    T113 ov5640加载驱动报错,PE11申请不到,被占用了。
    9573
      shz18877605430 LV 6 最后由 编辑
      board.dts
       * Allwinner Technology CO., Ltd. sun8iw20p1 platform
       * modify base on juno.dts
      /memreserve/ 0x41B00000 0x00100000;
      #include <dt-bindings/clock/sun8iw20-ccu.h>
      #include <dt-bindings/clock/sun8iw20-r-ccu.h>
      #include <dt-bindings/clock/sun8iw20-rtc.h>
      #include <dt-bindings/reset/sun8iw20-ccu.h>
      #include <dt-bindings/reset/sun8iw20-r-ccu.h>
      #include <dt-bindings/interrupt-controller/arm-gic.h>
      #include <dt-bindings/gpio/gpio.h>
      #include <dt-bindings/gpio/sun4i-gpio.h>
      #include <dt-bindings/thermal/thermal.h>
      #include <dt-bindings/power/r528-power.h>
      	model = "sun8iw20";
      	compatible = "allwinner,sun8iw20p1";
      	interrupt-parent = <&gic>;
      	#address-cells = <2>;
      	#size-cells = <2>;
      	aliases {
      		serial0 = &uart0;
      		serial1 = &uart1;
      		serial2 = &uart2;
      		serial3 = &uart3;
      		serial4 = &uart4;
      		serial5 = &uart5;
      		spi0 = &spi0;
      		spi1 = &spi1;
      		twi0 = &twi0;
      		twi1 = &twi1;
      		twi2 = &twi2;
      		twi3 = &twi3;
      		mmc0 = &sdc0;
      		mmc2 = &sdc2;
      		pwm = &pwm;
      		pwm0 = &pwm0;
      		pwm1 = &pwm1;
      		pwm2 = &pwm2;
      		pwm3 = &pwm3;
      		pwm4 = &pwm4;
      		pwm5 = &pwm5;
      		pwm6 = &pwm6;
      		pwm7 = &pwm7;
      		ir0 = &s_cir0;
      		ve0 = &ve;
      		tv0 = &tv0;
      		tvd = &tvd;
      		tvd0 = &tvd0;
      		share_space0 = &share_space0;
      	chosen {
      		bootargs = "earlyprintk=sunxi-uart,0x2500000 loglevel=8 initcall_debug=0 console=ttyS0 init=/init";
      		//bootargs = "loglevel=8 initcall_debug=0 console=ttyS0 init=/init";
      		linux,initrd-start = <0x0 0x0>;
      		linux,initrd-end = <0x0 0x0>;
      	firmware {
      		optee {
      			compatible = "linaro,optee-tz";
      			method = "smc";
      	cpus {
      		enable-method = "allwinner,sun8iw20p1";
      		#address-cells = <1>;
      		#size-cells = <0>;
      		cpu0: cpu@0 {
      			device_type = "cpu";
      			compatible = "arm,cortex-a7","arm,armv7";
      			reg = <0x0>;
      			enable-method = "psci";
      			clocks = <&ccu CLK_CPUX>;
      			dynamic-power-coefficient = <156>;
      			cpu-idle-states = <&CPU_SLEEP &CLUSTER_SLEEP>;
      			operating-points-v2 = <&cpu_opp_table>;
      			#cooling-cells = <2>;
      		cpu1: cpu@1 {
      			reg = <0x1>;
      		idle-states {
      			entry-method = "arm,psci";
      			CPU_SLEEP: cpu-sleep {
      				compatible = "arm,idle-state";
      				arm,psci-suspend-param = <0x0010000>;
      				entry-latency-us = <46>;
      				exit-latency-us = <59>;
      				min-residency-us = <3570>;
      				local-timer-stop;
      			CLUSTER_SLEEP: cluster-sleep {
      				arm,psci-suspend-param = <0x1010000>;
      				entry-latency-us = <47>;
      				exit-latency-us = <74>;
      				min-residency-us = <5000>;
      				local-timer-stop;
      	psci {
      		compatible = "arm,psci-1.0";
      		method = "smc";
      	dump_reg: dump_reg@20000 {
      		compatible = "allwinner,sunxi-dump-reg";
      		reg = <0x0 0x00020000 0x0 0x0004>;
      		/* 0x00020000: dump_reg test addr, 0x0004: dump_reg test size */
      	cpu_opp_table: cpu-opp-table {
      		compatible = "allwinner,sun50i-operating-points";
      		nvmem-cells = <&speedbin_efuse>, <&cpubin_efuse>;
      		nvmem-cell-names = "speed", "bin";
      		opp-shared;
      		opp@480000000 {
      			opp-hz = /bits/ 64 <480000000>;
      			clock-latency-ns = <244144>; /* 8 32k periods */
      			opp-microvolt-a0 = <900000>;
      			opp-microvolt-a1 = <900000>;
      			opp-microvolt-a2 = <900000>;
      			opp-microvolt-b0 = <950000>;
      			opp-supported-hw = <0x3>;
      		opp@720000000 {
      			opp-hz = /bits/ 64 <720000000>;
      		opp@912000000 {
      			opp-hz = /bits/ 64 <912000000>;
      			opp-microvolt-a0 = <950000>;
      		opp@1008000000 {
      			opp-hz = /bits/ 64 <1008000000>;
      			opp-microvolt-a0 = <1000000>;
      		opp@1104000000 {
      			opp-hz = /bits/ 64 <1104000000>;
      			opp-microvolt-a0 = <1050000>;
      			opp-microvolt-a1 = <950000>;
      			opp-microvolt-a2 = <950000>;
      		opp@1200000000 {
      			opp-hz = /bits/ 64 <1200000000>;
      			opp-microvolt-a0 = <1100000>;
      			opp-microvolt-a1 = <1000000>;
      			opp-microvolt-a2 = <1000000>;
      			opp-supported-hw = <0x1>;
      	dcxo24M: dcxo24M_clk {
      		#clock-cells = <0>;
      		compatible = "fixed-clock";
      		clock-frequency = <24000000>;
      		clock-output-names = "dcxo24M";
      	rc_16m: rc16m_clk {
      		#clock-cells = <0>;
      		clock-frequency = <16000000>;
      		clock-accuracy = <300000000>;
      		clock-output-names = "rc-16m";
      	ext_32k: ext32k_clk {
      		#clock-cells = <0>;
      		clock-frequency = <32768>;
      		clock-output-names = "ext-32k";
      	dram: dram {
      		compatible = "allwinner,dram";
      		clocks = <&ccu CLK_PLL_DDR0>;
      		clock-names = "pll_ddr";
      	memory@40000000 {
      		device_type = "memory";
      		reg = <0x00000000 0x40000000 0x00000000 0x20000000>;
      	share_space0: share_space@42100000 {
      		#size-cells = <1>;
      		deice_tpye = "share_space0";
      		/* dsp write addr and len */
      		/* arm write addr and len */
      		/* dsp log addr and len */
      		/* reserve */
      		reg = <	0x42100000 0x00001000
      			0x42101000 0x00001000
      			0x42102000 0x0000E000
      			0x00000000 0x00000000>;
      	gic: interrupt-controller@3020000 {
      		compatible = "arm,cortex-a15-gic", "arm,cortex-a9-gic";
      		#interrupt-cells = <3>;
      		#address-cells = <0>;
      		device_type = "gic";
      		interrupt-controller;
      		reg = <0x0 0x03021000 0 0x1000>, /* GIC Dist */
      		      <0x0 0x03022000 0 0x2000>, /* GIC CPU */
      		      <0x0 0x03024000 0 0x2000>, /* GIC VCPU Control */
      		      <0x0 0x03026000 0 0x2000>; /* GIC VCPU */
      		interrupts = <GIC_PPI 9 0xf04>; /* GIC Maintenence IRQ */
      	timer_arch {
      		compatible = "arm,armv7-timer";
      		interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>,
      			     <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>,
      			     <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>,
      			     <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>;
      		arm,cpu-registers-not-fw-configured;
      		arm,no-tick-in-suspend;
      	pmu {
      		compatible = "arm,cortex-a7-pmu";
      		interrupts = <GIC_SPI 172 4>,
      			     <GIC_SPI 173 4>;
      	power: power-management@ff000000 {
      		compatible = "allwinner,r528-pmu", "syscon", "simple-mfd";
      		reg = <0x0 0x07001000 0x0 0x400>;
      		pd: power-controller {
      			compatible = "allwinner,r528-power-controller";
      			clocks = <&r_ccu CLK_R_PPU>;
      			clock-names = "ppu";
      			resets = <&r_ccu RST_R_PPU>;
      			reset-names = "ppu_rst";
      			#power-domain-cells = <1>;
      			#size-cells = <0>;
      			/* These power domains are grouped by VD_SYS */
      			pd_ve@R528_PD_VE {
      				reg = <R528_PD_VE>;
      	mmu_aw: iommu@2010000 {
      		compatible = "allwinner,sunxi-iommu";
      		reg = <0x0 0x02010000 0x0 0x1000>;
      		interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH>;
      		interrupt-names = "iommu-irq";
      		clocks = <&ccu CLK_BUS_IOMMU>;
