    v851s uart3 设置成普通串口收发
    5660
      chhjnavy LV 5 最后由 编辑
      由于UART0 被设定为系统dubug 输出(简单来说就是将ttyS0 设定为console),所以使用UART3 作为普通的串口,进行与别的设备通信。
      1. 查看硬件电路图SCH_Schematic1_2022-11-23,查看uart3 的TX RX pin 脚
      电路图pdf路径:Yuzukilizard/Hardware/Schematic/SCH_Schematic1_2022-11-23.pdf
      从图中可以看出TX = PE12 RX = PE13 。
      PE12 PE13 可以通过排插用杜邦线接出,排插电路图如下:
      2. 由于pin脚复用原因,我们需要查看pin 脚复用情况
      pin 脚复用手册V851SE_PINOUT_V0.1.xlsx路径:
      Yuzukilizard/Hardware/Datasheets/V851SE_PINOUT_V0.1.xlsx
      记住PE12 PE13 用作UART3-TX UART3-RX 是function7 ,这个很重要,一会我们在board.dts 文件中需要用到。
      3. 配置设备树文件 board.dts
      设备树文件通过of 文件解析出属性,进一步被应用(原理此处不再介绍)。
      board.dts 路径:tina-v853-docker/device/config/chips/v851s/configs/lizard/board.dts
      在设备树中搜索UART 找到UART3 相关配置
      &uart0 {
      	pinctrl-0 = <&uart0_pins_active>;
      	pinctrl-1 = <&uart0_pins_sleep>;
      &uart1 {
      	pinctrl-0 = <&uart1_pins_active>;
      	pinctrl-1 = <&uart1_pins_sleep>;
      	status = "disabled";
      &uart2 {
      	pinctrl-0 = <&uart2_pins_active>;
      	pinctrl-1 = <&uart2_pins_sleep>;
      &uart3 {
      	pinctrl-0 = <&uart3_pins_active>;
      	pinctrl-1 = <&uart3_pins_sleep>;
      &pio {
      	uart0_pins_active: uart0@0 {
      		allwinner,pins = "PH9", "PH10";
      		allwinner,function = "uart0";
      		allwinner,muxsel = <5>;
      		allwinner,drive = <1>;
      		allwinner,pull = <1>;
      	uart0_pins_sleep: uart0@1 {
      		allwinner,function = "gpio_in";
      		allwinner,muxsel = <0>;
      	uart1_pins_active: uart1@0 {
      		allwinner,pins = "PG6", "PG7";
      		allwinner,function = "uart1";
      		allwinner,muxsel = <4>;
      	uart1_pins_sleep: uart1@1 {
      	uart2_pins_active: uart2@0 {
      		allwinner,pins = "PA8", "PA9";
      		allwinner,function = "uart2";
      		allwinner,muxsel = <6>;
      	uart2_pins_sleep: uart2@1 {
      	uart3_pins_active: uart3@0 {
      		allwinner,pins = "PE12", "PE13";
      		allwinner,function = "uart3";
      		allwinner,muxsel = <7>;
      	uart3_pins_sleep: uart3@1 {
      1)将uart3 设定为 status = "okay";
      2)将uart3 pin 脚设为 allwinner,pins = "PE12", "PE13";
      3)将uart3 pin复用为function7 :allwinner,muxsel = <7>;
      修改完成后,重新编译img
      make -j1 V=s
      pack
      使用烧录软件:PhoenixSuit ,具体烧录方法参考:https://dongshanpi.com/YuzukiHD-Lizard/03-1_FlashSystem/#usb
      烧录后,通过adb shell 进入终端,就可以查看到设备节点:/dev/ttyS3 ,通过open 设备终端,就可以进行read write 操作。
      4. 通过设备节点 /dev/ttyS3 进行收发操作
      1)写应用程序
      #include <stdio.h>     /*标准输入输出定义*/
      #include <stdlib.h>    /*标准函数库定义*/
      #include <unistd.h>    /*Unix标准函数定义*/
      #include <sys/types.h>
      #include <sys/stat.h>  /*六文件控制定义*/
      #include <fcntl.h>      /*PX终端控制定义*/
      #include <termios.h>
      #include <errno.h>
      #include <string.h>
      enum parameter_type {
          PT_PROGRAM_NAME = 0,
          PT_DEV_NAME,
          PT_CYCLE,
          PT_NUM
      #define DBG(string, args...) \
          do { \
                  printf("%s, %s()%u---",__FILE__,__FUNCTION__,__LINE__); \
                  printf(string, ##args); \
                  printf("\n"); \
          } while (0)
      void usage(void) {
          printf("You should input as: \n");
          printf("\t select_test [/dev/name] [Cyclee Cnt]\n");
      int OpenDev(char *name) {
          int fd = open(name, O_RDWR );
          if (-1 == fd)
              DBG("Can not OPen(%s)!", name);
          return fd;
       * @brief  设置串口通信速率
       * @param fd 类型 int打开串口的文件句柄长
       * @param speed 类型 int 串口速度
       * @return void
      void set_speed(int fd, int speed) {
          int	i;
          int	status;
          struct termios Opt = {0};
