    芒果派 T113-s3外接以太网调试,ifconfig能看到eth0,无法up
    5395
      lucky123456 LV 4 最后由 WhycanService 编辑
      [348]HELLO! BOOT0 is starting!
      [351]BOOT0 commit : adaf1174cc
      [354]set pll start
      [356]fix vccio detect value:0xc0
      [363]periph0 has been enabled
      [366]set pll end
      [368][pmu]: bus read error
      [370]board init ok
      [372]ZQ value = 0x2f
      [374]get_pmu_exist() = -1
      [377]ddr_efuse_type: 0xa
      [379]trefi:7.8ms
      [382][AUTO DEBUG] single rank and full DQ!
      [386]ddr_efuse_type: 0xa
      [389]trefi:7.8ms
      [391][AUTO DEBUG] rank 0 row = 13
      [394][AUTO DEBUG] rank 0 bank = 8
      [398][AUTO DEBUG] rank 0 page size = 2 KB
      [402]DRAM BOOT DRIVE INFO: V0.33
      [405]DRAM CLK = 936 MHz
      [407]DRAM Type = 3 (2:DDR2,3:DDR3)
      [411]DRAMC read ODT  off.
      [413]DRAM ODT value: 0x42.
      [416]ddr_efuse_type: 0xa
      [419]DRAM SIZE =128 M
      [421]dram_tpr4:0x0
      [423]PLL_DDR_CTRL_REG:0xf8004d00
      [426]DRAM_CLK_REG:0xc0000000
      [429][TIMING DEBUG] MR2= 0x20
      [437]DRAM simple test OK.
      [439]rtc standby flag is 0x0, super standby flag is 0x0
      [445]dram size =128
      [447]card no is 0
      [449]sdcard 0 line count 4
      [452][mmc]: mmc driver ver 2021-05-21 14:47
      [461][mmc]: Wrong media type 0x0
      [464][mmc]: ***Try SD card 0***
      [474][mmc]: HSSDR52/SDR25 4 bit
      [477][mmc]: 50000000 Hz
      [479][mmc]: 7660 MB
      [481][mmc]: ***SD/MMC 0 init OK!!!***
      [573]Loading boot-pkg Succeed(index=0).
      [577]Entry_name        = u-boot
      [584]Entry_name        = optee
      [588]Entry_name        = dtb
      [591]mmc not para
      [592]Jump to second Boot.
      U-Boot 2018.05 (Apr 10 2023 - 16:00:21 +0800) Allwinner Technology
      [00.644]CPU:   Allwinner Family
      [00.647]Model: sun8iw20
      [00.649]DRAM:  128 MiB
      [00.653]Relocation Offset is: 04ebc000
      [00.678]secure enable bit: 0
      [00.681]smc_tee_inform_fdt failed with: -65526[00.685]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.691]gic: sec monitor mode
      [00.694]flash init start
      [00.696]workmode = 0,storage type = 1
      [00.699][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
      [00.705][mmc]: get sdc_type fail and use default host:tm1.
      [00.711][mmc]: can't find node "mmc0",will add new node
      [00.716][mmc]: fdt err returned <no error>
      [00.720][mmc]: Using default timing para
      [00.723][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.742][mmc]: card_caps:0x3000000a
      [00.745][mmc]: host_caps:0x3000003f
      [00.749]sunxi flash init ok
      [00.751]line:703 init_clocks
      [00.754]drv_disp_init
      [00.770]unable to map hdmi registers
      [00.774]drv_disp_init finish
      [00.788]Loading Environment from SUNXI_FLASH... OK
      [00.807]boot_gui_init:start
      [00.809]set disp.dev2_output_type fail. using defval=0
      [00.816]boot_gui_init:finish
      [00.828]bmp_name=bootlogo.bmp size 38454
      38454 bytes read in 4 ms (9.2 MiB/s)
      [00.853]Item0 (Map) magic is bad
      [00.856]the secure storage item0 copy0 magic is bad
      [00.872]Item0 (Map) magic is bad
      [00.875]the secure storage item0 copy1 magic is bad
      [00.880]Item0 (Map) magic is bad
      [00.883]out of usb burn from boot: not need burn key
      List file under ULI/factory
      root_partition is rootfs
      set root to /dev/mmcblk0p5
      [00.900]update part info
      [00.903]update bootcmd
      [00.907]change working_fdt 0x43e7be70 to 0x43e5be70
      [00.927]update dts
      [01.006]LCD open finish        0
      [02.118]no vendor_boot partition is found
      Android's image name: t113-mq_r
      [02.129]Starting kernel ...