      		clock-names = "iommu";
      		#iommu-cells = <2>;
      	reg_pio1_8: pio-18 {
      		regulator-name = "pio-18";
      		regulator-min-microvolt = <1800000>;
      		regulator-max-microvolt = <1800000>;
      	reg_pio3_3: pio-33 {
      		regulator-name = "pio-33";
      	thermal-zones {
      		cpu_thermal_zone: cpu_thermal_zone {
      			polling-delay-passive = <500>;
      			polling-delay = <1000>;
      			thermal-sensors = <&ths 0>;
      			sustainable-power = <589>;
      			cpu_trips: trips {
      				cpu_threshold: trip-point@0 {
      					temperature = <70000>;
      					type = "passive";
      					hysteresis = <0>;
      				cpu_target: trip-point@1 {
      					temperature = <90000>;
      					type = "passive";
      					hysteresis = <0>;
      				cpu_crit: cpu_crit@0 {
      					temperature = <110000>;
      					type = "critical";
      					hysteresis = <0>;
      			cooling-maps {
      				map0 {
      					trip = <&cpu_target>;
      					cooling-device = <&cpu0
      					THERMAL_NO_LIMIT
      					THERMAL_NO_LIMIT>;
      					contribution = <1024>;
      	soc: soc@3000000 {
      		compatible = "simple-bus";
      		#size-cells = <2>;
      		ranges;
      		device_type = "soc";
      		sram_ctrl: sram_ctrl@3000000 {
      			compatible = "allwinner,sram_ctrl";
      			reg = <0x0 0x3000000 0 0x16C>;
      			soc_ver {
      				offset = <0x24>;
      				mask = <0x7>;
      				shift = <0>;
      				ver_a = <0x18590000>;
      				ver_b = <0x18590002>;
      				ver_d = <0x18590003>;
      			soc_id {
      				offset = <0x200>;
      				mask = <0x1>;
      				shift = <22>;
      			soc_bin {
      				offset = <0x0>;
      				mask = <0x3ff>;
      				shift = <0x0>;
      		rtc_ccu: rtc_ccu@7090000 {
      			compatible = "allwinner,sun8iw20-rtc-ccu";
      			device_type = "rtc-ccu";
      			reg = <0x0 0x07090000 0x0 0x320>;  /* The same as rtc */
      			#clock-cells = <1>;
      		ccu: ccu@2001000 {
      			compatible = "allwinner,sun8iw20-ccu";
      			reg = <0x0 0x02001000 0x0 0x1000>;
      			clocks = <&dcxo24M>, <&rtc_ccu CLK_OSC32K>, <&rtc_ccu CLK_IOSC>;
      			clock-names = "hosc", "losc", "iosc";
      			#clock-cells = <1>;
      			#reset-cells = <1>;
      		r_ccu: r_ccu@7010000 {
      			compatible = "allwinner,sun8iw20-r-ccu";
      			reg = <0x0 0x07010000 0x0 0x240>;
      			clocks = <&dcxo24M>, <&rtc_ccu CLK_OSC32K>, <&rtc_ccu CLK_IOSC>,
      				 <&ccu CLK_PLL_PERIPH0>;
      			clock-names = "hosc", "losc", "iosc", "pll-periph0";
      			#clock-cells = <1>;
      			#reset-cells = <1>;
      		rtc: rtc@7090000 {
      			compatible = "allwinner,sun8iw20-rtc";
      			device_type = "rtc";
      			wakeup-source;
      			interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&r_ccu CLK_R_AHB_BUS_RTC>, <&rtc_ccu CLK_RTC_1K>, <&rtc_ccu CLK_RTC_SPI>;
      			clock-names = "r-ahb-rtc", "rtc-1k", "rtc-spi";
      			resets = <&r_ccu RST_R_AHB_BUS_RTC>;
      			gpr_cur_pos = <6>;
      		dma:dma-controller@3002000 {
      			compatible = "allwinner,sun8iw20-dma";
      			reg = <0x0 0x03002000 0x0 0x1000>;
      			interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_DMA>, <&ccu CLK_MBUS_DMA>;
      			clock-names = "bus", "mbus";
      			dma-channels = <8>;
      			dma-requests = <48>;
      			resets = <&ccu RST_BUS_DMA>;
      			#dma-cells = <1>;
      		soc_timer0: timer@2050000 {
      			compatible = "allwinner,sun4i-a10-timer";
      			device_type = "soc_timer";
      			reg = <0x0 0x02050000 0x0 0xA0>;
      			interrupts = <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&dcxo24M>;
      		wdt: watchdog@20500A0 {
      			compatible = "allwinner,sun6i-a31-wdt";
      			reg = <0x0 0x020500A0 0x0 0x20>;  /* In Timers Spec */
      			interrupts = <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>;  /* In GIC Spec */
      		mbus0: mbus-controller@3102000 {
      			compatible = "allwinner,sun8i-mbus";
      			reg = <0x0 0x03102000 0x0 0x1000>;  /* In SDRAM Controller Spec: DRAMC Common Register */
      			#mbus-cells = <1>;
      		pio: pinctrl@2000000 {
      			compatible = "allwinner,sun8iw20-pinctrl";
      			reg = <0x0 0x02000000 0x0 0x500>;
      			interrupts = <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>,  /* AW1859_GIC_Spec: GPIOB: 101-32=69 */
      				     <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>,
      				     <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>,
      				     <GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>,
      				     <GIC_SPI 77 IRQ_TYPE_LEVEL_HIGH>,
      				     <GIC_SPI 79 IRQ_TYPE_LEVEL_HIGH>;
      			device_type = "pio";
      			clocks = <&ccu CLK_APB0>, <&dcxo24M>, <&rtc_ccu CLK_OSC32K>;
      			clock-names = "apb", "hosc", "losc";
      			gpio-controller;
      			#gpio-cells = <3>;
      			#size-cells = <0>;
      			vcc-pf-supply = <&reg_pio1_8>;
      			vcc-pfo-supply = <&reg_pio3_3>;
      			test_pins_a: test_pins@0 {
      				allwinner,pins = "PB0", "PB1";
      				allwinner,function = "test";
      				allwinner,muxsel = <0x9>;
      				allwinner,drive = <1>;
      				allwinner,pull = <1>;
      			test_pins_b: test_pins@1 {
      				function = "io_disabled";
      				allwinner,muxsel = <0xF>;
      			csi_mclk0_pins_a: csi_mclk0@0 {
      				pins = "PE3";
      				function = "csi0";
      				drive-strength = <10>;
      			csi_mclk0_pins_b: csi_mclk0@1 {
      				pins = "PE3";
      				function = "gpio_in";
      			csi0_pins_a: csi0@0 {
      				pins = "PE2", "PE0", "PE1", "PE4", "PE5",
      						 "PE6", "PE7", "PE8", "PE9", "PE10", "PE11";
      				function = "ncsi0";
      			csi0_pins_b: csi0@1 {
      			lvds0_pins_a: lvds0@0 {
      				pins  = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9";
      				function = "lvds0";
      				drive-strength = <30>;
      				bias-disable;
      			lvds0_pins_b: lvds0@1 {
      				bias-disable;
      			rgb24_pins_a: rgb24@0 {
      				pins = "PB2", "PB3", "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", \
      					"PB4", "PB5", "PD6", "PD7", "PD8", "PD9", "PD10", "PD11", \
      					"PB6", "PB7", "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", \
      				function = "lcd0";
      				bias-disable;
      			rgb24_pins_b: rgb24@1 {
      				bias-disable;
      			rgb18_pins_a: rgb18@0 {
      				pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", \
      				function = "lcd0";
      				bias-disable;
      			rgb18_pins_b: rgb18@1 {
      				bias-disable;
      			dsi2lane_pins_a: dsi2lane@0 {
      				pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5";
      				function = "dsi";
      				bias-disable;
      			dsi2lane_pins_b: dsi2lane@1 {
      				bias-disable;
      			dsi4lane_pins_a: dsi4lane@0 {
      				function = "dsi";
      				bias-disable;
      			dsi4lane_pins_b: dsi4lane@1 {
      				bias-disable;
      		pinctrl_test: pinctrl_test@0 {
      			reg = <0x0 0x0 0x0 0x0>;
      			compatible = "allwinner,sunxi-pinctrl-test";
      			device_type = "pinctrl-test";
      			/* For pin state selecting test */
      			pinctrl-0 = <&test_pins_a>;
      			pinctrl-1 = <&test_pins_b>;
      			/* For pin basic_function/irq test */
      			test-gpios = <&pio PB 0 GPIO_ACTIVE_LOW>;
      			interrupt-parent = <&pio>;
      			interrupts = <PB 1 IRQ_TYPE_LEVEL_HIGH>;
      		uart0: uart@2500000 {
      			device_type = "uart0";
