    W25N01GVZEIG 这玩意不知道咋回事,三两下文件系统就变成了只读
    3397
    • U
      ubuntu LV 7 最后由 编辑
      [    1.212368] sunxi-spinand-phy: ========== arch info ==========
      [    1.218908] sunxi-spinand-phy: Model:               W25N01GVZEIG
      [    1.225662] sunxi-spinand-phy: Munufacture:         Winbond
      [    1.231919] sunxi-spinand-phy: DieCntPerChip:       1
      [    1.237588] sunxi-spinand-phy: BlkCntPerDie:        1024
      [    1.243553] sunxi-spinand-phy: PageCntPerBlk:       64
      [    1.249312] sunxi-spinand-phy: SectCntPerPage:      4
      [    1.254996] sunxi-spinand-phy: OobSizePerPage:      64
      [    1.260767] sunxi-spinand-phy: BadBlockFlag:        0x0
      [    1.266624] sunxi-spinand-phy: OperationOpt:        0x7
      [    1.272497] sunxi-spinand-phy: MaxEraseTimes:       65000
      [    1.278548] sunxi-spinand-phy: EccFlag:             0x0
      [    1.284415] sunxi-spinand-phy: EccType:             2
      [    1.290093] sunxi-spinand-phy: EccProtectedType:    3
      [    1.295755] sunxi-spinand-phy: ========================================
      [    1.303180] sunxi-spinand-phy:
      [    1.306704] sunxi-spinand-phy: ========== physical info ==========
      [    1.313643] sunxi-spinand-phy: TotalSize:    128 M
      [    1.319012] sunxi-spinand-phy: SectorSize:   512 B
      [    1.324397] sunxi-spinand-phy: PageSize:     2 K
      [    1.329584] sunxi-spinand-phy: BlockSize:    128 K
      [    1.334953] sunxi-spinand-phy: OOBSize:      64 B
      [    1.340248] sunxi-spinand-phy: ========================================
      [    1.347664] sunxi-spinand-phy:
      [    1.351199] sunxi-spinand-phy: ========== logical info ==========
      [    1.358038] sunxi-spinand-phy: TotalSize:    128 M
      [    1.363419] sunxi-spinand-phy: SectorSize:   512 B
      [    1.368788] sunxi-spinand-phy: PageSize:     4 K
      [    1.373978] sunxi-spinand-phy: BlockSize:    256 K
      [    1.379347] sunxi-spinand-phy: OOBSize:      128 B
      [    1.384727] sunxi-spinand-phy: ========================================
      [    1.392277] sunxi-spinand-phy: block lock register: 0x00
      [    1.398365] sunxi-spinand-phy: feature register: 0x19
      [    1.404057] sunxi-spinand-phy: sunxi physic nand init end
      [    1.410492] Creating 4 MTD partitions on "sunxi_mtd_nand":
      [    1.416649] 0x000000000000-0x000000100000 : "boot0"
      [    1.430374] 0x000000100000-0x000000400000 : "uboot"
      [    1.439641] random: fast init done
      [    1.450363] 0x000000400000-0x000000500000 : "secure_storage"
      [    1.470346] 0x000000500000-0x000008000000 : "sys"
      [    1.531030] sunxi-spinand-phy: phy blk 340 is bad
      [    1.561563] sunxi-spinand-phy: phy blk 474 is bad
      [    1.567033] sunxi-spinand-phy: phy blk 476 is bad
      [    1.572496] sunxi-spinand-phy: phy blk 478 is bad
      [    1.579080] sunxi-spinand-phy: phy blk 486 is bad
      [    1.587600] sunxi-spinand-phy: phy blk 504 is bad
      [    1.593071] sunxi-spinand-phy: phy blk 506 is bad
      [    1.603610] sunxi-spinand-phy: phy blk 540 is bad
      [    1.612800] sunxi-spinand-phy: phy blk 566 is bad
      [    1.618845] sunxi-spinand-phy: phy blk 572 is bad
      [    1.626753] sunxi-spinand-phy: phy blk 590 is bad
      [    1.632513] sunxi-spinand-phy: phy blk 594 is bad
      [    1.637945] sunxi-spinand-phy: phy blk 596 is bad
      [    1.643405] sunxi-spinand-phy: phy blk 598 is bad
      [    1.652585] sunxi-spinand-phy: phy blk 624 is bad
      [    1.658945] sunxi-spinand-phy: phy blk 632 is bad
      [    1.664394] sunxi-spinand-phy: phy blk 634 is bad
      [    1.674812] sunxi-spinand-phy: phy blk 668 is bad
      [    1.681519] sunxi-spinand-phy: phy blk 678 is bad
      [    1.686950] sunxi-spinand-phy: phy blk 680 is bad
      [    1.751023] libphy: Fixed MDIO Bus: probed
      U 1 条回复 最后回复 回复 引用 分享 0
      • U
        ubuntu LV 7 @ubuntu 最后由 编辑
        # touch /opt/aaa
        touch: /opt/aaa: Read-only file system
        U 2 条回复 最后回复 回复 引用 分享 0
        • U
          烧完,ping一个晚上就gg了
          • U
            ubuntu LV 7 @ubuntu 最后由 whycan 编辑
            重烧又可以:
            烧录日志:
            2222222222222222[28]HELLO! BOOT0 is starting!
            [31]BOOT0 commit : 88480af-dirty
            [34]set pll start
            [40]periph0 has been enabled
            [43]set pll end
            [45][pmu]: bus read error
            [47]board init ok
            [49]key press : 2
            [51]detected user input 2
            [644]fes begin commit:88480af-dirty
            [647]set pll start
            [653]periph0 has been enabled
            [656]set pll end
            [658][pmu]: bus read error
            [660]board init ok
            [662]beign to init dram
            [664]ZQ value = 0x2e
            [666]get_pmu_exist() = -1
            [669]ddr_efuse_type: 0xa
            [671]trefi:7.8ms
            [673][AUTO DEBUG] single rank and full DQ!
            [677]ddr_efuse_type: 0xa
            [679]trefi:7.8ms
            [682][AUTO DEBUG] rank 0 row = 13
            [685][AUTO DEBUG] rank 0 bank = 8
            [688][AUTO DEBUG] rank 0 page size = 2 KB
            [692]DRAM BOOT DRIVE INFO: V0.33
            [695]DRAM CLK = 936 MHz
            [697]DRAM Type = 3 (2:DDR2,3:DDR3)
            [700]DRAMC read ODT  off.
            [702]DRAM ODT value: 0x42.
            [705]ddr_efuse_type: 0xa
            [708]DRAM SIZE =128 M
            [710]dram_tpr4:0x0
            [712]PLL_DDR_CTRL_REG:0xf8004d00
            [715]DRAM_CLK_REG:0xc0000000
            [717][TIMING DEBUG] MR2= 0x20
            [721]DRAM simple test OK.
            [724]rtc standby flag is 0x0, super standby flag is 0x0
            [729]init dram ok
            U-Boot 2018.05-g24521d6-dirty (Mar 28 2023 - 22:01:17 +0800) Allwinner Technology
            [03.122]CPU:   Allwinner Family
            [03.125]Model: sun8iw20
            ready
            [03.146]DRAM:  128 MiB
            [03.149]Relocation Offset is: 04ecc000
            [03.173]secure enable bit: 0
            [03.176]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
            [03.182]gic: normal mode
            [03.185]flash init start
            [03.187]workmode = 16,storage type = 0
            try card 2
            set card number 2
            get card number 2
            [03.195][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
            [03.201][mmc]: Is not Boot mode!
            [03.204][mmc]: SUNXI SDMMC Controller Version:0x50310
            [03.215][mmc]: ************Try SD card 2************
            [03.220][mmc]: mmc 2 cmd timeout 100 status 100
            [03.224][mmc]: smc 2 err, cmd 8,  RTO
            [03.228][mmc]: mmc 2 close bus gating and reset
            [03.233][mmc]: mmc 2 cmd timeout 100 status 100
            [03.237][mmc]: smc 2 err, cmd 55,  RTO
            [03.240][mmc]: mmc 2 close bus gating and reset
            [03.245][mmc]: ************Try MMC card 2************
            [03.253][mmc]: mmc 2 cmd timeout 100 status 100
            [03.258][mmc]: smc 2 err, cmd 1,  RTO
            [03.261][mmc]: mmc 2 close bus gating and reset
            [03.265][mmc]: Card did not respond to voltage select!
            [03.270][mmc]: ************SD/MMC 2 init error!************
            [03.275][mmc]: mmc init product failed
            MMC init failed
            try emmc fail
            [03.282]sunxi-spinand: AW SPINand MTD Layer Version: 1.5 20200407
            [03.288]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.9 20200306
            [03.295]sunxi-spinand-phy: request spi0 gpio ok
            [03.300]sunxi-spinand-phy: request general tx dma channel ok!
            [03.305]sunxi-spinand-phy: request general rx dma channel ok!