          int speed_arr[] = {B230400, B115200, B57600, B38400, B19200, B9600, B4800, B2400, B1200, B300, B38400, B19200, B9600, B4800, B2400, B1200, B300, };
          int name_arr[] = {230400,115200, 57600, 38400, 19200, 9600, 4800, 2400, 1200, 300, 38400, 19200, 9600, 4800, 2400, 1200, 300, };
          tcgetattr(fd, &Opt);
          for ( i= 0; i < sizeof(speed_arr) / sizeof(int); i++) {
              if (speed == name_arr[i])
                  break;
          tcflush(fd, TCIOFLUSH);
          cfsetispeed(&Opt, speed_arr[i]);
          cfsetospeed(&Opt, speed_arr[i]);
          Opt.c_lflag &= ~(ICANON | ECHO | ECHOE | ISIG); /*Input*/
          Opt.c_oflag &= ~OPOST;	/*Output*/
          status = tcsetattr(fd, TCSANOW, &Opt);
          if (status != 0) {
              DBG("tcsetattr fd");
              return;
      *@brief	设置串口数据位,停止位和效验位
      *@param fd	类型    int 打开的串口文件句柄
      *@param  databits 类 型  int 数 据位	取值  为  7 或者8
      *@param  stopbits 类 型  int 停 止位	取值为  1 或者2
      *@param parity 类型 int 效验类型 取值为N,E,O,,S
      int set_Parity(int fd,int databits,int stopbits,int parity) {
      	struct termios options;
          if ( tcgetattr( fd,&options) != 0) {
              perror("SetupSerial 1");
              return -1;
          options.c_cflag &= ~CSIZE;
          switch (databits) /*设置数据位数*/
              case 7:
              options.c_cflag |= CS7;
              break;
              case 8:
              options.c_cflag |= CS8;
              break;
              default:
              fprintf(stderr,"Unsupported data size\n");
              return -1;
          switch (parity)
              case 'n':
              case 'N':
                  options.c_cflag &= ~PARENB;	/* Clear parity enable */
                  options.c_iflag &= ~INPCK;	/* Enable parity checking */
                  break;
              case 'o':
              case 'O':
                  options.c_cflag |= (PARODD | PARENB); /* 设置为奇效验*/
                  options.c_iflag |= INPCK;	/* Disnable parity checking */
                  break;
              case 'e':
              case 'E':
                  options.c_cflag |= PARENB;	/* Enable parity */
                  options.c_cflag &= ~PARODD;	/*	*/
                  break;
              case 'S':
              case 's': /*as no parity*/
                  options.c_cflag &= ~CSTOPB;break;
              default:
                  fprintf(stderr,"Unsupported parity\n");
                  return -1;
          /* 设置停止位*/
          switch (stopbits)
              case 1:
                  break;
              case 2:
                  options.c_cflag |= CSTOPB;
                  break;
              default:
                  fprintf(stderr,"Unsupported stop bits\n");
                  return -1;
          /* Set input parity option */
          if (parity != 'n')
          tcflush(fd,TCIFLUSH);
          options.c_cc[VTIME] = 150; /*	15 seconds*/
          options.c_cc[VMIN] = 0; /* Update the options and do it NOW */
          if (tcsetattr(fd,TCSANOW,&options) != 0) {
              perror("SetupSerial 3");
              return -1;
      void str_print(char *buf, int len) {
          int i;
          for (i=0; i<len; i++) {
      	    if (i%10 == 0)
      	    printf("\n");
      	    printf("0x%02x ", buf[i]);
      	printf("\n");
      int	main(int argc, char **argv)
      	int i = 0;
      	int fd = 0;
      	int cnt = 0;
      	char buf[256];
      	char buf_s[4];
      	int ret;
      	fd_set rd_fdset;
      	struct timeval dly_tm;	// delay time in select()
      	if (argc != PT_NUM) {
              usage();
              return -1;
      	sscanf(argv[PT_CYCLE], "%d", &cnt);
      	if (cnt == 0)
      	    cnt = 0xFFFF;
      	fd = OpenDev(argv[PT_DEV_NAME]);