      			reg = <0x0 0x02500000 0x0 0x400>;
      			interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>;
      			sunxi,uart-fifosize = <64>;
      			clocks = <&ccu CLK_BUS_UART0>;
      			clock-names = "uart0";
      			uart0_port = <0>;
      			uart0_type = <2>;
      			status = "disabled";
      		uart1: uart@2500400 {
      			device_type = "uart1";
      			reg = <0x0 0x02500400 0x0 0x400>;
      			sunxi,uart-fifosize = <256>;
      			clocks = <&ccu CLK_BUS_UART1>;
      			clock-names = "uart1";
      			uart1_port = <1>;
      			uart1_type = <4>;
      		uart2: uart@2500800 {
      			device_type = "uart2";
      			reg = <0x0 0x02500800 0x0 0x400>;
      			interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_UART2>;
      			clock-names = "uart2";
      			resets = <&ccu RST_BUS_UART2>;
      			uart2_port = <2>;
      			uart2_type = <4>;
      		uart3: uart@2500c00 {
      			device_type = "uart3";
      			reg = <0x0 0x02500c00 0x0 0x400>;
      			interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_UART3>;
      			clock-names = "uart3";
      			resets = <&ccu RST_BUS_UART3>;
      			uart3_port = <3>;
      			uart3_type = <4>;
      		uart4: uart@2501000 {
      			device_type = "uart4";
      			reg = <0x0 0x02501000 0x0 0x400>;
      			interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_UART4>;
      			clock-names = "uart4";
      			resets = <&ccu RST_BUS_UART4>;
      			uart4_port = <4>;
      			uart4_type = <2>;
      		uart5: uart@2501400 {
      			device_type = "uart5";
      			reg = <0x0 0x02501400 0x0 0x400>;
      			interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_UART5>;
      			clock-names = "uart5";
      			resets = <&ccu RST_BUS_UART5>;
      			uart5_port = <5>;
      			uart5_type = <2>;
      		cryptoengine: ce@03040000 {
      			compatible = "allwinner,sunxi-ce";
      			device_name = "ce";
      			reg = <0x0 0x03040000 0x0 0xa0>, /* non-secure space */
      			      <0x0 0x03040800 0x0 0xa0>; /* secure space */
      			interrupts = <GIC_SPI 52 IRQ_TYPE_EDGE_RISING>, /*non-secure*/
      				   <GIC_SPI 53 IRQ_TYPE_EDGE_RISING>; /* secure*/
      			clock-frequency = <400000000>; /* 400MHz */
      			clocks = <&ccu CLK_BUS_CE>, <&ccu CLK_CE>, <&ccu CLK_MBUS_CE>,
      					<&ccu CLK_PLL_PERIPH0_2X>;
      			clock-names = "bus_ce", "ce_clk", "mbus_ce", "pll_periph0_2x";
      			resets = <&ccu RST_BUS_CE>;
      		gmac0: eth@4500000 {
      			compatible = "allwinner,sunxi-gmac";
      			reg = <0x0 0x04500000 0x0 0x10000>,
      			      <0x0 0x03000030 0x0 0x4>;
      			interrupts = <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>;
      			interrupt-names = "gmacirq";
      			clocks = <&ccu CLK_BUS_EMAC0>, <&ccu CLK_EMAC0_25M>;
      			clock-names = "gmac", "ephy";
      			resets = <&ccu RST_BUS_EMAC0>;
      			device_type = "gmac0";
      			gmac-power0;
      			gmac-power1;
      			gmac-power2;
      		sdc2: sdmmc@4022000 {
      			device_type = "sdc2";
      			interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>;
      				 <&ccu CLK_PLL_PERIPH0_2X>,
      				 <&ccu CLK_MMC2>,
      				 <&ccu CLK_BUS_MMC2>;
      			resets = <&ccu RST_BUS_MMC2>;
      			reset-names = "rst";
      			pinctrl-0 = <&sdc2_pins_a>;
      			pinctrl-1 = <&sdc2_pins_b>;
      			bus-width = <4>;
      			req-page-count = <2>;
      			cap-mmc-highspeed;
      			cap-cmd23;
      			mmc-cache-ctrl;
      			non-removable;
      			/*max-frequency = <200000000>;*/
      			max-frequency = <50000000>;
      			cap-erase;
      			mmc-high-capacity-erase-size;
      			no-sdio;
      			no-sd;
      			/*-- speed mode --*/
      			/*sm0: DS26_SDR12*/
      			/*sm1: HSSDR52_SDR25*/
      			/*sm2: HSDDR52_DDR50*/
      			/*sm3: HS200_SDR104*/
      			/*sm4: HS400*/
      			/*-- frequency point --*/
      			/*f0: CLK_400K*/
      			/*f1: CLK_25M*/
      			/*f2: CLK_50M*/
      			/*f3: CLK_100M*/
      			/*f4: CLK_150M*/
      			/*f5: CLK_200M*/
      			sdc_tm4_sm0_freq0 = <0>;
      			sdc_tm4_sm0_freq1 = <0>;
      			sdc_tm4_sm1_freq1 = <0>;
      			sdc_tm4_sm2_freq1 = <0>;
      			sdc_tm4_sm4_freq0_cmd = <0>;
      			sdc_tm4_sm4_freq1_cmd = <0>;
      			/*vmmc-supply = <&reg_3p3v>;*/
      			/*vqmc-supply = <&reg_3p3v>;*/
      			/*vdmc-supply = <&reg_3p3v>;*/
      			/*vmmc = "vcc-card";*/
      			/*vqmc = "";*/
      			/*vdmc = "";*/
      			/*sunxi-power-save-mode;*/
      		sdc0: sdmmc@4020000 {
      			device_type = "sdc0";
      			reg = <0x0 0x04020000 0x0 0x1000>;
      			interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>;
      				 <&ccu CLK_MMC0>,
      				 <&ccu CLK_BUS_MMC0>;
      			resets = <&ccu RST_BUS_MMC0>;
      			pinctrl-names = "default","mmc_1v8","sleep","uart_jtag";
      			pinctrl-0 = <&sdc0_pins_a>;
      			pinctrl-1 = <&sdc0_pins_b>;
      			pinctrl-2 = <&sdc0_pins_c>;
      			pinctrl-3 = <&sdc0_pins_d &sdc0_pins_e>;
      			bus-width = <4>;
      			/*non-removable;*/
      			/*broken-cd;*/
      			/*cd-inverted*/
      			/*cd-gpios = <&pio PF 6 GPIO_ACTIVE_LOW>;*/
      			/* vmmc-supply = <&reg_3p3v>;*/
      			/* vqmc-supply = <&reg_3p3v>;*/
      			/* vdmc-supply = <&reg_3p3v>;*/
      			/*vqmc = "";*/
      			/*vdmc = "";*/
      			cap-sd-highspeed;
      			cap-wait-while-busy;
      			no-sdio;
      			no-mmc;
      			/*sd-uhs-sdr50;*/
      			/*sd-uhs-ddr50;*/
      			/*cap-sdio-irq;*/
      			/*keep-power-in-suspend;*/
      			/*ignore-pm-notify;*/
      			/*sunxi-dly-400k = <1 0 0 0>; */
      			/*sunxi-dly-26M  = <1 0 0 0>;*/
      			/*sunxi-dly-52M  = <1 0 0 0>;*/
      			/*sunxi-dly-52M-ddr4  = <1 0 0 0>;*/
      			/*sunxi-dly-52M-ddr8  = <1 0 0 0>;*/
      			/*sunxi-dly-104M  = <1 0 0 0>;*/
      			/*sunxi-dly-208M  = <1 0 0 0>;*/
      			/*sunxi-dly-104M-ddr  = <1 0 0 0>;*/
      			/*sunxi-dly-208M-ddr  = <1 0 0 0>;*/
      		sdc1: sdmmc@4021000 {
      			device_type = "sdc1";
      			reg = <0x0 0x04021000 0x0 0x1000>;
      			interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>;
      				 <&ccu CLK_MMC1>,
      				 <&ccu CLK_BUS_MMC1>;
      			resets = <&ccu RST_BUS_MMC1>;
      			pinctrl-0 = <&sdc1_pins_a>;
      			pinctrl-1 = <&sdc1_pins_b>;
      			bus-width = <4>;
      			/*broken-cd;*/
      			/*cd-inverted*/
      			/*cd-gpios = <&pio PG 6 6 1 2 0>;*/
      			/*vqmc = "";*/
      			/*vdmc = "";*/
      			cap-sd-highspeed;
      			no-mmc;
      			/*sd-uhs-sdr50;*/
      			/*sd-uhs-ddr50;*/
      			/*sd-uhs-sdr104;*/
      			/*cap-sdio-irq;*/
      			/*sunxi-dly-400k = <1 0 0 0 0>; */
      			/*sunxi-dly-26M  = <1 0 0 0 0>;*/
      			/*sunxi-dly-52M  = <1 0 0 0 0>;*/
      			sunxi-dly-52M-ddr4  = <1 0 0 0 2>;
      			/*sunxi-dly-52M-ddr8  = <1 0 0 0 0>;*/
      			sunxi-dly-104M  = <1 0 0 0 1>;
      			/*sunxi-dly-208M  = <1 1 0 0 0>;*/
      			sunxi-dly-208M  = <1 0 0 0 1>;
      			/*sunxi-dly-104M-ddr  = <1 0 0 0 0>;*/
      			/*sunxi-dly-208M-ddr  = <1 0 0 0 0>;*/
      		tpadc: tpadc@2009c00 {
      			compatible = "allwinner,tp_key";
      			reg = <0x0 0x02009c00 0x0 0x400>;
      			interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_TPADC>, <&ccu CLK_BUS_TPADC>;
      			clock-names = "mod", "bus";
      			clock-frequency = <1000000>;
      			resets = <&ccu RST_BUS_TPADC>;
      		rtp:rtp@2009c00 {
      			compatible = "allwinner,sun8i-ts";
      			interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>;