            [03.310]sunxi-spinand-phy: set spic0 clk to 20 Mhz
            [03.315]sunxi-spinand-phy: init spic0 clk ok
            [03.360]sunxi-spinand-phy: not detect any munufacture from id table
            [03.367]sunxi-spinand-phy: get spi-nand Model from fdt fail
            [03.372]sunxi-spinand-phy: get phy info from fdt fail
            [03.377]sunxi-spinand-phy: not detect munufacture from fdt
            [03.382]sunxi-spinand-phy: detect munufacture from id table: Winbond
            [03.388]sunxi-spinand-phy: detect spinand id: ff21aaef ffffffff
            [03.394]sunxi-spinand-phy: ========== arch info ==========
            [03.399]sunxi-spinand-phy: Model:               W25N01GVZEIG
            [03.404]sunxi-spinand-phy: Munufacture:         Winbond
            [03.409]sunxi-spinand-phy: DieCntPerChip:       1
            [03.413]sunxi-spinand-phy: BlkCntPerDie:        1024
            [03.418]sunxi-spinand-phy: PageCntPerBlk:       64
            [03.423]sunxi-spinand-phy: SectCntPerPage:      4
            [03.427]sunxi-spinand-phy: OobSizePerPage:      64
            [03.432]sunxi-spinand-phy: BadBlockFlag:        0x0
            [03.436]sunxi-spinand-phy: OperationOpt:        0x7
            [03.441]sunxi-spinand-phy: MaxEraseTimes:       65000
            [03.446]sunxi-spinand-phy: EccFlag:             0x0
            [03.450]sunxi-spinand-phy: EccType:             2
            [03.455]sunxi-spinand-phy: EccProtectedType:    3
            [03.459]sunxi-spinand-phy: ========================================
            [03.465]sunxi-spinand-phy:
            [03.467]sunxi-spinand-phy: ========== physical info ==========
            [03.473]sunxi-spinand-phy: TotalSize:    128 M
            [03.477]sunxi-spinand-phy: SectorSize:   512 B
            [03.481]sunxi-spinand-phy: PageSize:     2 K
            [03.485]sunxi-spinand-phy: BlockSize:    128 K
            [03.489]sunxi-spinand-phy: OOBSize:      64 B
            [03.494]sunxi-spinand-phy: ========================================
            [03.500]sunxi-spinand-phy:
            [03.502]sunxi-spinand-phy: ========== logical info ==========
            [03.508]sunxi-spinand-phy: TotalSize:    128 M
            [03.512]sunxi-spinand-phy: SectorSize:   512 B
            [03.516]sunxi-spinand-phy: PageSize:     4 K
            [03.520]sunxi-spinand-phy: BlockSize:    256 K
            [03.524]sunxi-spinand-phy: OOBSize:      128 B
            [03.528]sunxi-spinand-phy: ========================================
            [03.535]sunxi-spinand-phy: set spic0 clk to 100 Mhz
            [03.539]sunxi-spinand-phy: block lock register: 0x00
            [03.544]sunxi-spinand-phy: feature register: 0x19
            [03.548]sunxi-spinand-phy: sunxi physic nand init end
            [03.553]Loading Environment from SUNXI_FLASH... OK
            [03.557]try to burn key
            [03.560]out of usb burn from boot: not need burn key
            sunxi work mode=0x10
            run usb efex
            buf queue page size = 16384
            delay time 2500
            weak:otg_phy_config
            usb init ok
            set address 0xc
            set address 0xc ok
            SUNXI_EFEX_ERASE_TAG
            erase_flag = 0x12
            origin_erase_flag = 0x1
            FEX_CMD_fes_verify_status
            FEX_CMD_fes_verify last err=0
            the 0 mbr table is ok
            the 1 mbr table is ok
            the 2 mbr table is ok
            the 3 mbr table is ok
            total mbr part 7
            part[0] classname :DISK
            part[0] addrlo    :0x8000
            part[0] lenlo     :0x800
            part[0] user_type :32768
            part[0] keydata   :0
            part[0] ro        :0
            part[1] name      :env
            part[1] classname :DISK
            part[1] addrlo    :0x8800
            part[1] lenlo     :0x1f8
            part[1] user_type :32768
            part[1] keydata   :0
            part[1] ro        :0
            part[2] name      :env-redund
            part[2] classname :DISK
            part[2] addrlo    :0x89f8
            part[2] lenlo     :0x1f8
            part[2] user_type :32768
            part[2] keydata   :0
            part[2] ro        :0
            part[3] name      :boot
            part[3] classname :DISK
            part[3] addrlo    :0x8bf0
            part[3] lenlo     :0x21e8
            part[3] user_type :32768
            part[3] keydata   :0
            part[3] ro        :0
            part[4] name      :rootfs
            part[4] classname :DISK
            part[4] addrlo    :0xadd8
            part[4] lenlo     :0x142f8
            part[4] user_type :32768
            part[4] keydata   :0
            part[4] ro        :0
            part[5] name      :rootfs_data
            part[5] classname :DISK
            part[5] addrlo    :0x1f0d0
            part[5] lenlo     :0x9e98
            part[5] user_type :32768
            part[5] keydata   :0
            part[5] ro        :0
            part[6] name      :UDISK
            part[6] classname :DISK
            part[6] addrlo    :0x28f68
            part[6] lenlo     :0x0
            part[6] user_type :33024
            part[6] keydata   :0
            part[6] ro        :0
            total part: 8
            mbr 0, 8000, 8000
            boot-resource 1, 800, 8000
            env 2, 1f8, 8000
            env-redund 3, 1f8, 8000
            boot 4, 21e8, 8000
            rootfs 5, 142f8, 8000
            rootfs_data 6, 9e98, 8000
            UDISK 7, 0, 8100
            [06.668]erase blk 0 to blk 32
            need erase flash: 18
            [06.778]mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys)
            defaults:
            mtdids  : nand0=nand
            [06.829]MTD info (4)
            [06.830]pagesize: 0x1000
            [06.833]blksize: 0x40000
            [06.835]num  offset     bytes      name
            [06.838]0    0x00000000 0x00100000 boot0
            [06.842]1    0x00100000 0x00300000 uboot
            [06.846]2    0x00400000 0x00100000 secure_storage
            [06.850]3    0x00500000 0x07b00000 sys
            [06.854]ubi attach the last part of mtd device: NO.3
            [06.911]ubi0: attaching mtd4
            [06.942]ubi0: fixable bit-flip detected at PEB 163
            [06.979]ubi0 warning: scan_peb: bad ec header at pnum 364, drop this block
            [07.008]ubi0: scanning is finished
            [07.014]ubi0: attached mtd4 (name "sys", size 123 MiB)
            [07.019]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
            [07.025]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
            [07.031]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
            [07.038]ubi0: good PEBs: 472, bad PEBs: 20, corrupted PEBs: 0
            [07.043]ubi0: user volume: 8, internal volumes: 1, max. volumes count: 128
            [07.050]ubi0: max/mean erase counter: 3/1, WL threshold: 4096, image sequence number: 0
            [07.057]ubi0: available PEBs: 0, total reserved PEBs: 472, PEBs reserved for bad PEB handling: 0
            [07.146]ubi0: fixable bit-flip detected at PEB 364
            [07.150]ubi0: run torture test for PEB 364
            [07.233]ubi0: fixable bit-flip detected at PEB 364
            [07.237]ubi0 error: torture_peb: read problems on freshly erased PEB 364, must be bad
            [07.244]ubi0 error: erase_worker: failed to erase PEB 364, error -5
            [07.250]ubi0 error: erase_worker: no reserved/available physical eraseblocks
            [07.257]ubi0 warning: ubi_ro_mode: switch to read-only mode
            [07.262]ubi0 error: do_work: work failed with error code -5
            [07.268]ubi0 error: ubi_do_worker: ubi_bgt0d: work failed with error code -5
            [07.275]erase blk 0 to blk 32
            [07.377]erase blk 40 to blk 1024
            [08.311]blk 340 is bad, skip to erase
            [08.315]blk 341 is bad, skip to erase
            [08.728]blk 474 is bad, skip to erase
            [08.732]blk 475 is bad, skip to erase
            [08.735]blk 476 is bad, skip to erase
            [08.738]blk 477 is bad, skip to erase
            [08.742]blk 478 is bad, skip to erase
            [08.745]blk 479 is bad, skip to erase
            [08.768]blk 486 is bad, skip to erase
            [08.771]blk 487 is bad, skip to erase
            [08.825]blk 504 is bad, skip to erase
            [08.828]blk 505 is bad, skip to erase
            [08.832]blk 506 is bad, skip to erase
            [08.835]blk 507 is bad, skip to erase
            [08.942]blk 540 is bad, skip to erase
            [08.945]blk 541 is bad, skip to erase
            [09.024]blk 566 is bad, skip to erase
            [09.028]blk 567 is bad, skip to erase
            [09.045]blk 572 is bad, skip to erase
            [09.048]blk 573 is bad, skip to erase
            [09.103]blk 590 is bad, skip to erase
            [09.107]blk 591 is bad, skip to erase
            [09.117]blk 594 is bad, skip to erase
            [09.120]blk 595 is bad, skip to erase
            [09.124]blk 596 is bad, skip to erase
            [09.127]blk 597 is bad, skip to erase
            [09.130]blk 598 is bad, skip to erase
            [09.134]blk 599 is bad, skip to erase
            [09.216]blk 624 is bad, skip to erase
            [09.220]blk 625 is bad, skip to erase
            [09.243]blk 632 is bad, skip to erase
            [09.246]blk 633 is bad, skip to erase
            [09.250]blk 634 is bad, skip to erase
