    T113-S3 (128M DDR3) 也播不了1080p视频吗?
    5311
    • U
      ubuntu LV 7 最后由 编辑
        WhycanService LV 8 最后由 编辑
        测试可以播放,不过为啥omm的程序是lv_example
        U 2 条回复 最后回复 回复 引用 分享 0
        • U
          ubuntu LV 7 @WhycanService 最后由 whycan 编辑
          @whycanservice
          root@TinaLinux:/# tplayerdemo /mnt/exUDISK/film/
          5.Ice.Age.Collision.Course.2016.BD1080P.X264.AAC.Mandarin&English.CHS-ENG.mp4
          bhsj.mp4
          root@TinaLinux:/# tplayerdemo /mnt/exUDISK/film/5.Ice.Age.Collision.Course.2016.
          BD1080P.X264.AAC.Mandarin\&English.CHS-ENG.mp4
          WARNING: awplayer <cdx_log_set_level:30>: cdx Set log level to 6
          INFO   : cedarc <CedarPluginVDInit:79>: register h264 decoder success!
          INFO   : cedarc <CedarPluginVDInit:84>: register mjpeg decoder success!
          INFO   : cedarc <CedarPluginVDInit:86>: register mpeg2 decoder success!
          INFO   : cedarc <CedarPluginVDInit:92>: register mpeg4dx decoder success!
          INFO   : cedarc <CedarPluginVDInit:79>: register mpeg4H263 decoder success!
          INFO   : cedarc <CedarPluginVDInit:90>: register mpeg4Normal decoder success!
          INFO   : cedarc <CedarPluginVDInit:74>: register vc1 decoder success!
          INFO   : cedarc <CedarPluginVDInit:85>: register h265 decoder success!
          * This program implements a simple player, you can type commands to control the player.
          * To show what commands supported, type 'help'.
          dd: writing '/dev/fb0': No space left on device
          7201+0 records in
          7200+0 records out
          argc = 2
          argv[0] = tplayerdemo
          argv[1] = /mnt/exUDISK/film/5.Ice.Age.Collision.Course.2016.BD1080P.X264.AAC.Mandarin&English.CHS-ENG.mp4
          may be is one file:cut down suffix is:.mp4
          find the matched type:.mp4
          create player:0
          tag   : tina3.5
          branch: tina-dev
          xplayer:process message XPLAYER_COMMAND_SET_AUDIOSINK.
          xplayer:process message XPLAYER_COMMAND_SET_SURFACE.
          xplayer:process message XPLAYER_COMMAND_SET_SUBCTRL.
          xplayer:process message XPLAYER_COMMAND_SET_DI.
          create player[0]:0x150ccf8
          screen width:480,screen height:1920
          1:playVideo:0
          before TPlayerSetDataSource,4759580:/mnt/exUDISK/film/5.Ice.Age.Collision.Course.2016.BD1080P.X264.AAC.Mandarin&English.CHS-ENG.mp4
          xplayer:process message XPLAYER_COMMAND_SET_SOURCE.
          xplayer:process message XPLAYER_COMMAND_PREPARE.
          ERROR  : CdxFlvParser.c <__CdxFlvParserProbe:4030>: FlvProbe failed.
          ERROR  : CdxAviParser <__CdxAviParserProbe:1251>: AviProbe failed.
          INFO   : cedarc <log_set_level:43>: Set log level to 5 from /vendor/etc/cedarc.conf[52493.212155] VE: VE real_freq=576000000
          [52493.212155]
          ERROR  : cedarc <DebugCheckConfig:301>: now cedarc log level:5
          WARNING: cedarc <getSocIdString:1117>: cannot open /dev/sunxi_soc_info, it maybe ok!
          setDataSource end
          *****tplayer:video width = 1920,height = 1080
          warning: unknown callback from Tinaplayer.
          TPLAYER_NOTIFY_PREPARED,has prepared.
          TPlayerPrepare end
          TPlayerSetHoldLastPicture()
          xplayer:process message XPLAYER_COMMAND_START.
          (Allwinner Audio Middle Layer),line(958) : Create Decoder!!=====
          (Allwinner Audio Middle Layer),line(592) : AudioDec_Installaudiolib ok
          (Allwinner Audio Middle Layer),line(595) : audio decoder init start ...
          (AllwinnerAlibs),line(50) :
          >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Audio <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
          tag   : audiocodec-v1.2
          branch: new
          commit: 3ba65962c01cbf1280ddda19d843009b6ef8ce85
          date  : Tue Jan 8 16:25:27 2019 +0800
          (AllwinnerAlibs),line(679) : ----Loading so success!
          (AllwinnerAlibs),line(877) : *************pAudioStreamInfo start******************
          (AllwinnerAlibs),line(878) : eCodecFormat         :id(4), name(aac low-complexy)
          (AllwinnerAlibs),line(879) : eSubCodecFormat      :0
          (AllwinnerAlibs),line(880) : nChannelNum          :6
          (AllwinnerAlibs),line(881) : nBitsPerSample       :16
          (AllwinnerAlibs),line(882) : nSampleRate          :48000
          (AllwinnerAlibs),line(883) : nAvgBitrate          :0
          (AllwinnerAlibs),line(884) : nMaxBitRate          :0
          (AllwinnerAlibs),line(885) : nFileSize            :0
          (AllwinnerAlibs),line(886) : eAudioBitstreamSource:0
          (AllwinnerAlibs),line(887) : eDataEncodeType      :1
          (AllwinnerAlibs),line(888) : nCodecSpecificDataLen:2
          (AllwinnerAlibs),line(889) : pCodecSpecificData   :0xb5068378
          (AllwinnerAlibs),line(890) : nFlags               :0
          (AllwinnerAlibs),line(891) : nBlockAlign          :0
          (AllwinnerAlibs),line(892) : *************pAudioStreamInfo end  ******************
          (AAC Decoder),line(36) : init successs...
          (Allwinner Audio Middle Layer),line(603) : AUDIO DECODE INIT OK...0
          started.
          WARNING: cedarc <H264MallocBuffer:1407>:  h264 scale down fbm buffer number need double check!
          [52493.924765] tplayerdemo invoked oom-killer: gfp_mask=0x142dc2(GFP_HIGHUSER|__GFP_NOWARN|__GFP_COMP|__GFP_ZERO), order=0, oom_score_adj=0
          [52493.938614] CPU: 1 PID: 14010 Comm: tplayerdemo Tainted: G      D           5.4.61 #307
          [52493.947592] Hardware name: Generic DT based system
          [52493.952985] [<c010de4c>] (unwind_backtrace) from [<c010a5f4>] (show_stack+0x10/0x14)
          [52493.961678] [<c010a5f4>] (show_stack) from [<c06d5b68>] (dump_stack+0x88/0xa4)
          [52493.969787] [<c06d5b68>] (dump_stack) from [<c01914a0>] (dump_header+0x50/0x200)
          [52493.978088] [<c01914a0>] (dump_header) from [<c01918a0>] (oom_kill_process+0x80/0x298)
          [52493.986973] [<c01918a0>] (oom_kill_process) from [<c0192220>] (out_of_memory+0x300/0x354)
          [52493.996153] [<c0192220>] (out_of_memory) from [<c01c038c>] (__alloc_pages_nodemask+0x704/0x970)
          [52494.005921] [<c01c038c>] (__alloc_pages_nodemask) from [<c050eca4>] (ion_system_heap_allocate+0x134/0x254)
          [52494.016759] [<c050eca4>] (ion_system_heap_allocate) from [<c050d72c>] (ion_buffer_alloc+0xc8/0x274)
          [52494.026913] [<c050d72c>] (ion_buffer_alloc) from [<c050e21c>] (ion_dmabuf_alloc+0x50/0xc8)
          [52494.036189] [<c050e21c>] (ion_dmabuf_alloc) from [<c050d060>] (ion_ioctl+0x114/0x2d0)
          [52494.044979] [<c050d060>] (ion_ioctl) from [<c01dd8b8>] (vfs_ioctl+0x28/0x3c)
          [52494.052892] [<c01dd8b8>] (vfs_ioctl) from [<c01de0a4>] (do_vfs_ioctl+0x90/0x6e0)
          [52494.061193] [<c01de0a4>] (do_vfs_ioctl) from [<c01de72c>] (ksys_ioctl+0x38/0x54)
          [52494.069494] [<c01de72c>] (ksys_ioctl) from [<c0101000>] (ret_fast_syscall+0x0/0x54)
          [52494.078081] Exception stack(0xc2423fa8 to 0xc2423ff0)
          [52494.083749] 3fa0:                   01511fa0 b6a1cf18 00000005 c0184900 b37feac0 01511fa0
          [52494.092926] 3fc0: 01511fa0 b6a1cf18 b6a1d078 00000036 10624dd3 b6a3b0c8 015255e0 b6ec1e1c