      		spi0: spi@4025000 {
      			#size-cells = <0>;
      			compatible = "allwinner,sun8i-spi";
      			device_type = "spi0";
      			reg = <0x0 0x04025000 0x0 0x1000>;
      			interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_PLL_PERIPH0>, <&ccu CLK_SPI0>, <&ccu CLK_BUS_SPI0>;
      			clock-names = "pll", "mod", "bus";
      			resets = <&ccu RST_BUS_SPI0>;
      			spi0_cs_number = <1>;
      			spi0_cs_bitmap = <1>;
      			dmas = <&dma 22>, <&dma 22>;
      			dma-names = "tx", "rx";
      		spi1: spi@4026000 {
      			#size-cells = <0>;
      			device_type = "spi1";
      			reg = <0x0 0x04026000 0x0 0x1000>;
      			interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_PLL_PERIPH0>, <&ccu CLK_SPI1>, <&ccu CLK_BUS_SPI1>;
      			resets = <&ccu RST_BUS_SPI1>;
      			spi1_cs_number = <1>;
      			spi1_cs_bitmap = <1>;
      			dmas = <&dma 23>, <&dma 23>;
      		ve: ve@1c0e000 {
      			    compatible = "allwinner,sunxi-cedar-ve";
      			    reg = <0x0 0x01c0e000 0x0 0x1000>,
      				<0x0 0x03000000 0x0 0x10>,
      				<0x0 0x03001000 0x0 0x1000>;
      			    interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>;
      			    clocks = <&ccu CLK_BUS_VE>, <&ccu CLK_VE>, <&ccu CLK_MBUS_VE>;
      			    clock-names = "bus_ve", "ve", "mbus_ve";
      			    resets = <&ccu RST_BUS_VE>;
      			    power-domains = <&pd R528_PD_VE>;
      			    iommus = <&mmu_aw 0 1>;
      		twi0: twi@2502000{
      			#size-cells = <0>;
      			compatible = "allwinner,sun8i-twi";
      			device_type = "twi0";
      			reg = <0x0 0x02502000 0x0 0x400>;
      			interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_I2C0>;
      			resets = <&ccu RST_BUS_I2C0>;
      			clock-names = "bus";
      			clock-frequency = <400000>;
      		twi1: twi@2502400{
      			#size-cells = <0>;
      			device_type = "twi1";
      			reg = <0x0 0x02502400 0x0 0x400>;
      			interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_I2C1>;
      			resets = <&ccu RST_BUS_I2C1>;
      			clock-frequency = <200000>;
      		twi2: twi@2502800{
      			#size-cells = <0>;
      			device_type = "twi2";
      			reg = <0x0 0x02502800 0x0 0x400>;
      			interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_I2C2>;
      			resets = <&ccu RST_BUS_I2C2>;
      			clock-frequency = <100000>;
      		twi3: twi@2502c00{
      			#size-cells = <0>;
      			device_type = "twi3";
      			reg = <0x0 0x02502c00 0x0 0x400>;
      			interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_I2C3>;
      			resets = <&ccu RST_BUS_I2C3>;
      		ledc: ledc@2008000 {
      			#size-cells = <0>;
      			interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>;
      			interrupt-names = "ledcirq";
      			dmas = <&dma 42>, <&dma 42>;
      			dma-names = "rx", "tx";
      			resets = <&ccu RST_BUS_LEDC>;
      			reset-names = "ledc_reset";
      			status = "disable";
      		pwm: pwm@2000c00 {
      			#pwm-cells = <0x3>;
      			compatible = "allwinner,sunxi-pwm";
      			reg = <0x0 0x02000c00 0x0 0x400>;
      			clocks = <&ccu CLK_BUS_PWM>;
      			resets = <&ccu RST_BUS_PWM>;
      			pwm-number = <8>;
      			pwm-base = <0x0>;
      			sunxi-pwms = <&pwm0>, <&pwm1>, <&pwm2>, <&pwm3>, <&pwm4>,
      				<&pwm5>, <&pwm6>, <&pwm7>;
      		pwm0: pwm0@2000c10 {
      			compatible = "allwinner,sunxi-pwm0";
      			reg = <0x0 0x02000c10 0x0 0x4>;
      			reg_base = <0x02000c00>;
      		pwm1: pwm1@2000c11 {
      			compatible = "allwinner,sunxi-pwm1";
      			reg = <0x0 0x02000c11 0x0 0x4>;
      		pwm2: pwm2@2000c12 {
      			compatible = "allwinner,sunxi-pwm2";
      			reg = <0x0 0x02000c12 0x0 0x4>;
      		pwm3: pwm3@2000c13 {
      			compatible = "allwinner,sunxi-pwm3";
      			reg = <0x0 0x02000c13 0x0 0x4>;
      		pwm4: pwm4@2000c14 {
      			compatible = "allwinner,sunxi-pwm4";
      			reg = <0x0 0x02000c14 0x0 0x4>;
      		pwm5: pwm5@2000c15 {
      			compatible = "allwinner,sunxi-pwm5";
      			reg = <0x0 0x02000c15 0x0 0x4>;
      		pwm6: pwm6@2000c16 {
      			compatible = "allwinner,sunxi-pwm6";
      			reg = <0x0 0x02000c16 0x0 0x4>;
      		pwm7: pwm7@2000c17 {
      			compatible = "allwinner,sunxi-pwm7";
      			reg = <0x0 0x02000c17 0x0 0x4>;
      		lcd_fb0: lcd_fb0@0 {
      			compatible = "allwinner,sunxi-lcd_fb0";
      			pinctrl-names = "active","sleep";
      		keyboard0: keyboard@2009800 {
      			compatible = "allwinner,keyboard_1350mv";
      			reg = <0x0 0x02009800 0x0 0x400>;
      			interrupts = <GIC_SPI 61 IRQ_TYPE_EDGE_RISING>;
      			clocks = <&ccu CLK_BUS_LRADC>;
      			clock-names = "mclk";
      			resets = <&ccu RST_BUS_LRADC>;
      			key_cnt = <5>;
      			key0 = <210 115>;
      			key1 = <410 114>;
      			key2 = <590 139>;
      			key3 = <750 28>;
      			key4 = <880 172>;
      			wakeup-source;
      		sid@3006000 {
      			compatible = "allwinner,sun8iw20p1-sid", "allwinner,sunxi-sid";
      			reg = <0x0 0x03006000 0 0x1000>;
      			#size-cells = <1>;
      			secure_status {
      				reg = <0x0 0>;
      				offset = <0xa0>;
      				size = <0x4>;
      			chipid {
      				reg = <0x0 0>;
      				offset = <0x200>;
      				size = <0x10>;
      			rotpk {
      				reg = <0x0 0>;
      				offset = <0x140>;
      				size = <0x4>;
      			speedbin_efuse: speedbin@00 {
      				reg = <0x00 4>;
      			cpubin_efuse: cpubin@28 {
      				reg = <0x28 4>;
      			ths_calib: calib@14 {
      				reg = <0x14 8>;
      		gpadc: gpadc@2009000 {
      			compatible = "allwinner,sunxi-gpadc";
      			reg = <0x0 0x02009000 0x0 0x400>;
      			interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_GPADC>;
      			resets = <&ccu RST_BUS_GPADC>;
      		vind0: vind@5800800 {
      			#size-cells = <2>;
      			ranges;
      			device_id = <0>;
      			csi_top = <336000000>;
      			csi_isp = <327000000>;
      				<0x0 0x05800000 0x0 0x800>;
      			clocks = <&ccu CLK_CSI_TOP>, <&ccu CLK_PLL_VIDEO1_2X>,
      				<&ccu CLK_CSI0_MCLK>, <&dcxo24M>, <&ccu CLK_PLL_VIDEO1>,
      				<&ccu CLK_BUS_CSI>, <&ccu CLK_MBUS_CSI>;
      					"csi_bus", "csi_mbus";
      			resets = <&ccu RST_BUS_CSI>;
      			reset-names = "csi_ret";
      			pinctrl-names = "mclk0-default", "mclk0-sleep";
      			pinctrl-0 = <&csi_mclk0_pins_a>;
      			pinctrl-1 = <&csi_mclk0_pins_b>;
      			csi0: csi@5801000{
      				reg = <0x0 0x05801000 0x0 0x1000>;
      				interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>;
      				pinctrl-0 = <&csi0_pins_a>;
      				pinctrl-1 = <&csi0_pins_b>;
      				device_id = <0>;
      				iommus = <&mmu_aw 1 1>;
      			isp0: isp@5809410 {
      				reg = <0x0 0x05809410 0x0 0x10>;
      				device_id = <0xfe>;
      			isp1: isp@5809420 {
      				reg = <0x0 0x05809420 0x0 0x10>;
      				device_id = <0xff>;
      			scaler0: scaler@5809430 {
      				reg = <0x0 0x05809430 0x0 0x10>;
      				device_id = <0xfe>;
      			scaler1: scaler@5809440 {
      				reg = <0x0 0x05809440 0x0 0x10>;
      				device_id = <0xff>;
      			actuator0: actuator@5809450 {
      				device_type = "actuator0";
      				reg = <0x0 0x05809450 0x0 0x10>;
      				actuator0_slave = <0x18>;
      				actuator0_af_pwdn = <>;
      			flash0: flash@5809460 {
      				device_type = "flash0";
      				reg = <0x0 0x05809460 0x0 0x10>;
      				flash0_type = <2>;
      				flash0_en = <>;
      				flash0_mode = <>;