            [09.253]blk 635 is bad, skip to erase
            [09.361]blk 668 is bad, skip to erase
            [09.365]blk 669 is bad, skip to erase
            [09.394]blk 678 is bad, skip to erase
            [09.398]blk 679 is bad, skip to erase
            [09.401]blk 680 is bad, skip to erase
            [09.404]blk 681 is bad, skip to erase
            [10.490]sunxi-spinand: spinand secure storage ok for phy blk 32 and 33
            [10.497]Item0 (Map) magic is bad
            [10.499]the secure storage map is empty
            [10.540]sunxi-spinand: write secure storage itme 0 ok
            [10.545]erase secure storage: 0 ok
            SUNXI_EFEX_MBR_TAG
            mbr size = 0x10000
            force mbr
            defaults:
            mtdids  : nand0=nand
            [10.593]MTD info (4)
            [10.595]pagesize: 0x1000
            [10.597]blksize: 0x40000
            [10.599]num  offset     bytes      name
            [10.603]0    0x00000000 0x00100000 boot0
            [10.607]1    0x00100000 0x00300000 uboot
            [10.610]2    0x00400000 0x00100000 secure_storage
            [10.615]3    0x00500000 0x07b00000 sys
            [10.618]MBR info (unalign):
            [10.621]partno   addr       sects      type       name
            [10.625]0        0x00000000 0x00008000 0x00000001 mbr
            [10.630]1        0x00008000 0x00000800 0x00008000 boot-resource
            [10.636]2        0x00008800 0x000001f8 0x00008000 env
            [10.641]3        0x000089f8 0x000001f8 0x00008000 env-redund
            [10.646]4        0x00008bf0 0x000021e8 0x00008000 boot
            [10.651]5        0x0000add8 0x000142f8 0x00008000 rootfs
            [10.656]6        0x0001f0d0 0x00009e98 0x00008000 rootfs_data
            [10.661]7        0x00028f68 0x00000000 0x00008100 UDISK
            [10.666]ubi attach the last part of mtd device: NO.3
            [10.671]MBR info (align):
            [10.673]partno   addr       sects      type       name
            [10.678]0        0x00002800 0x000081f0 0x00000001 mbr
            [10.683]1        0x0000a9f0 0x000009d8 0x00008000 boot-resource
            [10.689]2        0x0000b3c8 0x000001f8 0x00008000 env
            [10.693]3        0x0000b5c0 0x000001f8 0x00008000 env-redund
            [10.699]4        0x0000b7b8 0x00002370 0x00008000 boot
            [10.704]5        0x0000db28 0x000144d8 0x00008000 rootfs
            [10.709]6        0x00022000 0x00009f78 0x00008000 rootfs_data
            [10.714]7        0x0002bf78 0x00000000 0x00008100 UDISK
            [10.719]ubi attach the last part of mtd device: NO.3
            [10.724]ubi attatch mtd, name: sys
            [10.727]ubi0: detaching mtd4
            [10.730]ubi0: mtd4 is detached
            [10.732]ubi0: attaching mtd4
            [10.777]ubi0: scanning is finished
            [10.780]ubi0: empty MTD device detected
            [10.807]ubi0: attached mtd4 (name "sys", size 123 MiB)
            [10.812]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
            [10.818]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
            [10.824]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
            [10.830]ubi0: good PEBs: 472, bad PEBs: 20, corrupted PEBs: 0
            [10.836]ubi0: user volume: 0, internal volumes: 1, max. volumes count: 128
            [10.842]ubi0: max/mean erase counter: 0/0, WL threshold: 4096, image sequence number: 0
            [10.850]ubi0: available PEBs: 468, total reserved PEBs: 4, PEBs reserved for bad PEB handling: 0
            Creating dynamic volume boot-resource of size 1290240
            Creating dynamic volume boot of size 4644864
            Creating dynamic volume rootfs of size 42577920
            Creating dynamic volume rootfs_data of size 20901888
            No size specified -> Using max size (33804288)
            [14.184]reset last volume size to 0x101e8
            Creating dynamic volume UDISK of size 33804288
            [14.241]fill gap start: volume mbr sects 0x7f80
            [16.461]fill gap end: volume mbr
            [16.464]update partition map
            [16.467]logical area info: 468 258048 last_lba: 235871
            [16.475]logical area info: 468 258048 last_lba: 235871
            [16.482]logical area info: 468 258048 last_lba: 235871
            [16.490]logical area info: 468 258048 last_lba: 235871
            [16.498]logical area info: 468 258048 last_lba: 235871
            [16.505]logical area info: 468 258048 last_lba: 235871
            [16.513]logical area info: 468 258048 last_lba: 235871
            [16.521]logical area info: 468 258048 last_lba: 235871
            [16.528]logical area info: 468 258048 last_lba: 235871
            [16.536]logical area info: 468 258048 last_lba: 235871
            [16.544]logical area info: 468 258048 last_lba: 235871
            [16.551]logical area info: 468 258048 last_lba: 235871
            [16.559]logical area info: 468 258048 last_lba: 235871
            [16.566]logical area info: 468 258048 last_lba: 235871
            [16.574]logical area info: 468 258048 last_lba: 235871
            [16.582]logical area info: 468 258048 last_lba: 235871
            [16.589]logical area info: 468 258048 last_lba: 235871
            [16.597]logical area info: 468 258048 last_lba: 235871
            [16.605]logical area info: 468 258048 last_lba: 235871
            [16.612]logical area info: 468 258048 last_lba: 235871
            [16.620]logical area info: 468 258048 last_lba: 235871
            [16.628]logical area info: 468 258048 last_lba: 235871
            [16.635]logical area info: 468 258048 last_lba: 235871
            [16.643]logical area info: 468 258048 last_lba: 235871
            [16.651]logical area info: 468 258048 last_lba: 235871
            [16.801]fill gap start: volume boot-resource sects 0x264
            [16.879]fill gap end: volume boot-resource
            FEX_CMD_fes_verify_value, start 0x8000, size high 0x0:low 0xb3800
            FEX_CMD_fes_verify_value 0x4e0977e6
            [16.956]fill gap start: volume env sects 0xf8
            [17.031]fill gap end: volume env
            FEX_CMD_fes_verify_value, start 0x8800, size high 0x0:low 0x20000
            FEX_CMD_fes_verify_value 0x8c36594c
            [17.080]fill gap start: volume env-redund sects 0xf8
            [17.155]fill gap end: volume env-redund
            FEX_CMD_fes_verify_value, start 0x89f8, size high 0x0:low 0x20000
            [18.089]fill gap start: volume boot sects 0x9c
            [18.168]fill gap end: volume boot
            FEX_CMD_fes_verify_value, start 0x8bf0, size high 0x0:low 0x429800
            FEX_CMD_fes_verify_value 0xa3b02706
            [27.238]fill gap start: volume rootfs sects 0x4d0
            [27.319]fill gap end: volume rootfs
            [27.444]ubi0: fixable bit-flip detected at PEB 276
            [27.449]ubi0: schedule PEB 276 for scrubbing
            [27.464]ubi0: fixable bit-flip detected at PEB 276
            [27.532]ubi0: scrubbed PEB 276 (LEB 5:10), data moved to PEB 262
            [27.891]ubi0: fixable bit-flip detected at PEB 312
            [27.895]ubi0: schedule PEB 312 for scrubbing
            [27.910]ubi0: fixable bit-flip detected at PEB 312
            [27.977]ubi0: fixable bit-flip detected at PEB 276
            [27.981]ubi0: run torture test for PEB 276
            [28.064]ubi0: fixable bit-flip detected at PEB 276
            [28.068]ubi0 error: torture_peb: read problems on freshly erased PEB 276, must be bad
            [28.075]ubi0 error: erase_worker: failed to erase PEB 276, error -5
            [28.081]ubi0 error: erase_worker: no reserved/available physical eraseblocks
            [28.088]ubi0 warning: ubi_ro_mode: switch to read-only mode
            [28.093]ubi0 error: do_work: work failed with error code -5
            [28.099]ubi0 error: ubi_do_worker: ubi_bgt0d: work failed with error code -5
            [28.184]ubi0: fixable bit-flip detected at PEB 322
            [28.188]ubi0: schedule PEB 322 for scrubbing
            [28.248]ubi0: fixable bit-flip detected at PEB 327
            [28.252]ubi0: schedule PEB 327 for scrubbing
            [28.289]ubi0: fixable bit-flip detected at PEB 330
            [28.294]ubi0: schedule PEB 330 for scrubbing
            [28.320]ubi0: fixable bit-flip detected at PEB 332
            [28.324]ubi0: schedule PEB 332 for scrubbing
            [28.384]ubi0: fixable bit-flip detected at PEB 337
            [28.388]ubi0: schedule PEB 337 for scrubbing
            [28.403]ubi0: fixable bit-flip detected at PEB 338
            [28.408]ubi0: schedule PEB 338 for scrubbing
            [28.423]ubi0: fixable bit-flip detected at PEB 339
            [28.427]ubi0: schedule PEB 339 for scrubbing
            [28.520]ubi0: fixable bit-flip detected at PEB 346
            [28.525]ubi0: schedule PEB 346 for scrubbing
            [28.551]ubi0: fixable bit-flip detected at PEB 348
            [28.555]ubi0: schedule PEB 348 for scrubbing
            [28.570]ubi0: fixable bit-flip detected at PEB 349
            [28.575]ubi0: schedule PEB 349 for scrubbing
            [28.612]ubi0: fixable bit-flip detected at PEB 352
            [28.616]ubi0: schedule PEB 352 for scrubbing
            [28.665]ubi0: fixable bit-flip detected at PEB 356
            [28.669]ubi0: schedule PEB 356 for scrubbing
            [28.762]ubi0: fixable bit-flip detected at PEB 364
            [28.767]ubi0: schedule PEB 364 for scrubbing
