
      [00.509]sunxi-spinand-phy: EccProtectedType:    3
      [00.514]sunxi-spinand-phy: ========================================
      [00.520]sunxi-spinand-phy:
      [00.522]sunxi-spinand-phy: ========== physical info ==========
      [00.528]sunxi-spinand-phy: TotalSize:    128 M
      [00.532]sunxi-spinand-phy: SectorSize:   512 B
      [00.536]sunxi-spinand-phy: PageSize:     2 K
      [00.540]sunxi-spinand-phy: BlockSize:    128 K
      [00.544]sunxi-spinand-phy: OOBSize:      64 B
      [00.548]sunxi-spinand-phy: ========================================
      [00.554]sunxi-spinand-phy:
      [00.557]sunxi-spinand-phy: ========== logical info ==========
      [00.562]sunxi-spinand-phy: TotalSize:    128 M
      [00.566]sunxi-spinand-phy: SectorSize:   512 B
      [00.571]sunxi-spinand-phy: PageSize:     4 K
      [00.575]sunxi-spinand-phy: BlockSize:    256 K
      [00.579]sunxi-spinand-phy: OOBSize:      128 B
      [00.583]sunxi-spinand-phy: ========================================
      [00.589]sunxi-spinand-phy: set spic0 clk to 100 Mhz
      [00.594]sunxi-spinand-phy: block lock register: 0x00
      [00.599]sunxi-spinand-phy: feature register: 0x19
      [00.603]sunxi-spinand-phy: sunxi physic nand init end
      [00.608]mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,                      -(sys)
      defaults:
      mtdids  : nand0=nand
      [00.659]MTD info (4)
      [00.661]pagesize: 0x1000
      [00.663]blksize: 0x40000
      [00.665]num  offset     bytes      name
      [00.669]0    0x00000000 0x00100000 boot0
      [00.672]1    0x00100000 0x00300000 uboot
      [00.676]2    0x00400000 0x00100000 secure_storage
      [00.680]3    0x00500000 0x07b00000 sys
      [00.684]ubi attach the last part of mtd device: NO.3
      [00.760]ubi0: attaching mtd4
      [00.861]ubi0: scanning is finished
      [00.868]ubi0: attached mtd4 (name "sys", size 123 MiB)
      [00.872]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [00.879]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [00.885]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [00.891]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
      [00.897]ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
      [00.903]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
      [00.911]ubi0: available PEBs: 0, total reserved PEBs: 492, PEBs reserved for bad PEB handling: 20
      [00.919]sunxi flash init ok
      [00.922]line:703 init_clocks
      [00.925]init_clocks:finish
      [00.928]drv_disp_init
      [00.939]get flash lcd idx 0
      [00.952]HDMI 2.0 driver init start!
      [00.955]fdt_path_offset hdmi fail
      [00.958]unable to map hdmi registers
      [00.961]drv_disp_init finish
      [00.964]boot_gui_init:start
      [00.967]set disp.dev2_output_type fail. using defval=0
      [00.972]disp 0, clk: pll(525000000),clk(525000000),dclk(75000000) dsi_rate(525000000)
           clk real:pll(528000000),clk(528000000),dclk(75428571) dsi_rate(0)
      [00.987]switch device: sel=0, type=1, mode=4, format=0, bits=0, eotf=4, cs=260
      [00.995]boot_gui_init:finish
      [00.997]logical area info: 468 258048 last_lba: 235871
      [01.006]logical area info: 468 258048 last_lba: 235871
      [01.010]MTD info (4)
      [01.012]pagesize: 0x1000
      [01.014]blksize: 0x40000
      [01.017]num  offset     bytes      name
      [01.020]0    0x00000000 0x00100000 boot0
      [01.024]1    0x00100000 0x00300000 uboot
      [01.027]2    0x00400000 0x00100000 secure_storage
      [01.032]3    0x00500000 0x07b00000 sys
      [01.036]MBR info (unalign):
      [01.038]partno   addr       sects      type       name
      [01.043]0        0x00000000 0x00008000 0x00000001 mbr
      [01.048]1        0x00008000 0x00001b88 0x00008000 boot-resource