      [02.131][mmc]: MMC Device 2 not found
      [02.135][mmc]: mmc 2 not find, so not exit
      [    0.000000] Linux version 5.4.61 (root@luke) (arm-openwrt-linux-muslgnueabi-gcc.bin (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) 6.4.1, GNU ld (GNU Binutils) 2.27) #24 SMP PREEMPT Mon Apr 10 07:58:37 UTC 2023
      [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500C00 clk_ignore_unused initcall_debug=0 console=ttyS3,115200 rootdelay=2 loglevel=8 root=/dev/mmcblk0p5 init=/pseudo_init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:private@mmcblk0p6:rootfs_data@mmcblk0p7:UDISK@mmcblk0p8 cma=4M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun8iw20p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05(04/10/2023-16:00:21) mbr_offset=1032192 disp_reserve=1536000,0x43f06000 androidboot.dramsize=128
      [    0.000000] Memory: 106036K/131072K available (6144K kernel code, 319K rwdata, 1632K rodata, 1024K init, 1170K bss, 20940K reserved, 4096K cma-reserved)
      [    0.000000] random: get_random_bytes called from start_kernel+0x26c/0x3ec with crng_init=0
      [    0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
      [    0.008007] Switching to timer-based delay loop, resolution 41ns
      [    0.014167] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
      [    0.023863] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.034211] pid_max: default: 32768 minimum: 301
      [    0.038954] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.046279] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.054605] CPU: Testing write buffer coherency: ok
      [    0.059812] /cpus/cpu@0 missing clock-frequency property
      [    0.065129] /cpus/cpu@1 missing clock-frequency property
      [    0.070461] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [    0.076610] Setting up static identity map for 0x40100000 - 0x40100060
      [    0.083263] rcu: Hierarchical SRCU implementation.
      [    0.088455] smp: Bringing up secondary CPUs ...
      [    0.094079] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [    0.094197] smp: Brought up 1 node, 2 CPUs
      [    0.104019] SMP: Total of 2 processors activated (96.00 BogoMIPS).
      [    0.110196] CPU: All CPU(s) started in SVC mode.
      [    0.115268] devtmpfs: initialized
      [    0.129735] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [    0.137848] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.147942] pinctrl core: initialized pinctrl subsystem
      [    0.154102] NET: Registered protocol family 16
      [    0.160093] DMA: preallocated 256 KiB pool for atomic coherent allocations
      [    0.195466] rtc_ccu: sunxi ccu init OK
      [    0.201527] ccu: sunxi ccu init OK
      [    0.205343] r_ccu: sunxi ccu init OK
      [    0.228878] iommu: Default domain type: Translated
      [    0.233963] sunxi iommu: irq = 24
      [    0.238109] SCSI subsystem initialized
      [    0.242102] usbcore: registered new interface driver usbfs
      [    0.247680] usbcore: registered new interface driver hub
      [    0.253068] usbcore: registered new device driver usb
      [    0.259014] Advanced Linux Sound Architecture Driver Initialized.
      [    0.265632] Bluetooth: Core ver 2.22
      [    0.269298] NET: Registered protocol family 31
      [    0.273736] Bluetooth: HCI device and connection manager initialized
      [    0.280128] Bluetooth: HCI socket layer initialized
      [    0.285001] Bluetooth: L2CAP socket layer initialized
      [    0.290069] Bluetooth: SCO socket layer initialized
      [    0.295166] pwm module init!
      [    0.299270] g2d 5410000.g2d: Adding to iommu group 0
      [    0.304540] G2D: rcq version initialized.major:252
      [    0.310187] clocksource: Switched to clocksource arch_sys_counter
      [    0.324841] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
      [    0.334145] NET: Registered protocol family 2
      [    0.339066] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
      [    0.347486] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.355186] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
      [    0.362257] TCP: Hash tables configured (established 1024 bind 1024)
      [    0.368702] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.375265] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.382441] NET: Registered protocol family 1
      [    0.387738] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
      [    0.398034] spi spi0: spi0 supply spi not found, using dummy regulator
      [    0.404750] sunxi_spi_resource_get()2116 - [spi0] SPI MASTER MODE
      [    0.410899] sunxi_spi_resource_get()2154 - Failed to get sample mode
      [    0.417260] sunxi_spi_resource_get()2159 - Failed to get sample delay
      [    0.423714] sunxi_spi_resource_get()2163 - sample_mode:-1431633921 sample_delay:-1431633921
      [    0.432142] sunxi_spi_clk_init()2205 - [spi0] mclk 100000000
      [    0.438393] sunxi_spi_probe()2623 - [spi0]: driver probe succeed, base c881f000, irq 40
      [    0.448053] workingset: timestamp_bits=30 max_order=15 bucket_order=0
      [    0.459488] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [    0.465522] ntfs: driver 2.1.32 [Flags: R/W].
      [    0.498424] io scheduler mq-deadline registered
      [    0.502969] io scheduler kyber registered
      [    0.508018] [DISP]disp_module_init
      [    0.511966] disp 5000000.disp: Adding to iommu group 0
      [    0.517597] [DISP] parser_disp_init_para,line:1430:
      [    0.517601] of_property_read fb0_width fail
      [    0.526684] [DISP] disp_init,line:2386:
      [    0.526688] smooth display screen:0 type:1 mode:4
      [    0.535952] disp_al_manager_apply ouput_type:1
      [    0.540491] [DISP]disp_module_init finish
      [    0.540567] [DISP] lcd_clk_config,line:744:
      [    0.540576] disp 0, clk: pll(0),clk(0),dclk(0) dsi_rate(0)
      [    0.540576]      clk real:pll(297000000),clk(288000000),dclk(0) dsi_rate(0)
      [    0.545497] sunxi_sid_init()551 - insmod ok
      [    0.566322] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
      [    0.576537] uart uart3: uart3 supply uart not found, using dummy regulator
      [    0.583686] uart3: ttyS3 at MMIO 0x2500c00 (irq = 34, base_baud = 1500000) is a SUNXI
      [    0.591578] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
      ▒[    0.599546] printk: console [ttyS3] enabled
      [    0.608461] printk: bootconsole [earlycon0] disabled
      [    0.619810] misc dump reg init
      [    0.624385] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
      [    0.635562] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
      [    0.642805] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
      [    0.650090] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
      [    0.657494] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
      [    0.664012] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
      [    0.670959] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
      [    0.678646] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
      [    0.686466] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
      [    0.694560] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
      [    0.702154] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
      [    0.708879] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
      [    0.716400] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=207 assert=0
      [    0.724347] [ADDR_MGT] addr_mgt_probe: module version: v1.0.11
      [    0.731497] [ADDR_MGT] addr_mgt_probe: success.