            [28.815]ubi0: fixable bit-flip detected at PEB 368
            [28.820]ubi0: schedule PEB 368 for scrubbing
            [28.863]ubi0: fixable bit-flip detected at PEB 372
            [28.867]ubi0: schedule PEB 372 for scrubbing
            [28.954]ubi0: fixable bit-flip detected at PEB 378
            [28.959]ubi0: schedule PEB 378 for scrubbing
            [28.974]ubi0: fixable bit-flip detected at PEB 379
            [28.978]ubi0: schedule PEB 379 for scrubbing
            [28.994]ubi0: fixable bit-flip detected at PEB 380
            [28.998]ubi0: schedule PEB 380 for scrubbing
            [29.024]ubi0: fixable bit-flip detected at PEB 382
            [29.028]ubi0: schedule PEB 382 for scrubbing
            [29.077]ubi0: fixable bit-flip detected at PEB 386
            [29.081]ubi0: schedule PEB 386 for scrubbing
            [29.130]ubi0: fixable bit-flip detected at PEB 390
            [29.134]ubi0: schedule PEB 390 for scrubbing
            [29.160]ubi0: fixable bit-flip detected at PEB 392
            [29.165]ubi0: schedule PEB 392 for scrubbing
            [29.246]ubi0: fixable bit-flip detected at PEB 399
            [29.251]ubi0: schedule PEB 399 for scrubbing
            [29.277]ubi0: fixable bit-flip detected at PEB 401
            [29.281]ubi0: schedule PEB 401 for scrubbing
            [29.296]ubi0: fixable bit-flip detected at PEB 402
            [29.301]ubi0: schedule PEB 402 for scrubbing
            [29.316]ubi0: fixable bit-flip detected at PEB 403
            [29.320]ubi0: schedule PEB 403 for scrubbing
            [29.402]ubi0: fixable bit-flip detected at PEB 409
            [29.407]ubi0: schedule PEB 409 for scrubbing
            [29.455]ubi0: fixable bit-flip detected at PEB 413
            [29.460]ubi0: schedule PEB 413 for scrubbing
            [29.497]ubi0: fixable bit-flip detected at PEB 416
            [29.501]ubi0: schedule PEB 416 for scrubbing
            [29.516]ubi0: fixable bit-flip detected at PEB 417
            [29.521]ubi0: schedule PEB 417 for scrubbing
            [29.569]ubi0: fixable bit-flip detected at PEB 421
            [29.574]ubi0: schedule PEB 421 for scrubbing
            [29.589]ubi0: fixable bit-flip detected at PEB 422
            [29.593]ubi0: schedule PEB 422 for scrubbing
            [29.675]ubi0: fixable bit-flip detected at PEB 429
            [29.679]ubi0: schedule PEB 429 for scrubbing
            [29.728]ubi0: fixable bit-flip detected at PEB 433
            [29.732]ubi0: schedule PEB 433 for scrubbing
            FEX_CMD_fes_verify_value, start 0xadd8, size high 0x0:low 0x27c5000
            FEX_CMD_fes_verify_value 0xe1001ae8
            bootfile_mode=4
            SUNXI_EFEX_BOOT1_TAG
            boot1 size = 0x138000, max size = 0x400000
            uboot size = 0x138000
            storage type = 0
            preserved len:16384
            [29.833]uboot blk range [8-32)
            [29.836]download uboot to block 8 (10 blocks) len 1248K
            [30.111]download uboot to block 18 (10 blocks) len 1248K
            bootfile_mode=4
            SUNXI_EFEX_BOOT0_TAG
            boot0 size = 0xc000
            dram para[0] = 3a8
            dram para[1] = 3
            dram para[2] = 7b7bfb
            dram para[3] = 0
            dram para[4] = 10d2
            dram para[5] = 800000
            dram para[6] = 1e14
            dram para[7] = 42
            dram para[8] = 20
            dram para[9] = 0
            dram para[10] = 4899d7
            dram para[11] = 1c241d0
            dram para[12] = a4073
            dram para[13] = b4787896
            dram para[14] = 0
            dram para[15] = 48484848
            dram para[16] = 48
            dram para[17] = 1620121e
            dram para[18] = 0
            dram para[19] = 0
            dram para[20] = 0
            dram para[21] = 340000
            dram para[22] = 46
            dram para[23] = b4006103
            dram para[24] = 0
            dram para[25] = 0
            dram para[26] = 0
            dram para[27] = 0
            dram para[28] = 0
            dram para[29] = 0
            dram para[30] = 0
            dram para[31] = 0
            storage type = 0
            [30.458]download boot0 to block 0 len 48K
            [30.474]download boot0 to block 1 len 48K
            [30.491]download boot0 to block 2 len 48K
            [30.507]download boot0 to block 3 len 48K
            [30.523]download boot0 to block 4 len 48K
            [30.540]download boot0 to block 5 len 48K
            [30.556]download boot0 to block 6 len 48K
            [30.572]download boot0 to block 7 len 48K
            sunxi_efex_next_action=2
            exit usb
            next work 2
            启动日志:
            ▒[28]HELLO! BOOT0 is starting!T
            [34]set pll start
            [43]set pll end
            [47]board init ok
            [49]ZQ value = 0x2d
            [51]get_pmu_exist() = -1
            [53]DRAM BOOT DRIVE INFO: V0.33
            [56]DRAM CLK = 936 MHz
            [59]DRAM Type = 3 (2:DDR2,3:DDR3)
            [62]DRAMC read ODT  off.
            [64]DRAM ODT value: 0x42.
            [67]ddr_efuse_type: 0xa
            [70]DRAM SIZE =128 M
            [72]dram_tpr4:0x0
            [73]PLL_DDR_CTRL_REG:0xf8004d00
            [76]DRAM_CLK_REG:0xc0000000
            [79][TIMING DEBUG] MR2= 0x20
            [86]DRAM simple test OK.
            [89]rtc standby flag is 0x0, super standby flag is 0x0
            [94]dram size =128
            [97]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
            [102]block from 8 to 32
            [197]Check is correct.
            [199]dma 0x29c0c int is not used yet
            [202]dma 0x29c0c int is free, you do not need to free it again
            [208]Entry_name        = u-boot
            [214]Entry_name        = optee
            [218]Entry_name        = dtb
            [221]Jump to second Boot.
            [00.274]CPU:   Allwinner Family
            [00.277]Model: sun8iw20
            ready
            [00.299]DRAM:  128 MiB
            [00.302]Relocation Offset is: 04ecc000
            [00.326]secure enable bit: 0
            [00.329]smc_tee_inform_fdt failed with: -65526[00.333]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
            [00.340]gic: sec monitor mode
            [00.343]flash init start
            [00.345]workmode = 0,storage type = 0
            [BCC] 0x4025038 = 0x20000000, [DMA] 0x4025088 = 0x000000e5
            [00.391]sunxi-spinand-phy: not detect any munufacture from id table
            [00.398]sunxi-spinand-phy: get spi-nand Model from fdt fail
            [00.403]sunxi-spinand-phy: get phy info from fdt fail
            defaults:
            mtdids  : nand0=nand
            [00.503]ubi0: attaching mtd4
            [00.535]ubi0: fixable bit-flip detected at PEB 163
            [00.571]ubi0: fixable bit-flip detected at PEB 364
            [00.598]ubi0: scanning is finished
            [00.604]ubi0: attached mtd4 (name "sys", size 123 MiB)
            [00.609]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
            [00.615]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
            [00.621]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
            [00.627]ubi0: good PEBs: 472, bad PEBs: 20, corrupted PEBs: 0
            [00.633]ubi0: user volume: 8, internal volumes: 1, max. volumes count: 128
            [00.640]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
            [00.647]ubi0: available PEBs: 0, total reserved PEBs: 472, PEBs reserved for bad PEB handling: 0
            [00.707]ubi0: scrubbed PEB 163 (LEB 0:15), data moved to PEB 276
            [00.721]ubi0: fixable bit-flip detected at PEB 364
            [00.736]ubi0: fixable bit-flip detected at PEB 364
            [00.805]ubi0: scrubbed PEB 364 (LEB 5:89), data moved to PEB 261
            [00.818]sunxi flash init ok
            [00.820]line:703 init_clocks
            [00.823]drv_disp_init
            [00.836]drv_disp_init finish
            [00.839]boot_gui_init:start
            [00.842]set disp.dev2_output_type fail. using defval=0
            [00.978]set disp.fb0_width fail. using defval=0
            [00.982]set disp.fb0_height fail. using defval=0
            [00.986]boot_gu[00.988]smallwitpi lcd_panel_init 187 xxxxxxxxxxxxxxxxxx
            i_init:finish
            [01.281]LCD open finish
            [01.326]bmp_name=bootlogo.bmp size 691254
            691254 bytes read in 31 ms (21.3 MiB/s)
            [01.454]Loading Environment from SUNXI_FLASH... OK
            [01.474]Item0 (Map) magic is bad
            [01.480]secure storage read widevine fail with:-1
            [01.487]secure storage read ec_key fail with:-1
            [01.494]secure storage read ec_cert1 fail with:-1
            [01.502]secure storage read ec_cert2 fail with:-1
            [01.509]secure storage read ec_cert3 fail with:-1
            [01.516]secure storage read rsa_key fail with:-1
            [01.524]secure storage read rsa_cert1 fail with:-1
            [01.531]secure storage read rsa_cert2 fail with:-1
            [01.539]secure storage read rsa_cert3 fail with:-1
            [01.544]out of usb burn from boot: not need burn key
            [01.558]update bootcmd
            [01.569]change working_fdt 0x43e8be70 to 0x43e6be70
            [01.589]update dts
            [01.795]no vendor_boot partition is found
            Android's image name: t113-whycanpim
            [01.807]Starting kernel ...