      [01.053]2        0x00009b88 0x000001f8 0x00008000 env
      [01.058]3        0x00009d80 0x000001f8 0x00008000 env-redund
      [01.063]4        0x00009f78 0x00005000 0x00008000 boot
      [01.068]5        0x0000ef78 0x000103e8 0x00008000 rootfs
      [01.073]6        0x0001f360 0x00005780 0x00008000 recovery
      [01.078]7        0x00024ae0 0x0000ee20 0x00008000 rootfs_data
      [01.084]8        0x00033900 0x00005a90 0x00000000 UDISK
      [01.089]ubi attach the last part of mtd device: NO.3
      [01.093]MBR info (align):
      [01.096]partno   addr       sects      type       name
      [01.101]0        0x00002800 0x000081f0 0x00000001 mbr
      [01.105]1        0x0000a9f0 0x00001b90 0x00008000 boot-resource
      [01.111]2        0x0000c580 0x000001f8 0x00008000 env
      [01.116]3        0x0000c778 0x000001f8 0x00008000 env-redund
      [01.121]4        0x0000c970 0x000050b8 0x00008000 boot
      [01.126]5        0x00011a28 0x000105d8 0x00008000 rootfs
      [01.131]6        0x00022000 0x00005898 0x00008000 recovery
      [01.136]7        0x00027898 0x0000ee38 0x00008000 rootfs_data
      [01.142]8        0x000366d0 0x00005a90 0x00000000 UDISK
      [01.150]logical area info: 468 258048 last_lba: 235871
      [01.159]logical area info: 468 258048 last_lba: 235871
      [0[01.169]LCD open finish
      1.167]logical area info: 468 258048 last_lba: 235871
      [01.179]logical area info: 468 258048 last_lba: 235871
      [01.188]logical area info: 468 258048 last_lba: 235871
      [01.196]logical area info: 468 258048 last_lba: 235871
      [01.205]logical area info: 468 258048 last_lba: 235871
      [01.213]logical area info: 468 258048 last_lba: 235871
      [01.222]logical area info: 468 258048 last_lba: 235871
      [01.230]logical area info: 468 258048 last_lba: 235871
      [01.239]logical area info: 468 258048 last_lba: 235871
      [01.247]logical area info: 468 258048 last_lba: 235871
      [01.255]logical area info: 468 258048 last_lba: 235871
      [01.264]logical area info: 468 258048 last_lba: 235871
      [01.272]logical area info: 468 258048 last_lba: 235871
      [01.281]logical area info: 468 258048 last_lba: 235871
      [01.289]logical area info: 468 258048 last_lba: 235871
      [01.298]logical area info: 468 258048 last_lba: 235871
      [01.306]logical area info: 468 258048 last_lba: 235871
      [01.315]logical area info: 468 258048 last_lba: 235871
      [01.323]logical area info: 468 258048 last_lba: 235871
      [01.332]logical area info: 468 258048 last_lba: 235871
      [01.340]logical area info: 468 258048 last_lba: 235871
      [01.349]logical area info: 468 258048 last_lba: 235871
      [01.357]logical area info: 468 258048 last_lba: 235871
      [01.365]logical area info: 468 258048 last_lba: 235871
      [01.378]logical area info: 468 258048 last_lba: 235871
      [01.386]logical area info: 468 258048 last_lba: 235871
      [01.395]logical area info: 468 258048 last_lba: 235871
      [01.403]logical area info: 468 258048 last_lba: 235871
      [01.412]logical area info: 468 258048 last_lba: 235871
      [01.420]logical area info: 468 258048 last_lba: 235871
      54 bytes read in 0 ms
      [01.427]bmp_name=bootlogo.bmp size 1152056
      [01.435]logical area info: 468 258048 last_lba: 235871
      [01.443]logical area info: 468 258048 last_lba: 235871
      [01.452]logical area info: 468 258048 last_lba: 235871
      1152056 bytes read in 56 ms (19.6 MiB/s)
      [01.534]logical area info: 468 258048 last_lba: 235871
      [01.542]logical area info: 468 258048 last_lba: 235871
      [01.551]logical area info: 468 258048 last_lba: 235871
      [01.559]logical area info: 468 258048 last_lba: 235871
      [01.568]logical area info: 468 258048 last_lba: 235871
      [01.576]logical area info: 468 258048 last_lba: 235871
      [01.585]logical area info: 468 258048 last_lba: 235871
      [01.593]logical area info: 468 258048 last_lba: 235871
      [01.602]logical area info: 468 258048 last_lba: 235871
      [01.610]logical area info: 468 258048 last_lba: 235871
      [01.619]logical area info: 468 258048 last_lba: 235871
      [01.627]logical area info: 468 258048 last_lba: 235871
      [01.636]logical area info: 468 258048 last_lba: 235871
      [01.644]logical area info: 468 258048 last_lba: 235871
      [01.653]logical area info: 468 258048 last_lba: 235871
      [01.661]logical area info: 468 258048 last_lba: 235871
      [01.670]logical area info: 468 258048 last_lba: 235871
      [01.678]logical area info: 468 258048 last_lba: 235871
      [01.687]logical area info: 468 258048 last_lba: 235871
      [01.695]logical area info: 468 258048 last_lba: 235871
      [01.704]logical area info: 468 258048 last_lba: 235871
      [01.712]logical area info: 468 258048 last_lba: 235871
      [01.721]logical area info: 468 258048 last_lba: 235871
      [01.729]logical area info: 468 258048 last_lba: 235871
      [01.738]logical area info: 468 258048 last_lba: 235871
      [01.746]logical area info: 468 258048 last_lba: 235871
      [01.755]logical area info: 468 258048 last_lba: 235871
      [01.760]Loading Environment from SUNXI_FLASH... OK
      [01.784]try to burn key
      [01.786]out of usb burn from boot: not need burn key
      [01.790]sunxi-spinand: spinand secure storage ok for phy blk 32 and 33
      [01.798]Item0 (Map) magic is bad
      [01.800]the secure storage map is empty
      [01.808]logical area info: 468 258048 last_lba: 235871
      [01.816]logical area info: 468 258048 last_lba: 235871
      [01.824]logical area info: 468 258048 last_lba: 235871
      [01.833]no item name ubi.mtd in the map
      [01.836]no item name ubi.block in the map
      [01.840]no item name clk_ignore_unused initcall_debugrootfstype in the map
      [01.847]no item name rootfstype in the map
      [01.850]no item name snum in the map
      [01.854]no item name mac in the map
      [01.857]no item name wifi_mac in the map
      [01.861]no item name bt_mac in the map
      [01.864]no item name specialstr in the map
      [01.868]root_partition is rootfs
      [01.871]nand_root is /dev/ubiblock0_5
      [01.874]set root to /dev/ubiblock0_5
      [01.878]set aw-ubi-spinand.ubootblks to 24
      [01.881]ubi attach the last part of mtd device: NO.3
      [01.886]ubi attach the last part of mtd device: NO.3
      [01.891]set ubi_attach_mtdnum to 3
      [01.894]update ubi part info ok
      [01.897]key 0
      [01.902]logical area info: 468 258048 last_lba: 235871
      [01.910]logical area info: 468 258048 last_lba: 235871
      [01.918]logical area info: 468 258048 last_lba: 235871
      [01.923]no misc partition is found
      [01.926]update bootcmd
      [01.932]logical area info: 468 258048 last_lba: 235871
      [01.940]logical area info: 468 258048 last_lba: 235871
      [01.948]logical area info: 468 258048 last_lba: 235871
      [01.953]fdt check ok
      [01.955]change working_fdt 0x42aa4da0 to 0x42a84da0
      [01.960]replace_fdt success addr:0x42200000
      [01.965](weak)update dtb dram start
      [01.991]update dtb dram  end
      [01.998]update dts
      [01.999]Net:   noncached_alloc(): addr = 0x42f2b080
      noncached_alloc(): addr = 0x42f2b0c0
      noncached_alloc(): addr = 0x42f2b100
      noncached_alloc(): addr = 0x42f2b940
      geth_sys_init fail!
      [02.019]Board Net Initialization Failed
      [02.023]No ethernet found.
      [02.034]partinfo: name boot, start 0x9f78, size 0x5000