      				flash0_flvdd = "";
      				flash0_flvdd_vol = <>;
      				device_id = <0>;
      			sensor0: sensor@5809470 {
      				device_type = "sensor0";
      				sensor0_mname = "ov5640";
      				sensor0_twi_cci_id = <2>;
      				sensor0_twi_addr = <0x78>;
      				sensor0_mclk_id = <0>;
      				sensor0_pos = "rear";
      				sensor0_isp_used = <0>;
      				sensor0_fmt = <0>;
      				sensor0_stby_mode = <0>;
      				sensor0_vflip = <0>;
      				sensor0_hflip = <0>;
      				sensor0_iovdd-supply = <>;
      				sensor0_iovdd_vol = <>;
      				sensor0_avdd-supply = <>;
      				sensor0_avdd_vol = <>;
      				sensor0_dvdd-supply = <>;
      				sensor0_dvdd_vol = <>;
      				sensor0_power_en = <>;
      				sensor0_reset = <&pio PE 9 GPIO_ACTIVE_LOW>;
      				sensor0_pwdn = <&pio PE 8 GPIO_ACTIVE_LOW>;
      				sensor0_sm_vs = <>;
      				flash_handle = <&flash0>;
      				act_handle = <&actuator0>;
      				device_id = <0>;
      				status	= "okay";
      			sensor1: sensor@5809480 {
      				reg = <0x0 0x05809480 0x0 0x10>;
      				device_type = "sensor1";
      				sensor1_mname = "ov5647";
      				sensor1_twi_cci_id = <3>;
      				sensor1_twi_addr = <0x6c>;
      				sensor1_mclk_id = <1>;
      				sensor1_pos = "front";
      				sensor1_isp_used = <0>;
      				sensor1_fmt = <0>;
      				sensor1_stby_mode = <0>;
      				sensor1_vflip = <0>;
      				sensor1_hflip = <0>;
      				sensor1_iovdd-supply = <>;
      				sensor1_iovdd_vol = <>;
      				sensor1_avdd-supply = <>;
      				sensor1_avdd_vol = <>;
      				sensor1_dvdd-supply = <>;
      				sensor1_dvdd_vol = <>;
      				sensor1_power_en = <>;
      				sensor1_sm_vs = <>;
      				flash_handle = <>;
      				act_handle = <>;
      				device_id = <1>;
      				status	= "okay";
      			vinc0: vinc@5809000 {
      				device_type = "vinc0";
      				interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>;
      				vinc0_csi_sel = <0>;
      				vinc0_mipi_sel = <0xff>;
      				vinc0_isp_sel = <0>;
      				vinc0_tdm_rx_sel = <0xff>;
      				vinc0_rear_sensor_sel = <0>;
      				vinc0_front_sensor_sel = <0>;
      				vinc0_sensor_list = <0>;
      				device_id = <0>;
      			vinc1: vinc@5809200 {
      				device_type = "vinc1";
      				reg = <0x0 0x05809200 0x0 0x200>;
      				interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>;
      				vinc1_csi_sel = <0>;
      				vinc1_mipi_sel = <0xff>;
      				vinc1_isp_sel = <1>;
      				vinc1_tdm_rx_sel = <0xff>;
      				vinc1_rear_sensor_sel = <0>;
      				vinc1_front_sensor_sel = <0>;
      				vinc1_sensor_list = <0>;
      				device_id = <1>;
      		s_cir0: s_cir@7040000 {
      			compatible = "allwinner,s_cir";
      			reg = <0x0 0x07040000 0x0 0x400>;
      			interrupts = <GIC_SPI 151 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&r_ccu CLK_R_APB0_BUS_IRRX>, <&dcxo24M>, <&r_ccu CLK_R_APB0_IRRX>;
      			clock-names = "bus", "pclk", "mclk";
      			resets = <&r_ccu RST_R_APB0_BUS_IRRX>;
      		ir1: ir@2003000 {
      			compatible = "allwinner,irtx";
      			reg = <0x0 0x02003000 0x0 0x400>;
      			interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_IR_TX>, <&dcxo24M>, <&ccu CLK_IR_TX>;
      			resets = <&ccu RST_BUS_IR_TX>;
      		di: deinterlace@5400000 {
      			compatible = "allwinner,sunxi-deinterlace";
      			reg = <0x0 0x05400000 0x0 0x0000ffff>;
      			interrupts = <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_DI>,
      				 <&ccu CLK_BUS_DI>,
      			clock-names = "clk_di",
      				      "pll_periph",
      				      "clk_bus_di";
      			resets = <&ccu RST_BUS_DI>;
      			reset-names = "rst_bus_di";
      			assigned-clocks = <&ccu CLK_DI>;
      			assigned-clock-parents = <&ccu CLK_PLL_PERIPH0_2X>;
      			assigned-clock-rates = <300000000>;
      			iommus = <&mmu_aw 4 1>;
      		g2d: g2d@5410000 {
      			compatible = "allwinner,sunxi-g2d";
      			reg = <0x0 0x05410000 0x0 0x3ffff>;
      			interrupts = <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_G2D>, <&ccu CLK_G2D>, <&ccu CLK_MBUS_G2D>;
      			clock-names = "bus", "g2d", "mbus_g2d";
      			resets = <&ccu RST_BUS_G2D>;
      			iommus = <&mmu_aw 3 1>;
      		disp: disp@5000000 {
      			compatible = "allwinner,sunxi-disp";
      			reg = <0x0 0x05000000 0x0 0x3fffff>,	/* de0 */
      			      <0x0 0x05460000 0x0 0xfff>,	/*display_if_top*/
      			      <0x0 0x05461000 0x0 0xfff>,	/* tcon-lcd0 */
      			      <0x0 0x05470000 0x0 0xfff>,	/* tcon-tv */
      			      <0x0 0x05450000 0x0 0x1fff>;	/* dsi0*/
      			interrupts = <GIC_SPI 90 IRQ_TYPE_LEVEL_HIGH>,/*tcon-lcd0*/
      				     <GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>,/*tcon-tv */
      				     <GIC_SPI 92 IRQ_TYPE_LEVEL_HIGH>;/*dsi*/
      			clocks = <&ccu CLK_DE0>,
      				 <&ccu CLK_DE0>,
      				 <&ccu CLK_BUS_DE0>,
      				 <&ccu CLK_BUS_DE0>,
      				 <&ccu CLK_BUS_DPSS_TOP0>,
      				 <&ccu CLK_MIPI_DSI>,
      				 <&ccu CLK_BUS_MIPI_DSI>,
      				 <&ccu CLK_TCON_LCD0>,
      				 <&ccu CLK_TCON_TV>,
      				 <&ccu CLK_BUS_TCON_LCD0>,
      				 <&ccu CLK_BUS_TCON_TV>,
      				 <&ccu CLK_BUS_MIPI_DSI>;
      			clock-names = "clk_de0",
      					"clk_de1",
      					"clk_bus_de0",
      					"clk_bus_de1",
      					"clk_bus_dpss_top0",
      					"clk_bus_dpss_top1",
      					"clk_mipi_dsi0",
      					"clk_bus_mipi_dsi0",
      					"clk_tcon0",
      					"clk_tcon1",/*tcon-tv actually*/
      					"clk_bus_tcon0",
      					"clk_bus_tcon1",/*tcon-tv actually*/
      					"clk_mipi_dsi0",
      					"clk_bus_mipi_dsi0";
      			resets = <&ccu RST_BUS_DE0>,
      				 <&ccu RST_BUS_DE0>,
      				 <&ccu RST_BUS_DPSS_TOP0>,
      				 <&ccu RST_BUS_MIPI_DSI>,
      				 <&ccu RST_BUS_TCON_LCD0>,
      				 <&ccu RST_BUS_TCON_TV>,
      				 <&ccu RST_BUS_LVDS0>;
      			reset-names = "rst_bus_de0",
      					"rst_bus_de1",
      					"rst_bus_dpss_top0",
      					"rst_bus_dpss_top1",
      					"rst_bus_mipi_dsi0",
      					"rst_bus_tcon0",
      					"rst_bus_tcon1",
      					"rst_bus_lvds0";
      			assigned-clocks = <&ccu CLK_DE0>,
      			<&ccu CLK_TCON_TV>;
      			assigned-clock-parents = <&ccu CLK_PLL_PERIPH0_2X>,
      			<&ccu CLK_PLL_VIDEO0_4X>,
      			<&ccu CLK_PLL_VIDEO1_4X>;
      			assigned-clock-rates = <300000000>,
      			<150000000>,
      			<0>,
      			<0>;
      			boot_disp = <0>;
      			boot_disp1 = <0>;
      			boot_disp2 = <0>;
      			fb_base = <0>;
      			iommus = <&mmu_aw 2 0>;
      		lcd0: lcd0@5461000 {
      			compatible = "allwinner,sunxi-lcd0";
      			reg = <0x0 0x05461000 0x0 0xfff>;
      		tv0: tv0@5600000 {
      			compatible = "allwinner,sunxi-tv";
      			reg = <0x0 0x05600000 0x0 0x3fff>,
      				<0x0 0x05604000 0x0 0x3fff>;
      			clocks = <&ccu CLK_BUS_TVE_TOP>,
      				 <&ccu CLK_TVE>,
      				 <&ccu CLK_BUS_TVE>;
      			clock-names = "clk_bus_tve_top",
      				      "clk_tve",
      				      "clk_bus_tve";
      			resets = <&ccu RST_BUS_TVE_TOP>,
      				 <&ccu RST_BUS_TVE>;
      			reset-names = "rst_bus_tve_top", "rst_bus_tve";
      			device_type = "tv0";
      		hwspinlock: hwspinlock@0x3005000 {
      			compatible = "allwinner,sunxi-hwspinlock";
      			reg = <0x0 0x3005000 0x0 0x1000>;
      			#hwlock-cells = <1>;
      			clocks = <&ccu CLK_BUS_SPINLOCK>;
      			clock-names = "clk_hwspinlock_bus";