            [    0.000000] Linux version 5.4.61 (whycan@ubuntu) (arm-openwrt-linux-gnueabi-gcc.bin (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) 6.4.1, GNU ld (GNU Binutils) 2.27) #306 SMP PREEMPT Tue Mar 28 14:14:07 UTC 2023
            [    0.000000] cma: Reserved 32 MiB at 0x46000000
            [    0.000000] Kernel command line: ubi.mtd=sys ubi.block=0,rootfs earlyprintk=sunxi-uart,0x02500C00 clk_ignore_unused initcall_debug=0 console=ttyS3,115200 loglevel=8 root=/dev/ubiblock0_5 rootfstype=squashfs init=/pseudo_init partitions=mbr@ubi0_0:boot-resource@ubi0_1:env@ubi0_2:env-redund@ubi0_3:boot@ubi0_4:rootfs@ubi0_5:rootfs_data@ubi0_6:UDISK@ubi0_7: cma=32M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw20p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.05-g24521d6-dirty(03/28/2023-22:01:17) disp_reserve=3686400,0x43f0e000 aw-ubi-spinand.ubootblks=24 androidboot.dramsize=128
            [    0.000000] Memory: 81360K/131072K available (6144K kernel code, 305K rwdata, 1716K rodata, 1024K init, 1177K bss, 16944K reserved, 32768K cma-reserved)
            [    0.008016] Switching to timer-based delay loop, resolution 41ns
            [    0.014191] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
            [    0.023951] Console: colour dummy device 80x30
            [    0.028417] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
            [    0.038785] pid_max: default: 32768 minimum: 301
            [    0.043519] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
            [    0.050835] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
            [    0.059164] CPU: Testing write buffer coherency: ok
            [    0.064374] /cpus/cpu@0 missing clock-frequency property
            [    0.069691] /cpus/cpu@1 missing clock-frequency property
            [    0.075030] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
            [    0.081175] Setting up static identity map for 0x40100000 - 0x40100060
            [    0.087823] rcu: Hierarchical SRCU implementation.
            [    0.093025] smp: Bringing up secondary CPUs ...
            [    0.098669] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
            [    0.098791] smp: Brought up 1 node, 2 CPUs
            [    0.108586] SMP: Total of 2 processors activated (96.00 BogoMIPS).
            [    0.114764] CPU: All CPU(s) started in SVC mode.
            [    0.119838] devtmpfs: initialized
            [    0.134658] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
            [    0.142770] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
            [    0.152636] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
            [    0.160781] pinctrl core: initialized pinctrl subsystem
            [    0.167325] NET: Registered protocol family 16
            [    0.173268] DMA: preallocated 256 KiB pool for atomic coherent allocations
            [    0.217181] rtc_ccu: sunxi ccu init OK
            [    0.223431] ccu: sunxi ccu init OK
            [    0.227273] r_ccu: sunxi ccu init OK
            [    0.270138] iommu: Default domain type: Translated
            [    0.276248] sunxi iommu: irq = 24
            [    0.280692] SCSI subsystem initialized
            [    0.284973] usbcore: registered new interface driver usbfs
            [    0.291048] usbcore: registered new interface driver hub
            [    0.296463] usbcore: registered new device driver usb
            [    0.301747] videodev: Linux video capture interface: v2.00
            [    0.308263] Advanced Linux Sound Architecture Driver Initialized.
            [    0.315255] Bluetooth: Core ver 2.22
            [    0.318934] NET: Registered protocol family 31
            [    0.323374] Bluetooth: HCI device and connection manager initialized
            [    0.329761] Bluetooth: HCI socket layer initialized
            [    0.334652] Bluetooth: L2CAP socket layer initialized
            [    0.339723] Bluetooth: SCO socket layer initialized
            [    0.344886] pwm module init!
            [    0.349152] g2d 5410000.g2d: Adding to iommu group 0
            [    0.354492] G2D: rcq version initialized.major:252
            [    0.360227] clocksource: Switched to clocksource arch_sys_counter
            [    0.375137] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
            [    0.395046] NET: Registered protocol family 2
            [    0.399954] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
            [    0.408364] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
            [    0.416049] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
            [    0.423131] TCP: Hash tables configured (established 1024 bind 1024)
            [    0.429588] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
            [    0.436150] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
            [    0.443306] NET: Registered protocol family 1
            [    0.448653] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
            [    0.458975] spi spi0: spi0 supply spi not found, using dummy regulator
            [    0.465799] sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
            [    0.471970] sunxi_spi_resource_get()2189 - Failed to get sample mode
            [    0.478333] sunxi_spi_resource_get()2194 - Failed to get sample delay
            [    0.484787] sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_delay:-1431633921
            [    0.493191] sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
            [    0.499465] sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base c881f000, irq 41
            [    0.509550] workingset: timestamp_bits=30 max_order=15 bucket_order=0
            [    0.525252] squashfs: version 4.0 (2009/01/31) Phillip Lougher
            [    0.531426] ntfs: driver 2.1.32 [Flags: R/W].
            [    0.565903] io scheduler mq-deadline registered
            [    0.570484] io scheduler kyber registered
            [    0.576215] [DISP]disp_module_init
            [    0.580172] disp 5000000.disp: Adding to iommu group 0
            [    0.585882] [DISP] parser_disp_init_para,line:1430:
            [    0.585886] of_property_read fb0_width fail
            [    0.594993] [DISP] disp_init,line:2386:
            [    0.594997] smooth display screen:0 type:1 mode:4
            [    0.619950] display_fb_request,fb_id:0
            [    0.629778] Freeing logo buffer memory: 3600K
            [    0.634688] disp_al_manager_apply ouput_type:1
            [    0.639284] [DISP] lcd_clk_config,line:744:
            [    0.639295] disp 0, clk: pll(396000000),clk(396000000),dclk(66000000) dsi_rate(66000000)
            [    0.639295]      clk real:pll(396000000),clk(396000000),dclk(99000000) dsi_rate(150000000)
            [    0.640773] [DISP]disp_module_init finish
            [    0.643827] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
            [    0.661703] sunxi_sid_init()551 - insmod ok
            [    0.679311] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
            [    0.689528] uart uart1: get regulator failed
            [    0.693895] uart uart1: uart1 supply uart not found, using dummy regulator
            [    0.701128] uart1: ttyS1 at MMIO 0x2500400 (irq = 34, base_baud = 1500000) is a SUNXI
            [    0.709864] uart uart3: get regulator failed
            [    0.714272] uart uart3: uart3 supply uart not found, using dummy regulator
            [    0.721483] uart3: ttyS3 at MMIO 0x2500c00 (irq = 35, base_baud = 1500000) is a SUNXI
            [    0.729327] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
            ▒[    0.737321] printk: console [ttyS3] enabled
            [    0.746278] printk: bootconsole [earlycon0] disabled
            [    0.758051] misc dump reg init
            [    0.762612] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
            [    0.769882] sunxi-rfkill soc@3000000:rfkill@0: devm_pinctrl_get() failed!
            [    0.777550] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
            [    0.784911] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
            [    0.792365] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
            [    0.798909] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
            [    0.805888] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=110 assert=1
            [    0.813773] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
            [    0.821920] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
            [    0.829560] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
            [    0.836374] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
            [    0.843931] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=112 assert=0
            [    0.852082] [ADDR_MGT] addr_mgt_probe: module version: v1.0.10
            [    0.859291] [ADDR_MGT] addr_mgt_probe: success.