      [    0.736798] dma-buf: Running sanitycheck
      [    0.741267] dma-buf: Running dma_fence
      [    0.745444] sizeof(dma_fence)=48
      [    0.749142] dma-buf: Running dma_fence/sanitycheck
      [    0.754552] dma-buf: Running dma_fence/test_signaling
      [    0.760231] dma-buf: Running dma_fence/test_add_callback
      [    0.766154] dma-buf: Running dma_fence/test_late_add_callback
      [    0.772583] dma-buf: Running dma_fence/test_rm_callback
      [    0.778408] dma-buf: Running dma_fence/test_late_rm_callback
      [    0.784729] dma-buf: Running dma_fence/test_status
      [    0.790074] dma-buf: Running dma_fence/test_error
      [    0.795328] dma-buf: Running dma_fence/test_wait
      [    0.800488] dma-buf: Running dma_fence/test_wait_timeout
      [    0.840201] dma-buf: Running dma_fence/test_stub
      [    0.845367] dma-buf: Running dma_fence/race_signal_callback
      [    0.920195] thread_signal_callback[0] completed 36483 passes, 21 misses
      [    0.927601] thread_signal_callback[1] completed 36473 passes, 12 misses
      [    1.000197] thread_signal_callback[0] completed 40567 passes, 40566 misses
      [    1.007890] thread_signal_callback[1] completed 40594 passes, 40594 misses
      [    1.016069] sunxi-spinand: AW SPINand MTD Layer Version: 2.3 20211223
      [    1.023354] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
      [    1.034335] random: fast init done
      [    1.215298] random: crng init done
      [    2.030205] sunxi-spinand-phy: read id failed : -110
      [    2.035766] spi-nand: probe of spi0.0 failed with error -110
      [    2.042973] libphy: Fixed MDIO Bus: probed
      [    2.048309] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
      [    2.059542] sunxi gmac driver's version: 1.0.0
      [    2.064713] gmac-power0: NULL
      [    2.068020] gmac-power1: NULL
      [    2.071348] gmac-power2: NULL
      [    2.074672] rtl8363nb_vb_init->694 rtk8363 init=====
      [    2.080228] rtk_switch_probe->1011 flyranchao data = 0x0 regValue = 0x0===
      [    2.087901] rtk switch init failed!
      [    2.092781] Failed to alloc md5
      [    2.096290] eth0: Use random mac address
      [    2.100960] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    2.108238] sunxi-ehci: EHCI SUNXI driver
      [    2.113165] get ehci1-controller wakeup-source is fail.
      [    2.119106] sunxi ehci1-controller don't init wakeup source
      [    2.125392] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0b6b920, 0x:c8835000, irq_no:3a
      [    2.137381] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator
      [    2.149824] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
      [    2.161941] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
      [    2.169172] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
      [    2.179069] sunxi-ehci 4200000.ehci1-controller: irq 58, io mem 0x04200000
      [    2.220200] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
      [    2.228774] hub 1-0:1.0: USB hub found
      [    2.233043] hub 1-0:1.0: 1 port detected
      [    2.237975] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    2.244911] sunxi-ohci: OHCI SUNXI driver
      [    2.249873] get ohci1-controller wakeup-source is fail.
      [    2.255825] sunxi ohci1-controller don't init wakeup source
      [    2.262055] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0b6bbb0
      [    2.271719] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator
      [    2.284158] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
      [    2.296272] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
      [    2.303518] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
      [    2.313356] sunxi-ohci 4200400.ohci1-controller: irq 59, io mem 0x04200400
      [    2.394999] hub 2-0:1.0: USB hub found
      [    2.399216] hub 2-0:1.0: 1 port detected
      [    2.404279] usbcore: registered new interface driver usb-storage
      [    2.411157] i2c /dev entries driver
      [    2.415115] sunxi cedar version 1.1
      [    2.419199] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
      [    2.425500] VE: sunxi_cedar_probe power-domain init!!!
      [    2.431246] VE: install start!!!
      [    2.431246]
      [    2.436743] VE: cedar-ve the get irq is 41
      [    2.436743]
      [    2.443174] VE: ve_debug_proc_info:11dfd1b2, data:9b1c56d5, lock:40ef2fa4
      [    2.443174]
      [    2.452428] VE: install end!!!
      [    2.452428]
      [    2.457474] VE: sunxi_cedar_probe
      [    2.461421] Bluetooth: HCI UART driver ver 2.3
      [    2.466377] Bluetooth: HCI UART protocol H4 registered
      [    2.472138] Bluetooth: HCI UART protocol BCSP registered
      [    2.478058] Bluetooth: HCI UART protocol (null) registered
      [    2.484210] Bluetooth: HCI Realtek H5 protocol initialized
      [    2.492481] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.22 2021-12-20 15:40)
      [    2.502447] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
      [    2.508605] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
      [    2.514958] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
      [    2.521395] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
      [    2.527802] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
      [    2.534316] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
      [    2.540836] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
      [    2.547338] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
      [    2.554286] sunxi-mmc 4020000.sdmmc: Got CD GPIO
      [    2.559788] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.570912] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
      [    2.591013] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.615366] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
      [    2.621048] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.633094] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.22 2021-12-20 15:40)
      [    2.643041] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
      [    2.644115] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.649201] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
      [    2.667039] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
      [    2.673474] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
      [    2.679889] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
      [    2.679901] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.686408] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
      [    2.704481] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
      [    2.705737] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.710997] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
      [    2.729072] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
      [    2.738533] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.749662] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [    2.764855] mmc0: host does not support reading read-only switch, assuming write-enable
      [    2.773809] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.786421] sunxi-mmc 4021000.sdmmc: detmode:manually by software
      [    2.793251] mmc0: Problem switching card into high-speed mode!
      [    2.793957] exFAT: Version 1.3.0
      [    2.799762] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 25000000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.799769] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    2.803451] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 25000000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
      [    2.816008] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    2.822061] mmc0: new SDHC card at address 0001
      [    2.833793] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.841447] mmcblk0: mmc0:0001 SD16G 7.48 GiB
      [    2.847197] sunxi-spdif 2036000.spdif: Not using gpio-spdif gpio from dts
      [    2.870853] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
      [    2.870853]
      [    2.872902] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.888014]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
      [    2.899647] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
      [    2.915787] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
      [    2.923970] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    2.931553] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    2.938442] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
      [    2.948171] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    2.955019] [SNDCODEC][sunxi_card_init][583]:card init finished
      [    2.961645] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    2.968371] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    2.980058] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
      [    2.990925] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input0
      [    3.002799] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
      [    3.011739] NET: Registered protocol family 10
      [    3.017786] Segment Routing with IPv6
      [    3.021929] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
      [    3.029342] NET: Registered protocol family 17
      [    3.034467] Bluetooth: RFCOMM TTY layer initialized
      [    3.039930] Bluetooth: RFCOMM socket layer initialized
      [    3.045711] Bluetooth: RFCOMM ver 1.11
      [    3.050536] Registering SWP/SWPB emulation handler
      [    3.070288] sun8iw20-pinctrl 2000000.pinctrl: missing pins property in node twi2
      [    3.078583] sunxi-i2c: probe of 2502800.twi failed with error -22
      [    3.087702] sunxi-audio-card 203605c.soundspdif: use dummy codec for simple card.
      [    3.096234] debugfs: Directory '2036000.spdif' with parent 'sndspdif' already present!
      [    3.105512] sunxi-audio-card 203605c.soundspdif: snd-soc-dummy-dai <-> 2036000.spdif mapping ok
      [    3.116199] get ehci0-controller wakeup-source is fail.
      [    3.122217] sunxi ehci0-controller don't init wakeup source
      [    3.128436] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0b6b400, 0x:c88b2000, irq_no:38
      [    3.140392] [sunxi-ehci0]: Not init ehci0
      [    3.145197] get ohci0-controller wakeup-source is fail.
      [    3.151129] sunxi ohci0-controller don't init wakeup source
      [    3.157361] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0b6b690
      [    3.166986] [sunxi-ohci0]: Not init ohci0
      [    3.172798] get usb_detect_mode is fail, -22
      [    3.177563] get det_vbus is fail, -84
      [    3.181691] get id is fail, -84
      [    3.187158] clk: Not disabling unused clocks
      [    3.192384] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      [    3.202044] cfg80211: failed to load regulatory.db
      [    3.202058] ALSA device list:
      [    3.210702]   #0: audiocodec
      [    3.213911]   #1: sndspdif
      [    3.217130] Waiting 2 sec before mounting root device...
      [    4.200220]
      [    4.200220] insmod_device_driver
      [    4.200220]
      [    4.207372] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
      [    4.219406] device_chose finished 142!
      [    5.260646] EXT4-fs (mmcblk0p5): mounted filesystem without journal. Opts: (null)
      [    5.269059] VFS: Mounted root (ext4 filesystem) readonly on device 179:5.
      [    5.278294] devtmpfs: mounted
      [    5.283567] Freeing unused kernel memory: 1024K
      [    5.288748] Run /pseudo_init as init process
      [    6.017342] EXT4-fs: Warning: mounting with data=journal disables delayed allocation and O_DIRECT support!