      			resets = <&ccu RST_BUS_SPINLOCK>;
      			num-locks = <32>;
      		/* old msgbox in dts
      		msgbox: msgbox@3003000 {
      			compatible = "sunxi,msgbox-amp";
      			reg = <0x0 0x03003000 0x0 0x1000>,
      			      <0x0 0x01701000 0x0 0x1000>,
      			      <0x0 0x0601f000 0x0 0x1000>;
      			interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>,
      					<GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>,
      					<GIC_SPI 130 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_MSGBOX0>;
      			rpmsg_id = "sunxi,dsp-msgbox","sunxi,dsp-power-msgbox";
      			resets = <&ccu RST_BUS_MSGBOX0>;
      			msgbox_amp_counts = <3>;
      			msgbox_amp_local = <0>;
      			rpmsg_amp_remote-0 = <1>;
      			rpmsg_read_channel-0 = <1>;
      			rpmsg_write_channel-0 = <1>;
      			rpmsg_amp_remote-1 = <1>;
      			rpmsg_read_channel-1 = <0>;
      			rpmsg_write_channel-1 = <0>;
      			compatible = "allwinner,sun8iw20-msgbox";
      			#mbox-cells = <1>;
      			local_id = <0>;
      		hdmi: hdmi@5500000 {
      			compatible = "allwinner,sunxi-hdmi";
      			reg = <0x0 0x05500000 0x0 0xfffff>;
      			interrupts = <GIC_SPI 93 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_HDMI>,
      				<&ccu CLK_HDMI_24M>,
      				<&ccu CLK_HDMI_CEC>,
      				<&ccu CLK_TCON_TV>;
      			clock-names = "clk_bus_hdmi",
      					"clk_ddc",
      					"clk_cec",
      					"clk_tcon_tv";
      			resets = <&ccu RST_BUS_HDMI_SUB>,
      				<&ccu RST_BUS_HDMI_MAIN>;
      			reset-names = "rst_bus_sub",
      				      "rst_bus_main";
      			assigned-clocks = <&ccu CLK_HDMI_CEC>;
      			assigned-clock-parents = <&ccu CLK_HDMI_CEC_32K>;
      			assigned-clock-rates = <0>;
      		usbc0:usbc0@0 {
      			device_type = "usbc0";
      			compatible = "allwinner,sunxi-otg-manager";
      			usb_port_type = <2>;
      			usb_detect_type = <1>;
      			usb_id_gpio;
      			usb_det_vbus_gpio;
      			usb_regulator_io = "nocare";
      			usb_wakeup_suspend = <0>;
      			usb_luns = <3>;
      			usb_serial_unique = <0>;
      			rndis_wceis = <1>;
      		udc:udc-controller@0x04100000 {
      			compatible = "allwinner,sunxi-udc";
      			reg = <0x0 0x04100000 0x0 0x1000>, /*udc base*/
      			      <0x0 0x00000000 0x0 0x100>; /*sram base*/
      			interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_OTG>;
      			clock-names = "bus_otg";
      			resets = <&ccu RST_BUS_OTG>, <&ccu RST_USB_PHY0>;
      			reset-names = "otg", "phy";
      		ehci0:ehci0-controller@0x04101000 {
      			compatible = "allwinner,sunxi-ehci0";
      			reg = <0x0 0x04101000 0x0 0xFFF>, /*hci0 base*/
      			      <0x0 0x00000000 0x0 0x100>, /*sram base*/
      			      <0x0 0x04100000 0x0 0x1000>; /*otg base*/
      			interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_EHCI0>;
      			clock-names = "bus_hci";
      			resets = <&ccu RST_BUS_EHCI0>, <&ccu RST_USB_PHY0>;
      			reset-names = "hci", "phy";
      			hci_ctrl_no = <0>;
      		ohci0:ohci0-controller@0x04101400 {
      			compatible = "allwinner,sunxi-ohci0";
      			reg = <0x0 0x04101400 0x0 0xFFF>, /*hci0 base*/
      			interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_OHCI0>, <&ccu CLK_USB_OHCI0>;
      			clock-names = "bus_hci", "ohci";
      			resets = <&ccu RST_BUS_OHCI0>, <&ccu RST_USB_PHY0>;
      			hci_ctrl_no = <0>;
      		usbc1:usbc1@0 {
      			device_type = "usbc1";
      			status = "disable";
      		ehci1:ehci1-controller@0x04200000 {
      			compatible = "allwinner,sunxi-ehci1";
      			reg = <0x0 0x04200000 0x0 0xFFF>, /*ehci1 base*/
      			interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_EHCI1>;
      			resets = <&ccu RST_BUS_EHCI1>, <&ccu RST_USB_PHY1>;
      			hci_ctrl_no = <1>;
      			status = "disable";
      		ohci1:ohci1-controller@0x04200400 {
      			compatible = "allwinner,sunxi-ohci1";
      			reg = <0x0 0x04200400 0x0 0xFFF>, /*ohci1 base*/
      			interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_OHCI1>, <&ccu CLK_USB_OHCI1>;
      			resets = <&ccu RST_BUS_OHCI1>, <&ccu RST_USB_PHY1>;
      			hci_ctrl_no = <1>;
      			status = "disable";
      		/* codec addr: 0x02030000, the others is invalid to avoid build warining */
      		codec:codec@2030000 {
      			#sound-dai-cells = <0>;
      			compatible = "allwinner,sunxi-internal-codec";
      			reg = <0x0 0x02030000 0x0 0x34c>;
      			clocks = <&ccu CLK_PLL_AUDIO0>,
      				 <&ccu CLK_PLL_AUDIO1_DIV5>,
      				 <&ccu CLK_AUDIO_DAC>,
      				 <&ccu CLK_AUDIO_ADC>,
      				 <&ccu CLK_BUS_AUDIO_CODEC>;
      			clock-names = "pll_audio0", "pll_audio1_div5",
      				      "audio_clk_dac", "audio_clk_adc",
      				      "audio_clk_bus";
      			resets = <&ccu RST_BUS_AUDIO_CODEC>;
      			rx_sync_en  = <0x00>;
      			device_type = "codec";
      		dummy_cpudai:dummy_cpudai@203034c {
      			compatible = "allwinner,sunxi-dummy-cpudai";
      			reg = <0x0 0x0203034c 0x0 0x4>;
      			tx_fifo_size    = <128>;
      			rx_fifo_size    = <256>;
      			dac_txdata      = <0x02030020>;
      			adc_txdata      = <0x02030040>;
      			playback_cma    = <128>;
      			capture_cma     = <256>;
      			device_type = "cpudai";
      			dmas = <&dma 7>, <&dma 7>;
      		sndcodec:sound@2030340 {
      			compatible = "allwinner,sunxi-codec-machine";
      			reg = <0x0 0x02030340 0x0 0x4>;
      			interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>;
      			sunxi,audio-codec = <&codec>;
      			sunxi,cpudai-controller = <&dummy_cpudai>;
      			device_type = "sndcodec";
      		sunxi_rpaf_dsp0:rpaf-dsp@203034c {
      			compatible = "allwinner,rpaf-dsp0";
      			device_type = "sunxi_rpaf_dsp0";
      			dsp_id = <0x0>;
      		/* dmic addr: 0x02031000, the others is invalid to avoid build warining */
      		dmic:dmic@2031000{
      			compatible = "allwinner,sunxi-dmic";
      			reg = <0x0 0x02031000 0x0 0x50>;
      			clocks = <&ccu CLK_PLL_AUDIO0>, /* 98.304M / 90.3168M */
      				 <&ccu CLK_DMIC>,
      				 <&ccu CLK_BUS_DMIC>;
      			clock-names = "pll_audio", "dmic", "dmic_bus";
      			resets = <&ccu RST_BUS_DMIC>;
      			dmas		= <&dma 8>;
      			dma-names	= "rx";
      			interrupts	= <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>;
      			clk_parent	= <0x1>;
      			data_vol	= <0xB0>;
      			rx_chmap	= <0x76543210>;
      			device_type = "dmic";
      		dmic_codec:sound@2031050{
      			compatible = "dmic-codec";
      			reg = <0x0 0x02031050 0x0 0x4>;
      			num-channels = <8>;
      		sounddmic:sounddmic@2031060 {
      			reg = <0x0 0x02031060 0x0 0x4>;
      			compatible = "sunxi,simple-audio-card";
      			simple-audio-card,name = "snddmic";
      			simple-audio-card,capture_only;
      			simple-audio-card,cpu {
      				sound-dai = <&dmic>;
      			simple-audio-card,codec {
      				sound-dai = <&dmic_codec>;
      		/* daudio0 addr: 0x02032000, the others is invalid to avoid build warining */
      		daudio0:daudio@2032000 {
      			compatible = "allwinner,sunxi-daudio";
      			reg = <0x0 0x02032000 0x0 0xa0>;
      				 <&ccu CLK_I2S0>,
      				 <&ccu CLK_BUS_I2S0>;
      			clock-names = "pll_audio", "i2s0", "i2s0_bus";
      			resets = <&ccu RST_BUS_I2S0>;
      			dmas		= <&dma 3>, <&dma 3>;
      			interrupts	= <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>;
      			pinctrl_used		= <0x01>;
      			sign_extend		= <0x00>;
      			tx_data_mode		= <0x00>;
      			rx_data_mode		= <0x00>;
      			msb_lsb_first		= <0x00>;
      			pcm_lrck_period		= <0x80>;
      			slot_width_select	= <0x20>;
      			frametype		= <0x00>;
      			tdm_config		= <0x01>;
      			tdm_num			= <0x00>;
      			mclk_div		= <0x00>;
      			clk_parent		= <0x00>;
      			capture_cma		= <128>;
      			tx_num			= <4>;
      			tx_chmap1		= <0x76543210>;
      			tx_chmap0		= <0xFEDCBA98>;
      			rx_num			= <4>;
      			rx_chmap3		= <0x03020100>;
      			rx_chmap2		= <0x07060504>;
      			rx_chmap1		= <0x0B0A0908>;
      			rx_chmap0		= <0x0F0E0D0C>;
      			asrc_function_en	= <0x00>;
      			device_type = "daudio0";
      		sounddaudio0: sounddaudio0@20320a0 {
      			reg = <0x0 0x020320a0 0x0 0x4>;
      			simple-audio-card,name = "snddaudio0";
      				sound-dai = <&daudio0>;
      		/* daudio1 addr: 0x02033000, the others is invalid to avoid build warining */
      		daudio1:daudio@2033000 {
      			reg = <0x0 0x02033000 0x0 0xa0>;
      				 <&ccu CLK_I2S1>,
      				 <&ccu CLK_BUS_I2S1>;
      			clock-names = "pll_audio", "i2s1", "i2s1_bus";
      			resets = <&ccu RST_BUS_I2S1>;
      			dmas		= <&dma 4>, <&dma 4>;
      			interrupts	= <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>;
      			frametype		= <0x00>;
      			tdm_num			= <0x01>;
      			mclk_div		= <0x00>;
      			tx_num			= <4>;
      			rx_num			= <4>;
      			device_type = "daudio1";
      		sounddaudio1: sounddaudio1@20330a0 {
      			reg = <0x0 0x020330a0 0x0 0x4>;
      			simple-audio-card,name = "snddaudio1";
      				sound-dai = <&daudio1>;
      		/* daudio2 addr: 0x02034000, the others is invalid to avoid build warining */
      		daudio2:daudio@2034000 {
      			reg = <0x0 0x02034000 0x0 0xa0>;
      				 <&ccu CLK_I2S2>,
      				 <&ccu CLK_BUS_I2S2>,
      				 <&ccu CLK_PLL_AUDIO0_4X>,
      				 <&ccu CLK_I2S2_ASRC>;
      			resets = <&ccu RST_BUS_I2S2>;
      			dmas		= <&dma 5>, <&dma 5>;
      			interrupts	= <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>;
      			daudio_type		= <0x00>;
      			frametype		= <0x00>;
      			tdm_num			= <0x02>;
      			mclk_div		= <0x01>;
      			tx_num			= <4>;
      			rx_num			= <4>;
      			device_type = "daudio2";
      		sounddaudio2: sounddaudio2@20340a0 {
      			reg = <0x0 0x020340a0 0x0 0x4>;
      			simple-audio-card,name = "snddaudio2";
      				sound-dai = <&daudio2>;
      		hdmiaudio: hdmiaudio@20340a4 {
      			reg = <0x0 0x020340a4 0x0 0x4>;
      			compatible = "allwinner,sunxi-hdmiaudio";
      		/* spdif addr: 0x02036000, the others is invalid to avoid build warining */
      		spdif:spdif@2036000 {
      			compatible = "allwinner,sunxi-spdif";
      			reg = <0x0 0x02036000 0x0 0x58>;
      			clocks = <&ccu CLK_PLL_AUDIO0_4X>,	/* 90.3168M */
      				 <&ccu CLK_SPDIF_TX>,
      				 <&ccu CLK_BUS_SPDIF>,
      				 <&ccu CLK_PLL_AUDIO1>,         /* 98.304M */
      				 <&ccu CLK_SPDIF_RX>;
      			clock-names = "pll_audio0", "spdif", "spdif_bus",
      				      "pll_audio1", "pll_audio1_div5",
      				      "pll_periph", "spdif_rx";
      			resets = <&ccu RST_BUS_SPDIF>;
      			dmas		= <&dma 2>, <&dma 2>;
      			interrupts	= <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>;
      			clk_parent	= <0x1>;
      			rx_sync_en      = <0>;
      			device_type = "spdif";
      		soundspdif:soundspdif@203605c {
      			reg = <0x0 0x0203605c 0x0 0x4>;
      			simple-audio-card,name = "sndspdif";
      				 sound-dai = <&spdif>;
      				 /*snd-soc-dummy*/
      		ths: ths@02009400 {
      			compatible = "allwinner,sun8iw20p1-ths";
      			reg = <0x0 0x02009400 0x0 0x400>;
      			clocks = <&ccu CLK_BUS_THS>;
      			resets = <&ccu RST_BUS_THS>;
      			nvmem-cells = <&ths_calib>;
      			nvmem-cell-names = "calibration";
      			#thermal-sensor-cells = <1>;
      		tvd: tvd@05c00000 {
      			compatible = "allwinner,sunxi-tvd";
      			reg = <0x0 0x05c00000 0x0 0x00010000>;/*tvd_top*/
      			interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_TVD_TOP>,
      			<&ccu CLK_MBUS_TVIN>;
      			clock-names = "clk_bus_tvd_top",
      			"clk_mbus_tvd";
      			resets = <&ccu RST_BUS_TVD_TOP>;
      			reset-names = "rst_bus_tvd_top";
      			tvd-number = <1>;
      			tvds = <&tvd0>;
      		tvd0: tvd0@05c01000 {
      			compatible = "allwinner,sunxi-tvd0";
      			reg = <0x0 0x05c01000 0x0 0x00010000>;
      			clocks = <&ccu CLK_TVD>,
      			<&ccu CLK_BUS_TVD>;
      			clock-names = "clk_tvd0","clk_bus_tvd0";
      			resets = <&ccu RST_BUS_TVD>;
      			reset-names = "rst_bus_tvd0";
      			assigned-clocks = <&ccu CLK_TVD>;
      			assigned-clock-parents = <&ccu CLK_PLL_VIDEO1>;
      			tvd_used = <1>;
      			tvd_if = <0>;
      sun8iw20p1.dtsi
      	model = "sun8iw20";
      	#size-cells = <2>;
      	aliases {
      		serial0 = &uart0;
      		serial1 = &uart1;
      		serial2 = &uart2;
      		serial3 = &uart3;
      		serial4 = &uart4;
      		serial5 = &uart5;
      		spi0 = &spi0;
      		spi1 = &spi1;
      		twi0 = &twi0;
      		twi1 = &twi1;
      		twi2 = &twi2;
      		twi3 = &twi3;
      		mmc0 = &sdc0;
      		mmc2 = &sdc2;
      		pwm = &pwm;
      		pwm0 = &pwm0;
      		pwm1 = &pwm1;
      		pwm2 = &pwm2;
      		pwm3 = &pwm3;
      		pwm4 = &pwm4;
      		pwm5 = &pwm5;
      		pwm6 = &pwm6;
      		pwm7 = &pwm7;
      		ir0 = &s_cir0;
      		ve0 = &ve;
      		tv0 = &tv0;
      		tvd = &tvd;
      		tvd0 = &tvd0;
      	chosen {
      	firmware {
      		optee {
      			method = "smc";
      	cpus {
      		#size-cells = <0>;
      		cpu0: cpu@0 {
      			reg = <0x0>;
      		cpu1: cpu@1 {
      			reg = <0x1>;
      		idle-states {
      				local-timer-stop;
      				local-timer-stop;
      	psci {
      		method = "smc";
      		opp-shared;
      		opp@480000000 {
      		opp@720000000 {
      		opp@912000000 {
      		opp@1008000000 {
      		opp@1104000000 {
      		opp@1200000000 {
      		#clock-cells = <0>;
      	rc_16m: rc16m_clk {
      		#clock-cells = <0>;
      		#clock-cells = <0>;
      	dram: dram {
      	memory@40000000 {
      		#size-cells = <1>;
      		/* reserve */
      	timer_arch {
      	pmu {
      			     <GIC_SPI 173 4>;
      			#size-cells = <0>;
      			pd_ve@R528_PD_VE {
      				reg = <R528_PD_VE>;
      		#iommu-cells = <2>;
      	thermal-zones {
      			cpu_trips: trips {
      					type = "passive";
      					hysteresis = <0>;
      					type = "passive";
      					hysteresis = <0>;
      					type = "critical";
      					hysteresis = <0>;
      			cooling-maps {
      				map0 {
      					THERMAL_NO_LIMIT
      					THERMAL_NO_LIMIT>;
      	soc: soc@3000000 {
      		#size-cells = <2>;
      		ranges;
      			soc_ver {
      				offset = <0x24>;
      				mask = <0x7>;
      				shift = <0>;
      			soc_id {
      				offset = <0x200>;
      				mask = <0x1>;
      				shift = <22>;
      			soc_bin {
      				offset = <0x0>;
      				mask = <0x3ff>;
      				shift = <0x0>;
      			#clock-cells = <1>;
      		ccu: ccu@2001000 {
      			#clock-cells = <1>;
      			#reset-cells = <1>;
      			#clock-cells = <1>;
      			#reset-cells = <1>;
      		rtc: rtc@7090000 {
      			wakeup-source;
      			gpr_cur_pos = <6>;
      			dma-channels = <8>;
      			#dma-cells = <1>;
      			#mbus-cells = <1>;
      			gpio-controller;
      			#gpio-cells = <3>;
      			#size-cells = <0>;
      				pins = "PE3";
      				function = "csi0";
      				pins = "PE3";
      				function = "ncsi0";
      				function = "lvds0";
      				bias-disable;
      				bias-disable;
      				function = "lcd0";
      				bias-disable;
      				bias-disable;
      				function = "lcd0";
      				bias-disable;
      				bias-disable;
      				function = "dsi";
      				bias-disable;
      				bias-disable;
      				function = "dsi";
      				bias-disable;
      				bias-disable;
      			uart0_port = <0>;
      			uart0_type = <2>;
      			uart1_port = <1>;
      			uart1_type = <4>;
      			uart2_port = <2>;
      			uart2_type = <4>;
      			uart3_port = <3>;
      			uart3_type = <4>;
      			uart4_port = <4>;
      			uart4_type = <2>;
      			uart5_port = <5>;
      			uart5_type = <2>;
      			device_name = "ce";
      			gmac-power0;
      			gmac-power1;
      			gmac-power2;
      				 <&ccu CLK_MMC2>,
      			bus-width = <4>;
      			cap-mmc-highspeed;
      			cap-cmd23;
      			mmc-cache-ctrl;
      			non-removable;
      			cap-erase;
      			no-sdio;
      			no-sd;
      			/*sm0: DS26_SDR12*/
      			/*sm4: HS400*/
      			/*f0: CLK_400K*/
      			/*f1: CLK_25M*/
      			/*f2: CLK_50M*/
      			/*f3: CLK_100M*/
      			/*f4: CLK_150M*/
      			/*f5: CLK_200M*/
      			/*vqmc = "";*/
      			/*vdmc = "";*/
      				 <&ccu CLK_MMC0>,
      			bus-width = <4>;
      			/*non-removable;*/
      			/*broken-cd;*/
      			/*cd-inverted*/
      			/*vqmc = "";*/
      			/*vdmc = "";*/
      			cap-sd-highspeed;
      			no-sdio;
      			no-mmc;
      			/*sd-uhs-sdr50;*/
      			/*sd-uhs-ddr50;*/
      			/*cap-sdio-irq;*/
      				 <&ccu CLK_MMC1>,
      			bus-width = <4>;
      			/*broken-cd;*/
      			/*cd-inverted*/
      			/*vqmc = "";*/
      			/*vdmc = "";*/
      			cap-sd-highspeed;
      			no-mmc;
      			/*sd-uhs-sdr50;*/
      			/*sd-uhs-ddr50;*/
      			/*sd-uhs-sdr104;*/
      			/*cap-sdio-irq;*/
      		rtp:rtp@2009c00 {
      		spi0: spi@4025000 {
      			#size-cells = <0>;
      		spi1: spi@4026000 {
      			#size-cells = <0>;
      		ve: ve@1c0e000 {
      		twi0: twi@2502000{
      			#size-cells = <0>;
      		twi1: twi@2502400{
      			#size-cells = <0>;
      		twi2: twi@2502800{
      			#size-cells = <0>;
      		twi3: twi@2502c00{
      			#size-cells = <0>;
      			#size-cells = <0>;
      			status = "disable";
      		pwm: pwm@2000c00 {
      			#pwm-cells = <0x3>;
      			pwm-number = <8>;
      			pwm-base = <0x0>;
      			key_cnt = <5>;
      			key0 = <210 115>;
      			key1 = <410 114>;
      			key2 = <590 139>;
      			key3 = <750 28>;
      			key4 = <880 172>;
      			wakeup-source;
      		sid@3006000 {
      			#size-cells = <1>;
      			secure_status {
      				reg = <0x0 0>;
      				offset = <0xa0>;
      				size = <0x4>;
      			chipid {
      				reg = <0x0 0>;
      				offset = <0x200>;
      				size = <0x10>;
      			rotpk {
      				reg = <0x0 0>;
      				offset = <0x140>;
      				size = <0x4>;
      				reg = <0x00 4>;
      				reg = <0x28 4>;
      				reg = <0x14 8>;
      			#size-cells = <2>;
      			ranges;
      			device_id = <0>;
      			csi0: csi@5801000{
      				device_id = <0>;
      			isp0: isp@5809410 {
      				device_id = <0xfe>;
      			isp1: isp@5809420 {
      				device_id = <0xff>;
      				device_id = <0xfe>;
      				device_id = <0xff>;
      				flash0_type = <2>;
      				flash0_en = <>;
      				flash0_mode = <>;
      				flash0_flvdd = "";
      				device_id = <0>;
      				sensor0_fmt = <0>;
      				sensor0_sm_vs = <>;
      				device_id = <0>;
      				status	= "okay";
      				sensor1_fmt = <0>;
      				sensor1_sm_vs = <>;
      				flash_handle = <>;
      				act_handle = <>;
      				device_id = <1>;
      				status	= "okay";
      				device_id = <0>;
      				device_id = <1>;
      		ir1: ir@2003000 {
      				 <&ccu CLK_BUS_DI>,
      				      "pll_periph",
      				      "clk_bus_di";
      		g2d: g2d@5410000 {
      				 <&ccu CLK_DE0>,
      				 <&ccu CLK_BUS_DE0>,
      				 <&ccu CLK_BUS_DE0>,
      				 <&ccu CLK_TCON_TV>,
      					"clk_de1",
      					"clk_bus_de0",
      					"clk_bus_de1",
      					"clk_mipi_dsi0",
      					"clk_tcon0",
      					"clk_bus_tcon0",
      					"clk_mipi_dsi0",
      				 <&ccu RST_BUS_DE0>,
      					"rst_bus_de1",
      					"rst_bus_tcon0",
      					"rst_bus_tcon1",
      					"rst_bus_lvds0";
      			<&ccu CLK_TCON_TV>;
      			<150000000>,
      			<0>,
      			<0>;
      			boot_disp = <0>;
      			boot_disp1 = <0>;
      			boot_disp2 = <0>;
      			fb_base = <0>;
      		tv0: tv0@5600000 {
      				 <&ccu CLK_TVE>,
      				 <&ccu CLK_BUS_TVE>;
      				      "clk_tve",
      				      "clk_bus_tve";
      				 <&ccu RST_BUS_TVE>;
      			num-locks = <32>;
      			#mbox-cells = <1>;
      			local_id = <0>;
      				<&ccu CLK_TCON_TV>;
      					"clk_ddc",
      					"clk_cec",
      					"clk_tcon_tv";
      				      "rst_bus_main";
      		usbc0:usbc0@0 {
      			usb_id_gpio;
      			usb_det_vbus_gpio;
      			usb_luns = <3>;
      			rndis_wceis = <1>;
      			hci_ctrl_no = <0>;
      			hci_ctrl_no = <0>;
      		usbc1:usbc1@0 {
      			status = "disable";
      			hci_ctrl_no = <1>;
      			status = "disable";
      			hci_ctrl_no = <1>;
      			status = "disable";
      				      "audio_clk_bus";
      			dsp_id = <0x0>;
      		dmic:dmic@2031000{
      				 <&ccu CLK_DMIC>,
      			dmas		= <&dma 8>;
      			dma-names	= "rx";
      			clk_parent	= <0x1>;
      			data_vol	= <0xB0>;
      			num-channels = <8>;
      				 <&ccu CLK_I2S0>,
      			frametype		= <0x00>;
      			tdm_num			= <0x00>;
      			mclk_div		= <0x00>;
      			tx_num			= <4>;
      			rx_num			= <4>;
      				 <&ccu CLK_I2S1>,
      			frametype		= <0x00>;
      			tdm_num			= <0x01>;
      			mclk_div		= <0x00>;
      			tx_num			= <4>;
      			rx_num			= <4>;
      				 <&ccu CLK_I2S2>,
      			frametype		= <0x00>;
      			tdm_num			= <0x02>;
      			mclk_div		= <0x01>;
      			tx_num			= <4>;
      			rx_num			= <4>;
      			clk_parent	= <0x1>;
      			rx_sync_en      = <0>;
      				 /*snd-soc-dummy*/
      		ths: ths@02009400 {
      		tvd: tvd@05c00000 {
      			"clk_mbus_tvd";
      			tvd-number = <1>;
      			tvds = <&tvd0>;
      			<&ccu CLK_BUS_TVD>;
      			tvd_used = <1>;
      			tvd_if = <0>;
      日志
        WhycanService LV 8 @shz18877605430 最后由 编辑
        @shz18877605430 rc.local里删了
        S 2 条回复 最后回复 回复 引用 分享 0
          shz18877605430 LV 6 @WhycanService 最后由 编辑
          @whycanservice 已解决
            @whycanservice 当前出现了这个问题。
              @shz18877605430 vinc1为空对照检查下
              S 1 条回复 最后回复 回复 引用 分享 0
                @whycanservice 我用的是sensor0,只有一个ov5640摄像头,现在是[VIN_ERR]media_entity_find_link null 有问题,大佬这么怎么搞呢?
                  whycan晕哥 LV 9 @shz18877605430 最后由 编辑
                  @shz18877605430
                  我看了一下T113手册,没有发现ISP,
                  board.dts都这样修改试一试:
                  vinc0_isp_sel = <0xFF>;
                  vinc1_isp_sel = <0xFF>;
                    shz18877605430 LV 6 @whycan 最后由 编辑
                    @whycan 晕哥,我改了还是不行。这个源码我也看了,link的时候,对比不过,link返回了NULL。
                      WhycanService LV 8 最后由 编辑
                        D1-H (MQ-Pro)驱动 OV5640 摄像头
                        https://bbs.aw-ol.com/topic/4017/share/1