            [    0.864808] dma-buf: Running sanitycheck
            [    0.869239] dma-buf: Running dma_fence
            [    0.873502] sizeof(dma_fence)=48
            [    0.877240] dma-buf: Running dma_fence/sanitycheck
            [    0.882657] dma-buf: Running dma_fence/test_signaling
            [    0.888341] dma-buf: Running dma_fence/test_add_callback
            [    0.894344] dma-buf: Running dma_fence/test_late_add_callback
            [    0.900823] dma-buf: Running dma_fence/test_rm_callback
            [    0.906684] dma-buf: Running dma_fence/test_late_rm_callback
            [    0.913055] dma-buf: Running dma_fence/test_status
            [    0.918436] dma-buf: Running dma_fence/test_error
            [    0.923725] dma-buf: Running dma_fence/test_wait
            [    0.928904] dma-buf: Running dma_fence/test_wait_timeout
            [    0.970239] dma-buf: Running dma_fence/test_stub
            [    0.975437] dma-buf: Running dma_fence/race_signal_callback
            [    1.050234] thread_signal_callback[0] completed 39519 passes, 21001 misses
            [    1.057978] thread_signal_callback[1] completed 39490 passes, 20974 misses
            [    1.130235] thread_signal_callback[0] completed 40608 passes, 40606 misses
            [    1.137973] thread_signal_callback[1] completed 40623 passes, 40622 misses
            [    1.146267] sunxi-spinand: AW SPINand MTD Layer Version: 2.0 20201228
            [    1.153598] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
            [    1.161506] sunxi-spinand-phy: not detect any munufacture from id table
            [    1.168938] sunxi-spinand-phy: get spi-nand Model from fdt fail
            [    1.175600] sunxi-spinand-phy: get phy info from fdt fail
            [    1.181704] sunxi-spinand-phy: not detect munufacture from fdt
            [    1.188460] sunxi-spinand-phy: detect munufacture from id table: Winbond
            [    1.196002] sunxi-spinand-phy: detect spinand id: ff21aaef ffffffff
            [    1.203127] sunxi-spinand-phy: ========== arch info ==========
            [    1.209667] sunxi-spinand-phy: Model:               W25N01GVZEIG
            [    1.216428] sunxi-spinand-phy: Munufacture:         Winbond
            [    1.222702] sunxi-spinand-phy: DieCntPerChip:       1
            [    1.228364] sunxi-spinand-phy: BlkCntPerDie:        1024
            [    1.234330] sunxi-spinand-phy: PageCntPerBlk:       64
            [    1.240097] sunxi-spinand-phy: SectCntPerPage:      4
            [    1.245769] sunxi-spinand-phy: OobSizePerPage:      64
            [    1.251539] sunxi-spinand-phy: BadBlockFlag:        0x0
            [    1.257401] sunxi-spinand-phy: OperationOpt:        0x7
            [    1.263268] sunxi-spinand-phy: MaxEraseTimes:       65000
            [    1.269326] sunxi-spinand-phy: EccFlag:             0x0
            [    1.275199] sunxi-spinand-phy: EccType:             2
            [    1.280872] sunxi-spinand-phy: EccProtectedType:    3
            [    1.286540] sunxi-spinand-phy: ========================================
            [    1.293966] sunxi-spinand-phy:
            [    1.297483] sunxi-spinand-phy: ========== physical info ==========
            [    1.304428] sunxi-spinand-phy: TotalSize:    128 M
            [    1.309797] sunxi-spinand-phy: SectorSize:   512 B
            [    1.315177] sunxi-spinand-phy: PageSize:     2 K
            [    1.320367] sunxi-spinand-phy: BlockSize:    128 K
            [    1.325736] sunxi-spinand-phy: OOBSize:      64 B
            [    1.331018] sunxi-spinand-phy: ========================================
            [    1.338439] sunxi-spinand-phy:
            [    1.341969] sunxi-spinand-phy: ========== logical info ==========
            [    1.348801] sunxi-spinand-phy: TotalSize:    128 M
            [    1.354193] sunxi-spinand-phy: SectorSize:   512 B
            [    1.359563] sunxi-spinand-phy: PageSize:     4 K
            [    1.364750] sunxi-spinand-phy: BlockSize:    256 K
            [    1.370126] sunxi-spinand-phy: OOBSize:      128 B
            [    1.375511] sunxi-spinand-phy: ========================================
            [    1.383034] sunxi-spinand-phy: block lock register: 0x00
            [    1.389109] sunxi-spinand-phy: feature register: 0x19
            [    1.394790] sunxi-spinand-phy: sunxi physic nand init end
            [    1.401221] Creating 4 MTD partitions on "sunxi_mtd_nand":
            [    1.407399] 0x000000000000-0x000000100000 : "boot0"
            [    1.421231] 0x000000100000-0x000000400000 : "uboot"
            [    1.430524] random: fast init done
            [    1.441152] 0x000000400000-0x000000500000 : "secure_storage"
            [    1.461227] 0x000000500000-0x000008000000 : "sys"
            [    1.528459] sunxi-spinand-phy: phy blk 340 is bad
            [    1.561077] sunxi-spinand-phy: phy blk 474 is bad
            [    1.566567] sunxi-spinand-phy: phy blk 476 is bad
            [    1.572056] sunxi-spinand-phy: phy blk 478 is bad
            [    1.578658] sunxi-spinand-phy: phy blk 486 is bad
            [    1.587579] sunxi-spinand-phy: phy blk 504 is bad
            [    1.593084] sunxi-spinand-phy: phy blk 506 is bad
            [    1.605790] sunxi-spinand-phy: phy blk 540 is bad
            [    1.616809] sunxi-spinand-phy: phy blk 566 is bad
            [    1.623258] sunxi-spinand-phy: phy blk 572 is bad
            [    1.632446] sunxi-spinand-phy: phy blk 590 is bad
            [    1.638412] sunxi-spinand-phy: phy blk 594 is bad
            [    1.643940] sunxi-spinand-phy: phy blk 596 is bad
            [    1.649451] sunxi-spinand-phy: phy blk 598 is bad
            [    1.660479] sunxi-spinand-phy: phy blk 624 is bad
            [    1.667372] sunxi-spinand-phy: phy blk 632 is bad
            [    1.672900] sunxi-spinand-phy: phy blk 634 is bad
            [    1.685708] sunxi-spinand-phy: phy blk 668 is bad
            [    1.693067] sunxi-spinand-phy: phy blk 678 is bad
            [    1.698577] sunxi-spinand-phy: phy blk 680 is bad
            [    1.791730] libphy: Fixed MDIO Bus: probed
            [    1.797253] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
            [    1.808631] sunxi gmac driver's version: 1.0.0
            [    1.813813] gmac-power0: NULL
            [    1.817140] gmac-power1: NULL
            [    1.820522] gmac-power2: NULL
            [    1.824918] Failed to alloc md5
            [    1.828451] eth0: Use random mac address
            [    1.833189] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
            [    1.840582] sunxi-ehci: EHCI SUNXI driver
            [    1.845543] get ehci0-controller wakeup-source is fail.
            [    1.851533] sunxi ehci0-controller don't init wakeup source
            [    1.857811] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0b695d0, 0x:c8839000, irq_no:3c
            [    1.869835] [sunxi-ehci0]: Not init ehci0
            [    1.874635] get ehci1-controller wakeup-source is fail.
            [    1.880609] sunxi ehci1-controller don't init wakeup source
            [    1.886866] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0b69af0, 0x:c883d000, irq_no:3e
            [    1.898925] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator
            [    1.911476] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
            [    1.923699] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
            [    1.930987] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
            [    1.940957] sunxi-ehci 4200000.ehci1-controller: irq 62, io mem 0x04200000
            [    1.970249] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
            [    1.978932] hub 1-0:1.0: USB hub found
            [    1.983216] hub 1-0:1.0: 1 port detected
            [    1.988341] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
            [    1.995332] sunxi-ohci: OHCI SUNXI driver
            [    2.000356] get ohci0-controller wakeup-source is fail.
            [    2.006349] sunxi ohci0-controller don't init wakeup source
            [    2.012625] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0b69860
            [    2.022307] [sunxi-ohci0]: Not init ohci0
            [    2.027095] get ohci1-controller wakeup-source is fail.
            [    2.033078] sunxi ohci1-controller don't init wakeup source
            [    2.039353] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0b69d80
            [    2.049053] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator
            [    2.061598] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
            [    2.073847] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
            [    2.081130] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
            [    2.091056] sunxi-ohci 4200400.ohci1-controller: irq 63, io mem 0x04200400
            [    2.165127] hub 2-0:1.0: USB hub found
            [    2.169376] hub 2-0:1.0: 1 port detected
            [    2.174646] i2c /dev entries driver
            [    2.178655] sunxi cedar version 1.1
            [    2.182795] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
            [    2.189086] VE: sunxi_cedar_probe power-domain init!!!
            [    2.194881] VE: install start!!!
            [    2.194881]
            [    2.200454] VE: cedar-ve the get irq is 42
            [    2.200454]
            [    2.206924] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
            [    2.206924]
            [    2.216227] VE: install end!!!
            [    2.216227]
            [    2.221317] VE: sunxi_cedar_probe
            [    2.225335] Bluetooth: HCI UART driver ver 2.3
            [    2.230365] Bluetooth: HCI UART protocol H4 registered
            [    2.236127] Bluetooth: HCI UART protocol BCSP registered
            [    2.242153] Bluetooth: HCI UART protocol Three-wire (H5) registered
            [    2.249186] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
            [    2.256415] [XR_BT_LPM] bluesleep_probe: bt_wake polarity: 1
            [    2.262830] [XR_BT_LPM] bluesleep_probe: host_wake polarity: 1
            [    2.269384] [XR_BT_LPM] bluesleep_probe: wakeup source is disabled!
