    gst-omx编译报错
    • lajuchenghui
      逸俊晨晖 LV 5 最后由 编辑
      SDK1.01打上了最新的补丁
      编译gst-omx报错
      错误信息如下:
      oot@allwinner-VirtualBox:/home/allwinner/d1/D1/package/multimedia/gst1-omx# mm
      make package/multimedia/gst1-omx/install V=s
      make[1]: Entering directory `/home/allwinner/d1/D1'
      make[2]: Entering directory `/home/allwinner/d1/D1/package/multimedia/gst1-omx'
      make -C /home/allwinner/d1/D1/out/d1-nezha/compile_dir/target/gst-omx-1.16.3/ ARCH="riscv" AR="riscv64-unknown-linux-gnu-ar" CC="riscv64-unknown-linux-gnu-gcc" CXX="riscv64-unknown-linux-gnu-g++" CFLAGS="-Os -pipe -mcmodel=medany -mabi=lp64d -march=rv64gcxthead -g3 -fno-caller-saves -Wno-format-truncation -Wno-unused-result  -Wformat -Werror=format-security -Wl,-z,now -Wl,-z,relro" LDFLAGS="-L/home/allwinner/d1/D1/out/d1-nezha/staging_dir/target/usr/lib -L/home/allwinner/d1/D1/out/d1-nezha/staging_dir/target/lib -L/home/allwinner/d1/D1/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/usr/lib -L/home/allwinner/d1/D1/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/lib -znow -zrelro -Wl,-rpath-link=/home/allwinner/d1/D1/out/d1-nezha/staging_dir/target/rootfs/lib " TARGET_BOARD="d1"
      make[3]: Entering directory `/home/allwinner/d1/D1/out/d1-nezha/compile_dir/target/gst-omx-1.16.3'
      make  all-recursive
      make[4]: Entering directory `/home/allwinner/d1/D1/out/d1-nezha/compile_dir/target/gst-omx-1.16.3'
      Making all in common
      make[5]: Entering directory `/home/allwinner/d1/D1/out/d1-nezha/compile_dir/target/gst-omx-1.16.3/common'
      Making all in m4
      make[6]: Entering directory `/home/allwinner/d1/D1/out/d1-nezha/compile_dir/target/gst-omx-1.16.3/common/m4'
      make[6]: Nothing to be done for `all'.
      make[6]: Leaving directory `/home/allwinner/d1/D1/out/d1-nezha/compile_dir/target/gst-omx-1.16.3/common/m4'
      make[6]: Entering directory `/home/allwinner/d1/D1/out/d1-nezha/compile_dir/target/gst-omx-1.16.3/common'
      make[6]: Nothing to be done for `all-am'.
      make[6]: Leaving directory `/home/allwinner/d1/D1/out/d1-nezha/compile_dir/target/gst-omx-1.16.3/common'
      make[5]: Leaving directory `/home/allwinner/d1/D1/out/d1-nezha/compile_dir/target/gst-omx-1.16.3/common'
      Making all in omx
      make[5]: Entering directory `/home/allwinner/d1/D1/out/d1-nezha/compile_dir/target/gst-omx-1.16.3/omx'
        CCLD     libgstomx.la
      gcc: error: unrecognized argument in option '-mcmodel=medany'
      gcc: note: valid arguments to '-mcmodel=' are: 32 kernel large medium small
      gcc: error: unrecognized argument in option '-mabi=lp64d'
      gcc: note: valid arguments to '-mabi=' are: ms sysv
      make[5]: *** [libgstomx.la] Error 1
      make[5]: Leaving directory `/home/allwinner/d1/D1/out/d1-nezha/compile_dir/target/gst-omx-1.16.3/omx'
      make[4]: *** [all-recursive] Error 1
      make[4]: Leaving directory `/home/allwinner/d1/D1/out/d1-nezha/compile_dir/target/gst-omx-1.16.3'
      make[3]: *** [all] Error 2
      make[3]: Leaving directory `/home/allwinner/d1/D1/out/d1-nezha/compile_dir/target/gst-omx-1.16.3'
      make[2]: *** [/home/allwinner/d1/D1/out/d1-nezha/compile_dir/target/gst-omx-1.16.3/.built] Error 2
      make[2]: Leaving directory `/home/allwinner/d1/D1/package/multimedia/gst1-omx'
      make[1]: *** [package/multimedia/gst1-omx/install] Error 2
      make[1]: Leaving directory `/home/allwinner/d1/D1'
      make: *** [package/multimedia/gst1-omx/install] Error 2
      root@allwinner-VirtualBox:/home/allwinner/d1/D1/package/multimedia/gst1-omx#
      在文件out/d1-nezha/compile_dir/target/gst-omx-1.16.3/omx/Makefile 可以看到
      这些变量 CC CCAS 被错误得指定为了gcc 其他文件的CC CCAS都是riscv64-unknown-linux-gnu-gcc 所以上面报了个gcc认不得-mcmodel=medany的错 实际上riscv是认得的
      现在问题就是不知道哪里导致Makefile一些本该指定为riscv64-unknown-linux-gnu-gcc 指定为了gcc 当然在Makefile直接把gcc手动改为riscv64-unknown-linux-gnu-gcc也不行😭 😭 😭
      和这个贴一样的😧 😧 😧
      https://bbs.aw-ol.com/topic/293/
      • U
        ubuntu LV 7 最后由 编辑
        我测试过,默认的编译确实就是这个错误。
        试一试 patch
        D1_open_tina_multimedia_update_0730.tar.gz
        Tina_支持gstreamer,更新多媒体中间件:
        1、Tina升级gstreamer主包及其各插件包到1.16.3版本,支持RV架构;
        2、gstreamer显示插件sunxifbsink支持g2d硬件旋转;
        3、更新多媒体中间件。
        2021-07-30 20:50:38
        44.222MB
        这里直接下载吧: D1_open_tina_multimedia_update_0730.tar.gz
        lajuchenghui 1 条回复 最后回复 回复 引用 分享 0
        • lajuchenghui
          逸俊晨晖 LV 5 @ubuntu 最后由 编辑
          @ubuntu
          这个0730补丁我打过了
          里面一些源文件我对比了 发现确实是打上了
          后面发现唯独package/multidedia/gst-omx/Makefile没变成打完补丁后的 然后我替换了补丁里面的 编译通过了😧
          总之可以了😁 😁 😁