          [52494.102100] 3fe0: b6a1cf44 b37fea84 b6a0ab34 b6cdb93c
          [52494.107896] Mem-Info:
          [52494.110550] active_anon:1134 inactive_anon:0 isolated_anon:0
          [52494.110550]  active_file:86 inactive_file:128 isolated_file:0
          [52494.110550]  unevictable:0 dirty:0 writeback:0 unstable:0
          [52494.110550]  slab_reclaimable:673 slab_unreclaimable:2483
          [52494.110550]  mapped:0 shmem:0 pagetables:61 bounce:0
          [52494.110550]  free:7390 free_pcp:0 free_cma:7053
          [52494.146163] Node 0 active_anon:4536kB inactive_anon:0kB active_file:344kB inactive_file:512kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:0kB dirty:0kB writeback:0kB shmem:0kB writeback_tmp:0kB unstable:0kB all_unreclaimable? yes
          [52494.170699] Normal free:29560kB min:1348kB low:1684kB high:2020kB active_anon:4536kB inactive_anon:0kB active_file:344kB inactive_file:512kB unevictable:0kB writepending:0kB present:131072kB managed:118752kB mlocked:0kB kernel_stack:568kB pagetables:244kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:28212kB
          [52494.201468] lowmem_reserve[]: 0 0
          [52494.205208] Normal: 24*4kB (UMEC) 37*8kB (UEC) 17*16kB (UE) 21*32kB (UC) 1*64kB (U) 0*128kB 0*256kB 1*512kB (C) 1*1024kB (C) 1*2048kB (C) 6*4096kB (C) = 29560kB
          [52494.221414] Free pages count per migrate typeat order:     0      1      2      3      4      5      6      7      8      9     10
          [52494.234784] zone   Normal, type    Unmovable     21     29     14     20      1      0      0      0      0      0      0
          [52494.247298] zone   Normal, type      Movable      1      0      0      0      0      0      0      0      0      0      0
          [52494.259765] zone   Normal, type  Reclaimable      1      6      3      0      0      0      0      0      0      0      0
          [52494.272215] zone   Normal, type          CMA      1      2      0      1      0      0      0      1      1      1      6
          [52494.284698] zone   Normal, type   HighAtomic      0      0      0      0      0      0      0      0      0      0      0
          [52494.297156] zone   Normal, type      Isolate      0      0      0      0      0      0      0      0      0      0      0
          [52494.309601] 214 total pagecache pages
          [52494.313727] 32768 pages RAM
          [52494.316861] 0 pages HighMem/MovableOnly
          [52494.321197] 3080 pages reserved
          [52494.324722] 8192 pages cma reserved
          [52494.328656] Tasks state (memory values in pages):
          [52494.333950] [  pid  ]   uid  tgid total_vm      rss pgtables_bytes swapents oom_score_adj name
          [52494.343659] [  13993]     0 13993      715       27    10240        0             0 sh
          [52494.352568] [  14003]     0 14003    35576     1086   104448        0             0 tplayerdemo
          [52494.362377] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),task=tplayerdemo,pid=14003,uid=0
          [52494.372336] Out of memory: Killed process 14003 (tplayerdemo) total-vm:142304kB, anon-rss:4344kB, file-rss:0kB, shmem-rss:0kB, UID:0 pgtables:102kB oom_score_adj:0
          [52494.391315] oom_reaper: reaped process 14003 (tplayerdemo), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
          Killed
          root@TinaLinux:/#
          这次没有 lv_example 了。
          • U
            ubuntu LV 7 @WhycanService 最后由 编辑
            @whycanservice
            播放720p没问题,
            那除了和分辨率有关系,还和码率有关系吗?
              WhycanService LV 8 @ubuntu 最后由 编辑
              @ubuntu 格式,码率,帧率都有关系
              U 1 条回复 最后回复 回复 引用 分享 0
              • U
                @whycanservice
                搞定了,换 T133-I + 256M DDR 解决了。