            [    2.269384]
            [    2.278085] [XR_BT_LPM] bluesleep_probe: uart_index(1)
            [    2.286324] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
            [    2.296335] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
            [    2.302561] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
            [    2.308910] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
            [    2.315370] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
            [    2.321827] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
            [    2.328370] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
            [    2.334931] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
            [    2.341484] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
            [    2.348427] sunxi-mmc 4020000.sdmmc: Got CD GPIO
            [    2.353806] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
            [    2.360479] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
            [    2.371652] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
            [    2.391792] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
            [    2.416207] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
            [    2.421919] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
            [    2.430794] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
            [    2.443095] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
            [    2.449297] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
            [    2.455670] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
            [    2.462142] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
            [    2.468588] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
            [    2.475149] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
            [    2.481703] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
            [    2.488245] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
            [    2.494823] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
            [    2.504218] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
            [    2.515423] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
            [    2.535575] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
            [    2.559821] sunxi-mmc 4021000.sdmmc: detmode:manually by software
            [    2.567420] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
            [    2.570773] sunxi_led_probe()1751 - start
            [    2.582202] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
            [    2.583614] sunxi_get_str_of_property()1597 - failed to get the string of propname led_regulator!
            [    2.596862] sunxi-mmc 4021000.sdmmc: card claims to support voltages below defined range
            [    2.605130] sunxi_register_led_classdev()1485 - led_classdev start
            [    2.606951] sunxi_led_probe()1847 - finish
            [    2.624253] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
            [    2.626537] usbcore: registered new interface driver usbkbd
            [    2.637643] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
            [    2.643930] usbcore: registered new interface driver usbmouse
            [    2.655703] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
            [    2.661954] exFAT: Version 1.3.0
            [    2.674447] mmc1: new high speed SDIO card at address 0001
            [    2.680711] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
            [    2.695064] sunxi-daudio 2034000.daudio: regulator missing or invalid
            [    2.703079] sunxi-codec-machine 2030340.sound: ASoC: failed to init link audiocodec: -517
            [    2.712293] [SNDCODEC][sunxi_card_dev_probe][784]:snd_soc_register_card failed -517
            [    2.722484] NET: Registered protocol family 10
            [    2.728519] Segment Routing with IPv6
            [    2.732791] NET: Registered protocol family 17
            [    2.737934] Bluetooth: RFCOMM TTY layer initialized
            [    2.743588] Bluetooth: RFCOMM socket layer initialized
            [    2.749378] Bluetooth: RFCOMM ver 1.11
            [    2.754305] Registering SWP/SWPB emulation handler
            [    2.774573] sunxi-i2c sunxi-i2c2: sunxi-i2c2 supply twi not found, using dummy regulator
            [    2.784630] sunxi-i2c sunxi-i2c2: probe success
            [    2.791811] sunxi-audio-card 20340a0.sounddaudio2: use dummy codec for simple card.
            [    2.800554] debugfs: Directory '2034000.daudio' with parent 'snddaudio2' already present!
            [    2.810256] sunxi-audio-card 20340a0.sounddaudio2: snd-soc-dummy-dai <-> 2034000.daudio mapping ok
            [    2.821388] sunxi-codec-machine 2030340.sound: ASoC: failed to init link audiocodec: -517
            [    2.830622] [SNDCODEC][sunxi_card_dev_probe][784]:snd_soc_register_card failed -517
            [    2.839454] sunxi-codec-machine 2030340.sound: ASoC: failed to init link audiocodec: -517
            [    2.848718] [SNDCODEC][sunxi_card_dev_probe][784]:snd_soc_register_card failed -517
            [    2.857809] ubi0: attaching mtd3
            [    2.951221] ubi0: fixable bit-flip detected at PEB 163
            [    3.102425] random: crng init done
            [    3.124928] ubi0: scanning is finished
            [    3.138694] ubi0: attached mtd3 (name "sys", size 123 MiB)
            [    3.144906] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
            [    3.152630] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
            [    3.160260] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
            [    3.168068] ubi0: good PEBs: 472, bad PEBs: 20, corrupted PEBs: 0
            [    3.174911] ubi0: user volume: 8, internal volumes: 1, max. volumes count: 128
            [    3.183068] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
            [    3.192455] ubi0: available PEBs: 0, total reserved PEBs: 472, PEBs reserved for bad PEB handling: 0
            [    3.202737] ubi0: background thread "ubi_bgt0d" started, PID 1001
            [    3.211297] block ubiblock0_5: created from ubi0:5(rootfs)
            [    3.218627] sunxi-codec-machine 2030340.sound: ASoC: failed to init link audiocodec: -517
            [    3.222353] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
            [    3.227922] [SNDCODEC][sunxi_card_dev_probe][784]:snd_soc_register_card failed -517
            [    3.237592] clk: Not disabling unused clocks
            [    3.250974] cfg80211: failed to load regulatory.db
            [    3.256440] ALSA device list:
            [    3.259770]   #0: snddaudio2
            [    3.263027] alloc_fd: slot 0 not NULL!
            [    3.270586] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
            [    3.280682] devtmpfs: mounted
            [    3.285925] Freeing unused kernel memory: 1024K
            [    3.340363] Run /pseudo_init as init process
            [    3.667006] UBIFS (ubi0:6): default file-system created
            [    3.673559] UBIFS (ubi0:6): Mounting in unauthenticated mode
            [    3.680046] UBIFS (ubi0:6): background thread "ubifs_bgt0_6" started, PID 1036
            [    3.808848] UBIFS (ubi0:6): UBIFS: mounted UBI device 0, volume 6, name "rootfs_data"
            [    3.817692] UBIFS (ubi0:6): LEB size: 258048 bytes (252 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
            [    3.828832] UBIFS (ubi0:6): FS size: 18321408 bytes (17 MiB, 71 LEBs), journal size 2064385 bytes (1 MiB, 6 LEBs)
            [    3.840360] UBIFS (ubi0:6): reserved for root: 865365 bytes (845 KiB)
            [    3.847587] UBIFS (ubi0:6): media format: w5/r0 (latest is w5/r0), UUID 12F5F2DD-D005-4218-8985-F2E2D100980F, small LPT model
            [    4.101038] get ctp_power is fail, -22
            [    4.105248] get ctp_power_ldo_vol is fail, -22
            [    4.110374] sunxi_ctp_startup: ctp_power_io is invalid.
            [    4.116274] get ctp_gesture_wakeup fail, no gesture wakeup
            [    4.122474] gt9xxnew_ts 2-0014: 2-0014 supply ctp not found, using dummy regulator
            [    4.300502] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
            [    4.312634] 8<--- cut here ---
            [    4.316085] Unable to handle kernel NULL pointer dereference at virtual address 00000290
            [    4.325188] pgd = afc5e7de
            [    4.328220] [00000290] *pgd=00000000
            [    4.330478] input: gt9xxnew_ts as /devices/virtual/input/input0
            [    4.332262] Internal error: Oops: 17 [#1] PREEMPT SMP ARM
            [    4.339706] sunxi-codec-machine 2030340.sound: ASoC: failed to init link audiocodec: -517
            [    4.344911] Modules linked in: gt9xxnew_ts(+)
            [    4.344926] CPU: 0 PID: 1005 Comm: usb_device_chos Not tainted 5.4.61 #306
            [    4.344929] Hardware name: Generic DT based system
            [    4.344943] PC is at typec_set_data_role+0x0/0x3c
            [    4.344949] LR is at usb_msg_center+0x120/0x21c
            [    4.344954] pc : [<c049d0d8>]    lr : [<c0495ec8>]    psr: 600e0013
            [    4.344958] sp : c52a9f58  ip : c51a9e58  fp : 00000000
            [    4.344966] r10: c52b66dc  r9 : c5827db4  r8 : 00000000
            [    4.355438] [SNDCODEC][sunxi_card_dev_probe][784]:snd_soc_register_card failed -517
            [    4.359010] r7 : c0b6adb0  r6 : c0a04e08  r5 : 00000000  r4 : c0b6aebc
            [    4.359019] r3 : 00000000  r2 : b520ebe4  r1 : 00000000  r0 : 00000000
            [    4.424384] Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
            [    4.432391] Control: 10c5387d  Table: 440a406a  DAC: 00000051
            [    4.438839] Process usb_device_chos (pid: 1005, stack limit = 0x11829875)
            [    4.446452] Stack: (0xc52a9f58 to 0xc52aa000)
            [    4.451347] 9f40:                                                       c0b6adb0 00000000
            [    4.460534] 9f60: 00000000 b520ebe4 c0b6adac c0b6adb0 c52b6680 00000000 c0494bdc c0494c1c
            [    4.469716] 9f80: c52b66c0 c52a8000 c52b6680 c0133cc0 c52b6680 c0133ba0 00000000 00000000
            [    4.478911] 9fa0: 00000000 00000000 00000000 c01010e8 00000000 00000000 00000000 00000000
            [    4.488085] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
            [    4.497269] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
            [    4.506462] [<c049d0d8>] (typec_set_data_role) from [<00000000>] (0x0)
            [    4.513788] Code: e8bd8010 c0b6b01c c03e74e4 c03e74c8 (e5903290)
            Starting syslogd: OK
            Starting klogd: OK
            Running sysctl: [    4.520804] ---[ end trace ab1867fe5df282c1 ]---
            OK
            Starting audio: Invalid mixer control
            Successfully play boot music
            Starting mdev... OK
            playing '/home/res/audio/startup.wav': 2 ch, 48000 hz, 16 bit
            [    5.380113] sunxi_gpadc_init,2151, success
            [    5.385163] sunxi_gpadc_setup: get channel scan data failed
            [    5.392268] input: sunxi-gpadc0 as /devices/virtual/input/input1
            [    5.399595] sunxi-codec-machine 2030340.sound: ASoC: failed to init link audiocodec: -517
            [    5.408843] [SNDCODEC][sunxi_card_dev_probe][784]:snd_soc_register_card failed -517
            [    5.556235] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
            [    5.572555] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
            [    5.937639] sunxi-codec-machine 2030340.sound: ASoC: failed to init link audiocodec: -517
            [    5.946993] [SNDCODEC][sunxi_card_dev_probe][784]:snd_soc_register_card failed -517
            Saving random seed: OK
            Starting network: wh=480x1920, vwh=480x1920, bpp=32, rotated=1[    6.068661] VE: enable hw clock
            Turn on double buffering.
            Turn on 2d hardware acceleration.
            Turn on 2d hardware rotation acceleration.
            [    6.074358] enable_cedar_hw_clk,552
            OK
            enable android usb
            insmod: can't insert '/lib/modules/5.4.61/sunxi_usb_udc.ko': No such file or directory
            insmod: can't insert '/lib/modules/5.4.61/sunxi_usbc.ko': No such file or directory
            [    6.176795] file system registered
            [    6.302227] read descriptors
            [    6.305507] read strings
            ------light up RGB LED-----
            [    8.347795] usbcore: registered new interface driver usb-storage
            Starting adbd: /etc/init.d/S91adbd: line 11: can't create /sys/class/android_usb/android0/enable: Permission denied
            /etc/init.d/S91adbd: line 12: can't create /sys/class/android_usb/android0/idVendor: Permission denied
            /etc/init.d/S91adbd: line 13: can't create /sys/class/android_usb/android0/idProduct: Permission denied
            /etc/init.d/S91adbd: line 14: can't create /sys/class/android_usb/android0/functions: Permission denied
            /etc/init.d/S91adbd: line 15: can't create /sys/class/android_usb/android0/enable: Permission denied
            [    8.454387] ubi0: fixable bit-flip detected at PEB 403
            [    8.460270] ubi0: schedule PEB 403 for scrubbing
            [    8.472562] android_work: sent uevent USB_STATE=CONNECTED
            [    8.521261] ubi0: fixable bit-flip detected at PEB 403
            [    8.601423] configfs-gadget gadget: high-speed config #1: c
            [    8.607877] android_work: sent uevent USB_STATE=CONFIGURED
            [    8.631441] ubi0: scrubbed PEB 403 (LEB 5:128), data moved to PEB 163
            [    8.689449] ubi0: fixable bit-flip detected at PEB 402
            [    8.695246] ubi0: schedule PEB 402 for scrubbing
            wpa_supplicant v2.9
            random: Trying to read entropy from /dev/random
            Initializing interface 'wlan0' conf '/etc/wifi/wpa_supplicant.conf' driver 'nl80211' ctrl_interface 'N/A' bridge 'N/A'
            Configuration file '/etc/wifi/wpa_supplicant.conf' -> '/etc/wifi/wpa_supplicant.conf'
            Reading configuration file '/etc/wifi/wpa_supplicant.conf'
            [    8.738628] ubi0: fixable bit-flip detected at PEB 402
            ctrl_interface='/etc/wifi/sockets'
            disable_scan_offload=1
            update_config=1
            wowlan_triggers='any'
            Reading configuration file '/etc/wifi/wpa_supplicant_overlay.conf'
            nl80211: Supported cipher 00-0f-ac:1
            nl80211: Supported cipher 00-0f-ac:5
            nl80211: Supported cipher 00-0f-ac:2
            nl80211: Supported cipher 00-0f-ac:4
            nl80211: Supported vendor command: vendor_id=0x1018 subcmd=1
            nl80211: Supported vendor command: vendor_id=0x1a11 subcmd=4106
            nl80211: Supported vendor command: vendor_id=0x1a11 subcmd=4107
            nl80211: Supported vendor event: vendor_id=0x1018 subcmd=0
            nl80211: Supported vendor event: vendor_id=0x1018 subcmd=1
            nl80211: interface wlan0 in phy phy0
            nl80211: Set mode ifindex 3 iftype 2 (STATION)
            nl80211: Subscribe to mgmt frames with non-AP handle 0x43a328
            nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x43a328 match=0104
            nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x43a328 match=040a
            nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x43a328 match=040b
            nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x43a328 match=040c
            nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x43a328 match=040d
            nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x43a328 match=090a
            nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x43a328 match=090b
            nl80211: Register frame[    8.860986] ubi0: scrubbed PEB 402 (LEB 5:127), data moved to PEB 403
             type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x43a328 match=090c
            nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x43a328 match=090d
            nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x43a328 match=0801
            nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x43a328 match=06
            nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x43a328 match=0a07
            nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x43a328 match=0a11
            nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x43a328 match=0a1a
            nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x43a328 match=1101
            nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x43a328 match=1102
            nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x43a328 match=0505
            nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x43a328 match=0500
            rfkill: initial event: idx=1 type=1 op=0 soft=0 hard=0
            netlink: Operstate: ifindex=3 linkmode=1 (userspace-control), operstate=5 (IF_OPER_DORMANT)
            Add interface wlan0 to a new radio phy0
            nl80211: Regulatory information - country=00
            nl80211: 2402-2472 @ 40 MHz 20 mBm
            nl80211: 2457-2482 @ 20 MHz 20 mBm (no IR)
            nl80211: 2474-2494 @ 20 MHz 20 mBm (no OFDM) (no IR)
            nl80211: 5170-5250 @ 80 MHz 20 mBm (no IR)
            nl80211: 5250-5330 @ 80 MHz 20 mBm (DFS) (no IR)
            nl80211: 5490-5730 @ 160 MHz 20 mBm (DFS) (no IR)
            nl80211: 5735-5835 @ 80 MHz 20 mBm (no IR)
            nl80211: 57240-63720 @ 2160 MHz 0 mBm
            nl80211: Added 802.11b mode based on 802.11g information
            nl802[    9.321768] ubi0: fixable bit-flip detected at PEB 368
            11: Mode IEEE 802.11g: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467[NO_IR] 2472[NO_IR] 2484[DISABLED]
            nl80211: M[    9.333517] ubi0: schedule PEB 368 for scrubbing
            ode IEEE 802.11b: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467[NO_IR] 2472[NO_IR] 2484[DISABLED]
            wlan0: Own MAC address: 48:8f:4c:01:b2:78
            wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=0 set_tx=0 seq_len=0 key_len=0
            wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=1 set_tx=0 seq_len=0 key_len=0
            wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=2 set_tx=0 seq_len=0 key_len=0
            wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=3 set_tx=0 seq_len=0 key_len=0
            wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=4 set_tx=0 seq_len=0 key_len=0
            wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=5 set_tx=0 seq_len=0 key_len=0
            wlan0: RSN: flushing PMKID list in the driver
            nl80211: Flush PMKIDs
            wlan0: State: DISCONNECTED -> INACTIVE
            [    9.434691] ubi0: fixable bit-flip detected at PEB 368
            [    9.531368] ubi0: scrubbed PEB 368 (LEB 5:93), data moved to PEB 402
            wlan0: WPS: UUID based on MAC address: d8646a0f-1d8d-5656-8c71-bc6ec2532745
            EAPOL: SUPP_PAE entering state DISCONNECTED
            EAPOL: Supplicant port status: Unauthorized
            nl80211: Skip set_supp_port(unauthorized) while not associated
            EAPOL: KEY_RX entering state NO_KEY_RECEIVE
            EAPOL: SUPP_BE entering state INITIALIZE
            EAP: EAP entering state DISABLED
            Using existing control interface directory.
            nl80211: Setting wowlan
            wlan0: Added interface wlan0
            wlan0: State: INACTIVE -> DISCONNECTED
            nl80211: Set wlan0 operstate 0->0 (DORMANT)
            netlink: Operstate: ifindex=3 linkmode=-1 (no change), operstate=5 (IF_OPER_DORMANT)
            Daemonize..
            udhcpc: started, v1.33.0
            udhcpc: sending discover
            [   10.062185] adbd (1214): /proc/1214/oom_adj is deprecated, please use /proc/1214/oom_score_adj instead.
            udhcpc: no lease, forking to background
            /usr/bin/lvgl8_dashboard_demo: /lib/libc.so.6: version `GLIBC_2.28' not found (required by /usr/bin/lvgl8_dashboard_demo)
            # touch /opt/cccc.txt
