    D1H开启dropbear无法通过SecureCRT SSH连接
    12488
      wjx163208 LV 4 最后由 xiaowenge 编辑
      环境:D1H,Tina Linux2.0 SDK
      操作:make menuconfig选择dropbear,编译打包生成的镜像,烧写到板卡后,windows下通过SecureCRT SSH连接不上(已经启动了dropbear)报错如下:
      The client has disconnected from the server.  Reason:
      The server's host key failed to verify.  This could mean that the server you are connected to is impersonating the server it claims to be. A connection could not be established.
      请教一下,有没有人碰到过这个问题,如何解决?
      whycan 2 条回复 最后回复 回复 引用 分享 0
        whycan晕哥 LV 9 @wjx163208 最后由 编辑
        @wjx163208
        key 有问题
          @wjx163208
          参考这里:bing search dropbear
          W 1 条回复 最后回复 回复 引用 分享 0
            wjx163208 LV 4 @whycan 最后由 编辑
            @whycan 现在的key是自动生成了,在/etc/dropbear/下,dropbear_rsa_host_key,且试过不支持dss类型key,请问下具体key有什么问题,谢谢!
              @wjx163208
              ssh-keygen -t rsa
              这个生成密钥对可以用吗?
                @whycan 不行。我使用两块D1-H板卡,可以SSH连接,windows下使用SecureCRT SSH就不行。
                  @wjx163208
                  用 mobaXterm 试一试
                    @whycan 都试过,不行
                      @wjx163208
                      这地方填上私钥了吗?
                        @whycan 还是不行
                          @wjx163208
                          用ubuntu 的ssh命令可以连吗?
                            wjx163208 LV 4 @whycan 最后由 xiaowenge 编辑
                            @whycan 尝试过,也不行
                            OpenSSH_6.6.1, OpenSSL 1.0.1f 6 Jan 2014
                            debug1: Reading configuration data /etc/ssh/ssh_config
                            debug1: /etc/ssh/ssh_config line 19: Applying options for *
                            debug1: Connecting to 192.168.1.100 [192.168.1.100] port 22.
                            debug1: Connection established.
                            debug1: identity file /home/cc/.ssh/id_rsa type 1
                            debug1: identity file /home/cc/.ssh/id_rsa-cert type -1
                            debug1: identity file /home/cc/.ssh/id_dsa type -1
                            debug1: identity file /home/cc/.ssh/id_dsa-cert type -1
                            debug1: identity file /home/cc/.ssh/id_ecdsa type -1
                            debug1: identity file /home/cc/.ssh/id_ecdsa-cert type -1
                            debug1: identity file /home/cc/.ssh/id_ed25519 type -1
                            debug1: identity file /home/cc/.ssh/id_ed25519-cert type -1
                            debug1: Enabling compatibility mode for protocol 2.0
                            debug1: Local version string SSH-2.0-OpenSSH_6.6.1p1 Ubuntu-2ubuntu2
                            debug1: Remote protocol version 2.0, remote software version dropbear_2015.71
                            debug1: no match: dropbear_2015.71
                            debug1: SSH2_MSG_KEXINIT sent
                            debug1: SSH2_MSG_KEXINIT received
                            debug1: kex: server->client aes128-ctr hmac-md5 none
                            debug1: kex: client->server aes128-ctr hmac-md5 none
                            debug1: sending SSH2_MSG_KEX_ECDH_INIT
                            debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
                            debug1: Server host key: RSA 65:f2:3c:fe:af:29:7d:16:d7:92:56:93:18:0b:1d:47
                            debug1: Host '192.168.1.100' is known and matches the RSA host key.
                            debug1: Found key in /home/cc/.ssh/known_hosts:3
                            hash mismatch
                            debug1: ssh_rsa_verify: signature incorrect
                            key_verify failed for server_host_key
                              @wjx163208 在 D1H开启dropbear无法通过SecureCRT SSH连接 中说:
                              192.168.1.100
                              192.168.1.100 的 ssh 私钥配置了吗?
                                @whycan 这个就是板卡,自动生成了dropbear_rsa_host_key,在/etc/dropbear下
                                  whycan晕哥 LV 9 @wjx163208 最后由 whycan 编辑
                                  @wjx163208
                                  我的意思是说在乌邦图的ssh配置
                                  你需要配置私钥,否则ssh不知道你用哪个钥匙开门。
                                    @whycan ubuntu也用ssh-keygen生成了密钥,就是这个现象。
                                      @wjx163208
                                      $ ls ~/.ssh/ -l
                                      total 48
                                      -rw------- 1 whycan whycan  562 Mar 31 13:36 config
                                      -rw------- 1 whycan whycan 1680 May  2  2022 id_rsa.bitbucket
                                      $ cat ~/.ssh/config
                                      Host sdk.allwinnertech.com
                                          IdentityFile ~/.ssh/sdk.allwinnertech.com.private
                                          User whycan
                                      Host bitbucket.org
                                          IdentityFile ~/.ssh/id_rsa.bitbucket
                                          User root
                                      你大概需要这样配置。
                                        @whycan 我ssh用-i指定了文件,跟这个应该一样。然后按照你这个整了个配置文件,现象一样。
