    运行directfb 的 demo出错
    directfb
    • U
      ubuntu LV 7 最后由 编辑
      # df_window
      (*) Direct/Thread: Started 'SigHandler' (12001) [CRITICAL - OTHER/0] <8388608>...
         ~~~~~~~~~~~~~~~~~~~~~~~~~| DirectFB 1.7.7 |~~~~~~~~~~~~~~~~~~~~~~~~~~
              (c) 2012-2015  DirectFB integrated media GmbH
              (c) 2001-2015  The world wide DirectFB Open Source Community
              (c) 2000-2004  Convergence (integrated media) GmbH
      (*) DirectFB/Core: Single Application Core. (2023-03-28 12:14)
      (*) Direct/Memcpy: Using libc memcpy()
      (*) Direct/Thread: Started 'Fusion Dispatch' (12002) [MESSAGING - OTHER/0] <8388608>...
      (!) DirectFB/core/vt: Couldn't open neither `/dev/tty0' nor `/dev/vc/0'!
          --> No such file or directory
      (!) DirectFB/Core: Could not initialize 'system_core' core!
          --> A general initialization error occured
       (!!!)  *** UNIMPLEMENTED [fusion_dispatch] *** [fusion.c:3937]
        whycan晕哥 LV 9 @ubuntu 最后由 whycan 编辑
        @ubuntu
        https://blog.51cto.com/u_15899439/5909239
        根据提示信息,directfb貌似依赖/dev/tty0或者/dev/vc/*设备节点,根据提示,打开/dev/vt/*使能配置
        CONFIG_VT选项将会打开内核对Virtual Terminal的支持,CONFIG_VT 打开后,内核才会支持带显示和键盘的终端设备,由于这类终端设备上通常可以打开多个virtual termial,类似于gnome console,所以叫做virtual terminal,配置上讲:
