    一个 Linux下非对称加密demo,ubuntu18.04验证通过
    • U
      ubuntu LV 7 最后由 whycan 编辑
      生成密钥对:
      openssl genrsa -out private_key.pem 2048
      openssl rsa -in private_key.pem -outform PEM -pubout -out public_key.pem
      #include <string.h>
      #include <openssl/rsa.h>
      #include <openssl/pem.h>
      int main() {
          // 加载RSA密钥对
          RSA *rsa_keypair = RSA_new();
          FILE *private_key_file = fopen("private_key.pem", "r");
          PEM_read_RSAPrivateKey(private_key_file, &rsa_keypair, NULL, NULL);
          fclose(private_key_file);
          // 加载公钥
          RSA *rsa_public_key = RSA_new();
          FILE *public_key_file = fopen("public_key.pem", "r");
          PEM_read_RSA_PUBKEY(public_key_file, &rsa_public_key, NULL, NULL);
          fclose(public_key_file);
          // 明文数据
          char *plaintext = "Hello, world!";
          // 分配内存保存加密后的数据
          int plaintext_len = strlen(plaintext);
          int encrypted_len = RSA_size(rsa_public_key);
          unsigned char *encrypted_data = (unsigned char *)malloc(encrypted_len);
          // 加密数据
          int result = RSA_public_encrypt(plaintext_len, (unsigned char *)plaintext,
                  encrypted_data, rsa_public_key, RSA_PKCS1_PADDING);
          if (result == -1) {
              printf("Error: RSA_public_encrypt failed!\n");
              return -1;
          // 输出加密后的数据
          printf("Encrypted data: ");
          for (int i = 0; i < result; i++) {
              printf("%02x", encrypted_data[i]);
          printf("\n");
          // 分配内存保存解密后的数据
          int decrypted_len = RSA_size(rsa_keypair);
          unsigned char *decrypted_data = (unsigned char *)malloc(decrypted_len);
          // 解密数据
          result = RSA_private_decrypt(encrypted_len, encrypted_data, decrypted_data,
                  rsa_keypair, RSA_PKCS1_PADDING);
          if (result == -1) {
              printf("Error: RSA_private_decrypt failed!\n");
              return -1;
          // 输出解密后的数据
          printf("Decrypted data: %s\n", decrypted_data);
          // 释放内存
          free(encrypted_data);
          free(decrypted_data);
          RSA_free(rsa_keypair);
          RSA_free(rsa_public_key);
      编译指令:
      gcc -o rsa_example rsa_example.c -lcrypto
      运行:
      ./rsa_example
      Encrypted data: 831bbcc94a2f5b30b605849d4756273b7d88d4995f2a2688f26aab81ef3ab992e7fcebe0530e8c0d5c4f889313648f319d55e2321d48edec4e1760959ca24b168               2d0e06911c3e1f8e94357f10b88f2fd6a0e3b1978a8ce6252de849d410f36b1123d7a4a66913eb1bd6c8096fb80f15bda150530a77f6aace39008f35bf7873d11a4903fa0d97647a6               18630b7781732a81d72e17771c60cf343b18565f1e49422dcd2de33cb4f18693a1def0c9b029ec6d1b96991bde6e55b3bdd972391df3c403c13fe27b38df75b4aeb963ad34cd0d55b               26f810d0735017c0e93da288c12bcf71a9b08cacee9923843a506585b534b484ef63119fe813dbf90b9c85fd707ef
      Decrypted data: Hello, world!