      	if (fd < 0)
      	    return -1;
      	set_speed(fd,19200);
      	if (set_Parity(fd,8,1,'N') == -1) {
              printf("Set Parity Error\n");
              exit (0);
      	printf("Select(%s), Cnt %d. \n", argv[PT_DEV_NAME], cnt);
      	while (i<cnt) {
              FD_ZERO(&rd_fdset);
              FD_SET(fd, &rd_fdset);
              dly_tm.tv_sec = 5;
              dly_tm.tv_usec = 0;
              memset(buf, 0, 256);
              ret = select(fd+1, &rd_fdset, NULL, NULL, &dly_tm);
              DBG("select() return %d, fd = %d", ret, fd);
              if (ret == 0)
                  continue;
              if (ret < 0) {
                  printf("select(%s) return %d. [%d]: %s \n", argv[PT_DEV_NAME], ret, errno,
                  strerror(errno));
                  continue;
              i++;
              ret = read(fd, buf, 256);
              printf("Cnt%d: read(%s) return %d.\n", i, argv[PT_DEV_NAME], ret);
              str_print(buf, ret);
              buf_s[0] = 0x55;
              buf_s[1] = 0xAA;
              buf_s[2] = 0x55;
              buf_s[3] = 0xAA;
              write(fd, buf_s, 256);
              DBG("send over %d\n");
          close(fd);
      2) 编写makefile
      #CROSS_COMPILE = arm-linux-
      #CROSS_COMPILE = arm-linux-gnueabihf-
      CROSS_COMPILE=/home/xxx/v851s/Yuzukilizard/toolchain/gcc-linaro-5.3.1-2016.05-x86_64_arm-linux-gnueabi/bin/arm-linux-gnueabi-
      # CPU = cortex-a7
      # FPU = fpv4-sp-d16
      AS                = $(CROSS_COMPILE)as
      LD                = $(CROSS_COMPILE)ld
      CC                = $(CROSS_COMPILE)gcc
      CXX               = $(CROSS_COMPILE)g++
      CPP               = $(CC) -E
      AR                = $(CROSS_COMPILE)ar
      NM                = $(CROSS_COMPILE)nm
      STRIP             = $(CROSS_COMPILE)strip
      OBJCOPY           = $(CROSS_COMPILE)objcopy
      OBJDUMP           = $(CROSS_COMPILE)objdump
      RANLIB            = $(CROSS_COMPILE)ranlib
      SIZE              = $(CROSS_COMPILE)size
      TOP_DIR           = $(shell pwd)
      CFLAGS_inc_path   += -I$(TOP_DIR)
      EXE	= UARTTest
      # CFLAGS_inc_path   += -I$(TOP_DIR)external/jpeg-9a
      # for H.264 hardware codec
      #CFLAGS_inc_path   += -I$(TOP_DIR)/../../prebuilt/include/cedar
      # CFLAGS += -std=gnu99 -mthumb -mabi=aapcs-linux -mlittle-endian
      # CFLAGS += -fdata-sections -ffunction-sections
      # CFLAGS += -mcpu=$(CPU) -mtune=$(CPU) -mfpu=$(FPU) -mfloat-abi=hard
      SRC_HAL += ./
      LIB_SRC := $(foreach spath, $(SRC_HAL), $(wildcard $(spath)*.c))
      OBJECT += $(patsubst %.c,%.o,$(LIB_SRC))
      LOCAL_INCLUDE += -I./
      #CFLAGS            += -O2 -ggdb3 -DNDEBUG
      CFLAGS            += $(LOCAL_INCLUDE) -static
      # LDFLAGS = -L../../library/arm-linux-gnueabihf
      # LIBS += -lawh264 -lvdecoder -lcdc_base -lMemAdapter -lVE -lvencoder -lvideoengine
      all:$(EXE)
      $(EXE):$(OBJECT)
      	@$(CC)  $(OBJECT) -o $(EXE) $(CFLAGS)
      #	@echo -- gcc  $(SRCS) --
      	@echo "Compile target done."
      	@echo "use src files"
      $(OBJECT):
      .PHONY:clean
      clean:
      	@rm -rf *.o $(OBJECT) $(EXE)
      	@echo "Clean done."
      需注意,将makefile 中的编译工具路径修改为自己的工具路径。
      3) make 后,产生可执行文件,adb push 到开发板中进行执行,执行命令:
      ./UARTTest /dev/ttyS3 4
      4)用杜邦线将PE12 PE13 GND 三根线接到电脑串口(需要串口转换小板子),波特率目前设定19200 ,使用串口工具,向板子随便发送数据,板子接受到数据,就会发送数据到电脑。
      Y 1 条回复 最后回复 回复 引用 分享 5
        yelong98 LV 7 @chhjnavy 最后由 编辑
        @chhjnavy 感谢谢谢帖子,对于入门非常有用,万丈高楼平地起
          aaabbb222 LV 4 最后由 编辑
          请问,nanopi neo的板子,如何修改串口设置? 我在公司 提供的内核代码中没有找到board.dts文件,只有sun8i-h3-nanopi-neo.dtsi文件,但该文件内容非常少。
            danny LV 3 最后由 编辑
            感谢楼主知识分享