      [    6.034172] EXT4-fs (mmcblk0p7): mounted filesystem with journalled data mode. Opts: data=journal
      skip mount overlayfs as now rootfs not squashfs
      [    6.144126] EXT4-fs (mmcblk0p5): re-mounted. Opts: (null)
      [   19.168503] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null)
      insmod: can't insert '/lib/modules/5.4.61/usb-storage.ko': No such file or directory
      [   19.193782] sunxi_gpadc_init,2151, success
      [   19.361304] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
      [   19.468408] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
      [   19.474689] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   19.486271] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [   19.506417] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   19.531937] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   19.546468] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   19.559685] sunxi-mmc 4021000.sdmmc: card claims to support voltages below defined range
      [   19.578345] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [   19.589877] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [   19.601655] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      [   19.614141] mmc1: new high speed SDIO card at address 0001
      ------run rc.final file-----
      mount: mounting /dev/mmcblk0p1 on /mnt/extsd failed: No such file or directory
      ------run profile file-----
      nodev   debugfs
      root@TinaLinux:/# [   24.409418] file system registered
      [   24.426285] configfs-gadget 4100000.udc-controller: failed to start g1: -19
      [   24.483662] read descriptors
      [   24.486921] read strings
      swu_param: ####
      swu_software: ####
      swu_mode: ####
      [   24.655215] sunxi_set_cur_vol_work()485 WARN: get power supply failed
      [   24.706750] android_work: sent uevent USB_STATE=CONNECTED
      [   24.846999] sunxi_set_cur_vol_work()485 WARN: get power supply failed
      [   24.921583] configfs-gadget gadget: high-speed config #1: c
      [   24.927924] android_work: sent uevent USB_STATE=CONFIGURED
      [   24.960203] sunxi_vbus_det_work()3454 WARN: get power supply failed
      [   24.967223] android_work: sent uevent USB_STATE=DISCONNECTED
      [   33.800213] usb1-vbus: disabling
      root@TinaLinux:/#
      root@TinaLinux:/# ifconfig -a
      eth0      Link encap:Ethernet  HWaddr DA:29:4D:59:5B:DA
                BROADCAST MULTICAST  MTU:1500  Metric:1
                collisions:0 txqueuelen:1000
                Interrupt:37
      wlan0     Link encap:Ethernet  HWaddr 94:A4:08:C2:A2:E5
      wlan1     Link encap:Ethernet  HWaddr 96:A4:08:C2:A2:E5
      root@TinaLinux:/# ifconfig eth0 up
      [   53.194183] libphy: 4500000.eth: probed
      [   53.199005] sunxi-gmac 4500000.eth eth0: eth0: Type(7) PHY ID 00070007 at 0 IRQ poll (4500000.eth-0:00)
      [   53.220007] sunxi-gmac 4500000.eth eth0: Initialize hardware error
      root@TinaLinux:/# [   62.312171] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   62.320742] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   62.827549] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   62.836118] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   62.883533] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   62.892092] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   63.256849] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   63.265422] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   63.343359] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   63.351919] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   63.439827] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   63.448388] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   63.507513] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   63.516074] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   63.857608] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   63.866176] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   63.930096] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   63.938657] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   64.357554] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   64.366121] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      [   64.515012] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [   64.523577] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device disconnect
      最后重复的打印是接入网线后产生的日志
        lucky123456 LV 4 @lucky123456 最后由 编辑
        dtsi文件gmac0如下:
        board.dts如下:
        • mangogeek
          mangogeek LV 8 最后由 编辑
          引脚怎么把PE10注释掉了?PE10是25M参考时钟。
            lucky123456 LV 4 @mangogeek 最后由 编辑
            @mangogeek 我用的外置25M晶振作为时钟,时钟这一项是不是可以不用配置
            • mangogeek
              mangogeek LV 8 @lucky123456 最后由 编辑
              @lucky123456 应该不行,RMII没有独立的tx-ck和rx-ck,所以共用一个时钟源来同步。将PE10打开看看是否有50M时钟给外部phy。
              剩下就是检查外边引脚电压是否匹配。
                @mangogeek 好的,我修改试试
